Other Parts Discussed in Thread: TVP5158
Hi experts,
I followed the install guide (../DVRRDK_04.01.00.xx/DM81xx_DVR_RDK_Install_Guide.pdf) to run the demo application (capture+encode+decode+display).
After my try, it only displays TI logo on monitor since the video input could not be detected (I connected a SD video input on daughter board) , any ideas??
Thanks in advance !!!
loading kernel modules...
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
Kernel bootargs validated
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
: values=127,127
| dBscale-min=-63.50dB,step=0.50dB,mute=0
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff10820
[m3vpss ] Remote Debug Shared Memory @ 0xbff21040
SysLink version : 2.20.02.20
SysLink module created on Date:Oct 23 2013 Time:13:14:36
Trace enabled
Trace SetFailureReason enabled
Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 )
Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
*** TVP5158 probe : START ***
TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e
TI DVR : TVP5158 device address : 0x58, 0x59, 0x5a, 0x5b
Device found : I2C (0xXX): 0x08 = 0x51
I2C (0xXX): 0x09 = 0x58
Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x58): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5a): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5c): 0x08 = 0x02
I2C (0x5c): 0x09 = 0x80
I2C (0x5e): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x59): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5b): Read ERROR !!! (reg[0x08], count = 2)
*** TVP5158 probe : END ***
/opt/dvr_rdk/ti814x
loading executable file from M3....
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss_512M_128M.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
[m3vpss ] ISS Freq : 480 MHz
After Ipc_startcallback status [0x00000000]
[m3vpss ] ***** VPSS Firmware build time 13:27:33 Oct 23 2013 EDG gcc 3.0 mode
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 240000000
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 480000 Khz ***
[m3vpss ]
[m3vpss ] 43: SYSTEM : System Common Init in progress !!!
[m3vpss ] 44: SYSTEM: IPC init in progress !!!
[m3vpss ] 44: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 46: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3video_512M_128M.xem3 on slave procId 1.
Started slave procId 1.
[m3video] ISS Freq : 480 MHz
[m3video] ***** VIDEO Firmware build time 13:28:27 Oct 23 2013 EDG gcc 3.0 mode
[m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 240000000
[m3video]
[m3video] *** UTILS: CPU KHz = 480000 Khz ***
[m3video]
[m3video] 384: SYSTEM : System Common Init in progress !!!
[m3video] 384: SYSTEM: IPC init in progress !!!
[m3video] 384: SYSTEM: Attaching to [HOST] ...
[m3video] 387: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
Attached to slave procId 0.
Loaded file ../firmware/dvr_rdk_fw_c6xdsp_512M_128M.xe674 on slave procId 0.
Started slave procId 0.
[c6xdsp ] DSP Freq : 750 MHz
[m3video] 546: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3vpss ] 549: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3video] 551: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 551: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 551: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_1] ...
[m3vpss ] 551: SYSTEM: Creating MsgQ Heap DMA: Module install successful, device major num = 251
[IPC_MSGQ_MSG_HEDRV: Module install successful
AP_2] ...
[c6xDRV: Module built on Oct 23 2013 13:15:33
dsp ] ***** VIDEO Firmware build time 13:26:24 Oct 23 2013 EDG gcc 3.0 mode
[m3video] 551: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 551: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 500000000, <NEW> - 750000000
[m3video] 552: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 551: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[c6xdsp ]
[m3video] 553: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[m3vpss ] 553: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[c6xdsp ] *** UTILS: CPU KHz = 750000 Khz ***
[m3video] 554: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[m3vpss ] 554: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[c6xdsp ]
[m3video] 554: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[m3vpss ] 554: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[c6xdsp ] 1: SYSTEM : System Common Init in progress !!!
[m3video] 554: SYSTEM: IPC init DONE !!!
[m3vpss ] 554: SYSTEM: IPC init DONE !!!
[c6xdsp ] 1: SYSTEM: IPC init in progress !!!
[c6xdsp ] 1: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 4: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 6: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[c6xdsp ] 8: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[c6xdsp ] 8: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_0] ...
[c6xdsp ] 8: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[c6xdsp ] 8: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[c6xdsp ] 9: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[c6xdsp ] 9: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[c6xdsp ] 9: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[c6xdsp ] 9: SYSTEM: IPC init DONE !!!
[c6xdsp ] 11: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
[c6xdsp ] 11: MEM: ERROR: SharedRegion_setEntry (2, 0x8fcef2dc) FAILED !!! (status=-1)
[m3video] 561: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
[m3vpss ] 561: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
[m3video] 562: MEM: Shared Region 1: Base = 0x88000000, Length = 0x04f00000 (79 MB)
[m3vpss ] 561: MEM: Shared Region 1: Base = 0x88000000, Length = 0x04f00000 (79 MB)
[m3video] 564: SYSTEM : System Common Init Done !!!
