Program on Beagle Bone Black with Uniflash
Other Parts Discussed in Thread: UNIFLASH, TPS65217
Hi, Everyone
I have a qestion.
I want to flash program with Uniflash and USB on Beagle Bone Black.
and I use PROCESSOR-SDK-LINUX-AM335X  02_00_00_00
I saw guidline:
processors.wiki.ti.com/.../Sitara_Linux_Program_the_eMMC_on_Beaglebone_Black
processors.wiki.ti.com/.../Sitara_Uniflash_Quick_Start_Guide
It is success U-boot and Kernel load and kernel start.
but It is always stop 27% and kernel is stop.
and I show you log.
U-Boot SPL 2015.07-00114-gf5078ef (Dec 20 2015 - 19:25:07)
Using default environment
usb_ether
Error: usb_ether address not set.
using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC c8:a0:30:c5:69:2d
HOST MAC de:ad:be:af:00:00
RNDIS ready
musb-hdrc: peripheral reset irq lost!
high speed config #2: 2 mA, Ethernet Gadget, using RNDIS
USB RNDIS network up!
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
Using usb_ether device
TFTP from server 192.168.2.1; our IP address is 192.168.2.2
Filename 'u-boot-restore.img'.
Load address: 0x807fffc0
Loading: ##########################
         546.9 KiB/s
done
Bytes transferred = 367292 (59abc hex)
U-Boot 2015.07-00114-gf5078ef (Dec 20 2015 - 19:25:07 -0800)
       Watchdog enabled
I2C:   ready
DRAM:  512 MiB
NAND:  0 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
reading uboot.env
Net:   cpsw, usb_ether
Hit any key to stop autoboot:  0
U-Boot#
U-Boot#
U-Boot# setenv ethact usb_ether
U-Boot# setenv serverip 192.168.2.1
U-Boot# setenv ipaddr 192.168.2.3
U-Boot# tftp zImage
MAC c8:a0:30:c5:69:2f
RNDIS ready
TFTP from server 192.168.2.1; our IP address is 192.168.2.3
Filename 'zImage'.
Load address: 0x82000000
Loading: T #################################################################
         390.6 KiB/s
done
Bytes transferred = 3230112 (3149a0 hex)
U-Boot# run findfdt
U-Boot# tftp ${fdtaddr} ${fdtfile}
RNDIS ready
Filename 'am335x-boneblack.dtb'.
Load address: 0x88000000
Loading: T ###
         5.9 KiB/s
done
Bytes transferred = 32990 (80de hex)
U-Boot# bootz ${loadaddr} - ${fdtaddr}
Kernel image @ 0x82000000 [ 0x000000 - 0x3149a0 ]
   Loading Device Tree to 8fff4000, end 8ffff0dd ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.1.6-g52c4aa7 (am335xprocessersdk02000000@ubuntu)                      (gcc version 4.9.3 20150413 (prerelease) (Linaro GCC 4.9-2015.05) ) #2 PREEMPT S                     un Dec 20 20:34:36 PST 2015
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio                     n cache
[    0.000000] Machine model: TI AM335x BeagleBone Black
[    0.000000] cma: Reserved 24 MiB at 0x9e800000
[    0.000000] Memory policy: Data cache writeback
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.0 (sgx neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pag                     es: 129920
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/nfs nfsroot                     =10.5.5.127:/home/am335_ezsdk_08000000/ti-sdk-am335x-evm-08.00.00.00/targetNFS,n                     olock rw ip=dhcp
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 485336K/524288K available (6247K kernel code, 254K rwdata                     , 2096K rodata, 260K init, 229K bss, 14376K reserved, 24576K cma-reserved, 0K hi                     ghmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc082e05c   (8345 kB)
[    0.000000]       .init : 0xc082f000 - 0xc0870000   ( 260 kB)
[    0.000000]       .data : 0xc0870000 - 0xc08afb28   ( 255 kB)
[    0.000000]        .bss : 0xc08b2000 - 0xc08eb7f8   ( 230 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrup                     ts
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000014] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478                     484971ns
[    0.000031] clocksource timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_                     idle_ns: 79635851949 ns
[    0.000040] OMAP clocksource: timer1 at 24000000 Hz
[    0.000203] Console: colour dummy device 80x30
[    0.000225] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.000230] This ensures that you still see kernel messages. Please
[    0.000235] update your kernel commandline.
