SSI3 not working
Hi
I had no problem with the SSI2 port on my Tiva Launchpad, but now I need to switch to SSI3 and it does not work anymore.
I probed the SPI clock signal and there is no clock signal at all.
Cheers Michael
My Code;
 * Copyright (c) 2015, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  ======== EK_TM4C1294XL.c ========
 *  This file is responsible for setting up the board specific items for the
 *  EK_TM4C1294XL board.
#include <stdint.h>
#include <stdbool.h>
#include <inc/hw_memmap.h>
#include <inc/hw_types.h>
#include <inc/hw_ints.h>
#include <inc/hw_gpio.h>
#include <driverlib/gpio.h>
#include <driverlib/flash.h>
#include <driverlib/sysctl.h>
#include <driverlib/i2c.h>
#include <driverlib/ssi.h>
#include <driverlib/uart.h>
#include <driverlib/udma.h>
#include <driverlib/pin_map.h>
#include <xdc/std.h>
#include <xdc/cfg/global.h>
#include <xdc/runtime/Error.h>
#include <xdc/runtime/System.h>
#include <ti/sysbios/family/arm/m3/Hwi.h>
#include "EK_TM4C1294XL.h"
#ifndef TI_DRIVERS_UART_DMA
#define TI_DRIVERS_UART_DMA 0
#endif
#ifndef TI_EXAMPLES_PPP
#define TI_EXAMPLES_PPP 0
#else
/* prototype for NIMU init function */
extern int USBSerialPPP_NIMUInit();
#endif
 *  =============================== DMA ===============================
#if defined(__TI_COMPILER_VERSION__)
#pragma DATA_ALIGN(dmaControlTable, 1024)
#elif defined(__IAR_SYSTEMS_ICC__)
#pragma data_alignment=1024
#elif defined(__GNUC__)
__attribute__ ((aligned (1024)))
#endif
static tDMAControlTable dmaControlTable[32];
static bool dmaInitialized = false;
/* Hwi_Struct used in the initDMA Hwi_construct call */
static Hwi_Struct dmaHwiStruct;
/* Hwi_Struct used in the usbBusFault Hwi_construct call */
static Hwi_Struct usbBusFaultHwiStruct;
 *  ======== dmaErrorHwi ========
static Void dmaErrorHwi(UArg arg)
    System_printf("DMA error code: %d\n", uDMAErrorStatusGet());
    uDMAErrorStatusClear();
    System_abort("DMA error!!");
 *  ======== EK_TM4C1294XL_usbBusFaultHwi ========
static Void EK_TM4C1294XL_usbBusFaultHwi(UArg arg)
     *  This function should be modified to appropriately manage handle
     *  a USB bus fault.
    System_printf("USB bus fault detected.");
    Hwi_clearInterrupt(INT_GPIOQ4);
    System_abort("USB error!!");
 *  ======== EK_TM4C1294XL_initDMA ========
void EK_TM4C1294XL_initDMA(void)
    Error_Block eb;
    Hwi_Params  hwiParams;
    if (!dmaInitialized) {
        Error_init(&eb);
        Hwi_Params_init(&hwiParams);
        Hwi_construct(&(dmaHwiStruct), INT_UDMAERR, dmaErrorHwi,
                      &hwiParams, &eb);
        if (Error_check(&eb)) {
            System_abort("Couldn't construct DMA error hwi");
        SysCtlPeripheralEnable(SYSCTL_PERIPH_UDMA);
        uDMAEnable();
        uDMAControlBaseSet(dmaControlTable);
        dmaInitialized = true;
 *  =============================== General ===============================
 *  ======== EK_TM4C1294XL_initGeneral ========
void EK_TM4C1294XL_initGeneral(void)
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOG);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOH);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOJ);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOK);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOL);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOM);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPION);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOP);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOQ);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOR);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOS);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOT);
 *  =============================== EMAC ===============================
/* Place into subsections to allow the TI linker to remove items properly */
#pragma DATA_SECTION(EMAC_config, ".const:EMAC_config")
#pragma DATA_SECTION(emacHWAttrs, ".const:emacHWAttrs")
#pragma DATA_SECTION(NIMUDeviceTable, ".data:NIMUDeviceTable")
#endif
#include <ti/drivers/EMAC.h>
#include <ti/drivers/emac/EMACSnow.h>
 *  Required by the Networking Stack (NDK). This array must be NULL terminated.
 *  This can be removed if NDK is not used.
