$ tar xf gcc-linaro-4.9-2015.05-x86_64_arm-linux-gnueabihf.tar.xz
$ sudo apt-get install git build-essential diffstat texinfo gawk chrpath dos2unix
Switch shell from dash to bash
$ sudo dpkg-reconfigure dash
$ git clone git://arago-project.org/git/projects/oe-layersetup.git tisdk
$ cd tisdk
$ ./oe-layertool-setup.sh -f configs/arago-fido-config.txt
$ cd sources
$ git clone git@internal server :Blue/arago.git meta-raymond-gdm
$ cd ../build
$ source conf/setenv
Change the conf/bblayers.conf
#Ensure that the meta-raymond-gdm is added. BBLAYERS += " \ /home/jvanderpool/dev/tisdk/sources/meta-raymond-gdm \
$ export PATH=$HOME/gcc-linaro-4.9-2015.05-x86_64_arm-linux-gnueabihf/bin:$PATH
$ MACHINE=am57xx-evm bitbake core-image-base
Check the sd card to see what the dev is
$ sudo ./../sources/meta-raymond-gdm/scripts/mksdboot_raymond_gmd.sh --device /dev/sdX --rootfs core-image-base
boot capture:-(
Any Clues?
U-Boot SPL 2015.07 (Dec 10 2015 - 10:08:12)
DRA752 ES1.1
U-Boot 2015.07 (Dec 10 2015 - 10:08:12 -0500)
CPU : DRA752 ES1.1
Board: Raymond GDM
I2C: ready
DRAM: 2 GiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Card did not respond to voltage select!
** Bad device mmc 0 **
Using default environment
Net: Net Initialization Skipped
No ethernet found.
Hit any key to stop autoboot: 0
Boot fastboot requested, resetting dofastboot ...
Saving Environment to FAT...
Booting into fastboot ...
Unknown command 'fastboot' - try 'help'
gpio: pin 58 (gpio 58) value is 0
## Error: "envboot" not defined
switch to partitions #0, OK
mmc1(part 0) is current device
SD/MMC found on device 1
reading uEnv.txt
** Unable to read file uEnv.txt **
reading /boot/zImage
4355976 bytes read in 224 ms (18.5 MiB/s)
reading /boot/am57xx-raymond-gdm.dtb
96053 bytes read in 11 ms (8.3 MiB/s)
Booting from mmc1 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x427788 ]
Loading Device Tree to 8ffe5000, end 8ffff734 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.13-gf0f52afb60 (jvanderpool@jvanderpool-workstation) (gcc version 4.9.3 20150413 (prerelease) (Linaro GCC 4.9-2015.05) ) #3 SMP PREE5
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: TI AM5728 Raymond-GDM
[ 0.000000] Reserved memory: unsupported node format, ignoring
[ 0.000000] cma: Reserved 24 MiB at 0x00000000fe400000
[ 0.000000] Forcing write-allocate cache policy for SMP
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] DRA752 ES1.1
[ 0.000000] PERCPU: Embedded 13 pages/cpu @ee55e000 s22848 r8192 d22208 u53248
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 521810
[ 0.000000] Kernel command line: console=ttyO2,115200n8 vram=16M root=PARTUUID=d3fe00ea-1ebf-584e-96c2-ca5488e60863 ro rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 2029968K/2094080K available (7827K kernel code, 746K rwdata, 3220K rodata, 1124K init, 6629K bss, 39536K reserved, 24576K cma-reserved, 129126)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0ad2024 (11049 kB)
[ 0.000000] .init : 0xc0ad3000 - 0xc0bec000 (1124 kB)
[ 0.000000] .data : 0xc0bec000 - 0xc0ca6960 ( 747 kB)
[ 0.000000] .bss : 0xc0ca9000 - 0xc1322568 (6630 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU debugfs-based tracing is enabled.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] OMAP clockevent source: timer1 at 32768 Hz
[ 0.000000] clocksource 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65535999984741ns
[ 0.000030] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000579] Architected cp15 timer(s) running at 6.14MHz (virt).
