Pramod,
Since you are sourcing DVDD33 supply to the all 4 DSP's from single PTH08000WAH module, you may need to use the recommended capacitors for all the DSP's (i.e., 4 sets for 4 DSP's) on their supply pins. The given recommendation is for single DSP.
Also you have to use the power module recommended capacitors on its output end. Please ensure that the power module output current is quite enough to supply all 4 DSP's.
Senthil
Hello Senthil,
Thanks for reply,
We have designed as per recommendation given in PTH08000WAH data sheet for output caps on module,
But output capacitance at output is low for our design,
Please can you recommend us the pin to pin matching power module with high output capacitance (alternate to PTH08000WAH)
Pramod
Pramod,
I am very sure about your design requirement. You may need to perform power integrity analysis to decide on the capacitor requirement. For other pin to pin compatible power module, i suggest you to post your query on below power management forum.
e2e.ti.com/.../
Senthil
Hello Senthil,
Thanks for reply,
We have to do power integrity analysis and check capacitor requirement for our design,
Pramod
