Other Parts Discussed in Thread: AM3358
Hi:
Recently I need to compile the am3358 net driver(cpsw) as a modules(the defautl the cpsw compiled into kernel), so I select the cpsw to M. and I get the ti_cpsw.ko.
When I reboot the linux system, the ti_cpsw is not intalled(I have already do "make modules_install"). so I input the command "modprobe ti_cpsw" and I could found the cpsw module as using the lsmod command.
however, when I input the command "rmmod ti_cpsw" that I want to remove the cpsw module from kernel I get some error as below:
[ 816.487398] removing device
[ 816.490225] ------------[ cut here ]------------
[ 816.495256] WARNING: at /usr/src/linux-3.8.13-bone70/drivers/net/ethernet/ti/cpsw.c:453 cpsw_rx_handler+0xb2/0xd0 [ti_cpsw]()
[ 816.507052] Modules linked in: ti_cpsw(-) g_ether libcomposite evdev omap_rng
[ 816.514564] [<c0010b11>] (unwind_backtrace+0x1/0x90) from [<c002f92f>] (warn_slowpath_common+0x3f/0x4c)
[ 816.524375] [<c002f92f>] (warn_slowpath_common+0x3f/0x4c) from [<c002f99d>] (warn_slowpath_null+0x11/0x18)
[ 816.534461] [<c002f99d>] (warn_slowpath_null+0x11/0x18) from [<bf820acf>] (cpsw_rx_handler+0xb2/0xd0 [ti_cpsw])
[ 816.545012] [<bf820acf>] (cpsw_rx_handler+0xb2/0xd0 [ti_cpsw]) from [<c0362a49>] (__cpdma_chan_process+0x85/0xb8)
[ 816.555728] [<c0362a49>] (__cpdma_chan_process+0x85/0xb8) from [<c0362b51>] (cpdma_chan_stop+0xa1/0x110)
[ 816.565627] [<c0362b51>] (cpdma_chan_stop+0xa1/0x110) from [<c0362c71>] (cpdma_chan_destroy+0x41/0x48)
[ 816.575348] [<c0362c71>] (cpdma_chan_destroy+0x41/0x48) from [<bf81fe0b>] (cpsw_remove+0x56/0xb4 [ti_cpsw])
[ 816.585535] [<bf81fe0b>] (cpsw_remove+0x56/0xb4 [ti_cpsw]) from [<c0306129>] (__device_release_driver+0x39/0x70)
[ 816.596162] [<c0306129>] (__device_release_driver+0x39/0x70) from [<c03065c1>] (driver_detach+0x71/0x74)
[ 816.606062] [<c03065c1>] (driver_detach+0x71/0x74) from [<c0305f1f>] (bus_remove_driver+0x3f/0x7c)
[ 816.615422] [<c0305f1f>] (bus_remove_driver+0x3f/0x7c) from [<bf820d01>] (cpsw_exit+0x8/0xf [ti_cpsw])
[ 816.625152] [<bf820d01>] (cpsw_exit+0x8/0xf [ti_cpsw]) from [<c0062e83>] (sys_delete_module+0x15f/0x1d4)
[ 816.635059] [<c0062e83>] (sys_delete_module+0x15f/0x1d4) from [<c000c861>] (ret_fast_syscall+0x1/0x44)
[ 816.644771] ---[ end trace c025b53d69825ec3 ]---
[ 816.650012] BUG: spinlock recursion on CPU#0, rmmod/1260
[ 816.655566] lock: 0xdf57b84c, .magic: dead4ead, .owner: rmmod/1260, .owner_cpu: 0
[ 816.663480] [<c0010b11>] (unwind_backtrace+0x1/0x90) from [<c029b0d7>] (do_raw_spin_lock+0x63/0xe0)
[ 816.672937] [<c029b0d7>] (do_raw_spin_lock+0x63/0xe0) from [<c05122c1>] (_raw_spin_lock_irqsave+0x21/0x28)
[ 816.683021] [<c05122c1>] (_raw_spin_lock_irqsave+0x21/0x28) from [<c0362bd1>] (cpdma_ctlr_stop+0x11/0x70)
[ 816.693011] [<c0362bd1>] (cpdma_ctlr_stop+0x11/0x70) from [<c0362d17>] (cpdma_ctlr_destroy+0x9f/0xc8)
[ 816.702644] [<c0362d17>] (cpdma_ctlr_destroy+0x9f/0xc8) from [<bf81fe13>] (cpsw_remove+0x5e/0xb4 [ti_cpsw])
[ 816.712824] [<bf81fe13>] (cpsw_remove+0x5e/0xb4 [ti_cpsw]) from [<c0306129>] (__device_release_driver+0x39/0x70)
[ 816.723450] [<c0306129>] (__device_release_driver+0x39/0x70) from [<c03065c1>] (driver_detach+0x71/0x74)
[ 816.733350] [<c03065c1>] (driver_detach+0x71/0x74) from [<c0305f1f>] (bus_remove_driver+0x3f/0x7c)