[ 0.000579] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000615] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000625] Switching to timer-based delay loop, resolution 162ns
[ 0.001306] Console: colour dummy device 80x30
[ 0.001335] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[ 0.001341] This ensures that you still see kernel messages. Please
[ 0.001347] update your kernel commandline.
[ 0.001353] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[ 0.001359] ... MAX_LOCKDEP_SUBCLASSES: 8
[ 0.001364] ... MAX_LOCK_DEPTH: 48
[ 0.001370] ... MAX_LOCKDEP_KEYS: 8191
[ 0.001375] ... CLASSHASH_SIZE: 4096
[ 0.001380] ... MAX_LOCKDEP_ENTRIES: 32768
[ 0.001385] ... MAX_LOCKDEP_CHAINS: 65536
[ 0.001391] ... CHAINHASH_SIZE: 32768
[ 0.001396] memory used by lock dependency info: 5151 kB
[ 0.001402] per task-struct memory footprint: 1152 bytes
[ 0.055663] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.055681] pid_max: default: 32768 minimum: 301
[ 0.056125] Security Framework initialized
[ 0.056359] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.056377] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.059800] Initializing cgroup subsys blkio
[ 0.059827] Initializing cgroup subsys memory
[ 0.059950] Initializing cgroup subsys devices
[ 0.060004] Initializing cgroup subsys freezer
[ 0.060051] Initializing cgroup subsys perf_event
[ 0.060184] CPU: Testing write buffer coherency: ok
[ 0.061356] /cpus/cpu@0 missing clock-frequency property
[ 0.061408] /cpus/cpu@1 missing clock-frequency property
[ 0.061418] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.061590] Setting up static identity map for 0x800082c0 - 0x80008318
[ 0.141757] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.141886] Brought up 2 CPUs
[ 0.141900] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.141907] CPU: All CPU(s) started in SVC mode.
[ 0.143923] devtmpfs: initialized
[ 0.436833] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.438626] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.470631] omap_hwmod: tptc0 using broken dt data from edma-controller
[ 0.471781] omap_hwmod: tptc1 using broken dt data from edma-controller
[ 0.746007] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.748405] pinctrl core: initialized pinctrl subsystem
[ 0.754943] NET: Registered protocol family 16
[ 0.756849] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.792189] cpuidle: using governor ladder
[ 0.822149] cpuidle: using governor menu
[ 0.857991] OMAP GPIO hardware version 0.1
[ 0.894841] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[ 0.897374] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[ 0.898694] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[ 0.899956] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[ 0.989621] No ATAGs?
[ 0.989672] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.989681] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.996177] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.996187] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.998667] OMAP DMA hardware revision 0.0
[ 1.154580] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 1.185931] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver
[ 1.186911] reg-fixed-voltage fixedregulator@2: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/wlan_pins_default, deferring probe
[ 1.187032] reg-fixed-voltage fixedregulator@3: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/wlan_rfsw_pins_default, deferring probe
[ 1.197604] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 1.198674] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 1.199722] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 1.200762] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 1.202002] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 1.204331] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 1.205526] vgaarb: loaded
[ 1.208827] SCSI subsystem initialized
[ 1.211324] usbcore: registered new interface driver usbfs
[ 1.211917] usbcore: registered new interface driver hub
[ 1.212340] usbcore: registered new device driver usb
[ 1.213920] omap_i2c 48070000.i2c: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/i2c1_pins_default, deferring probe
[ 1.214109] omap_i2c 48060000.i2c: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/i2c3_pins_default, deferring probe
[ 1.214286] omap_i2c 4807a000.i2c: could not find pctldev for node /ocp/l4@4a000000/scm@2000/pinmux@1400/i2c4_pins_default, deferring probe
[ 1.214791] media: Linux media interface: v0.10
[ 1.215296] Linux video capture interface: v2.00
[ 1.215651] pps_core: LinuxPPS API ver. 1 registered
[ 1.215658] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.215856] PTP clock support registered
[ 1.218627] omap-mailbox: probe of 48840000.mailbox failed with error -22
[ 1.219049] omap-mailbox: probe of 48842000.mailbox failed with error -22
[ 1.220889] Advanced Linux Sound Architecture Driver Initialized.
