Dear All,
We are using the processor SDK for working on VAYU EVM.
While working with Processor SDK , dss module is successfully initialized but still i am not getting anything on the display.
When i executed modetest command i am getting like this, here the connector ids are different than DRA7xx so please let me know because of that connector is he not driving anything on the display. If yes then please let me know how to change it?
trying to open device 'i915'...failed.
trying to open device 'radeon'...failed.
trying to open device 'nouveau'...failed.
trying to open device 'vmwgfx'...failed.
trying to open device 'omapdrm'...success.
Encoders:
id crtc type possible crtcs possible clones
25 28 TMDS 0x00000001 0x00000000
Connectors:
id encoder status type size (mm) modes encoders
26 25 connected unknown 0x0 1 25
modes:
name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot)
1280x800 60 1280 1328 1360 1404 800 804 811 823 flags: nhsync, nvsync; type: preferred, driver
props:
1 EDID:
flags: immutable blob
blobs:
value:
2 DPMS:
flags: enum
enums: On=0 Standby=1 Suspend=2 Off=3
value: 1
CRTCs:
id fb pos size
28 35 (0,0) (1280x800)
props:
21 trans-key-mode:
flags: enum
enums: disable=0 gfx-dst=1 vid-src=2
value: 0
22 trans-key:
flags: range
values: 0 16777215
value: 0
23 background:
flags: range
values: 0 16777215
value: 0
24 alpha_blender:
flags: range
values: 0 1
value: 0
17 rotation:
flags: bitmask
values: rotate-0=0x1 rotate-90=0x2 rotate-180=0x4 rotate-270=0x8 reflect-x=0x10 reflect-y=0x20
value: 0
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
30 0 (0,0) (0x0)
0 0 0 0 0 0 0 0 0 flags: ; type:
props:
21 trans-key-mode:
flags: enum
value: 0
22 trans-key:
flags: range
values: 0 16777215
value: 0
23 background:
flags: range
values: 0 16777215
value: 0
24 alpha_blender:
flags: range
values: 0 1
value: 0
17 rotation:
flags: bitmask
value: 0
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
Planes:
id crtc fb CRTC x,y x,y gamma size possible crtcs
27 28 35 0,0 0,0 0 0x00000001
formats: RG16 RX12 XR12 RA12 AR12 XR15 AR15 RG24 RX24 XR24 RA24 AR24
props:
5 type:
flags: immutable enum
enums: Overlay=0 Primary=1 Cursor=2
value: 1
17 rotation:
flags: bitmask
value: 1
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
29 30 0 0,0 0,0 0 0x00000002
formats: RG16 RX12 XR12 RA12 AR12 XR15 AR15 RG24 RX24 XR24 RA24 AR24 NV12 YUYV UYVY
props:
5 type:
value: 1
17 rotation:
flags: bitmask
value: 1
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
31 0 0 0,0 0,0 0 0x00000003
props:
5 type:
value: 0
17 rotation:
flags: bitmask
value: 1
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
32 0 0 0,0 0,0 0 0x00000003
props:
5 type:
value: 0
17 rotation:
flags: bitmask
value: 1
18 zorder:
flags: range
values: 0 3
value: 0
19 global_alpha:
flags: range
values: 0 255
value: 0
20 pre_mult_alpha:
flags: range
values: 0 1
value: 0
Frame buffers:
id size pitch
Thanks & Regards,
N.V.Subbaiah
