Other Parts Discussed in Thread: THS8200
hi,friends, My platform is DM6467T,DVSDK is 3.10 version.How can I find the following errors? Booting PSP Boot Loader Starting NAND Copy Booting Application @ 0x81080000 U-Boot 2009.08-00002-gcab1855 (Jan 20 2010 - 04:20:31) I2C: ready DRAM: 256 MB NAND: 128 MiB In: serial Out: serial Err: serial ARM Clock :- 495MHz DDR Clock :- 396MHz Net: Ethernet PHY: GENERIC @ 0x01 DaVinci EMAC Hit any key to stop autoboot: 0 BOOTP broadcast 1 DHCP client bound to address 192.168.154.248 Using DaVinci EMAC device TFTP from server 192.168.154.240; our IP address is 192.168.154.248 Filename 'uImage'. Load address: 0x80700000 Loading: ################################################################# ################################################################# ########### done Bytes transferred = 2061244 (1f73bc hex) ## Booting kernel from Legacy Image at 80700000 ...31)c00000Starting N Image Name: Linux-2.6.32-rc2-davinci1ad eraseblock 661 at 0x0000052a0000 Image Type: ARM Linux Kernel Image (uncompressed)DRAM: 256 Bad eraseblock 663 at 0x0000052e0 Data Size: 2061180 Bytes = 2 MB In: serial0ock 19 Load Address: 80008000 Bad eraseblock 665 at 0 Entry Point: 80008000 Verifying Checksum ... OK Bad erasebloc Loading Kernel Image ... OK00002ca00000 OK Starting kernel ... Net: Uncompressing Linux............................................................. DaVinci EMACsebl Bad eraseblock 671 at 0x0000053e0 ......................................................................... done, Bad erasebloc Bad eraseblock 673 at 0x000005420000CPU booting the kernel. bootdela PID hash table entries: 512 (order: -1, 2048 bytes)Boot 2009.08-00002-gcab1855 (Jan 20 Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)seblock 747 at 0x000005d60000e00001.0.21.00 Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)5dc0000nt size: 435/16380 bytes0x000003d400 Memory: 112MB = 112MB total Memory: 109140KB available (3876K code, 335K data, 144K init, 0K highmem) Ba Bad eraseblock 755 at SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Bad eraseblock 758 at 0x000005ec00 Hierarchical RCU implementation. NR_IRQS:245 Bad Console: colour dummy device 80x30md 'tftp;bootm'availa DaVinci: 43 gpio irqs NET: Registered protocol family 16 Bad eraseblock 782 at MUX: Setting register STSOMUX_DISABLE PINMUX0 (0x00000000) = 0x00000000 -> 0x0000000084 at 0x000006200000vice 80x30hdr MUX: Setting register STSIMUX_DISABLE bootarg Bad era PINMUX0 (0x00000000) = 0x00000000 -> 0x00000000 Bad eraseblock 515 at 0 Bad MUX: Setting register PTSOMUX_DISABLE Bad er PINMUX0 (0x00000000) = 0x00000000 -> 0x00000000at 0x000006300000mage MUX: Setting register PTSIMUX_DISABLE PINMUX0 (0x00000000) = 0x00000000 -> 0x00000001 BOOTP broadcast 1 bio: create slab at 06a0000: No link0000044c0000 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs 823 at 0x0000066e0000 usbcore: registered new interface driver hub Bad erasebloc usbcore: registered new device driver usb00000000 pcf857x 1-0038: gpios 145..152 on a pcf8 Bad eraseblock 833 at 0x000006820000 musb_hdrc: USB Peripheral mode controller at fec64000 using PIO, IRQ 13 Bad eraseblock 835 at 0x000006860000 broadcas NET: Registered protocol family 2 Bad eraseblo IP route cache hash table entries: 1024 (order: 0, 4096 bytes)e (uncompressed)e: reg TCP established hash table entries: 4096 (order: 3, 32768 bytes)0000t 0x000004a TCP bind hash table entries: 4096 (order: 2, 16384 bytes)lock 881 at 0x000006e20000 TCP: Hash tables configured (established 4096 bind 4096)block 884 at 0x000006e80000ry Point: 80008000 TCP reno registered io scheduler noop registeredaseblock 899 at 0x0000070600 io scheduler anticipatory registered (default)....................... CIR device registered successfully (Major = 252, Minor = Bad eraseblock 63 Bad eraseblock 903 at 0)000 Serial: 8250/16550 driver, 3 ports, IRQ sharing disabledernel Bad eraseblock 907 at 0x00000716 serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is 2): -220000054 