Hii,
I am working with ti-processor-sdk-linux-am57xx-evm on DRA7xx_EVM. I have changed the entire dts file according toDRA7xx_EVM hardware. I am not getting anything on the dispaly. I am getting display subsystem successfully initialized in the Kernel Log
[ 0.363848] OMAP DSS rev 6.1
[ 0.364094] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[ 0.380324] tlc59108 0-0040: Successfully initialized tlc59108
[ 0.419289] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.421544] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 299, base_baud = 3000000) is a 8250
[ 1.195416] console [ttyS0] enabled
[ 1.199679] [drm] Initialized drm 1.1.0 20060810
If i do modetest then i am getting like this, i suspect there is some issue with connector ids because when i worked on dra7xx, then connector ids are different please help me with this....
trying to open device 'i915'...failed.
trying to open device 'radeon'...failed.
trying to open device 'nouveau'...failed.
trying to open device 'vmwgfx'...failed.
trying to open device 'omapdrm'...success.
Encoders:
id crtc type possible crtcs possible clones
25 28 TMDS 0x00000001 0x00000000
Connectors:
id encoder status type size (mm) modes encoders
26 25 connected unknown 0x0 1 25
modes:
name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot)
1280x800 60 1280 1328 1360 1404 800 804 811 823 flags: nhsync, nvsync; type: preferred, driver
props:
1 EDID:
flags: immutable blob
blobs:
value:
2 DPMS:
flags: enum
enums: On=0 Standby=1 Suspend=2 Off=3
value: 1
CRTCs:
id fb pos size
28 35 (0,0) (1280x800)
props:
21 trans-key-mode:
flags: enum
enums: disable=0 gfx-dst=1 vid-src=2
value: 0
22 trans-key:
flags: range
values: 0 16777215
value: 0
23 background:
flags: range
values: 0 16777215
value: 0
24 alpha_blender:
flags: range
values: 0 1
value: 0
17 rotation:
flags: bitmask
values: rotate-0=0x1 rotate-90=0x2 rotate-180=0x4 rotate-270=0x8 reflect-x=0x10 reflect-y=0x20
value: 0
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
30 0 (0,0) (0x0)
0 0 0 0 0 0 0 0 0 flags: ; type:
props:
21 trans-key-mode:
flags: enum
value: 0
22 trans-key:
flags: range
values: 0 16777215
value: 0
23 background:
flags: range
values: 0 16777215
value: 0
24 alpha_blender:
flags: range
values: 0 1
value: 0
17 rotation:
flags: bitmask
value: 0
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
Planes:
id crtc fb CRTC x,y x,y gamma size possible crtcs
27 28 35 0,0 0,0 0 0x00000001
formats: RG16 RX12 XR12 RA12 AR12 XR15 AR15 RG24 RX24 XR24 RA24 AR24
props:
5 type:
flags: immutable enum
enums: Overlay=0 Primary=1 Cursor=2
value: 1
17 rotation:
flags: bitmask
value: 1
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
29 30 0 0,0 0,0 0 0x00000002
formats: RG16 RX12 XR12 RA12 AR12 XR15 AR15 RG24 RX24 XR24 RA24 AR24 NV12 YUYV UYVY
props:
5 type:
value: 1
17 rotation:
flags: bitmask
value: 1
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
31 0 0 0,0 0,0 0 0x00000003
props:
5 type:
value: 0
17 rotation:
flags: bitmask
value: 1
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
32 0 0 0,0 0,0 0 0x00000003
props:
5 type:
value: 0
17 rotation:
flags: bitmask
value: 1
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
Frame buffers:
id size pitch
Thanks & Regards,
Ganesh