[ 816.742711] [<c0305f1f>] (bus_remove_driver+0x3f/0x7c) from [<bf820d01>] (cpsw_exit+0x8/0xf [ti_cpsw])
[ 816.752435] [<bf820d01>] (cpsw_exit+0x8/0xf [ti_cpsw]) from [<c0062e83>] (sys_delete_module+0x15f/0x1d4)
[ 816.762335] [<c0062e83>] (sys_delete_module+0x15f/0x1d4) from [<c000c861>] (ret_fast_syscall+0x1/0x44)
[ 821.737079] BUG: spinlock lockup suspected on CPU#0, rmmod/1260
[ 821.743255] lock: 0xdf57b84c, .magic: dead4ead, .owner: rmmod/1260, .owner_cpu: 0
[ 821.751157] [<c0010b11>] (unwind_backtrace+0x1/0x90) from [<c029b14d>] (do_raw_spin_lock+0xd9/0xe0)
[ 821.760601] [<c029b14d>] (do_raw_spin_lock+0xd9/0xe0) from [<c05122c1>] (_raw_spin_lock_irqsave+0x21/0x28)
[ 821.770680] [<c05122c1>] (_raw_spin_lock_irqsave+0x21/0x28) from [<c0362bd1>] (cpdma_ctlr_stop+0x11/0x70)
[ 821.780667] [<c0362bd1>] (cpdma_ctlr_stop+0x11/0x70) from [<c0362d17>] (cpdma_ctlr_destroy+0x9f/0xc8)
[ 821.790295] [<c0362d17>] (cpdma_ctlr_destroy+0x9f/0xc8) from [<bf81fe13>] (cpsw_remove+0x5e/0xb4 [ti_cpsw])
[ 821.800471] [<bf81fe13>] (cpsw_remove+0x5e/0xb4 [ti_cpsw]) from [<c0306129>] (__device_release_driver+0x39/0x70)
[ 821.811094] [<c0306129>] (__device_release_driver+0x39/0x70) from [<c03065c1>] (driver_detach+0x71/0x74)
[ 821.820992] [<c03065c1>] (driver_detach+0x71/0x74) from [<c0305f1f>] (bus_remove_driver+0x3f/0x7c)
[ 821.830350] [<c0305f1f>] (bus_remove_driver+0x3f/0x7c) from [<bf820d01>] (cpsw_exit+0x8/0xf [ti_cpsw])
[ 821.840071] [<bf820d01>] (cpsw_exit+0x8/0xf [ti_cpsw]) from [<c0062e83>] (sys_delete_module+0x15f/0x1d4)
[ 821.849968] [<c0062e83>] (sys_delete_module+0x15f/0x1d4) from [<c000c861>] (ret_fast_syscall+0x1/0x44)
[ 821.860732] ------------[ cut here ]------------
[ 821.865563] kernel BUG at /home/eval/liuxcnc/beaglebone/machine-code/linux-3.8.13-bone70/net/core/dev.c:6286!
[ 821.875908] Internal error: Oops - BUG: 0 [#1] THUMB2
[ 821.881177] Modules linked in: ti_cpsw(-) g_ether libcomposite evdev omap_rng
[ 821.888655] CPU: 0 Tainted: G W (3.8.13xenomai #3)
[ 821.894926] PC is at free_netdev+0x7a/0x7c
[ 821.899202] LR is at _raw_spin_unlock_irqrestore+0x11/0x14
[ 821.904925] pc : [<c046c622>] lr : [<c0512329>] psr: 80000033
[ 821.904925] sp : ddf97ee8 ip : 00000000 fp : 00000800
[ 821.916903] r10: 00000000 r9 : 00000000 r8 : ddf96008
[ 821.922352] r7 : dd956d00 r6 : dd956800 r5 : dd956838 r4 : dd956814
[ 821.929159] r3 : 00000001 r2 : 00000000 r1 : 00000000 r0 : c08dfdb0
[ 821.935970] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment user
[ 821.943595] Control: 50c5387d Table: 9dfd8019 DAC: 00000015
[ 821.949587] Process rmmod (pid: 1260, stack limit = 0xddf96238)
[ 821.955761] Stack: (0xddf97ee8 to 0xddf98000)
[ 821.960307] 7ee0: dd956800 c08d3e70 df0af610 bf81fe65 bf81fdb5 df0af610
[ 821.968842] 7f00: bf821d88 df0af644 00000000 c0306129 bf821d88 df0af610 bf821d88 c03065c1
[ 821.977376] 7f20: 00000000 bf821d88 c08f68e0 c0305f1f 00000000 bf821dc8 00000800 bf820d01
[ 821.985911] 7f40: bf820cf9 c0062e83 ddf7fe40 635f6974 00777370 c010e16b 00000000 00000000
[ 821.994446] 7f60: df5753ec 00000000 c0966074 df575040 c08d8c6c ddf96000 df575040 c004371d
[ 822.002981] 7f80: ddf7fe40 00f96018 c000ca68 fffffffe b6fe8d10 bec9c920 00000081 c000ca68
[ 822.011515] 7fa0: ddf96000 c000c861 fffffffe b6fe8d10 b6fe8d40 00000800 38931800 38931800