 *  Double curly braces are needed to avoid GCC bug #944572
 *  https://bugs.launchpad.net/gcc-linaro/+bug/944572
#if TI_EXAMPLES_PPP
/* Use PPP driver for PPP example only */
NIMU_DEVICE_TABLE_ENTRY  NIMUDeviceTable[2] = {{USBSerialPPP_NIMUInit}, {NULL}};
#else
/* Default: use Ethernet driver */
NIMU_DEVICE_TABLE_ENTRY  NIMUDeviceTable[2] = {{EMACSnow_NIMUInit}, {NULL}};
#endif
/* EMAC objects */
EMACSnow_Object emacObjects[EK_TM4C1294XL_EMACCOUNT];
 *  EMAC configuration structure
 *  Set user/company specific MAC octates. The following sets the address
 *  to ff-ff-ff-ff-ff-ff. Users need to change this to make the label on
 *  their boards.
unsigned char macAddress[6] = {0xff, 0xff, 0xff, 0xff, 0xff, 0xff};
const EMACSnow_HWAttrs emacHWAttrs[EK_TM4C1294XL_EMACCOUNT] = {
    {EMAC0_BASE, INT_EMAC0, ~0 /* Interrupt priority */, macAddress}
const EMAC_Config EMAC_config[] = {
        &EMACSnow_fxnTable,
        &emacObjects[0],
        &emacHWAttrs[0]
    {NULL, NULL, NULL}
 *  ======== EK_TM4C1294XL_initEMAC ========
void EK_TM4C1294XL_initEMAC(void)
    uint32_t ulUser0, ulUser1;
    /* Get the MAC address */
    FlashUserGet(&ulUser0, &ulUser1);
    if ((ulUser0 != 0xffffffff) && (ulUser1 != 0xffffffff)) {
        System_printf("Using MAC address in flash\n");
         *  Convert the 24/24 split MAC address from NV ram into a 32/16 split MAC
         *  address needed to program the hardware registers, then program the MAC
         *  address into the Ethernet Controller registers.
        macAddress[0] = ((ulUser0 >>  0) & 0xff);
        macAddress[1] = ((ulUser0 >>  8) & 0xff);
        macAddress[2] = ((ulUser0 >> 16) & 0xff);
        macAddress[3] = ((ulUser1 >>  0) & 0xff);
        macAddress[4] = ((ulUser1 >>  8) & 0xff);
        macAddress[5] = ((ulUser1 >> 16) & 0xff);
    else if (macAddress[0] == 0xff && macAddress[1] == 0xff &&
             macAddress[2] == 0xff && macAddress[3] == 0xff &&
             macAddress[4] == 0xff && macAddress[5] == 0xff) {
        System_abort("Change the macAddress variable to match your boards MAC sticker");
    GPIOPinConfigure(GPIO_PF0_EN0LED0);  /* EK_TM4C1294XL_USR_D3 */
    GPIOPinConfigure(GPIO_PF4_EN0LED1);  /* EK_TM4C1294XL_USR_D4 */
    GPIOPinTypeEthernetLED(GPIO_PORTF_BASE, GPIO_PIN_0 | GPIO_PIN_4);
    /* Once EMAC_init is called, EMAC_config cannot be changed */
    EMAC_init();
 *  =============================== GPIO ===============================
#pragma DATA_SECTION(GPIOTiva_config, ".const:GPIOTiva_config")
#endif
#include <ti/drivers/GPIO.h>
#include <ti/drivers/gpio/GPIOTiva.h>
 * Array of Pin configurations
 * NOTE: The order of the pin configurations must coincide with what was
 *       defined in EK_TM4C1294XL.h
 * NOTE: Pins not used for interrupts should be placed at the end of the
 *       array.  Callback entries can be omitted from callbacks array to
 *       reduce memory usage.
GPIO_PinConfig gpioPinConfigs[] = {
    /* Input pins */
    /* EK_TM4C1294XL_USR_SW1 */
    GPIOTiva_PJ_0 | GPIO_CFG_IN_PU | GPIO_CFG_IN_INT_RISING,
    /* EK_TM4C1294XL_USR_SW2 */
    GPIOTiva_PJ_1 | GPIO_CFG_IN_PU | GPIO_CFG_IN_INT_RISING,
    /* Output pins */
