simultaneous encode/decode on AM57xx
hi experts,
I validate one channel decode/encode at the same time, but got the following messages. (SW: software-dl.ti.com/.../index_FDS.html)
Does it mean encode/decode can't be done simultaneously ???
root@am57xx-evm:~# viddec3test -s 30:1920x1080 1080p.264 --fps 30 &
[1] 1296
root@am57xx-evm:~# 0x2c070: Opening Display..
Forcing playback rate at 30 fps.
using 1 connectors, 800x480 display, multiplanar: 1
0x2c070: Opening Demuxer..
videnc2test 1920 1080 10 1920x1080_nv12.yuv out.h264 15 2000 h264 baseline 41 OMAPDRM[h264 @ 0x2db40] Estimating duration from bitrate, this may be inaccurate
Input #0, h264, from '1080p.264':
Duration: N/A, bitrate: N/A
Stream #0.0: Video: h264 (High), yuv420p, 1920x1080, 25 fps, 25 tbr, 25 tbn, 60 tbc
0x2c070: infile=1080p.264, width=1920, height=1080
0x2c070: padded_width=2048, padded_height=1184, num_buffers=7
Setting mode 1920x1080 on connector 30, crtc 32
0x2c070: Opening Engine..
displayBufsMode: 1
/home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-linux-gnueabi/omapdrmtest/1.0.0-r8/git/videnc2test.c:1222: main info: Dumping frame 0
/home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-linux-gnueabi/omapdrmtest/1.0.0-r8/git/videnc2test.c:1222: main info: Dumping frame 1
/home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-linux-gnueabi/omapdrmtest/1.0.0-r8/git/videnc2test.c:1222: main info: Dumping frame 2
/home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-linux-gnueabi/omapdrmtest/1.0.0-r8/git/videnc2test.c:1222: main info: Dumping frame 3
/home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-linux-gnueabi/omapdrmtest/1.0.0-r8/git/videnc2test.c:1222: main info: Dumping frame 4
/home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-linux-gnueabi/omapdrmtest/1.0.0-r8/git/videnc2test.c:1222: main info: Dumping frame 5
/home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-linux-gnueabi/omapdrmtest/1.0.0-r8/git/videnc2test.c:1222: main info: Dumping frame 6
/home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-linux-gnueabi/omapdrmtest/1.0.0-r8/git/videnc2test.c:1222: main info: Dumping frame 7
/home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-linux-gnueabi/omapdrmtest/1.0.0-r8/git/videnc2test.c:1222: main info: Dumping frame 8
/home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-linux-gnueabi/omapdrmtest/1.0.0-r8/git/videnc2test.c:1222: main info: Dumping frame 9
/home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-linux-gnueabi/omapdrmtest/1.0.0-r8/git/videnc2test.c:1222: main info: Dumping frame 10
Encoding completed successfully
root@am57xx-evm:~# MmRpc_call: Error: write failed
ERROR:decoder_process:403: 0x2c070: process returned error: -5
ERROR:decoder_process:404: 0x2c070: extendedError: 00000000
/home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-linux-gnueabi/libdce/3.00.08.02-r0/git/libdce.c:745: process Error: ERROR: Failed eError == DCE_EOK error val -5MmRpc_release: Error: unable to release buffer
/home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-linux-gnueabi/libdce/3.00.08.02-r0/git/libdce_linux.c:145: dce_buf_unlock Error: ERROR: Failed eError == DCE_EOK error val -5MmRpc_call: Error: write failed