[ 822.020051] 7fc0: fffffffe b6fe8d10 bec9c920 00000081 00000002 00000000 b6fe8008 00000800
[ 822.028585] 7fe0: bec9c81c bec9c5a8 b6f8da47 b6f1114c 80000010 b6fe8d40 9fefe821 9fefec21
[ 822.037140] [<c046c622>] (free_netdev+0x7a/0x7c) from [<bf81fe65>] (cpsw_remove+0xb0/0xb4 [ti_cpsw])
[ 822.046687] [<bf81fe65>] (cpsw_remove+0xb0/0xb4 [ti_cpsw]) from [<c0306129>] (__device_release_driver+0x39/0x70)
[ 822.057312] [<c0306129>] (__device_release_driver+0x39/0x70) from [<c03065c1>] (driver_detach+0x71/0x74)
[ 822.067209] [<c03065c1>] (driver_detach+0x71/0x74) from [<c0305f1f>] (bus_remove_driver+0x3f/0x7c)
[ 822.076567] [<c0305f1f>] (bus_remove_driver+0x3f/0x7c) from [<bf820d01>] (cpsw_exit+0x8/0xf [ti_cpsw])
[ 822.086292] [<bf820d01>] (cpsw_exit+0x8/0xf [ti_cpsw]) from [<c0062e83>] (sys_delete_module+0x15f/0x1d4)
[ 822.096192] [<c0062e83>] (sys_delete_module+0x15f/0x1d4) from [<c000c861>] (ret_fast_syscall+0x1/0x44)
[ 822.105906] Code: e8bd 4070 f49a bd7f (de02) e92d
[ 822.111056] ---[ end trace c025b53d69825ec4 ]---
[ 822.116060] [sched_delayed] sched: RT throttling activated
Message from syslogd@beaglebone at Dec 14 13:15:06 ...
kernel:[ 816.650012] BUG: spinlock recursion on CPU#0, rmmod/1260
kernel:[ 816.655566] lock: 0xdf57b84c, .magic: dead4ead, .owner: rmmod/1260, .owner_cpu: 0
kernel:[ 821.737079] BUG: spinlock lockup suspected on CPU#0, rmmod/1260
kernel:[ 821.743255] lock: 0xdf57b84c, .magic: dead4ead, .owner: rmmod/1260, .owner_cpu: 0
kernel:[ 821.875908] Internal error: Oops - BUG: 0 [#1] THUMB2
Me[ 822.205095] Unable to handle kernel NULL pointer dereference at virtual address 00000000
ssage from syslo[ 822.214621] pgd = ddfdc000, hw pgd = ddfdc000
gd@beaglebone at[ 822.220564] [00000000] *pgd=9df95831 Dec 14 13:15:06, *pte=00000000 ...
kernel:[, *ppte=00000000 821.949587] Pr
ocess rmmod (pid[ 822.232765] Internal error: Oops: 17 [#2] THUMB2
[ 822.238960] Modules linked in: ti_cpsw(-) g_ether libcomposite evdev omap_rng
[ 822.246436] CPU: 0 Tainted: G D W (3.8.13xenomai #3)
[ 822.252720] PC is at memcpy+0xd6/0x2dc
[ 822.256634] LR is at dev_ioctl+0x5af/0x5c4
[ 822.260906] pc : [<c028f656>] lr : [<c046e26f>] psr: 6000a833
[ 822.260906] sp : ddf9fec4 ip : 00000002 fp : 00000000
[ 822.272886] r10: 00000000 r9 : 00000000 r8 : ddf9e010
[ 822.278336] r7 : ddf9fed8 r6 : bec50ba4 r5 : dd956800 r4 : 00008927
[ 822.285145] r3 : 00008927 r2 : 00000002 r1 : 00000000 r0 : ddf9feea
[ 822.291956] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment user
[ 822.299584] Control: 50c5387d Table: 9dfdc019 DAC: 00000015
[ 822.305577] Process ifconfig (pid: 1261, stack limit = 0xddf9e238)
[ 822.312023] Stack: (0xddf9fec4 to 0xddfa0000)
[ 822.316570] fec0: ddf9feea 00008927 c046e26f 00000338 c00e8d4b 30687465 00000000
[ 822.325108] fee0: 00000000 00000000 b6ee1043 b6f794c0 00000068 0001d358 c08a4124 d6c25060
[ 822.333643] ff00: bec50ba4 00008927 ddf7f540 ddf7f540 00000008 00000000 00000000 c0117ff5
[ 822.342179] ff20: b6fcc000 00000001 00000035 c01070cf c08d8c6c 00000000 ddcf6248 00000000
[ 822.350715] ff40: 00001000 c000ca68 ddf9e000 ddcf6248 00000000 c05122c1 ddcf6248 00000000
[ 822.359249] ff60: 00008927 bec50ba4 00000000 ddf7f540 00000008 00000000 00000000 c011814f
[ 822.367786] ff80: 00000000 00000000 ddcf6248 0001d368 0001d370 0001b6d4 00000036 c000ca68