    /* EK_TM4C1294XL_USR_D1 */
    GPIOTiva_PN_1 | GPIO_CFG_OUT_STD | GPIO_CFG_OUT_STR_HIGH | GPIO_CFG_OUT_LOW,
    /* EK_TM4C1294XL_USR_D2 */
    GPIOTiva_PN_0 | GPIO_CFG_OUT_STD | GPIO_CFG_OUT_STR_HIGH | GPIO_CFG_OUT_LOW,
	/* Pins for SPI/OLED on Booster Pack 2 */
    /* EK_TM4C1294XL_USR_M7 */
    GPIOTiva_PM_7 | GPIO_CFG_OUT_STD | GPIO_CFG_OUT_STR_HIGH | GPIO_CFG_OUT_LOW,
    /* EK_TM4C1294XL_USR_P4 */
    GPIOTiva_PP_4 | GPIO_CFG_OUT_STD | GPIO_CFG_OUT_STR_HIGH | GPIO_CFG_OUT_LOW,
    /* EK_TM4C1294XL_USR_P5 */
    GPIOTiva_PP_5 | GPIO_CFG_OUT_STD | GPIO_CFG_OUT_STR_HIGH | GPIO_CFG_OUT_LOW,
    GPIOTiva_PD_2 | GPIO_CFG_OUT_STD | GPIO_CFG_OUT_STR_HIGH | GPIO_CFG_OUT_LOW,
	/* Pins for SPI/OLED on Booster Pack 1 */
    /* EK_TM4C1294XL_USR_M3 */
    GPIOTiva_PM_3 | GPIO_CFG_OUT_STD | GPIO_CFG_OUT_STR_HIGH | GPIO_CFG_OUT_LOW,
    /* EK_TM4C1294XL_USR_C7 */
    GPIOTiva_PC_7 | GPIO_CFG_OUT_STD | GPIO_CFG_OUT_STR_HIGH | GPIO_CFG_OUT_LOW,
    /* EK_TM4C1294XL_USR_H2 */
    GPIOTiva_PH_2 | GPIO_CFG_OUT_STD | GPIO_CFG_OUT_STR_HIGH | GPIO_CFG_OUT_LOW,
    /* EK_TM4C1294XL_USR_E4 */
    GPIOTiva_PE_4 | GPIO_CFG_OUT_STD | GPIO_CFG_OUT_STR_HIGH | GPIO_CFG_OUT_LOW,
 * Array of callback function pointers
 * NOTE: Pins not used for interrupts can be omitted from callbacks array to
 *       reduce memory usage (if placed at end of gpioPinConfigs array).
GPIO_CallbackFxn gpioCallbackFunctions[] = {
    NULL,  /* EK_TM4C1294XL_USR_SW1 */
    NULL   /* EK_TM4C1294XL_USR_SW2 */
/* The device-specific GPIO_config structure */
const GPIOTiva_Config GPIOTiva_config = {
    .pinConfigs = (GPIO_PinConfig *) gpioPinConfigs,
    .callbacks = (GPIO_CallbackFxn *) gpioCallbackFunctions,
    .numberOfPinConfigs = sizeof(gpioPinConfigs) / sizeof(GPIO_PinConfig),
    .numberOfCallbacks = sizeof(gpioCallbackFunctions)/sizeof(GPIO_CallbackFxn),
    .intPriority = (~0)
 *  ======== EK_TM4C1294XL_initGPIO ========
void EK_TM4C1294XL_initGPIO(void)
    /* Initialize peripheral and pins */
    GPIO_init();
 *  =============================== I2C ===============================
#pragma DATA_SECTION(I2C_config, ".const:I2C_config")
#pragma DATA_SECTION(i2cTivaHWAttrs, ".const:i2cTivaHWAttrs")
#endif
#include <ti/drivers/I2C.h>
#include <ti/drivers/i2c/I2CTiva.h>
/* I2C objects */
I2CTiva_Object i2cTivaObjects[EK_TM4C1294XL_I2CCOUNT];
/* I2C configuration structure, describing which pins are to be used */
const I2CTiva_HWAttrs i2cTivaHWAttrs[EK_TM4C1294XL_I2CCOUNT] = {
    {I2C7_BASE, INT_I2C7, ~0 /* Interrupt priority */},
    {I2C8_BASE, INT_I2C8, ~0 /* Interrupt priority */}
const I2C_Config I2C_config[] = {
    {&I2CTiva_fxnTable, &i2cTivaObjects[0], &i2cTivaHWAttrs[0]},
    {&I2CTiva_fxnTable, &i2cTivaObjects[1], &i2cTivaHWAttrs[1]},
    {NULL, NULL, NULL}
 *  ======== EK_TM4C1294XL_initI2C ========
void EK_TM4C1294XL_initI2C(void)
    /* I2C7 Init */
     * NOTE: TI-RTOS examples configure pins PD0 & PD1 for SSI2 or I2C7.  Thus,
     * a conflict occurs when the I2C & SPI drivers are used simultaneously in
     * an application.  Modify the pin mux settings in this file and resolve the
     * conflict before running your the application.
