MCSDK MSYS build error command not found
MCSDK 2.1.2.6
C6678
Windows 7
Latest MingGw (downloaded today)
I've followed the build steps in this directory
C:\ti\mcsdk_2_01_02_06\tools\boot_loader\ibl\doc
When I issue the command (in the msys bash shell)
make evm_c6678_i2c ENDIAN=little I2C_BUS_ADDR=0x51
the output is giving an error in two places:
making device
make -C ../../device/c64x/make CDEFS='-DIBL_CFG_I2C_MAP_TABLE_DATA_BUS_ADDR=0x51 -DEXCLUDE_COFF -DEXCLUDE_BIS -DEXCLUDE_NAND_GPIO -DSPI_MODE=1 -DSPI_ADDR_WIDTH=24 -DSPI_NPIN=5 -DSPI_CSEL=2 -DSPI_C2TDE
L=1 -DSPI_CLKDIV=8 -DSPI_ROM=1 -DPAD_FILE_ID_1=1 -DPAD_FILE_ID_2=1 -DINIT_EXE_FILE=ibl_c66x/ibl_init.i2c.be.ccs -DEXE_FILE_1= -DEXE_FILE_2=ibl_c66x/ibl.i2c.be.ccs' device
make[5]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/device/c64x/make'
q -I -a -ele.oa -o$.da ../../../device/c64x/c64x.s
/bin/sh: q: command not found
make[5]: [c64x.da] Error 127 (ignored)
Checking command line dependencies
and
make[3]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/main/c64x/make'
making device SPI_CFG=-DSPI_MODE=1 -DSPI_ADDR_WIDTH=24 -DSPI_NPIN=5 -DSPI_CSEL=2 -DSPI_C2TDEL=1 -DSPI_CLKDIV=8 -DSPI_ROM=1 -DPAD_FILE_ID_1=1 -DPAD_FILE_ID_2=1 -DINIT_EXE_FILE="ibl_c66x/ibl_init.i2c.be
.ccs" -DEXE_FILE_1="" -DEXE_FILE_2="ibl_c66x/ibl.i2c.be.ccs" CDEFS= EXCLUDES=COFF BIS NAND_GPIO
make -C ../device/c64x/make CDEFS='-DIBL_CFG_I2C_MAP_TABLE_DATA_BUS_ADDR=0x51 -DEXCLUDE_COFF -DEXCLUDE_BIS -DEXCLUDE_NAND_GPIO -DSPI_MODE=1 -DSPI_ADDR_WIDTH=24 -DSPI_NPIN=5 -DSPI_CSEL=2 -DSPI_C2TDEL=1
-DSPI_CLKDIV=8 -DSPI_ROM=1 -DPAD_FILE_ID_1=1 -DPAD_FILE_ID_2=1 -DINIT_EXE_FILE='"ibl_c66x/ibl_init.i2c.be.ccs"' -DEXE_FILE_1='""' -DEXE_FILE_2='"ibl_c66x/ibl.i2c.be.ccs"'' device
make[3]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/device/c64x/make'
make[3]: [c64x.da] Error 127 (ignored)
I attached the complete build output.
epatto@epattoPC /c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/make
$ make evm_c6678_i2c ENDIAN=little I2C_BUS_ADDR=0x51
make -f makestg1 I2C_BUS_ADDR=0x51 I2C_MAP_ADDR=0x500 \
ENDIAN_MODE=little ARCH=c64x TARGET=c66x EVM=c6678l SPI=no SPI_DEFS='SPI_MODE=1 SPI_ADDR_WIDTH=24 SPI_NPIN=5 SPI_CSEL=2 SPI_C2TDEL=1 SPI_CLKDIV=8 SPI_ROM=1' \
CEXCLUDES='COFF BIS NAND_GPIO' c66x
make[1]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/make'
make -f makestg2 ARCH=c64x TARGET=c66x ENDIAN=little I2C_SIZE_BYTES=0x20000 I2C_BUS_ADDR=0x51 INTERNAL_UTILS= SPI_DEFS='SPI_MODE=1 SPI_ADDR_WIDTH=24 SPI_NPIN=5 SPI_CSEL=2 SPI_C2TDEL=1 SPI_CLKDIV=8 SPI
_ROM=1' utils
make[2]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/make'
make -C ../util/btoccs
make[3]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/util/btoccs'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/util/btoccs'
make -C ../util/romparse TARGET=c66x
make[3]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/util/romparse'
same
make[3]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/util/romparse'