brd: module loaded loop: module loaded Ba at24 1-0050: 32768 byte 24c256 EEPROM (writable) rw root=/dev/nfs nfs Read MAC addr from EEPROM: 00:0e:99:00:00:00 Bad eraseblock 939 at 0x0000075600000054400 Uniform Multi-Platform E-IDE driver ide-gd driver 1.18 Bad er ide0: MMIO-DMA000075a0000er/work hda: TOSHIBA MK4032GAX, ATA DISK drive hda: UDMA/100 mode selected eraseblock 943 at 0x000007 ide0 at 0xfec661f0-0xfec661f7,0xfec663f6 on Bad eraseblock 964 at Console: colour dumm it) Scanning device for bad blocks0079c0000 Bad eraseblock 2 at 0x000000040000oop.. Bad Bad eraseblock 6 at 0x0000000c0000DMA Bad eraseblock 9 at 0x000000120000x000007a40000entries:4 at 0x Bad eraseblock 11 at 0x000000160000 PINMUX0 (0x000 Bad eraseblock 14 at 0x0000001c0000lock 989 at 0x000007ba0000rom 192 Bad eraseblock 17 at 0x000000220000 Bad eraseblock 991 at 0x00000 Bad eraseblock 20 at 0x0000002800000000080 Bad eraseblock 24 at 0x00000 Bad eraseblock 40 at 0x00000050000000 -> 0x000000001, mask=255.255.255 Bad eraseblock 42 at 0x000000540000 Bad eraseblock 44 at 0x0000005800000000X: Setting register PTSIMUX_DIS Bad eraseblock 46 at 0x0000005c0000 Bad eraseblock 48 at 0x00000060000000007dc0000 PINMUX0 (0x0000 Bad eraseblock 51 at 0x000000660000 Bad eraseblock 54 at 0x0000006c0000 at 0x000007e20000d eraseblock 767 Bad eraseblock 56 at 0x000000700000 Bad eraseblock 58 at 0x000000740000k 1011 at 0x000007e60 Bad eraseblock 65 at 0x00000082000000000000-0x000000020000 : "params" Bad eraseblock 68 at 0x000000880000 Bad eraseblock 39 Bad eraseblock 70 at 0x0000008c0000 0x000000020000-0x000000160000 : Bad eraseblock 72 at 0x000000900000 driver usbfs Bad eraseblock 75 at 0x000000960000 0x000000160 Bad eraseblock 77 at 0x0000009a0000 registered new interface driver Bad eraseblock 79 at 0x0000009e0000 Bad eraseblock 82 at 0x000000a40000: "filesystem"c0 Bad eraseblock 85 at 0x000000aa0000 registered new device driver usb Bad eraseblock 87 at 0x000000ae0000 davinci_nand davinci_nand.0: co Bad eraseblock 90 at 0x000000b40000.152 on a pcf8574a411 at 0x00 Bad eraseblock 92 at 0x000000b80000 Bad eraseblock 106 at 0x000000d40000 Bad erasebloc Bad eraseblock 108 at 0x000000d80000ther gadget: using random self ether Bad eraseblock 110 at 0x000000dc0000003960000 Bad eraseblock 113 at 0x000000e20000 g_ether gadge Bad eraseblock 116 at 0x000000e8000039a0000ck 857 at 0x00000 Bad eraseblock 118 at 0x000000ec0000 io schedul Bad eraseblock 121 at 0x000000f20000 usb0: MAC 1e:15:b1:10:47:c000c Bad eraseblock 123 at 0x000000f60000uler anticipato Bad eraseblock 126 at 0x000000fc0000x000003a6000000fr000006 Bad eraseblock 128 at 0x000001000000 Bad eraseblock 146 at 0x00000124000002c: chip found @ 0x58 (DaVinci I2C Bad eraseblock 149 at 0x0000012a0000 Bad eraseblock 151 at 0x0000012e0000Bad eraseblock 480 at 0 Bad eraseblock 155 at 0x000001360000d @ 0x40 (DaVinci I2C adapter)0 seri Bad eraseblock 157 at 0x0000013a0000index 1 (IO0 Bad eraseblock 160 at 0x000001400000 Bad eraseblock 163 at 0x000001460000und @ 0x # Bad eraseblock 168 at 0x000001500000 0xf1 (ST Micro NAND 128MiB 3,3V 8-b Bad eraseblock 170 at 0x000001540000 Bad eraseblock 172 at 0x000001580000 Ba Bad eraseblock 184 at 0x000001700000 Bad eraseblock 189 at 0x0000017a0000 Bad eraseblock 191 at 0x0000017e0000 Bad eraseblock 193 at 0x000001820000 Bad eraseblock 197 at 0x0000018a0000 Bad eraseblock 201 at 0x000001920000 Bad eraseblock 203 at 0x000001960000 Bad eraseblock 206 at 0x0000019c0000 Bad eraseblock 208 at 0x000001a00000 Bad eraseblock 210 at 0x000001a40000 Bad eraseblock 213 at 0x000001aa0000 Bad eraseblock 215 at 0x000001ae0000 Bad eraseblock 218 at 0x000001b40000 Bad eraseblock 220 at 0x000001b80000 Bad eraseblock 222 at 0x000001bc0000 Bad eraseblock 224 at 0x000001c00000 Bad eraseblock 226 at 0x000001c40000 Bad eraseblock 228 at 0x000001c80000 Bad eraseblock 230 at 0x000001cc0000 Bad eraseblock 233 at 0x000001d20000 Bad eraseblock 235 at 0x000001d60000 Bad eraseblock 238 at 0x000001dc0000 Bad eraseblock 241 at 0x000001e20000 Ba