    /* Enable the peripheral */
    SysCtlPeripheralEnable(SYSCTL_PERIPH_I2C7);
    /* Configure the appropriate pins to be I2C instead of GPIO. */
    GPIOPinConfigure(GPIO_PD0_I2C7SCL);
    GPIOPinConfigure(GPIO_PD1_I2C7SDA);
    GPIOPinTypeI2CSCL(GPIO_PORTD_BASE, GPIO_PIN_0);
    GPIOPinTypeI2C(GPIO_PORTD_BASE, GPIO_PIN_1);
    /* I2C8 Init */
    SysCtlPeripheralEnable(SYSCTL_PERIPH_I2C8);
    GPIOPinConfigure(GPIO_PA2_I2C8SCL);
    GPIOPinConfigure(GPIO_PA3_I2C8SDA);
    GPIOPinTypeI2CSCL(GPIO_PORTA_BASE, GPIO_PIN_2);
    GPIOPinTypeI2C(GPIO_PORTA_BASE, GPIO_PIN_3);
    I2C_init();
 *  =============================== PWM ===============================
#pragma DATA_SECTION(PWM_config, ".const:PWM_config")
#pragma DATA_SECTION(pwmTivaHWAttrs, ".const:pwmTivaHWAttrs")
#endif
#include <ti/drivers/PWM.h>
#include <ti/drivers/pwm/PWMTiva.h>
#include <driverlib/pwm.h>
PWMTiva_Object pwmTivaObjects[EK_TM4C1294XL_PWMCOUNT];
/* PWM configuration structure */
const PWMTiva_HWAttrs pwmTivaHWAttrs[EK_TM4C1294XL_PWMCOUNT] = {
        PWM0_BASE,
        PWM_OUT_0,
        PWM_GEN_MODE_DOWN | PWM_GEN_MODE_DBG_RUN
const PWM_Config PWM_config[] = {
    {&PWMTiva_fxnTable, &pwmTivaObjects[0], &pwmTivaHWAttrs[0]},
    {NULL, NULL, NULL}
 *  ======== EK_TM4C1294XL_initPWM ========
void EK_TM4C1294XL_initPWM(void)
    /* Enable PWM peripherals */
    SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM0);
     * Enable PWM output on GPIO pins.  PWM output is connected to an Ethernet
     * LED on the development board (D4).  The PWM configuration
     * below will disable Ethernet functionality.
    GPIOPinConfigure(GPIO_PF0_M0PWM0);
    GPIOPinTypePWM(GPIO_PORTF_BASE, GPIO_PIN_0);
    PWM_init();
 *  =============================== SDSPI ===============================
#pragma DATA_SECTION(SDSPI_config, ".const:SDSPI_config")
#pragma DATA_SECTION(sdspiTivaHWattrs, ".const:sdspiTivaHWattrs")
#endif
#include <ti/drivers/SDSPI.h>
#include <ti/drivers/sdspi/SDSPITiva.h>
/* SDSPI objects */
SDSPITiva_Object sdspiTivaObjects[EK_TM4C1294XL_SDSPICOUNT];
/* SDSPI configuration structure, describing which pins are to be used */
const SDSPITiva_HWAttrs sdspiTivaHWattrs[EK_TM4C1294XL_SDSPICOUNT] = {
        SSI3_BASE,          /* SPI base address */
        GPIO_PORTQ_BASE,    /* SPI SCK PORT */
        GPIO_PIN_0,         /* SCK PIN */
        GPIO_PORTQ_BASE,    /* SPI MISO PORT*/
        GPIO_PIN_3,         /* MISO PIN */
        GPIO_PORTQ_BASE,    /* SPI MOSI PORT */
        GPIO_PIN_2,         /* MOSI PIN */
        GPIO_PORTP_BASE,    /* GPIO CS PORT */
        GPIO_PIN_4,         /* CS PIN */
const SDSPI_Config SDSPI_config[] = {
    {&SDSPITiva_fxnTable, &sdspiTivaObjects[0], &sdspiTivaHWattrs[0]},
    {NULL, NULL, NULL}
 *  ======== EK_TM4C1294XL_initSDSPI ========
void EK_TM4C1294XL_initSDSPI(void)
    /* SDSPI0 configuration */
    /* Enable the peripherals used by the SD Card */
    /* SDSPI1 configuration */
    SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI3);
    /* Configure pad settings */
    GPIOPadConfigSet(GPIO_PORTQ_BASE,
                     GPIO_PIN_0 | GPIO_PIN_2,
                     GPIO_STRENGTH_4MA, GPIO_PIN_TYPE_STD);
                     GPIO_PIN_3,
                     GPIO_STRENGTH_4MA, GPIO_PIN_TYPE_STD_WPU);
    GPIOPadConfigSet(GPIO_PORTP_BASE,
                     GPIO_PIN_4,
    GPIOPinConfigure(GPIO_PQ0_SSI3CLK);
    GPIOPinConfigure(GPIO_PQ3_SSI3XDAT1);
    GPIOPinConfigure(GPIO_PQ2_SSI3XDAT0);
     *  These GPIOs are connected to PA2 and PA3 and need to be brought into a
     *  GPIO input state so they don't interfere with SPI communications.