[ 1.226785] Bluetooth: Core ver 2.20
[ 1.226996] NET: Registered protocol family 31
[ 1.227003] Bluetooth: HCI device and connection manager initialized
[ 1.227084] Bluetooth: HCI socket layer initialized
[ 1.227141] Bluetooth: L2CAP socket layer initialized
[ 1.227330] Bluetooth: SCO socket layer initialized
[ 1.255437] DMA-API: preallocated 4096 debug entries
[ 1.255447] DMA-API: debugging enabled by kernel config
[ 1.255702] Switched to clocksource arch_sys_counter
[ 1.498070] NET: Registered protocol family 2
[ 1.500445] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.500614] TCP bind hash table entries: 8192 (order: 6, 294912 bytes)
[ 1.502072] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.502306] UDP hash table entries: 512 (order: 3, 40960 bytes)
[ 1.502519] UDP-Lite hash table entries: 512 (order: 3, 40960 bytes)
[ 1.503825] NET: Registered protocol family 1
[ 1.505513] RPC: Registered named UNIX socket transport module.
[ 1.505522] RPC: Registered udp transport module.
[ 1.505529] RPC: Registered tcp transport module.
[ 1.505536] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.508890] CPU PMU: Failed to parse /pmu/interrupt-affinity[0]
[ 1.508987] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 1.521701] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 1.522071] audit: initializing netlink subsys (disabled)
[ 1.522263] audit: type=2000 audit(1.509:1): initialized
[ 1.643180] VFS: Disk quotas dquot_6.6.0
[ 1.645405] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.675118] NFS: Registering the id_resolver key type
[ 1.675305] Key type id_resolver registered
[ 1.675313] Key type id_legacy registered
[ 1.675602] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 1.697276] alg: No test for stdrng (krng)
[ 1.697361] NET: Registered protocol family 38
[ 1.697664] bounce: pool size: 64 pages
[ 1.697717] io scheduler noop registered
[ 1.697744] io scheduler deadline registered
[ 1.697890] io scheduler cfq registered (default)
[ 1.720348] pinctrl-single 4a003400.pinmux: 281 pins at pa fc003400 size 1124
[ 1.783205] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[ 1.783231] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 1.783254] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 1.783277] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.783468] pci 0000:00:00.0: IOMMU is currently not supported for PCI
[ 1.785356] PCI: bus0: Fast back to back transfers disabled
[ 1.786387] PCI: bus1: Fast back to back transfers enabled
[ 1.786578] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[ 1.786594] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[ 1.786655] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.789281] backlight supply power not found, using dummy regulator
[ 1.789604] /backlight: could not get #pwm-cells for /ocp/epwmss@48440000/ecap@48440100
[ 1.789640] pwm-backlight backlight: unable to request PWM, trying legacy API
[ 1.794776] omapdss_dss 58000000.dss: master bind failed: -517
[ 1.800892] panel-dpi display: failed to find video source
[ 1.816602] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 1.844056] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 299, base_baud = 3000000) is a 8250
[ 1.850679] console [ttyS2] disabled
[ 1.850880] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 300, base_baud = 3000000) is a 8250
[ 2.955789] console [ttyS2] enabled
[ 2.963683] 48066000.serial: ttyS4 at MMIO 0x48066000 (irq = 301, base_baud = 3000000) is a 8250
[ 2.977011] 48068000.serial: ttyS5 at MMIO 0x48068000 (irq = 302, base_baud = 3000000) is a 8250
[ 2.990198] 48422000.serial: ttyS7 at MMIO 0x48422000 (irq = 303, base_baud = 3000000) is a 8250
[ 3.002935] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 304, base_baud = 3000000) is a 8250
[ 3.015713] [drm] Initialized drm 1.1.0 20060810
[ 3.093822] brd: module loaded
[ 3.140592] loop: module loaded
[ 3.148944] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 3.162048] at25 spi1.0: 512 Byte at25 eeprom, pagesize 1
[ 3.177616] tun: Universal TUN/TAP device driver, 1.6
[ 3.182690] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.191349] CAN device driver interface
[ 3.200097] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=341)
[ 3.213728] c_can_platform 48480000.can: c_can_platform device registered (regs=fa480000, irq=342)
