We are working on Lamar Board (TCI6630K2L).
Kindly provide some example project for 15 Mhz LTE CPRI test case.
Welcome to the TI E2E forum. I hope you will find many good answers here and in the TI.com documents and in the TI Wiki Pages (for processor issues). Be sure to search those for helpful information and to browse for the questions others may have asked on similar topics (e2e.ti.com). Please read all the links below my signature.
We will get back to you on the above query shortly. Thank you for your patience.
We found an example project "iqn2LteCpriK2LTestProject" in MCSDK ver 2_3_01_02_05. The test case are running for 20 MHz, 10 MHz, & 5 MHz.
However the 15 MHz is not running.
We have tried every possible combination of link rate & NumOfAxC for 15 MHz. But none of them worked.
Our Lamar board is in DSP-No BOOT configuration.
Kindly provide some feedback.
Attached is a K2L verification test that configures LTE15. It probably won't compile as-is due to it being pulled out of a larger test environment, but all of the configuration code should be included.