    GPIOPinTypeGPIOInput(GPIO_PORTA_BASE, GPIO_PIN_2);
    GPIOPinTypeGPIOInput(GPIO_PORTA_BASE, GPIO_PIN_3);
    SDSPI_init();
 *  =============================== SPI ===============================
#pragma DATA_SECTION(SPI_config, ".const:SPI_config")
#pragma DATA_SECTION(spiTivaDMAHWAttrs, ".const:spiTivaDMAHWAttrs")
#endif
#include <ti/drivers/SPI.h>
#include <ti/drivers/spi/SPITivaDMA.h>
/* SPI objects */
SPITivaDMA_Object spiTivaDMAObjects[EK_TM4C1294XL_SPICOUNT];
#pragma DATA_ALIGN(spiTivaDMAscratchBuf, 32)
#pragma data_alignment=32
__attribute__ ((aligned (32)))
#endif
uint32_t spiTivaDMAscratchBuf[EK_TM4C1294XL_SPICOUNT];
/* SPI configuration structure */
const SPITivaDMA_HWAttrs spiTivaDMAHWAttrs[EK_TM4C1294XL_SPICOUNT] = {
        SSI3_BASE,
        INT_SSI3,
        ~0,         // Interrupt priority
        &spiTivaDMAscratchBuf[0],
        0,
        UDMA_SEC_CHANNEL_TMR2A_14,
        UDMA_SEC_CHANNEL_TMR2B_15,
        uDMAChannelAssign,
        UDMA_CH14_SSI3RX,
        UDMA_CH15_SSI3TX
const SPI_Config SPI_config[] = {
    {&SPITivaDMA_fxnTable, &spiTivaDMAObjects[0], &spiTivaDMAHWAttrs[0]},
    {NULL, NULL, NULL}
 *  ======== EK_TM4C1294XL_initSPI ========
void EK_TM4C1294XL_initSPI(void)
    /* SSI2 */
	uint32_t g_ui32SysClock = 120 * 1e6;
    /* SSI3 */
                      GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2,
                      GPIO_PIN_3,
                      GPIO_PIN_4,
    GPIOPinConfigure(GPIO_PQ1_SSI3FSS);
    GPIOPinTypeSSI(GPIO_PORTQ_BASE, GPIO_PIN_0 | GPIO_PIN_1 |
                                    GPIO_PIN_2 | GPIO_PIN_3);
    SSIConfigSetExpClk(SSI3_BASE, g_ui32SysClock, SSI_FRF_MOTO_MODE_0, SSI_MODE_MASTER, 10000000, 8);
    EK_TM4C1294XL_initDMA();
    SPI_init();
 *  =============================== UART ===============================
#pragma DATA_SECTION(UART_config, ".const:UART_config")
#pragma DATA_SECTION(uartTivaHWAttrs, ".const:uartTivaHWAttrs")
#endif
#include <ti/drivers/UART.h>
#if TI_DRIVERS_UART_DMA
#include <ti/drivers/uart/UARTTivaDMA.h>
/* UART objects using DMA */
UARTTivaDMA_Object uartTivaObjects[EK_TM4C1294XL_UARTCOUNT];
/* UART DMA configuration structure */
const UARTTivaDMA_HWAttrs uartTivaHWAttrs[EK_TM4C1294XL_UARTCOUNT] = {
    {/* EK_TM4C1294XL_UART0 */
        UART0_BASE,
        INT_UART0,
        ~0,        /* Interrupt priority */
        UDMA_CH8_UART0RX,
        UDMA_CH9_UART0TX,
const UART_Config UART_config[] = {
        &UARTTivaDMA_fxnTable,
        &uartTivaObjects[0],
        &uartTivaHWAttrs[0]
    {NULL, NULL, NULL}
#else
#include <ti/drivers/uart/UARTTiva.h>
/* UART objects */
UARTTiva_Object uartTivaObjects[EK_TM4C1294XL_UARTCOUNT];
unsigned char uartTivaRingBuffer[32];
/* UART configuration structure */
const UARTTiva_HWAttrs uartTivaHWAttrs[EK_TM4C1294XL_UARTCOUNT] = {
        .baseAddr = UART0_BASE,
        .intNum = INT_UART0,
        .intPriority = ~0,
        .flowControl = UART_FLOWCONTROL_NONE,
        .ringBufPtr  = uartTivaRingBuffer,
        .ringBufSize = sizeof(uartTivaRingBuffer)
        &UARTTiva_fxnTable,
        &uartTivaHWAttrs[0]
    {NULL, NULL, NULL}
#endif /* TI_DRIVERS_UART_DMA */
 *  ======== EK_TM4C1294XL_initUART ========
void EK_TM4C1294XL_initUART(void)
    /* Enable and configure the peripherals used by the uart. */
    SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
    GPIOPinConfigure(GPIO_PA0_U0RX);
    GPIOPinConfigure(GPIO_PA1_U0TX);
    GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
    /* Initialize the UART driver */
#endif
    UART_init();
 *  =============================== USB ===============================
 *  ======== EK_TM4C1294XL_initUSB ========
 *  This function just turns on the USB
void EK_TM4C1294XL_initUSB(EK_TM4C1294XL_USBMode usbMode)
    Error_Block eb;
    /* Enable the USB peripheral and PLL */
    SysCtlPeripheralEnable(SYSCTL_PERIPH_USB0);
    SysCtlUSBPLLEnable();
    /* Setup pins for USB operation */
    GPIOPinTypeUSBAnalog(GPIO_PORTB_BASE, GPIO_PIN_0 | GPIO_PIN_1);
    GPIOPinTypeUSBAnalog(GPIO_PORTL_BASE, GPIO_PIN_6 | GPIO_PIN_7);
    /* Additional configurations for Host mode */
    if (usbMode == EK_TM4C1294XL_USBHOST) {
        /* Configure the pins needed */
        HWREG(GPIO_PORTD_BASE + GPIO_O_LOCK) = GPIO_LOCK_KEY;
        HWREG(GPIO_PORTD_BASE + GPIO_O_CR) = 0xff;
        GPIOPinConfigure(GPIO_PD6_USB0EPEN);
        GPIOPinTypeUSBDigital(GPIO_PORTD_BASE, GPIO_PIN_6 | GPIO_PIN_7);
         *  USB bus fault is routed to pin PQ4.  We create a Hwi to allow us
         *  to detect power faults and recover gracefully or terminate the
         *  program.  PQ4 is active low; set the pin as input with a weak
         *  pull-up.
