Other Parts Discussed in Thread: SYSBIOS, CC2650, CC2640
I tried a rebuild today and it fails with the error below, I don't know when it stopped to work. Can anyone help?
I'm using IAR 7.40.3.8938
I'm compiling BLESimplePeripheral from TI.
I'm using tirtos_simplelink_2_13_00_06.
Raul
Preprocessing library source files ...
1 [main] sh 9028 C:\Program Files\Git\usr\bin\sh.exe: *** fatal error in forked process - fork: can't reserve memory for parent stack 0x600000 - 0x800000, (child has 0x400000 - 0x600000), Win32 error 487
410 [main] sh 9028 cygwin_exception::open_stackdumpfile: Dumping stack trace to sh.exe.stackdump
5 [main] sh 12360 fork: child -1 - forked process 9028 died unexpectedly, retry 0, exit code 0x100, errno 11
C:/Users/RAULOC~1/AppData/Local/Temp/make7012-1.sh: fork: retry: No child processes
1044952 [main] sh 13240 C:\Program Files\Git\usr\bin\sh.exe: *** fatal error in forked process - fork: can't reserve memory for parent stack 0x600000 - 0x800000, (child has 0x400000 - 0x600000), Win32 error 487
1045433 [main] sh 13240 cygwin_exception::open_stackdumpfile: Dumping stack trace to sh.exe.stackdump
3225536 [main] sh 12360 fork: child -1 - forked process 13240 died unexpectedly, retry 0, exit code 0x100, errno 11
5271570 [main] sh 13952 C:\Program Files\Git\usr\bin\sh.exe: *** fatal error in forked process - fork: can't reserve memory for parent stack 0x600000 - 0x800000, (child has 0x400000 - 0x600000), Win32 error 487
5271913 [main] sh 13952 cygwin_exception::open_stackdumpfile: Dumping stack trace to sh.exe.stackdump
6559935 [main] sh 12360 fork: child -1 - forked process 13952 died unexpectedly, retry 0, exit code 0x100, errno 11
10583841 [main] sh 13748 C:\Program Files\Git\usr\bin\sh.exe: *** fatal error in forked process - fork: can't reserve memory for parent stack 0x600000 - 0x800000, (child has 0x400000 - 0x600000), Win32 error 487
10584188 [main] sh 13748 cygwin_exception::open_stackdumpfile: Dumping stack trace to sh.exe.stackdump
11932550 [main] sh 12360 fork: child -1 - forked process 13748 died unexpectedly, retry 0, exit code 0x100, errno 11
19979228 [main] sh 10072 C:\Program Files\Git\usr\bin\sh.exe: *** fatal error in forked process - fork: can't reserve memory for parent stack 0x600000 - 0x800000, (child has 0x400000 - 0x600000), Win32 error 487
19979694 [main] sh 10072 cygwin_exception::open_stackdumpfile: Dumping stack trace to sh.exe.stackdump
22780149 [main] sh 12360 fork: child -1 - forked process 10072 died unexpectedly, retry 0, exit code 0x100, errno 11
C:/Users/RAULOC~1/AppData/Local/Temp/make7012-1.sh: fork: Resource temporarily unavailable
gmake[1]: *** [sysbios.arm3] Error 254
gmake[1]: Leaving directory `C:/git/holster/ble_CC2650/Projects/ble/Holster/CC26xx/IAR/Config/src/sysbios'
gmake: *** [C:/git/holster/ble_CC2650/Projects/ble/Holster/CC26xx/IAR/Config/src/sysbios/sysbios.arm3] Error 2
Build of libraries failed.
error: xdc.cfg.SourceDir: "C:/ti/xdctools_3_31_01_33_core/packages/xdc/cfg/SourceDir.xs", line 209: xdc.cfg.SourceDir : Build of generated source libraries failed: exit status = 2:
js: "C:/ti/xdctools_3_31_01_33_core/packages/xdc/cfg/Main.xs", line 160: Error: Configuration failed!