[ 822.376323] ffa0: ddf9e000 c000c861 0001d368 0001d370 00000008 00008927 bec50ba4 bec50ba4
[ 822.384858] ffc0: 0001d368 0001d370 0001b6d4 00000036 00000000 00000000 b6fd1000 00000000
[ 822.393394] ffe0: 0001b958 bec50ba0 0000d8ef b6f2591c 60000010 00000008 9fefe821 9fefec21
[ 822.401935] Code: bfc8 f811 3b01 bfa8 (f811) 4b01
: 1260, stack li[ 822.407009] ---[ end trace c025b53d69825ec5 ]---
mit = 0xddf96238)
kernel:[ 821.955761] Stack: (0xddf97ee8 to 0xddf98000)
kernel:[ 821.960307] 7ee0: dd956800 c08d3e70 df0af610 bf81fe65 bf81fdb5 df0af610
kernel:[ 821.968842] 7f00: bf821d88 df0af644 00000000 c0306129 bf821d88 df0af610 bf821d88 c03065c1
kernel:[ 821.977376] 7f20: 00000000 bf821d88 c08f68e0 c0305f1f 00000000 bf821dc8 00000800 bf820d01
kernel:[ 821.985911] 7f40: bf820cf9 c0062e83 ddf7fe40 635f6974 00777370 c010e16b 00000000 00000000
kernel:[ 821.994446] 7f60: df5753ec 00000000 c0966074 df575040 c08d8c6c ddf96000 df575040 c004371d
kernel:[ 822.002981] 7f80: ddf7fe40 00f96018 c000ca68 fffffffe b6fe8d10 bec9c920 00000081 c000ca68
kernel:[ 822.011515] 7fa0: ddf96000 c000c861 fffffffe b6fe8d10 b6fe8d40 00000800 38931800 38931800
kernel:[ 822.020051] 7fc0: fffffffe b6fe8d10 bec9c920 00000081 00000002 00000000 b6fe8008 00000800
kernel:[ 822.028585] 7fe0: bec9c81c bec9c5a8 b6f8da47 b6f1114c 80000010 b6fe8d40 9fefe821 9fefec21
kernel:[ 822.105906] Code: e8bd 4070 f49a bd7f (de02) e92d
Message from syslogd@beaglebone at Dec 14 13:15:07 ...
kernel:[ 822.232765] Internal error: Oops: 17 [#2] THUMB2
kernel:[ 822.305577] Process ifconfig (pid: 1261, stack limit = 0xddf9e238)
kernel:[ 822.312023] Stack: (0xddf9fec4 to 0xddfa0000)
kernel:[ 822.316570] fec0: ddf9feea 00008927 c046e26f 00000338 c00e8d4b 30687465 00000000
kernel:[ 822.325108] fee0: 00000000 00000000 b6ee1043 b6f794c0 00000068 0001d358 c08a4124 d6c25060
kernel:[ 822.333643] ff00: bec50ba4 00008927 ddf7f540 ddf7f540 00000008 00000000 00000000 c0117ff5
kernel:[ 822.342179] ff20: b6fcc000 00000001 00000035 c01070cf c08d8c6c 00000000 ddcf6248 00000000
kernel:[ 822.350715] ff40: 00001000 c000ca68 ddf9e000 ddcf6248 00000000 c05122c1 ddcf6248 00000000
kernel:[ 822.359249] ff60: 00008927 bec50ba4 00000000 ddf7f540 00000008 00000000 00000000 c011814f
kernel:[ 822.367786] ff80: 00000000 00000000 ddcf6248 0001d368 0001d370 0001b6d4 00000036 c000ca68
kernel:[ 822.376323] ffa0: ddf9e000 c000c861 0001d368 0001d370 00000008 00008927 bec50ba4 bec50ba4
kernel:[ 822.384858] ffc0: 0001d368 0001d370 0001b6d4 00000036 00000000 00000000 b6fd1000 00000000
kernel:[ 822.393394] ffe0: 0001b958 bec50ba0 0000d8ef b6f2591c 60000010 00000008[ 822.743449] Unable to handle kernel NULL pointer dereference at virtual address 00000000
9fefe821 9fefec[ 822.752388] pgd = c0004000, hw pgd = ddb10000
21
Message[ 822.758328] [00000000] *pgd=00000000 from syslogd@be
aglebone at Dec [ 822.764876] Internal error: Oops: 5 [#3] THUMB2
[ 822.770982] Modules linked in: ti_cpsw(-) g_ether libcomposite evdev omap_rng
[ 822.778461] CPU: 0 Tainted: G D W (3.8.13xenomai #3)
[ 822.784742] PC is at packet_release+0x9a/0x214
[ 822.789377] LR is at 0x1
[ 822.792019] pc : [<c04ee802>] lr : [<00000001>] psr: 60000133
[ 822.792019] sp : ddf6dd80 ip : ddf6dd50 fp : ddf6c008
[ 822.803998] r10: ddf805c8 r9 : df0165d0 r8 : c091746c
[ 822.809449] r7 : d6a64ac0 r6 : dd83fc34 r5 : dd83ff6c r4 : dd83fc00
