Hi All
We are working on a custom board right now that is based on DM8168 with EZSDK 5_05_02_00. We are trying to verify PAL output from IOUTD.
When we are trying the following command:
/usr/share/ti/ti-omx/decode_display_a8host_debug.xv5T -i /usr/share/ti/data/videos/dm816x_1080p_demo.264 -w 1920 -h 1080 -f 30 -g 0 -c h264 -d 0
We are getting the output on HDMI. But when we try with this command
/usr/share/ti/ti-omx/decode_display_a8host_debug.xv5T -i /usr/share/ti/data/videos/dm816x_1080p_demo.264 -w 1920 -h 1080 -f 30 -g 0 -c h264 -d 2
We are facing a problem:
/usr/share/ti/ti-omx/decode_display_a8host_debug.xv5T -i /usr/share/ti/data/videos/dm816x_1080p_demo.264 -w 1920 -h 1080 -f 30 -g 0 -c h264 - d 2
input file: /usr/share/ti/data/videos/dm816x_1080p_demo.264
width: 1920
height: 1080
frame_rate: 30
gfx: fbdev disable
codec: h264
display_id: 2
Decoder-Display example
OMX_Init completed
UIAClient is ready to send a UIA configuration command
UIAClient received UIA_CONFIGURE_ACK
UIAClient is done sending requests
opening file
decoder compoenent is created
PADX: 32 PADY: 24
level set is 12
scalar compoenent is created
set input port params (width = 1920, height = 1080)
set output port params (width = 736, height = 480)
set number of channels
set input resolution
set output resolution
enable scalar input port
got eventEnable/Disable Event
enable scalar output port
NF compoenent is created
enable NF input port
enable NF output port
found handle 0x13fb70 for component OMX.TI.VPSSM3.VFDC
got display handle
found handle 0x143b78 for component OMX.TI.VPSSM3.CTRL.DC
Buffer Size computed: 353280
setting input and output memory type to default
enable input port
connect call for decoder-scalar
connect call for scalar - nf
connect call for nf - display
decoder inport buffers allocated
decoder outport buffers allocated
got eventState changed to: OMX_StateIdle
decoder state IDLE
Scalar input port use buffer done
scalar outport buffers allocated
scalar state IDLE
Noise Filter input port use buffer done
Noise Filter outport buffers allocated
Noise Filter state IDLE
ctrl-dc state IDLE
display state IDLE
got eventState changed to: OMX_StateExecuting
display control state execute
got event*** unrecoverable error: OMX_ErrorBadParameter (0x80001005)
It used to work well with EVM. Can anyone suggest what can be the problem?
