C6748 LC DEV KIT VER A7E.DSN
Could I get a copy of the C6748 LC DEV KIT VER A7E.DSN that works with Orcad V9.2.
  • HI
    I have moved this to the right device forum.
    I believe all we have is what is posted on the product page
    www.ti.com/.../tmdslcdk6748
    I will check with the team if we can help you further.
    Mukul
  • Joe,
    You can find the C6748 LC DEV KIT VER A7E.DSN schematic file in below link. However this design has been created using Allegro Design Entry CIS 16.5/16.6 version and you can downgrade it upto version 16.2. Beyond that version is not possible.
    http://www.ti.com/tool/tmdslcdk6748#Technical Documents
    Is there any specific reason for you to stick with V9.2 ? I think it is very old version. You can have free version of ORCAD 16.6 lite version from ORCAD website.
    Senthil
  • tried the orcad free v16 Product
    Limits in Lite Version
    OrCAD Capture CIS Lite
    - You cannot save designs that have more than 75 nets, including the hierarchical blocks in the design. You can still view or create larger designs.
    - You cannot save a design with more than 60 parts, including the hierarchical blocks in the design. You can still view or create larger designs.
    - You cannot have more than 1000 parts in the Capture CIS database.
    - The Internet Component Assistant (ICA) tab in the CIS Explorer window opens the About ActiveParts page (www.activeparts.com) and not the component search page.
    - You cannot create parts with more than 100 pins.
    - The Capture FPGA flow is not available.
    - You cannot validate Electrical Csets
    So, I will proceed with orcad v9.2 and make the dsp chip from scratch. Thanks for the info
  • another suggestion was
    With version 16.2, you can save it to version 7.2, and then perhaps saves up to 9.2