[ 822.816259] r3 : c08d8c6c r2 : 00000000 r1 : 00000000 r0 : 60000113
[ 822.823071] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment user
[ 822.830697] Control: 50c5387d Table: 9db10019 DAC: 00000015
[ 822.836692] Process dhclient (pid: 1184, stack limit = 0xddf6c238)
[ 822.843141] Stack: (0xddf6dd80 to 0xddf6e000)
[ 822.847689] dd80: ddf6c008 c05122c1 ddf805c8 00000001 00000000 d6ce3380 00000000 00000000
[ 822.856226] dda0: d6a64ac0 00000000 d6a64ae0 00000008 d6c20548 c045ed6f c045eddd ddf805c0
[ 822.864761] ddc0: 00000000 c045ede7 c045eddd c010e111 00000000 00000000 df79992c ddf810c0
[ 822.873297] dde0: c0966074 df799580 00000001 ddf6c010 00000020 c0043729 c09237e4 dda49c80
[ 822.881833] de00: df799580 df799944 dda49cc8 c0033773 ddf6de40 00000016 00000000 ddf6c000
[ 822.890369] de20: 00000000 00000009 df799580 0000000f ddf6c000 df070e40 00000000 ddf6c000
[ 822.898904] de40: 00000008 00000020 ddf6c008 c0033c9b 00418004 00000000 00000009 ddf6def0
[ 822.907441] de60: 00000000 c003cdd3 00000000 dd9ae544 dd9ae040 c0920378 df070e40 ddf6c000
[ 822.915977] de80: ddf6df10 08430000 ddf6c000 ddf6dedc 00000000 00000001 b6e0e3d0 b6e0e3d4
[ 822.924513] dea0: ddf6dfb0 c08d8c6c fffffdfe 00000000 00000000 c000edc3 00000000 00000000
[ 822.933049] dec0: 00000008 c0107741 00000000 00000000 b6f8a4c0 dd9bc000 00000003 ffffff9c
[ 822.941584] dee0: ddf6df10 ffffff9c ddf6c000 c08a4194 00000009 00000000 00000000 00000000
[ 822.950119] df00: 00000000 00000000 17ce219a 00000000 9491a123 0017a611 32da5f20 000095bd
[ 822.958654] df20: befc9c74 000098f4 00000001 befc9c74 00000008 00000000 fffffdfe c011866f
[ 822.967190] df40: 000095bd 2f268c14 000095bd 000c120f befc9c74 ddf6df70 ebb9801c 000369a5
[ 822.975725] df60: 00000016 c0118e31 ddf6df70 befc9bc4 000098f4 ddf6c018 c000ca68 ddf6c000
[ 822.984260] df80: ddf6dfb0 c08d8c6c ddf6c000 00000000 00000000 c000f309 befc9c74 b6fcb550
[ 822.992795] dfa0: befc9c7c 0000008e c000ca68 c000c8ed 00000016 b6d01088 b6d01188 00000000
[ 823.001331] dfc0: befc9c74 b6fcb550 befc9c7c 0000008e 00000000 00000000 431bde83 00000000
[ 823.009867] dfe0: befc9c74 befc9c3c b6f85881 b6e0e3d0 40000010 00000016 00000000 00000000
[ 823.018424] [<c04ee802>] (packet_release+0x9a/0x214) from [<c045ed6f>] (sock_release+0xf/0x7c)
[ 823.027448] [<c045ed6f>] (sock_release+0xf/0x7c) from [<c045ede7>] (sock_close+0xb/0x1c)
[ 823.035931] [<c045ede7>] (sock_close+0xb/0x1c) from [<c010e111>] (__fput+0x5d/0x178)
[ 823.044051] [<c010e111>] (__fput+0x5d/0x178) from [<c0043729>] (task_work_run+0x6d/0x90)
[ 823.052532] [<c0043729>] (task_work_run+0x6d/0x90) from [<c0033773>] (do_exit+0x1cb/0x6b0)
[ 823.061190] [<c0033773>] (do_exit+0x1cb/0x6b0) from [<c0033c9b>] (do_group_exit+0x27/0x6c)
[ 823.069855] [<c0033c9b>] (do_group_exit+0x27/0x6c) from [<c003cdd3>] (get_signal_to_deliver+0x1c7/0x438)
[ 823.079797] [<c003cdd3>] (get_signal_to_deliver+0x1c7/0x438) from [<c000edc3>] (do_signal+0x57/0x38c)
[ 823.089458] [<c000edc3>] (do_signal+0x57/0x38c) from [<c000f309>] (do_work_pending+0x85/0x90)
[ 823.098390] [<c000f309>] (do_work_pending+0x85/0x90) from [<c000c8ed>] (work_pending+0x9/0x18)
[ 823.107411] Code: f380 8100 f8d2 222c (6813) 3b01
[ 823.112507] ---[ end trace c025b53d69825ec6 ]---
kernel:[ 822[ 823.118735] Fixing recursive fault but reboot is needed!