[ 3.227139] PPP generic driver version 2.4.2
[ 3.232523] PPP BSD Compression module registered
[ 3.237585] PPP Deflate Compression module registered
[ 3.242712] PPP MPPE Compression module registered
[ 3.247759] NET: Registered protocol family 24
[ 3.252814] usbcore: registered new interface driver smsc95xx
[ 3.258953] usbcore: registered new interface driver qmi_wwan
[ 3.265820] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.272440] ehci-pci: EHCI PCI platform driver
[ 3.277385] ehci-omap: OMAP-EHCI Host Controller driver
[ 3.283444] usbcore: registered new interface driver cdc_wdm
[ 3.289834] usbcore: registered new interface driver usbserial
[ 3.296006] usbcore: registered new interface driver qcserial
[ 3.302065] usbserial: USB Serial support registered for Qualcomm USB modem
[ 3.310940] mousedev: PS/2 mouse device common for all mice
[ 3.316682] -->tsc2013_init
[ 3.319485] tsc2013_init-->i2c_add_driver
[ 3.324011] i2c /dev entries driver
[ 3.338622] Bluetooth: HCI UART driver ver 2.3
[ 3.343090] Bluetooth: HCI UART protocol H4 registered
[ 3.348341] Bluetooth: HCI UART protocol BCSP registered
[ 3.353675] Bluetooth: HCI UART protocol LL registered
[ 3.358852] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 3.368392] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 3.373926] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[ 3.380548] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[ 3.386948] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[ 3.393330] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[ 3.400187] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[ 3.406692] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[ 3.438406] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 3.444787] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 3.451190] omap_hsmmc 480b4000.mmc: no pinctrl state for ddr_1_8v mode
[ 3.457848] omap_hsmmc 480b4000.mmc: no pinctrl state for hs mode
[ 3.463968] omap_hsmmc 480b4000.mmc: no pinctrl state for hs200_1_8v mode
[ 3.471357] reg-fixed-voltage fixedregulator-vdd_3v3: Failed to resolve vin-supply for vdd_3v3
[ 3.507551] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr25 mode
[ 3.513933] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr12 mode
[ 3.520337] omap_hsmmc 480d1000.mmc: no pinctrl state for hs mode
[ 3.566837] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.573599] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 3.655329] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[ 3.662531] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 3.670086] alg: skcipher: setkey failed on test 5 for ecb-des-omap: flags=100
[ 3.678518] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
[ 3.697278] alg: skcipher-ddst: setkey failed on test 5 for ecb-des-omap: flags=100
[ 3.722163] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 3.784898] oprofile: using timer interrupt.
[ 3.789981] Initializing XFRM netlink socket
[ 3.794396] NET: Registered protocol family 17
[ 3.800119] NET: Registered protocol family 15
[ 3.804605] can: controller area network core (rev 20120528 abi 9)
[ 3.811803] NET: Registered protocol family 29
[ 3.817015] can: raw protocol (rev 20120528)
[ 3.821365] can: broadcast manager protocol (rev 20120528 t)
[ 3.827495] can: netlink gateway (rev 20130117) max_hops=1
[ 3.834692] Bluetooth: RFCOMM TTY layer initialized
[ 3.839784] Bluetooth: RFCOMM socket layer initialized
[ 3.844985] Bluetooth: RFCOMM ver 1.11
[ 3.848851] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.854185] Bluetooth: BNEP filters: protocol multicast
[ 3.859487] Bluetooth: BNEP socket layer initialized
[ 3.864496] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.870582] Bluetooth: HIDP socket layer initialized
[ 3.876444] Key type dns_resolver registered
[ 3.881053] omap_voltage_late_init: Voltage driver support not added
[ 3.888574] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.voltdm
[ 3.894884] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.voltdm
[ 3.901227] omap_voltdm 4a003b20.voltdm: Unable to get vdd regulator:-517
[ 3.908108] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517
[ 3.916963] cpu cpu0: cpu0 clock notifier not ready, retry
[ 3.923396] Power Management for TI OMAP4+ devices.