[m3vpss ] 564: SYSTEM : System Common Init Done !!!
[m3video] 564: SYSTEM : System Video Init in progress !!!
[m3vpss ] 564: SYSTEM : System VPSS Init in progress !!!
[m3video] 564: SYSTEM : System Video Init Done !!!
[m3video] 565: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3video] 565: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3video] 565: SYSTEM: ListElem Shared Addr = 0xbf173e00
[m3video] 568: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 568: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 568: SYSTEM: ListElem Shared Addr = 0xbf177300
[m3video] 575: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
[m3video] 576: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
[m3video] 576: SYSTEM: ListElem Shared Addr = 0xbf17a800
[m3video] 579: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
[m3video] 579: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
[m3video] 579: SYSTEM: ListElem Shared Addr = 0xbf1a0000
[m3video] 582: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
[m3vpss ] === I2C0/2 Clk is active ===
[m3video] 582: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
[m3vpss ] 587: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[m3video] 582: SYSTEM: ListElem Shared Addr = 0xbf1c5800
[m3vpss ] 587: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3video] 599: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
[m3vpss ] 588: SYSTEM: ListElem Shared Addr = 0xbf1eb000
[m3video] 600: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 590: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3video] 600: SYSTEM: ListElem Shared Addr = 0xbf1f1a00
[m3vpss ] 591: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3video] 603: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 591: SYSTEM: ListElem Shared Addr = 0xbf1ee500
[m3video] 603: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 609: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
[m3video] 603: SYSTEM: ListElem Shared Addr = 0xbf210480
[m3vpss ] 609: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
[m3video] 605: HDVICP: Doing PRCM for IVAHD[0] ...
[m3vpss ] 609: SYSTEM: ListElem Shared Addr = 0xbf22ef00
[m3video] 606: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3vpss ] 612: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
[m3video] 607: UTILS: DMA: HWI Create for INT62 !!!
[m3vpss ] 612: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
[m3video] 607: SYSTEM : ISS Init in progress !!!
[m3vpss ] 612: SYSTEM: ListElem Shared Addr = 0xbf254700
[m3video] 608: SYSTEM : ISS Power-ON in progress !!!
[m3vpss ] 615: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
[m3video] 617: SYSTEM : ISS Power-ON in progress DONE !!!
[m3vpss ] 616: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
[m3video] 617: SYSTEM : ISS Init in progress DONE !!!
[m3vpss ] 616: SYSTEM: ListElem Shared Addr = 0xbf279f00
[m3video] 618: VCOP BOOST BIT is Set
[m3vpss ] 618: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3video] 618: SYSTEM : VCOP Init in progress !!!
[m3vpss ] 618: SYSTEM : FVID2 Init in progress !!!
[m3video] 618: SYSTEM : VCOP needs 172 B of memory !!!
[m3video] 619: SYSTEM : VCOP Init in progress DONE !!!
[m3video] 619: SYSTEM : Initializing Links !!!
[m3video] 620: SYSTEM : FREE SPACE : System Heap = 6263296 B, Mbx = 10240 msgs)
[m3vpss ] TILER_STATS: CNT :8BIT
[m3video] 620: SYSTEM : FREE SPACE : SR0 Heap = 6426368 B (6 MB)
[m3vpss ] TILER_STATS: CNT RESOLUTION: 16384 x 5440
[m3video] 620: SYSTEM : FREE SPACE : Frame Buffer = 117440384 B (111 MB)
[m3vpss ] TILER_STATS: BUCKET RESOLUTION: 16384 x 5436
[m3video] 620: SYSTEM : FREE SPACE : Bitstream Buffer = 82837376 B (78 MB)
[m3vpss ] TILER_STATS: NUM FREE BUCKETS: 1
[m3video] 620: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] TILER_STATS: NUM USED BUCKETS: 0
[m3video] 622: SYSTEM : FREE SPACE : Tiler 8-bit = 89063424 B (84 MB) - TILER ON
[m3vpss ] TILER_STATS: TOTAL FREE AREA: 89063424 (99 %)
[m3video] 622: SYSTEM : FREE SPACE : Tiler 16-bit = 44040192 B (42 MB) - TILER ON
[m3vpss ] TILER_STATS: TOTAL USED AREA: 0 (0 %)
[m3video] 682: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] Received character 's'
[m3video] Received character 's'
[m3vpss ] TILER_STATS: CNT :16BIT
[m3vpss ] TILER_STATS: CNT RESOLUTION: 32768 x 1344
[m3vpss ] TILER_STATS: BUCKET RESOLUTION: 32768 x 1344
[m3vpss ] TILER_STATS: TOTAL FREE AREA: 44040192 (100 %)
[m3vpss ] 699: SYSTEM : FVID2 Init in progress DONE !!!