.401935] Code: b[ 823.126240] Unable to handle kernel paging request at virtual address 54685525
fc8 f811 3b01 bf[ 823.134626] pgd = c0004000, hw pgd = ddb10000
[ 823.140577] [54685525] *pgd=00000000
[ 823.145893] Internal error: Oops: 5 [#4] THUMB2
[ 823.150617] Modules linked in: ti_cpsw(-) g_ether libcomposite evdev omap_rng
[ 823.158088] CPU: 0 Tainted: G D W (3.8.13xenomai #3)
[ 823.164362] PC is at strnlen+0x2/0x34
[ 823.168183] LR is at string.isra.6+0x29/0xa4
[ 823.172636] pc : [<c02953be>] lr : [<c02969c5>] psr: 20000133
[ 823.172636] sp : df12bdb8 ip : 00000020 fp : 00000002
[ 823.184614] r10: 00000020 r9 : c054ab1c r8 : 00000000
[ 823.190063] r7 : ffffffff r6 : c09248ec r5 : 54685525 r4 : c0924516
[ 823.196873] r3 : 00000000 r2 : 54685525 r1 : ffffffff r0 : 54685525
[ 823.203682] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment kernel
[ 823.211488] Control: 50c5387d Table: 9db10019 DAC: 00000015
[ 823.217479] Process kworker/0:1 (pid: 13, stack limit = 0xdf12a238)
[ 823.224015] Stack: (0xdf12bdb8 to 0xdf12c000)
[ 823.228560] bda0: ffffffff c07983fe
[ 823.237097] bdc0: c0798400 df12bea0 c09248ec c02973a1 ffffffff ffffffff c0922de0 df12be28
[ 823.245632] bde0: 000003e0 c092450c ff0a0004 ffffffff 00000000 000003e0 c08d3880 c0923c28
[ 823.254167] be00: ffffffff 00000000 00000000 00000000 c0923c28 c0297741 00000000 c0031243
[ 823.262703] be20: 00000000 c05126db 00041673 83126e98 df12a000 00000000 00000000 00000000
[ 823.271238] be40: df12a000 c0510f5b 00000000 df12be9c ddf40ed0 00000000 c07983f4 00000000
[ 823.279773] be60: dd956800 00000000 00000000 c050e2d1 c07983f4 df12be9c c09248ec df12be9c
[ 823.288308] be80: ddf40ec0 ddf40ed0 00000000 dd956d00 00000000 bf81f7cf c07983f4 54685525
[ 823.296843] bea0: ddf40ed0 00000000 df5c9c00 df5c9e2c df5c9e78 00000000 00000000 0000000f
[ 823.305379] bec0: c09203a0 c0354d3d df5c9e2c df101140 c08d5b08 c0e02400 00000000 c0041b2d
[ 823.313913] bee0: c08d5b08 c00425f7 c08d5380 c08d5ca8 c08d8c6c c08d5c20 df101154 c08d5c28
[ 823.322448] bf00: df12a018 8c13521d c08d5b00 c0965da4 df101140 c004277f c08d5b08 c091ffaf
[ 823.330985] bf20: 00000000 00000000 00000000 df07be64 df12bf7c df101140 c0042655 00000000
[ 823.339520] bf40: 00000000 00000000 00000000 c0045663 00000000 00000000 00000000 df101140
[ 823.348055] bf60: 00000000 00000001 dead4ead ffffffff ffffffff df12bf74 df12bf74 00000000
[ 823.356590] bf80: 00000001 dead4ead ffffffff ffffffff df12bf90 df12bf90 00000000 df07be64
[ 823.365125] bfa0: c00455e1 00000000 00000000 c000c957 00000000 00000000 00000000 00000000
[ 823.373658] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 823.382192] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 823.390737] [<c02953be>] (strnlen+0x2/0x34) from [<c07983fe>] (__func__.16338+0x1883ee/0x1be378)
[ 823.399909] Code: 4610 4770 bf00 b199 (7803) b19b
[ 823.404940] ---[ end trace c025b53d69825ec7 ]---
Message from syslogd@beaglebone at Dec 14 13:15:08 ...
kernel:[ 822.764876] Internal error: Oops: 5 [#3] THUMB2
kernel:[ 822.836692] Process dhclient (pid: 1184, stack limit = 0xddf6c238)
kernel:[ 822.843141] Stack: (0xddf6dd80 to 0xddf6e000)
Message from syslogd@beaglebone [ 823.449080] Unable to handle kernel NULL pointer dereference at virtual address 00000000
at Dec 14 13:15:[ 823.458418] pgd = ddfa0000, hw pgd = ddfa0000
08 ...