[ 3.928842] ThumbEE CPU extension supported.
[ 3.933185] Registering SWP/SWPB emulation handler
[ 3.941653] kmemleak: Kernel memory leak detector initialized
[ 3.951039] dmm 4e000000.dmm: workaround for errata i878 in use
[ 3.955730] kmemleak: Automatic memory scanning thread started
[ 3.965488] dmm 4e000000.dmm: initialized all PAT entries
[ 3.998073] bq32k 0-0068: rtc core: registered bq32k as rtc0
[ 4.005646] palmas 0-0058: Irq flag is 0x00000007
[ 4.016780] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
[ 4.088488] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 4.098904] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 4.127369] tmp102 3-0048: initialized
[ 4.132252] -->tsc2013_probe
[ 4.135210] tsc2013 3-004b: GPIO not specified in DT (of_get_gpio returned -2)
[ 4.143481] tsc2013_probe-->tsc2013_hw_init
[ 4.147964] -->tsc2013_hw_init
[ 4.151333] tsc2013_probe-->tsc2013_sw_init
[ 4.155720] tsc2013_i2c_write_register : CFG[62] = 0xa58c
[ 4.161300] tsc2013_i2c_write_register : CFG[6a] = 0x0
[ 4.166714] tsc2013_i2c_write_register : CFG[72] = 0xb81c
[ 4.173583] input: tsc2013_ts as /devices/virtual/input/input0
[ 4.179527] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
[ 4.186904] OMAP DSS rev 6.1
[ 4.190242] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 4.199741] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 4.205041] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[ 4.211535] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[ 4.218009] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[ 4.224391] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[ 4.230787] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[ 4.237249] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[ 4.244307] vdd_3v3: supplied by regen1
[ 4.288571] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 4.294953] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 4.301356] omap_hsmmc 480b4000.mmc: no pinctrl state for ddr_1_8v mode
[ 4.308015] omap_hsmmc 480b4000.mmc: no pinctrl state for hs mode
[ 4.314135] omap_hsmmc 480b4000.mmc: no pinctrl state for hs200_1_8v mode
[ 4.361328] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr25 mode
[ 4.367816] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr12 mode
[ 4.374258] omap_hsmmc 480d1000.mmc: no pinctrl state for hs mode
[ 4.409857] mmc0: MAN_BKOPS_EN bit is not set
[ 4.414777] mmc0: new MMC card at address 0001
[ 4.421563] mmcblk0: mmc0:0001 MMC04G 3.60 GiB
[ 4.426858] mmcblk0boot0: mmc0:0001 MMC04G partition 1 16.0 MiB
[ 4.433459] mmcblk0boot1: mmc0:0001 MMC04G partition 2 16.0 MiB
[ 4.467296] mmcblk0: p1 p2 p3
[ 4.496393] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.voltdm
[ 4.502739] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.voltdm
[ 4.511186] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.voltdm
[ 4.517586] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.voltdm
[ 4.523906] omap_hsmmc 480d1000.mmc: card claims to support voltages below defined range
[ 4.545456] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.553616] mmc1: new SDIO card at address 0001
[ 4.572458] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.579300] [drm] No driver support for vblank timestamp query.
[ 4.592102] [drm] Enabling DMM ywrap scrolling
[ 4.637109] Console: switching to colour frame buffer device 60x34
[ 4.644221] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[ 4.650195] omapdrm omapdrm.0: registered panic notifier
[ 4.686484] omapwb-m2m: Device registered as video10
[ 4.691477] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[ 4.698270] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 4.703377] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[ 4.709887] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[ 4.716379] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[ 4.722757] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[ 4.729161] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[ 4.735538] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[ 4.767483] bq32k 0-0068: setting system clock to 2015-12-15 18:21:52 UTC (1450203712)
[ 4.826954] ldousb: disabling
[ 4.830232] wlan-en-regulator: disabling
[ 4.834172] pbias_mmc_omap5: disabling
[ 4.838352] ALSA device list:
[ 4.841327] No soundcards found.