[    0.000251] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[    0.089328] pid_max: default: 32768 minimum: 301
[    0.089421] Security Framework initialized
[    0.089470] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.089479] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.090090] Initializing cgroup subsys blkio
[    0.090113] Initializing cgroup subsys memory
[    0.090150] Initializing cgroup subsys devices
[    0.090163] Initializing cgroup subsys freezer
[    0.090175] Initializing cgroup subsys perf_event
[    0.090200] CPU: Testing write buffer coherency: ok
[    0.090557] Setting up static identity map for 0x80008200 - 0x80008270
[    0.091910] devtmpfs: initialized
[    0.099973] VFP support v0.3: implementor 41 architecture 3 part 30 variant c                      rev 3
[    0.107342] omap_hwmod: tptc0 using broken dt data from edma
[    0.107438] omap_hwmod: tptc1 using broken dt data from edma
[    0.107520] omap_hwmod: tptc2 using broken dt data from edma
[    0.111784] omap_hwmod: debugss: _wait_target_disable failed
[    0.166111] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max                     _idle_ns: 19112604462750000 ns
[    0.168051] pinctrl core: initialized pinctrl subsystem
[    0.169197] NET: Registered protocol family 16
[    0.171205] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.199318] cpuidle: using governor ladder
[    0.229306] cpuidle: using governor menu
[    0.232318] OMAP GPIO hardware version 0.1
[    0.240134] No ATAGs?
[    0.240165] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.276209] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[    0.278873] vgaarb: loaded
[    0.279415] SCSI subsystem initialized
[    0.279888] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wk                     up@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[    0.280023] pps_core: LinuxPPS API ver. 1 registered
[    0.280030] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome                     tti <giometti@linux.it>
[    0.280059] PTP clock support registered
[    0.280761] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.280952] Advanced Linux Sound Architecture Driver Initialized.
[    0.281663] Switched to clocksource timer1
[    0.290449] NET: Registered protocol family 2
[    0.291184] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.291228] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.291266] TCP: Hash tables configured (established 4096 bind 4096)
[    0.291342] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.291358] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.291500] NET: Registered protocol family 1
[    0.291915] RPC: Registered named UNIX socket transport module.
[    0.291929] RPC: Registered udp transport module.
[    0.291935] RPC: Registered tcp transport module.
[    0.291940] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.292706] CPU PMU: Failed to parse /pmu/interrupt-affinity[0]
[    0.292745] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counter                     s available
[    0.294373] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.294450] audit: initializing netlink subsys (disabled)
[    0.294512] audit: type=2000 audit(0.280:1): initialized
[    0.300747] VFS: Disk quotas dquot_6.6.0
[    0.300930] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.302937] NFS: Registering the id_resolver key type
[    0.303009] Key type id_resolver registered
[    0.303015] Key type id_legacy registered
[    0.303077] jffs2: version 2.2. (NAND) (SUMMARY)  c 2001-2006 Red Hat, Inc.
[    0.305281] NET: Registered protocol family 38
[    0.305346] io scheduler noop registered
[    0.305358] io scheduler deadline registered
[    0.305408] io scheduler cfq registered (default)
[    0.306321] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[    0.307970] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    0.308901] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.312062] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 155, base_baud =                      3000000) is a 8250
[    0.954999] console [ttyS0] enabled
[    0.959372] [drm] Initialized drm 1.1.0 20060810
[    0.964380] slave hdmi: could not get i2c
[    0.977367] brd: module loaded
[    0.984825] loop: module loaded
[    0.988790] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.997107] mousedev: PS/2 mouse device common for all mice
[    1.002815] i2c /dev entries driver
[    1.007188] omap_hsmmc 48060000.mmc: Got CD GPIO
[    1.089158] mmc0: host does not support reading read-only switch, assuming wr                     ite-enable
[    1.097524] ledtrig-cpu: registered to indicate activity on CPUs
[    1.103985] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    1.109860] mmc0: new high speed SDHC card at address 1234
[    1.116335] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[    1.121988] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    1.129631]  remoteproc0: wkup_m3 is available
[    1.134296]  mmcblk0: p1 p2
[    1.137945]  remoteproc0: Note: remoteproc is still under development and con                     sidered experimental.
[    1.147116]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backwar                     d compatibility isn't yet guaranteed.
[    1.158811]  remoteproc0: Direct firmware load for am335x-pm-firmware.elf fai                     led with error -2
[    1.172233] oprofile: using arm/armv7
[    1.176230] Initializing XFRM netlink socket
[    1.180553] NET: Registered protocol family 17
[    1.185132]  remoteproc0: Falling back to user helper
[    1.190428] NET: Registered protocol family 15
[    1.195138] Key type dns_resolver registered
[    1.199643] omap_voltage_late_init: Voltage driver support not added
[    1.207571] ThumbEE CPU extension supported.