make -C ../util/i2cConfig c66x MAINDEFS='-DIBL_CFG_I2C_MAP_TABLE_DATA_BUS_ADDR=0x51 -DEXCLUDE_COFF -DEXCLUDE_BIS -DEXCLUDE_NAND_GPIO -DSPI_MODE=1 -DSPI_ADDR_WIDTH=24 -DSPI_NPIN=5 -DSPI_CSEL=2 -DSPI_C2
TDEL=1 -DSPI_CLKDIV=8 -DSPI_ROM=1 -DPAD_FILE_ID_1=1 -DPAD_FILE_ID_2=1 -DINIT_EXE_FILE='"ibl_c66x/ibl_init.i2c.be.ccs"' -DEXE_FILE_1='""' -DEXE_FILE_2='"ibl_c66x/ibl.i2c.be.ccs"''
make[3]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/util/i2cConfig'
make -f makestg2 ARCH=c64x I2C_BUS_ADDR=0x51 I2C_MAP_ADDR=0x500 TARGET=c66x c66x
make[4]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/util/i2cConfig'
same
making hw
make -C ../../hw/c64x/make hw
make[5]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/hw/c64x/make'
same
make[5]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/hw/c64x/make'
making device
same
make[5]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/device/c64x/make'
cl6x -z -o i2cparam_c66x_le.out -m i2cparam_c66x_le.map i2cparam.le.oc ../../hw/c64x/make/i2c.le.oc ../../hw/c64x/make/pll.le.oc ../../hw/c64x/make/cfgpll.le.oc ../../hw/c64x/make/cfgpll2.le.oc ../../
device/c64x/make/c64x.le.oa ../../hw/c64x/make/psc.le.oc ../../device/c64x/make/c66xutil.le.oc i2cparam.cmd "C:/ti/C6000 Code Generation Tools 7.2.6"/lib/rts64plus.lib
<Linking>
make[4]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/util/i2cConfig'
make[3]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/util/i2cConfig'
make -C ../util/bconvert
make[3]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/util/bconvert'
make[3]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/util/bconvert'
make -C ../util/iblConfig/build EVM=c6678l I2C_MAP_ADDR=0x500
make[3]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/util/iblConfig/build'
touch input.txt
echo "file_name = ibl.bin" > input.txt
echo "device = 6" >> input.txt
echo "offset = 0x500" >> input.txt
echo "ethBoot-doBootp = " >> input.txt
echo "ethBoot-bootFormat = " >> input.txt
echo "ethBoot-ipAddr = " >> input.txt
echo "ethBoot-serverIp = " >> input.txt
echo "ethBoot-gatewayIp = " >> input.txt
echo "ethBoot-netmask = " >> input.txt
echo "ethBoot-fileName = " >> input.txt
gcc   -O2 -DEVM=c6678l -DI2C_MAP_ADDR=0x500 ./obj/iblConfig.obj ./obj/device.obj  -o iblConfig.out
cp iblConfig.out iblConfig.out.dbg
make[3]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/util/iblConfig/build'
make[2]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/make'
make -f makestg2 ARCH=c64x TARGET=c66x ENDIAN=little I2C_SIZE_BYTES=0x20000 I2C_BUS_ADDR=0x51 SPI_DEFS='SPI_MODE=1 SPI_ADDR_WIDTH=24 SPI_NPIN=5 SPI_CSEL=2 SPI_C2TDEL=1 SPI_CLKDIV=8 SPI_ROM=1' c66x
making main SPI_CFG=-DSPI_MODE=1 -DSPI_ADDR_WIDTH=24 -DSPI_NPIN=5 -DSPI_CSEL=2 -DSPI_C2TDEL=1 -DSPI_CLKDIV=8 -DSPI_ROM=1 -DPAD_FILE_ID_1=1 -DPAD_FILE_ID_2=1 -DINIT_EXE_FILE="ibl_c66x/ibl_init.i2c.be.c
make -C ../main/c64x/make CDEFS='-DIBL_CFG_I2C_MAP_TABLE_DATA_BUS_ADDR=0x51 -DEXCLUDE_COFF -DEXCLUDE_BIS -DEXCLUDE_NAND_GPIO -DSPI_MODE=1 -DSPI_ADDR_WIDTH=24 -DSPI_NPIN=5 -DSPI_CSEL=2 -DSPI_C2TDEL=1 -