kernel[ 823.464362] [00000000] *pgd=00000000:[ 822.847689]
dd80: ddf6c008 c[ 823.470914] Internal error: Oops: 5 [#5] THUMB2
[ 823.477017] Modules linked in: ti_cpsw(-) g_ether libcomposite evdev omap_rng
[ 823.484492] CPU: 0 Tainted: G D W (3.8.13xenomai #3)
[ 823.490777] PC is at dev_get_by_name+0x28/0x40
[ 823.495412] LR is at dev_get_by_name_rcu+0x41/0x4c
[ 823.500410] pc : [<c0469864>] lr : [<c0469779>] psr: 60000033
[ 823.500410] sp : ddf8dee8 ip : 00000003 fp : 00000000
[ 823.512388] r10: 00000000 r9 : ddf8c000 r8 : c000ca68
[ 823.517838] r7 : 0000011a r6 : befecb2c r5 : 00000010 r4 : 00000001
[ 823.524645] r3 : c08d8c6c r2 : 00000000 r1 : 00000000 r0 : dd956800
[ 823.531456] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment user
[ 823.539081] Control: 50c5387d Table: 9dfa0019 DAC: 00000015
[ 823.545074] Process dhclient (pid: 1280, stack limit = 0xddf8c238)
[ 823.551520] Stack: (0xddf8dee8 to 0xddf8e000)
[ 823.556066] dee0: c04ee055 df7e6400 df7e6400 c04ee07b 68746500 c0450030
[ 823.564602] df00: d6a643c0 00000010 d6a643c0 c045f2f7 00000000 00000000 74650011 00003068
[ 823.573136] df20: 00000000 00000000 ddf8c000 00000000 00000000 c010e3ed c0273351 00000000
[ 823.581671] df40: df7e4040 dd886480 00000008 dd8864a4 ddf5c0c0 c000ca68 ddf8c000 00000000
[ 823.590204] df60: 00000000 c011e84f df7e4040 00000000 00000000 c0512303 df7e4040 c045f173
[ 823.598740] df80: ddf808c0 ddf8c018 c000ca68 d6a643c0 ddf8dfb0 0000031c 00000008 b6f495a8
[ 823.607276] dfa0: b6e23f10 c000c861 00000008 b6f495a8 00000008 befecb2c 00000010 befecb3b
[ 823.615811] dfc0: 00000008 b6f495a8 b6e23f10 0000011a 00000004 00000000 b6f36864 00000000
[ 823.624346] dfe0: 00000011 befecb28 b6e48ccd b6d7e79c 20000010 00000008 00000000 00000000
[ 823.632900] [<c0469864>] (dev_get_by_name+0x28/0x40) from [<c04ee07b>] (packet_bind_spkt+0x27/0x40)
[ 823.642354] [<c04ee07b>] (packet_bind_spkt+0x27/0x40) from [<c045f2f7>] (sys_bind+0x33/0x4c)
[ 823.651202] [<c045f2f7>] (sys_bind+0x33/0x4c) from [<c000c861>] (ret_fast_syscall+0x1/0x44)
[ 823.659951] Code: f381 8100 f8d0 122c (680b) 3301
05122c1 ddf805c8[ 823.665030] ---[ end trace c025b53d69825ec8 ]---
kernel:[ 822.856226] dda0: d6a64ac0 00000000 d6a64ae0 00000008 d6c20548 c045ed6f c045eddd ddf805c0
kernel:[ 822.864761] ddc0: 00000000 c045ede7 c045eddd c010e111 00000000 00000000 df79992c ddf810c0
kernel:[ 822.873297] dde0: c0966074 df799580 00000001 ddf6c010 00000020 c0043729 c09237e4 dda49c80
kernel:[ 822.881833] de00: df799580 df799944 dda49cc8 c0033773 ddf6de40 00000016 00000000 ddf6c000
kernel:[ 822.890369] de20: 00000000 00000009 df799580 0000000f ddf6c000 df070e40 00000000 ddf6c000
Message [ 823.748162] Unable to handle kernel NULL pointer dereference at virtual address 00000000
from syslogd@bea[ 823.757401] pgd = ddfd8000, hw pgd = ddfd8000
, *pte=000000001[ 823.763349] [00000000] *pgd=9df8d8314 13:15:08 ...