        GPIOPadConfigSet(GPIO_PORTQ_BASE, GPIO_PIN_4,
                         GPIO_STRENGTH_2MA, GPIO_PIN_TYPE_STD_WPU);
        GPIOIntTypeSet(GPIO_PORTQ_BASE, GPIO_PIN_4, GPIO_FALLING_EDGE);
        GPIOIntClear(GPIO_PORTQ_BASE, GPIO_PIN_4);
        /* Create a Hwi for PQ4 pin. */
        Error_init(&eb);
        Hwi_construct(&(usbBusFaultHwiStruct), INT_GPIOQ4,
                      EK_TM4C1294XL_usbBusFaultHwi, &hwiParams, &eb);
            System_abort("Couldn't construct USB bus fault hwi");
 *  =============================== USBMSCHFatFs ===============================
#pragma DATA_SECTION(USBMSCHFatFs_config, ".const:USBMSCHFatFs_config")
#pragma DATA_SECTION(usbmschfatfstivaHWAttrs, ".const:usbmschfatfstivaHWAttrs")
#endif
#include <ti/drivers/USBMSCHFatFs.h>
#include <ti/drivers/usbmschfatfs/USBMSCHFatFsTiva.h>
/* USBMSCHFatFs objects */
USBMSCHFatFsTiva_Object usbmschfatfstivaObjects[EK_TM4C1294XL_USBMSCHFatFsCOUNT];
/* USBMSCHFatFs configuration structure, describing which pins are to be used */
const USBMSCHFatFsTiva_HWAttrs usbmschfatfstivaHWAttrs[EK_TM4C1294XL_USBMSCHFatFsCOUNT] = {
    {INT_USB0, ~0 /* Interrupt priority */}
const USBMSCHFatFs_Config USBMSCHFatFs_config[] = {
        &USBMSCHFatFsTiva_fxnTable,
        &usbmschfatfstivaObjects[0],
        &usbmschfatfstivaHWAttrs[0]
    {NULL, NULL, NULL}
 *  ======== EK_TM4C1294XL_initUSBMSCHFatFs ========
void EK_TM4C1294XL_initUSBMSCHFatFs(void)
    /* Initialize the DMA control table */
    /* Call the USB initialization function for the USB Reference modules */
    EK_TM4C1294XL_initUSB(EK_TM4C1294XL_USBHOST);
    USBMSCHFatFs_init();
 *  =============================== Watchdog ===============================
#pragma DATA_SECTION(Watchdog_config, ".const:Watchdog_config")
#pragma DATA_SECTION(watchdogTivaHWAttrs, ".const:watchdogTivaHWAttrs")
#endif
#include <ti/drivers/Watchdog.h>
#include <ti/drivers/watchdog/WatchdogTiva.h>
/* Watchdog objects */
WatchdogTiva_Object watchdogTivaObjects[EK_TM4C1294XL_WATCHDOGCOUNT];
/* Watchdog configuration structure */
const WatchdogTiva_HWAttrs watchdogTivaHWAttrs[EK_TM4C1294XL_WATCHDOGCOUNT] = {
    /* EK_TM4C1294XL_WATCHDOG0 with 1 sec period at default CPU clock freq */
        WATCHDOG0_BASE,
        INT_WATCHDOG,
        80000000
const Watchdog_Config Watchdog_config[] = {
    {&WatchdogTiva_fxnTable, &watchdogTivaObjects[0], &watchdogTivaHWAttrs[0]},
    {NULL, NULL, NULL},
 *  ======== EK_TM4C1294XL_initWatchdog ========
 * NOTE: To use the other watchdog timer with base address WATCHDOG1_BASE,
 *       an additional function call may need be made to enable PIOSC. Enabling
 *       WDOG1 does not do this. Enabling another peripheral that uses PIOSC
 *       such as ADC0 or SSI0, however, will do so. Example:
 *       SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);
 *       SysCtlPeripheralEnable(SYSCTL_PERIPH_WDOG1);
 *       See the following forum post for more information:
 *       http://e2e.ti.com/support/microcontrollers/stellaris_arm_cortex-m3_microcontroller/f/471/p/176487/654390.aspx#654390
void EK_TM4C1294XL_initWatchdog(void)
    /* Enable peripherals used by Watchdog */
    SysCtlPeripheralEnable(SYSCTL_PERIPH_WDOG0);
    /* Initialize the Watchdog driver */
    Watchdog_init();