gmake.exe: *** [package/cfg/appBLE_prm3.xdl] Error 1
gmake.exe: *** Deleting file `package/cfg/appBLE_prm3.xdl'
gmake.exe: *** [package/cfg/appBLE_prm3.xdl] Deleting file `package/cfg/appBLE_prm3.h'
gmake.exe: *** [package/cfg/appBLE_prm3.xdl] Deleting file `package/cfg/appBLE_prm3.c'
js: "C:/ti/tirtos_simplelink_2_13_00_06/products/bios_6_42_00_08/packages/iar/tools/configuro/Main.xs", line 93: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
Error while running "c:/ti/xdctools_3_31_01_33_core/xs"
--xdcpath="c:/ti/tirtos_simplelink_2_13_00_06/packages;c:/ti/tirtos_simplelink_2_13_00_06/products/uia_2_00_02_39/packages;;c:/ti/tirtos_simplelink_2_13_00_06/products/bios_6_42_00_08/packages;" iar.tools.configuro -c "C:\
Program Files (x86)\IAR Systems\Embedded Workbench 7.2\arm" --cc "C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.2\arm\bin\iccarm.exe" --device "CC2640F128" --compileOptions "-D USE_ICALL -D
POWER_SAVING -D HEAPMGR_SIZE=2672 -D TI_DRIVERS_SPI_DMA_INCLUDED -D TI_DRIVERS_LCD_INCLUDED -D ICALL_MAX_NUM_TASKS=3 -D ICALL_MAX_NUM_ENTITIES=6 -D xdc_runtime_Assert_DISABLE_ALL -D
xdc_runtime_Log_DISABLE_ALL -D CC26XXWARE -D CC26XX --diag_suppress Pa050 -o C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640\FlashROM\Obj\ --debug --endian=little --cpu=Cortex-M3 -f C:\git\
holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640\..\..\..\..\..\..\..\Projects\ble\config\buildComponents.opt -f C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640\configPkg\
compiler.opt.defs -f C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640\..\..\Config\IAR-Boundary.bdef -e --fpu=None --dlib_config \"C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.2\arm\INC\c\
DLib_Config_Normal.h\" -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640/../../../Source/Application\ -I C:\git\holster\
ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640/../../../../../../../Projects/ble/Include\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640/../../../../../../../Projects/ble/ICall/Include\ -I C:\git\
holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640/../../../../../../../Projects/ble/Profiles/Roles/CC26xx\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\
CC2640/../../../../../../../Projects/ble/Profiles/Roles\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640/../../../../../../../Projects/ble/Profiles/DevInfo\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\
Application\CC2640/../../../../../../../Projects/ble/Profiles/SimpleProfile/CC26xx\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640/../../../../../../../Projects/ble/Profiles/SimpleProfile\ -I C:\git\holster\ble_CC2650\
Projects\ble\Holster\CC26xx\IAR\Application\CC2640/../../../../../../../Projects/ble/common/cc26xx\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640/../../../../../../../Components/applib/heap\ -I C:\git\holster\
ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640/../../../../../../../Components/ble/hci\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\
CC2640/../../../../../../../Components/ble/controller/CC26xx/include\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640/../../../../../../../Components/ble/host\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\
CC26xx\IAR\Application\CC2640/../../../../../../../Components/hal/target/CC2650/rom\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640/../../../../../../../Components/hal/target/CC2650TIRTOS\ -I C:\git\holster\
ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640/../../../../../../../Components/hal/target/_common/cc26xx\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\
CC2640/../../../../../../../Components/hal/include\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640/../../../../../../../Components/osal/include\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\
Application\CC2640/../../../../../../../Components/services/sdata\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640/../../../../../../../Components/services/saddr\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\
CC26xx\IAR\Application\CC2640/../../../../../../../Components/icall/include\ -I C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640/../../../../../../../Components/ble/include\ -I C:\ti\tirtos_simplelink_2_13_00_06\
products\cc26xxware_2_21_01_15600\ -I C:\ti\tirtos_simplelink_2_13_00_06\packages\ -I C:\ti\tirtos_simplelink_2_13_00_06\packages\ti\boards\SRF06EB\CC2650EM_7ID\ -Ohz" --linkOptions "-o C:\git\holster\ble_CC2650\Projects\ble\
Holster\CC26xx\IAR\Application\CC2640\FlashROM\Exe\SimpleBLEPeripheralAppFlashROM.out --map C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640\FlashROM\List\
SimpleBLEPeripheralAppFlashROM.map --config C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640\..\..\..\..\..\common\cc26xx\IAR\cc26xx_ble_app.icf --keep __vector_table -f C:\git\holster\ble_CC2650\
Projects\ble\Holster\CC26xx\IAR\Application\CC2640\configPkg\linker.cmd -f C:\git\holster\ble_CC2650\Projects\ble\Holster\CC26xx\IAR\Application\CC2640\..\..\Config\IAR-Boundary.xcl C:\ti\tirtos_simplelink_2_13_00_06\products\
cc26xxware_2_21_01_15600\driverlib\bin\iar\driverlib.lib C:\ti\tirtos_simplelink_2_13_00_06\packages\ti\drivers\lib\drivers_cc26xxware.arm3 --entry __iar_program_start --vfe" --profile release --projFile "C:\git\holster\ble_CC2650\
Projects\ble\Holster\CC26xx\IAR\Application\CC2640\CC2640App.ewp"
Total number of errors: 1
Total number of warnings: 0