kernel:[ 822., *ppte=00000000898904] de40: 00
000008 00000020 [ 823.775552] Internal error: Oops: 17 [#6] THUMB2
[ 823.781748] Modules linked in: ti_cpsw(-) g_ether libcomposite evdev omap_rng
[ 823.789222] CPU: 0 Tainted: G D W (3.8.13xenomai #3)
[ 823.795505] PC is at neigh_destroy+0x76/0xf8
[ 823.799969] LR is at _raw_spin_unlock_irqrestore+0x11/0x14
[ 823.805692] pc : [<c0473002>] lr : [<c0512329>] psr: 60000033
[ 823.805692] sp : ddfd1db0 ip : 00000010 fp : df533614
[ 823.817670] r10: 00000000 r9 : df1f6f40 r8 : 00000001
[ 823.823121] r7 : 00000003 r6 : dd956800 r5 : c08d8c6c r4 : df533600
[ 823.829930] r3 : 60000013 r2 : 00000000 r1 : 00000000 r0 : 00000000
[ 823.836741] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment user
[ 823.844367] Control: 50c5387d Table: 9dfd8019 DAC: 00000015
[ 823.850361] Process ifconfig (pid: 1281, stack limit = 0xddfd0238)
[ 823.856810] Stack: (0xddfd1db0 to 0xddfd2000)
[ 823.861356] 1da0: df533600 df1f6f0c dd956800 c0473157
[ 823.869891] 1dc0: df7ca220 c0471bb1 00000001 c0917390 ddf40200 dd956800 c08d8c6c c091a2d8
[ 823.878428] 1de0: 00000000 c091a410 ddf40200 c04731bb c0917390 ddf40200 dd956800 ddf40200
[ 823.886964] 1e00: 00000002 00000000 00000000 c04b0d07 c091aaac 00000002 ffffffff c05140e5
[ 823.895500] 1e20: c091a480 00000002 ddf40200 ffffffff 00000000 00000000 df566e0c c00498ef
[ 823.904036] 1e40: 00000000 c04aa1d9 00000000 00000000 ddf40200 ddf40208 00000000 c004990d
[ 823.912571] 1e60: 00000000 00000000 00000000 c04aa269 22222222 00000000 00000000 00000000
[ 823.921106] 1e80: 00000000 df566e0c 00000000 ddf40200 00000000 00000000 df566e00 00008916
[ 823.929642] 1ea0: be829cb8 c04ab673 00000000 c0107741 dd956800 ddfd0008 df566e0c ddf40200
[ 823.938179] 1ec0: 30687465 00000000 00000000 00000000 00000002 00000000 00000000 000007f1
[ 823.946714] 1ee0: fffffffe 00008916 00000016 c0917390 be829cb8 ddf7f180 00000005 00000000
[ 823.955250] 1f00: 00000030 c045df01 c045de35 d6a64760 be829cb8 00008916 ddf7f180 c0117ff5
[ 823.963785] 1f20: 00000000 c000ca68 df004780 ddf76cc0 0000001d c0107741 c0273351 00000000
[ 823.972321] 1f40: 0001b7c0 ddb37ec0 00000000 ddde22c0 ffffff9c 00012998 00000014 00000000
[ 823.980857] 1f60: 00008916 be829cb8 00000000 ddf7f180 00000005 00000000 00000030 c011814f
[ 823.989393] 1f80: 00000000 00000000 0001b17c be829ebc 00000000 0001b434 00000036 c000ca68
[ 823.997927] 1fa0: ddfd0000 c000c861 be829ebc 00000000 00000005 00008916 be829cb8 0001b3c4
[ 824.006462] 1fc0: be829ebc 00000000 0001b434 00000036 be829c38 be829d0c be829f8e 00000030
[ 824.014998] 1fe0: 0001b960 be829c10 0000aa61 b6e9391c 80000010 00000005 00000000 00000000
[ 824.023544] [<c0473002>] (neigh_destroy+0x76/0xf8) from [<c0473157>] (neigh_flush_dev+0x97/0xb0)
[ 824.032719] [<c0473157>] (neigh_flush_dev+0x97/0xb0) from [<c04731bb>] (neigh_ifdown+0x27/0xa8)
[ 824.041811] [<c04731bb>] (neigh_ifdown+0x27/0xa8) from [<c04b0d07>] (fib_inetaddr_event+0x7b/0x7c)
[ 824.051171] [<c04b0d07>] (fib_inetaddr_event+0x7b/0x7c) from [<c05140e5>] (notifier_call_chain+0x45/0x60)
[ 824.061170] [<c05140e5>] (notifier_call_chain+0x45/0x60) from [<c00498ef>] (__blocking_notifier_call_chain+0x27/0x34)
[ 824.072251] [<c00498ef>] (__blocking_notifier_call_chain+0x27/0x34) from [<c004990d>] (blocking_notifier_call_chain+0x11/0x14)
[ 824.084145] [<c004990d>] (blocking_notifier_call_chain+0x11/0x14) from [<c04aa269>] (__inet_del_ifa+0x71/0x1cc)
[ 824.094677] [<c04aa269>] (__inet_del_ifa+0x71/0x1cc) from [<c04ab673>] (devinet_ioctl+0x2d3/0x4a4)
[ 824.104037] [<c04ab673>] (devinet_ioctl+0x2d3/0x4a4) from [<c045df01>] (sock_ioctl+0xcd/0x1b4)
[ 824.113066] [<c045df01>] (sock_ioctl+0xcd/0x1b4) from [<c0117ff5>] (do_vfs_ioctl+0x2dd/0x3fc)
[ 824.121997] [<c0117ff5>] (do_vfs_ioctl+0x2dd/0x3fc) from [<c011814f>] (sys_ioctl+0x3b/0x58)
[ 824.130752] [<c011814f>] (sys_ioctl+0x3b/0x58) from [<c000c861>] (ret_fast_syscall+0x1/0x44)
[ 824.139591] Code: f383 8100 f8d6 122c (680b) 3b01
ddf6c008 c0033c9[ 824.144658] ---[ end trace c025b53d69825ec9 ]---
b 00418004 00000[ 824.150896] Kernel panic - not syncing: Fatal exception in interrupt
[ 824.158933] drm_kms_helper: panic occurred, switching back to text console
kernel:[ 822.907441] de60: 00000000 c003cdd3 00000000 dd9ae544 dd9ae040 c0920378 df070e40 ddf6c000
I know somewhere the program caused the null point which lead to kernel error. but the I do not know why, who could help me!!!