[    1.213930] Registering SWP/SWPB emulation handler
[    1.245044] mmc1: MAN_BKOPS_EN bit is not set
[    1.251554] mmc1: new high speed MMC card at address 0001
[    1.257956] mmcblk1: mmc1:0001 MMC02G 1.78 GiB
[    1.263121] mmcblk1boot0: mmc1:0001 MMC02G partition 1 1.00 MiB
[    1.269098] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    1.274507] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    1.280272] mmcblk1boot1: mmc1:0001 MMC02G partition 2 1.00 MiB
[    1.289997]  mmcblk1: p1 p2
[    1.403983] tda998x 0-0070: found TDA19988
[    1.409049] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.415726] [drm] No driver support for vblank timestamp query.
[    1.422025] tilcdc 4830e000.lcdc: No connectors reported conne
[   11.631678] Waiting up to 110 more seconds for network.
[   21.631675] Waiting up to 100 more seconds for network.[   31.631675] Waiting up to 90 more seconds for network.
[   41.631674] Waiting up to 80 more seconds for network.
[   51.631675] Waiting up to 70 more seconds for network.
[   61.181804]  remoteproc0: failed to load am335x-pm-firmware.elf
[   61.187769]  remoteproc0: powering up wkup_m3
[   61.192280]  remoteproc0: Direct firmware load for am335x-pm-firmware.elf failed with error -2
[   61.200929]  remoteproc0: Falling back to user helper
[   61.631692] Waiting up to 60 more seconds for network.
[   71.631674] Waiting up to 50 more seconds for network.
[   81.631673] Waiting up to 40 more seconds for network.
[   91.631673] Waiting up to 30 more seconds for network.
[  101.631673] Waiting up to 20 more seconds for network.
[  111.631682] Waiting up to 10 more seconds for network.
[  121.201754]  remoteproc0: request_firmware failed: -11
[  121.206914]  remoteproc0: rproc_boot failed
[  121.631674] Waiting up to 0 more seconds for network.
[  121.651687] Sending DHCP requests ..
[  124.721678] random: nonblocking pool is initialized
[  129.291665] ...
I do not use Ethernet.
Can you tell me how to set for skip ethernet waiting ?
Best Regards
Hiroyasu
    I will forward this to the software team but reply will be delayed until after the holidays.
  • Hi, Biser
    O.K. I wait for your reply after holidays.
    Best Regards
    Hiroyasu
    This "waiting up to X more seconds for network" message comes from net/ipv4/ipconfig.c source:
    while (time_before(jiffies, start +
                      msecs_to_jiffies(CONF_CARRIER_TIMEOUT))) {
            int wait, elapsed;
    for_each_netdev(&init_net, dev)
                 if (ic_is_init_dev(dev) && netif_carrier_ok(dev))
        goto have_carrier;
        msleep(1);
        if (time_before(jiffies, next_msg))
                  continue;
        elapsed = jiffies_to_msecs(jiffies - start);
        wait = (CONF_CARRIER_TIMEOUT - elapsed + 500)/1000;
        pr_info("Waiting up to %d more seconds for network.\n", wait);
        next_msg = jiffies + msecs_to_jiffies(CONF_CARRIER_TIMEOUT/12);
    Do you set the ip address statically (like ip=xxx.xxx.xxx.xxx) somewhere in your sources (uEnv.txt, u-boot env parameters, etc...)?
    Kernel is configured to wait up to 120 seconds for a network device. This is done with:
    #define CONF_CARRIER_TIMEOUT 120000
    You can lower this value in order to get rid of the 120 seconds timeout.
    Yordan
  • Hi, Yordan
    Thank you for your reply.
    These line are repeated.
    [ 914.011663] Waiting up to 20 more seconds for network.
    [ 924.011663] Waiting up to 10 more seconds for network.
    [ 934.011663] Waiting up to 0 more seconds for network.
    [ 934.031669] Sending DHCP requests ...... timed out!
    [ 1012.503775] IP-Config: Retrying forever (NFS root)...
    [ 1012.508871] net eth0: initializing cpsw version 1.12 (0)
    [ 1012.515843] libphy: PHY 4a101000.mdio:00 not found
    [ 1012.520655] net eth0: phy 4a101000.mdio:00 not found on slave 0
    [ 1012.526634] libphy: PHY 4a101000.mdio:01 not found
    [ 1012.531444] net eth0: phy 4a101000.mdio:01 not found on slave 1
    [ 1022.531665] Waiting up to 110 more seconds for network.
    [ 1032.531663] Waiting up to 100 more seconds for network.
    [ 1042.531663] Waiting up to 90 more seconds for network.
    I understand your answer can lower value.
    I want to skip.
    Do you know how to skip ?
    Best Regards
    Hiroyasu