 *  =============================== WiFi ===============================
#pragma DATA_SECTION(WiFi_config, ".const:WiFi_config")
#pragma DATA_SECTION(wiFiCC3100HWAttrs, ".const:wiFiCC3100HWAttrs")
#endif
#include <ti/drivers/WiFi.h>
#include <ti/drivers/wifi/WiFiCC3100.h>
/* WiFi objects */
WiFiCC3100_Object wiFiCC3100Objects[EK_TM4C1294XL_WIFICOUNT];
/* WiFi configuration structure */
const WiFiCC3100_HWAttrs wiFiCC3100HWAttrs[EK_TM4C1294XL_WIFICOUNT] = {
        GPIO_PORTM_BASE, /* IRQ port */
        GPIO_PIN_3,      /* IRQ pin */
        INT_GPIOM,       /* IRQ port interrupt vector */
        GPIO_PORTH_BASE, /* CS port */
        GPIO_PIN_2,      /* CS pin */
        GPIO_PORTC_BASE, /* WLAN EN port */
        GPIO_PIN_6       /* WLAN EN pin */
const WiFi_Config WiFi_config[] = {
        &WiFiCC3100_fxnTable,
        &wiFiCC3100Objects[0],
        &wiFiCC3100HWAttrs[0]
    {NULL,NULL, NULL},
 *  ======== EK_TM4C1294XL_initWiFi ========
void EK_TM4C1294XL_initWiFi(void)
    /* Configure EN & CS pins to disable CC3100 */
    GPIOPinTypeGPIOOutput(GPIO_PORTH_BASE, GPIO_PIN_2);
    GPIOPinTypeGPIOOutput(GPIO_PORTC_BASE, GPIO_PIN_6);
    GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_2, GPIO_PIN_2);
    GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_6, 0);
    /* Configure SSI2 for CC3100 */
    SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI2);
    GPIOPinConfigure(GPIO_PD3_SSI2CLK);
    GPIOPinConfigure(GPIO_PD1_SSI2XDAT0);
    GPIOPinConfigure(GPIO_PD0_SSI2XDAT1);
    GPIOPinTypeSSI(GPIO_PORTD_BASE, GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_3);
    /* Configure IRQ pin */
    GPIOPinTypeGPIOInput(GPIO_PORTM_BASE, GPIO_PIN_3);
    GPIOPadConfigSet(GPIO_PORTM_BASE, GPIO_PIN_3, GPIO_STRENGTH_2MA,
                     GPIO_PIN_TYPE_STD_WPD);
    GPIOIntTypeSet(GPIO_PORTM_BASE, GPIO_PIN_3, GPIO_RISING_EDGE);
    SPI_init();
    WiFi_init();
8130.EK_TM4C1294XL.h
 * are met:
 *  ======== gpiointerrupt.c ========
/* XDCtools Header files */
/* BIOS Header files */
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
/* TI-RTOS Header files */
/* Example/Board Header files */
#include "Board.h"
#include "oled.h"
#include "thumbstick.h"
#include <string.h>
void oled_window_init(void);
/* variable to be read by GUI Composer */
int count = 0;
int btn_count = 0;
int led_count = 0;
 *  ======== gpioButtonFxn0 ========
 *  Callback function for the GPIO interrupt on Board_BUTTON0.
void gpioButtonFxn0(void)
    /* Clear the GPIO interrupt and toggle an LED */
 //   GPIO_toggle(Board_LED0);
	volatile int cnt;
	btn_count++;
	//Task_sleep(1);
	//   GPIO_disableInt(Board_BUTTON0);
	for(cnt=0;cnt<100;cnt++);
	//   GPIO_enableInt(Board_BUTTON0);
 *  ======== pwmLEDFxn ========
 *  Task periodically increments the PWM duty for the on board LED.
Void Button0Fxn(UArg arg0, UArg arg1)
    /* Loop forever incrementing the PWM duty */
//   	initOLED();
//    oled_window_init();
	initSPI();
    	while (1){
    		Thumbstick_read();
    		Task_sleep(200);
/*    while (1) {
    	Semaphore_pend(semaphore0,BIOS_WAIT_FOREVER);
    	 while (btn_count!=led_count)
    		 led_count=btn_count;
        	 Task_sleep(1000);
    	 Semaphore_post(semaphore0);
 *  Task periodically bliks for the on board LED.