DSPI_CLKDIV=8 -DSPI_ROM=1 -DPAD_FILE_ID_1=1 -DPAD_FILE_ID_2=1 -DINIT_EXE_FILE='"ibl_c66x/ibl_init.i2c.be.ccs"' -DEXE_FILE_1='""' -DEXE_FILE_2='"ibl_c66x/ibl.i2c.be.ccs"'' main
make[3]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/main/c64x/make'
same
same
make[3]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/device/c64x/make'
making ethboot
make -C ../ethboot/c64x/make ethboot
make[3]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/ethboot/c64x/make'
same
make[3]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/ethboot/c64x/make'
making nandboot
make -C ../nandboot/c64x/make nandboot
make[3]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/nandboot/c64x/make'
same
make[3]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/nandboot/c64x/make'
making driver
make -C ../driver/c64x/make driver
make[3]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/driver/c64x/make'
same
make[3]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/driver/c64x/make'
making hw
make -C ../hw/c64x/make hw
make[3]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/hw/c64x/make'
same
make[3]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/hw/c64x/make'
making interp
make -C ../interp/c64x/make interp
make[3]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/interp/c64x/make'
same
make[3]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/interp/c64x/make'
making ecc
make -C ../ecc/c64x/make ecc
make[3]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/ecc/c64x/make'
same
make[3]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/ecc/c64x/make'
making norboot
make -C ../norboot/c64x/make norboot
make[3]: Entering directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/norboot/c64x/make'
same
make[3]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/norboot/c64x/make'
cat ibl_c66x/ibl_init_objs_template.inc | sed -e s/ENDIAN_TAG/le/g > ibl_c66x/ibl_init_objs.tmp
cl6x -ppo -DIBL_CFG_I2C_MAP_TABLE_DATA_BUS_ADDR=0x51 -DEXCLUDE_COFF -DEXCLUDE_BIS -DEXCLUDE_NAND_GPIO -DENDIAN_TAG=le ibl_c66x/ibl_init_objs.tmp
cp -f ibl_c66x/ibl_init_objs.pp ibl_c66x/ibl_init_objs.inc
cl6x -z -o ibl_c66x/ibl_c66x_init.out -m ibl_c66x/ibl_c66x_init.map ibl_c66x/ibl_init.cmd "C:/ti/C6000 Code Generation Tools 7.2.6"/lib/rts64plus.lib
<Linking>
cp -f ibl_c66x/ibl_c66x_init.out ibl_c66x/ibl_c66x_init.le.out
rm -f -f ibl_c66x/ibl_init_obj.inc
hex6x -order L ibl_c66x/ibl_init_image.rmd ibl_c66x/ibl_c66x_init.out
Translating to ASCII-Hex format...
   "ibl_c66x/ibl_c66x_init.out"   ==> .text
   "ibl_c66x/ibl_c66x_init.out"   ==> .cinit
   "ibl_c66x/ibl_c66x_init.out"   ==> .const
cp -f ibl_le.b ibl_c66x/ibl.b
../util/btoccs/b2ccs ibl_c66x/ibl.b ibl_c66x/ibl_init.le.ccs
hex6x -order L ibl_c66x/ibl_init.rmd ibl_c66x/ibl_c66x_init.out
   "ibl_c66x/ibl_c66x_init.out"   ==> .cinit    (BOOT LOAD)
   "ibl_c66x/ibl_c66x_init.out"   ==> .const    (BOOT LOAD)
   "ibl_c66x/ibl_c66x_init.out"   ==> .text     (BOOT LOAD)
../util/bconvert/bconvert64x -le ibl_le.b ibl.b
