When I call the function below:
/* Event init */ Event_construct(&Evt, ¶ms.ep);
It jumps directly to an error function that seems to be implying that it cannot allocate memory for this instance as if this is not being statically allocated:
/* construct */
void ti_sysbios_knl_Event_construct(ti_sysbios_knl_Event_Struct *__obj, const ti_sysbios_knl_Event_Params *__paramsPtr )
xdc_runtime_Error_raiseX(NULL, ti_sysbios_knl_Event_Module__id__C, NULL, 0, xdc_runtime_Error_E_generic, (xdc_IArg)"create policy error", 0);
However my configuration seems to be fine:
* SYSBIOS Modules
var BIOS = xdc.useModule('ti.sysbios.BIOS');
var HeapMem = xdc.module('ti.sysbios.heaps.HeapMem');
var halHwi = xdc.useModule('ti.sysbios.hal.Hwi');
var Event = xdc.useModule("ti.sysbios.knl.Event");
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
var Idle = xdc.useModule('ti.sysbios.knl.Idle');
var Task = xdc.useModule('ti.sysbios.knl.Task');
var Swi = xdc.useModule('ti.sysbios.knl.Swi');
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
/* No dynamic creation of modules during runtime */ Defaults.common$.memoryPolicy = Types.STATIC_POLICY;
And I already allocated memory for this instance:
static Event_Struct Evt;
So, can events only be used if dynamically allocated? Or is there something else I'm missing here?
Thanks!
George
