problem encoding both aac h264 together on the dm365
I have modfied the encode demo use the ittiam aac encoder and h264 video into dvsdk_3_10_00_12 according to the instructions in http://processors.wiki.ti.com/index.php/DM365_Audio_Codecs_Integration_with_DVSDK_2.10.01.18_Demos.
I find that I can encode video or ausio but not both together.
Please can you help?
I append a copy of encode.cfg file.
regards
Shlomo Kut
regards
Shlomo Kut
 *   Copyright (c)  Texas Instruments Incorporated 2009
 *   Use of this software is controlled by the terms and conditions found in the
 *   license agreement under which this software has been supplied or provided.
algSettings = xdc.useModule('ti.sdo.ce.alg.Settings');
algSettings.useCache = true;
/* Load support for the Codec Engine OSAL */
var osalGlobal = xdc.useModule('ti.sdo.ce.osal.Global');
osalGlobal.runtimeEnv = osalGlobal.LINUX;
/* Load support for the 'Davinci Multimedia Application Interface' module */
var DMAI = xdc.loadPackage('ti.sdo.dmai');
/* Load support for SimpleWidget */
var SW = xdc.loadPackage('ti.sdo.simplewidget');
environment['xdc.cfg.check.fatal'] = 'false';
var RMAN = xdc.useModule('ti.sdo.fc.rman.RMAN');
RMAN.useDSKT2 = false;
RMAN.persistentAllocFxn = "__ALG_allocMemory";
RMAN.persistentFreeFxn = "__ALG_freeMemory";
RMAN.semCreateFxn = "Sem_create";
RMAN.semDeleteFxn = "Sem_delete";
RMAN.semPendFxn = "Sem_pend";
RMAN.semPostFxn = "Sem_post";
RMAN.tableSize = 10;
var EDMA3 = xdc.useModule('ti.sdo.fc.edma3.Settings');
var vicp = xdc.useModule('ti.sdo.linuxutils.vicp.VICP');
var HDVICP = xdc.useModule('ti.sdo.fc.ires.hdvicp.HDVICP');
var VICP = xdc.useModule('ti.sdo.fc.ires.vicp.VICP2');
var VICPSYNC = xdc.useModule('ti.sdo.fc.vicpsync.VICPSYNC');
var HDVICPSYNC = xdc.useModule('ti.sdo.fc.hdvicpsync.HDVICPSYNC');
var VICP = xdc.useModule('ti.sdo.fc.memutils.MEMUTILS');
DDRSPACE = xdc.useModule('ti.sdo.fc.ires.addrspace.ADDRSPACE');
var EDMA3CHAN = xdc.useModule('ti.sdo.fc.ires.edma3chan.EDMA3CHAN');
var LSP = xdc.useModule('ti.sdo.linuxutils.edma.EDMA');
var CMEM = xdc.useModule('ti.sdo.linuxutils.cmem.CMEM');
xdc.loadPackage("ti.sdo.ce.video2");
xdc.loadPackage("ti.sdo.fc.hdvicpsync");
 *  ======== Engine Configuration ========
var MPEG4ENC = xdc.useModule('ti.sdo.codecs.mpeg4enc.ce.MPEG4ENC');
var H264ENC = xdc.useModule('ti.sdo.codecs.h264enc.ce.H264ENC');
var G711ENC = xdc.useModule('ti.sdo.ce.examples.codecs.g711.G711ENC');
var AACENC = xdc.useModule('ittiam.codecs.aaclc_enc.ce.AACLC_ENC');
var Engine = xdc.useModule('ti.sdo.ce.Engine');
var myEngine = Engine.create("encode", [
    {name: "mpeg4enc", mod: MPEG4ENC, local: true, groupId: 1},
    {name: "h264enc", mod: H264ENC, local: true, groupId: 1},
    {name: "g711enc", mod: G711ENC, local: true},
    {name: "aacenc", mod: AACENC, local: true},
xdc.loadPackage('ti.sdo.fc.ires.vicp').profile = "debug_trace";
xdc.loadPackage('ti.sdo.fc.ires.edma3chan').profile = "debug_trace";
xdc.loadPackage('ti.sdo.fc.rman').profile = "debug_trace";
xdc.loadPackage('ti.sdo.fc.edma3').profile = "debug_trace";
EDMA3CHAN.trace = true;
EDMA3CHAN.debug = true;
Program.main = null;
  • A lttile update on this situation.
    It seems the problem is not to do with the codec but to do with audio capture.
    When I capture video and attempt to record with arecord the video capture stops. Maybe it is a dma contention issue?
    I am using the davinci-staging-kernel.
    Please could anybody suggest a solution?
    thanks for your time,
    Shlomo Kut
  • Hello Shlomo,
    I'm seeing a similar issue with the h264fhdvenc encoder and aac encoder on the dm6467.
    Did you manage to solve this problem?
    Ram