Void LED1Fxn(UArg arg0, UArg arg1)
	int x;
    /* Loop forever blinking Led1 */
    while (1) {
    	Semaphore_pend(semaphore1,BIOS_WAIT_FOREVER);
    	if(btn_count==led_count)
    	while(btn_count==led_count)
			for(x=0;x<led_count;x++)
				 GPIO_write(Board_LED0, Board_LED_ON);
				 Task_sleep(200);
				 GPIO_write(Board_LED0, Board_LED_OFF);
				 Task_sleep(200);
			 Task_sleep(1000);
    	if(btn_count>led_count)
    		btn_count -= led_count;
    	Semaphore_post(semaphore1);
 *  ======== main ========
int main(void)
    /* Call board init functions */
    Board_initGeneral();
    Board_initGPIO();
 //   Board_initUART();
    Board_initSPI();
    /* Turn on user LED */
    System_printf("Starting the GPIO Interrupt example\nSystem provider is set"
                  " to SysMin. Halt the target to view any SysMin contents in"
                  " ROV.\n");
    /* SysMin will only print to the console when you call flush or exit */
    System_flush();
    /* install Button callback */
    GPIO_setCallback(Board_BUTTON0, gpioButtonFxn0);
    /* Enable interrupts */
    /* Start BIOS */
    BIOS_start();
    return (0);
	char data[15];
	oled_background(0, 0);
	oled_rectangle(0, 20, 96, 1, 0xFFFF);
	strcpy(data, "String");
	oled_text(data, 6, 0xFFFF, 0, 10, 10);
	oled_rectangle(96-1*7, 10, 7, 8, rgb2oled(0xFF, 0, 0));
	oled_rectangle(96-2*7, 10, 7, 8, rgb2oled(0, 0xFF, 0));
	oled_rectangle(96-3*7, 10, 7, 8, rgb2oled(0, 0, 0xFF));
	oled_frame(0, 40, 96, 50, 1, rgb2oled(0, 0, 0xFF));
	strcpy(data, "line");
	oled_text(data, 4, 0xFFFF, 0, 15, 60);
 * spi_wrapper.c
 *  Created on: 06.05.2015
 *      Author: Christoph R.
#include <stdint.h>
#include "Board.h"
#include "spi_wrapper.h"
#define SPI_FREQ	1e6
#define SPI_DATA	8
SPI_Handle masterSpiOled;
SPI_Handle masterSpiThumbStk;
SPI_Transaction masterTransaction;
bool transferOK;
unsigned char masterRxBuffer[SPI_MSG_LENGTH];
unsigned char masterTxBuffer[SPI_MSG_LENGTH] = "\0";
unsigned char masterRxBufferTS[3];
unsigned char masterTxBufferTS[3] = "\0";
void initSPI()
    /* Initialize SPI handle as default master */
 //   masterSpiOled = SPI_open(Board_SPI1, NULL);
    masterSpiThumbStk = SPI_open(Board_SPI1,  NULL);
    /*if (masterSpi == NULL) {
        System_abort("Error initializing SPI\n");
    else {
        System_printf("SPI initialized\n");
void SPI_PutSingle(uint8_t data)
	clearCS();
	masterTxBuffer[0] = data;
    /* Initialize master SPI transaction structure */
    masterTransaction.count = SPI_MSG_LENGTH;
    masterTransaction.txBuf = (Ptr)masterTxBuffer;
    masterTransaction.rxBuf = (Ptr)masterRxBuffer;
    /* Initiate SPI transfer */
    transferOK = SPI_transfer(masterSpiOled, &masterTransaction);
	setCS();
int SPI_GetDouble(uint8_t channel)
	int adcval=0;
//	setCS();
//	SysCtlDelay(g_ui32SysClock / 3 / 10 );		// 100 ms
	clearCSB_TS();
    masterTransaction.count = 3;
    masterTransaction.txBuf = (Ptr)masterTxBufferTS;
    masterTransaction.rxBuf = (Ptr)masterRxBufferTS;
    masterTxBufferTS[0] = 0x06;
    masterTxBufferTS[1] = channel << 6;
    masterTxBufferTS[2] = 0xFF;
    transferOK = SPI_transfer(masterSpiThumbStk, &masterTransaction);
    adcval=  masterRxBufferTS[1]<< 8| (masterRxBufferTS[2]);
    setCSB_TS();
    return adcval;
4380.spi_wrapper.h6646.thumbstick.h
 * thumstick.c
 *  Created on: 02.01.2016
 *      Author: Rubi
int Thumbstick_read(void)
	int adcval;
	adcval=SPI_GetDouble(0);
	adcval=SPI_GetDouble(1);
	return adcval;