[ 4.853923] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 4.861443] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 5.068281] EXT4-fs (mmcblk0p2): recovery complete
[ 5.078536] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.087147] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 5.096779] devtmpfs: mounted
[ 5.100564] Freeing unused kernel memory: 1124K (c0ad3000 - c0bec000)
[ 96.897666] udevd[151]: starting version 182
[ 97.745160] omap-rproc 58820000.ipu: device does not have specific CMA pool
[ 97.800868] remoteproc0: releasing 58820000.ipu
[ 97.806649] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 97.811841] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[ 97.856827] omap-rproc 55020000.ipu: device does not have specific CMA pool
[ 97.863829] remoteproc0: releasing 55020000.ipu
[ 97.882664] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[ 97.945703] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[ 97.952096] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[ 97.966582] omap-rproc 40800000.dsp: device does not have specific CMA pool
[ 97.973583] remoteproc0: releasing 40800000.dsp
[ 98.023196] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[ 98.054006] omap-rproc 41000000.dsp: device does not have specific CMA pool
[ 98.097858] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[ 98.131152] remoteproc0: releasing 41000000.dsp
[ 98.170139] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[ 98.192874] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 98.218262] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[ 98.224735] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[ 98.290292] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[ 98.298497] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[ 98.346739] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[ 98.353129] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[ 98.365338] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[ 98.397739] vpe 489d0000.vpe: Device registered as /dev/video0
[ 98.464653] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 98.478028] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[ 98.521658] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[ 98.544460] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[ 98.558060] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[ 98.566134] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[ 98.574095] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[ 99.087242] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 99.102056] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 99.136086] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[ 99.183555] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[ 99.241578] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[ 99.253856] ahci 4a140000.sata: forcing PORTS_IMPL to 0x1
[ 99.256146] wl1271_sdio: probe of mmc1:0001:2 failed with error -12
[ 99.325726] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[ 99.395912] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[ 99.402310] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[ 99.426222] (stk) :sysfs entries created
[ 99.459634] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 99.588714] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 99.589239] ahci 4a140000.sata: flags: 64bit ncq sntf pm led clo only pmp pio slum part ccc apst
[ 99.615609] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[ 99.629075] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[ 99.637663] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[ 99.644369] scsi host0: ahci
[ 99.662572] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[ 99.669309] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[ 99.686405] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[ 99.691446] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 338
[ 99.770365] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 99.776557] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[ 99.784294] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[ 99.794643] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[ 99.802639] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[ 99.809321] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[ 99.822762] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[ 100.035901] ata1: SATA link down (SStatus 0 SControl 300)
[ 100.626274] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 100.631643] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[ 100.639513] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[ 100.646424] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[ 100.652880] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[ 100.659274] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[ 100.665666] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[ 100.748796] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 100.754565] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 100.763839] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
[ 100.773874] xhci-hcd xhci-hcd.0.auto: irq 424, io mem 0x48890000
[ 100.781033] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 100.787912] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 100.795164] usb usb1: Product: xHCI Host Controller
[ 100.800374] usb usb1: Manufacturer: Linux 4.1.13-gf0f52afb60 xhci-hcd
[ 100.806876] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 100.815857] hub 1-0:1.0: USB hub found
[ 100.819817] hub 1-0:1.0: 1 port detected
[ 100.826630] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 100.827244] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 100.827317] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 100.827703] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 100.828477] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 100.828482] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 100.828487] usb usb2: Product: xHCI Host Controller
[ 100.828490] usb usb2: Manufacturer: Linux 4.1.13-gf0f52afb60 xhci-hcd
[ 100.828495] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 100.837645] hub 2-0:1.0: USB hub found
[ 100.837789] hub 2-0:1.0: 1 port detected
[ 100.900278] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[ 100.913502] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[ 100.926283] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[ 100.933283] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[ 100.939693] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[ 100.946094] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[ 101.009062] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 101.015158] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[ 101.015925] cryptodev: driver 1.6 loaded.
[ 101.027050] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[ 101.033434] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[ 101.041067] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[ 101.053456] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[ 101.061035] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[ 101.073811] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 101.247124] random: dd urandom read with 73 bits of entropy available
[ 692.367733] kmemleak: 1 new suspected memory leaks (see /sys/kernel/debug/kmemleak)