cp -f ibl.b ibl_c66x
../util/btoccs/b2i2c ibl_c66x/ibl.b ibl_c66x/ibl.i2c.b
../util/btoccs/b2ccs ibl_c66x/ibl.i2c.b ibl_c66x/ibl_init.i2c.le.ccs
sed -e 's/\\r//' ../util/symExtract/symExtract > ../util/symExtract/symExtract_unix
bash ../util/symExtract/symExtract_unix ibl_c66x/ibl_c66x_init.map ibl_c66x/ibl_init_symbols.inc iblBootBtbl iblMalloc iblFree iblMemset iblMemcpy
rm -f ../util/symExtract/symExtract_unix
cat ibl_c66x/ibl_objs_template.inc | sed -e s/ENDIAN_TAG/le/g > ibl_c66x/ibl_objs.tmp
cl6x -ppo -DIBL_CFG_I2C_MAP_TABLE_DATA_BUS_ADDR=0x51 -DEXCLUDE_COFF -DEXCLUDE_BIS -DEXCLUDE_NAND_GPIO -DENDIAN_TAG=le ibl_c66x/ibl_objs.tmp
cp -f ibl_c66x/ibl_objs.pp ibl_c66x/ibl_objs.inc
cl6x -z -o ibl_c66x/ibl_c66x.out -m ibl_c66x/ibl_c66x.le.map  ibl_c66x/ibl.cmd "C:/ti/C6000 Code Generation Tools 7.2.6"/lib/rts64plus.lib
<Linking>
cp -f ibl_c66x/ibl_c66x.out ibl_c66x/ibl_c66x.le.out
rm -f -f ibl_c66x/ibl_obj.inc
hex6x -order L ibl_c66x/ibl.rmd ibl_c66x/ibl_c66x.out
   "ibl_c66x/ibl_c66x.out"   ==> .cinit         (BOOT LOAD)
   "ibl_c66x/ibl_c66x.out"   ==> .const         (BOOT LOAD)
   "ibl_c66x/ibl_c66x.out"   ==> .text  (BOOT LOAD)
   "ibl_c66x/ibl_c66x.out"   ==> .switch        (BOOT LOAD)
../util/btoccs/b2ccs ibl_c66x/ibl.i2c.b ibl_c66x/ibl.i2c.le.ccs
make -f makestg2 ARCH=c64x TARGET=c66x I2CROM=little_endian I2C_BUS_ADDR=0x51 I2C_MAP_ADDRESS= EVM=c6678l COMPACT_I2C= SPI_DEFS='SPI_MODE=1 SPI_ADDR_WIDTH=24 SPI_NPIN=5 SPI_CSEL=2 SPI_C2TDEL=1 SPI_CLK
DIV=8 SPI_ROM=1'  i2crom spiRom
cl6x -ppo -I../cfg/c66x -DI2C_BUS_ADDR=0x51 -DI2C_MAP_ADDR=0x500 -DEVM=c6678l -DPAD_FILE_ID_1=1 -DPAD_FILE_ID_2=1 -DINIT_EXE_FILE='"ibl_c66x/ibl_init.i2c.le.ccs"' -DEXE_FILE_1='"ibl_c66x/ibl.i2c.le.cc
s"' -DEXE_FILE_2='""' ibl_c66x/i2crom.map.pre
../util/romparse/romparse  -rom_base 0x51 ibl_c66x/i2crom.map.pp
file_cp -f i2crom.ccs ibl_c66x/i2crom.ccs
cp -f i2crom.ccs ibl_c66x/i2crom.dat
../util/btoccs/ccs2bin -swap ibl_c66x/i2crom.ccs ibl_c66x/i2crom.bin
cp ibl_c66x/i2crom.bin ../util/iblConfig/build/ibl.bin
(cd ../util/iblConfig/build;./iblConfig.out)
Opened file ibl.bin
Generated updated binary ibl.bin
cp ../util/iblConfig/build/ibl.bin ibl_c66x/i2crom.bin
rm -f i2crom.ccs ibl_le.b ibl.b
Making SPI ROM
cl6x -ppo -I../cfg/c66x -DSPI_MODE=1 -DSPI_ADDR_WIDTH=24 -DSPI_NPIN=5 -DSPI_CSEL=2 -DSPI_C2TDEL=1 -DSPI_CLKDIV=8 -DSPI_ROM=1 -DPAD_FILE_ID_1=1 -DPAD_FILE_ID_2=1 -DINIT_EXE_FILE='"ibl_c66x/ibl_init.i2c
.le.ccs"' -DEXE_FILE_1='"ibl_c66x/ibl.i2c.le.ccs"' -DEXE_FILE_2='""' ibl_c66x/spiRom.map.pre
../util/romparse/romparse  -fill 0xff -rom_base 0 ibl_c66x/spiRom.map.pp
file_cp -f i2crom.ccs ibl_c66x/spiRom.ccs
cp -f i2crom.ccs ibl_c66x/spiRom.dat
make[1]: Leaving directory `/c/ti/mcsdk_2_01_02_06/tools/boot_loader_MikeLogan/ibl/src/make'
cp -f ibl_c66x/i2crom.dat bin/i2crom_0x51_c6678_le.dat
cp -f ibl_c66x/i2crom.bin bin/i2crom_0x51_c6678_le.bin
cp -f ../util/i2cConfig/i2cparam_c66x_le.out bin/i2cparam_0x51_c6678_le_0x500.out
Any thoughts on how to fix this?
Cheers2u
Eddie
