Hi all,
I found below dmesg log messages for USB0 port and How I can fix usb-phy supply vcc not found and gpios property of node in driver level or device tree?
dmesg log:
[ 5.075602] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/usb@47400000/usb-phy@47401300[0]'
[ 5.075735] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 5.226464] of_get_named_gpiod_flags: can't parse gpios property of node '/ocp/usb@47400000/usb-phy@47401b00[0]'
[ 5.226595] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 6.027437] random: nonblocking pool is initialized
[ 7.975670] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 7.975715] musb-hdrc: MHDRC RTL version 2.0
[ 7.975739] musb-hdrc: setup fifo_mode 4
[ 7.975780] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 7.976044] musb-hdrc musb-hdrc.0.auto: MUSB HDRC host driver
[ 8.014583] musb-hdrc musb-hdrc.0.auto: new USB bus registered, assigned bus number 1
[ 8.073334] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.080500] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.088169] usb usb1: Product: MUSB HDRC host driver
[ 8.093430] usb usb1: Manufacturer: Linux 3.14.26-2.0.1 musb-hcd
[ 8.099746] usb usb1: SerialNumber: musb-hdrc.0.auto
[ 8.325454] hub 1-0:1.0: USB hub found
[ 8.352269] hub 1-0:1.0: 1 port detected
Thanks & Regards
N Shankar
