This conflict is expected between ndk and messageq.
< my.cfg file >
var MultiProc = xdc.useModule('ti.sdo.utils.MultiProc');
var nameList=[];// = MultiProc.getDeviceProcNames();
switch (Program.platformName)
case "ti.sdo.ipc.examples.platforms.evm6678.core0":
case "ti.platforms.evm6678":
nameList = ["CORE0", "CORE1", "CORE2", "CORE3"];
break;
default:
throw("Unsupported platform: " + Program.platformName); }
/* * Since this is a single-image example, we don't (at build-time) which * processor we're building for. We therefore supply 'null' * as the local procName and allow IPC to set the local procId at runtime. */
MultiProc.setConfig(null, nameList);
var Memory = xdc.useModule('xdc.runtime.Memory');
var Log = xdc.useModule('xdc.runtime.Log');
//var Error = xdc.useModule('xdc.runtime.Error');
var System = xdc.useModule('xdc.runtime.System');
var SysStd = xdc.useModule('xdc.runtime.SysStd');
System.SupportProxy = SysStd;
var BiosCache = xdc.useModule('ti.sysbios.hal.Cache');
var SysMin = xdc.useModule("xdc.runtime.SysMin");
System.SupportProxy = SysMin;
SysMin.bufSize = 0x8000;
/* Support for %f in printf */
System.extendedFormats = '%$L%$S%$F%f%g%e';
/* Modules explicitly used in the application */
var MessageQ = xdc.useModule('ti.sdo.ipc.MessageQ');
//MessageQ.SetupTransportProxy = xdc.useModule('ti.sdo.ipc.transports.TransportShmNotifySetup');
var Ipc = xdc.useModule('ti.sdo.ipc.Ipc');
var HeapBufMP = xdc.useModule('ti.sdo.ipc.heaps.HeapBufMP');
var Notify = xdc.useModule('ti.sdo.ipc.Notify');
var Timestamp = xdc.useModule('xdc.runtime.Timestamp');
var HeapBuf = xdc.useModule('ti.sysbios.heaps.HeapBuf');
var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
var heapMemParams = new HeapMem.Params();
heapMemParams.size = 0x8000000;
heapMemParams.sectionName = "systemHeapMaster";
Program.global.heap1 = HeapMem.create(heapMemParams);
Memory.defaultHeapInstance = Program.global.heap1;
Memory.defaultHeapSize = 0x10000;
//var LoggerCircBuf = xdc.useModule('ti.uia.runtime.LoggerCircBuf');
var Load = xdc.useModule('ti.sysbios.utils.Load');
var Diags = xdc.useModule('xdc.runtime.Diags');
//var Defaults = xdc.useModule('xdc.runtime.Defaults');
//var Main = xdc.useModule('xdc.runtime.Main');
CpuTimestamp = xdc.useModule('ti.uia.family.c66.TimestampC66XLocal');
GlobalTimestamp = xdc.useModule('ti.uia.family.c66.TimestampC66XGlobal');
LogSync = xdc.useModule('ti.uia.runtime.LogSync');
LogSync.GlobalTimestampProxy = GlobalTimestamp;
LogSync.CpuTimestampProxy = CpuTimestamp;
CpuTimestamp.maxTimerClockFreq = {lo:1000000000,hi:0};
CpuTimestamp.maxBusClockFreq = {lo:1000000000,hi:0};
GlobalTimestamp.maxTimerClockFreq = {lo:250000000,hi:0};
GlobalTimestamp.maxBusClockFreq = {lo:1000000000,hi:0};
GlobalTimestamp.cpuCyclesPerTick = 4;
var LoggerBuf = xdc.useModule('xdc.runtime.LoggerBuf');
var Exc = xdc.useModule('ti.sysbios.family.c64p.Exception');
Exc.common$.logger = LoggerBuf.create();
Exc.enablePrint = true;
var LoggingSetup = xdc.useModule('ti.uia.sysbios.LoggingSetup');
/* Increase the sysbios logger and turn Hwi and Swi logging off */
LoggingSetup.sysbiosLoggerSize = 32768;
LoggingSetup.mainLoggerSize = 8*1024;
LoggingSetup.loadLoggerSize = 32768;
LoggingSetup.loadLogging = true;
LoggingSetup.sysbiosTaskLogging = false;
LoggingSetup.sysbiosSwiLogging = false;
LoggingSetup.sysbiosHwiLogging = false;
LoggingSetup.eventUploadMode = LoggingSetup.UploadMode_NONJTAGTRANSPORT;
.....my.cfg --> continue
