I have multiple projects in the workspace to run on different cores in DRA7xx.
Some .cfg files open without any issue.
But two .cfg files on two different projects I get an error when I double click on them in CCS
But those two files are OK to open in a text editor outside CCS.
Could not open the editor: An unexpected exception was thrown.
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2846)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2797)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2777)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2768)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:655)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:614)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileAction.java:99)
at org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystemEditorAction.java:99)
at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:221)
at org.eclipse.ui.navigator.CommonNavigatorManager$3.open(CommonNavigatorManager.java:185)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:462)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