[m3vpss ] 699: SYSTEM : Device Init in progress !!!
[m3vpss ] 787: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] HDVPSS Freq : 220 MHz
[m3vpss ] 833: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 834: UTILS: DMA: HWI Create for INT63 !!!
[m3vpss ] 835: SYSTEM : Initializing Links !!!
[m3vpss ] 835: SYSTEM : FREE SPACE : System Heap = 250280 B, Mbx = 10240 msgs)
[m3vpss ] 835: SYSTEM : FREE SPACE : SR0 Heap = 6426368 B (6 MB)
[m3vpss ] 835: SYSTEM : FREE SPACE : Frame Buffer = 113130368 B (107 MB)
[m3vpss ] 835: SYSTEM : FREE SPACE : Bitstream Buffer = 82837376 B (78 MB)
[m3vpss ] 837: SYSTEM : FREE SPACE : Tiler 8-bit = 89063424 B (84 MB) - TILER ON
[m3vpss ] 837: SYSTEM : FREE SPACE : Tiler 16-bit = 44040192 B (42 MB) - TILER ON
[m3vpss ] 985: SYSTEM : Initializing Links ... DONE !!!
[m3vpss ] 985: SYSTEM : Set Static L3 pressure for HDVPSS as High
[c6xdsp ] 1011: MEM: Shared Region 1: Base = 0x88000000, Length = 0x04f00000 (79 MB)
[c6xdsp ] 1011: SYSTEM : System Common Init Done !!!
[c6xdsp ] 1010: SYSTEM : System DSP Init in progress !!!
[c6xdsp ] 1010: SYSTEM : RpeServer_init() done... Ret Val 0!!!
[c6xdsp ] 1015: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
[c6xdsp ] 1015: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
[c6xdsp ] 1015: SYSTEM: ListElem Shared Addr = 0xbf29f700
[c6xdsp ] 1016: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
[c6xdsp ] 1016: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
[c6xdsp ] 1016: SYSTEM: ListElem Shared Addr = 0xbf2c4f00
[c6xdsp ] 1017: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
[c6xdsp ] 1017: SYSTEM: [module] vpss probe done.
Creating ListMP [DSP_IPC_IN_21] in region 0 ...
[c6xdsp ] 1017: SYSTEM: ListElem Shared Addr = 0xbf2ea700
[c6xdsp ] 1018: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[c6xdsp ] 1018: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[c6xdsp ] [module] ti81xxfb probe done.
1018: SYSTEM: ListElem Shared Addr = 0xbf30ff00
[c6xdsp ] 1019: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[c6xdsp ] 1019: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[c6xdsp ] 1019: SYSTEM: ListElem Shared Addr = 0xbf32e980
[c6xdsp ]HDMI W1 rev 4.0
!!WARNING.ResouHDMI CEC Spec version 1.2
rce already registered:2
[c6xdsp ] 1019: SYSTEM : Initializing Links !!!
[c6xdsp ] 1020: SYSTEM : FREE SPACE : System Heap = 6393472 B, Mbx = 10240 msgs)
[c6xdsp ] Received character 's'
/opt/dvr_rdk/ti814x
[c6xdsp ] 1032: SYSTEM : Initializing Links ... DONE !!!
[c6xdsp ] 1032: SYSTEM : System DSP Init Done !!!
ORG 0x46c00524: 0
NEW 0x46c00524: 2
running A8 applications...
Main Menu
1: 4CH VCAP + VENC + VDEC + VDIS - Progressive SD Encode + Decode
2: 8CH <D1+CIF> VCAP + VENC + VDEC + VDIS - Progressive SD Encode + Decode
3: 16CH RT VCAP + VENC + VDEC + VDIS - Progressive SD Encode + Decode
4: 16CH NRT <D1+CIF> VCAP + VENC + VDEC + VDIS - Progressive SD Encode + Decode
5: VDEC + VDIS - SD/HD Decode ONLY
e: Exit
Enter Choice: 1
--------------- CHANNEL DETAILS-------------
Capture Channels => 4
Enc Channels => Primary 4, Secondary 4
Dec Channels => 4
Disp Channels => 8
0: SYSTEM: System Common Init in progress !!!
0: SYSTEM: IPC init in progress !!!
11: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
11: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
11: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
11: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
11: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_3] ...
13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
14: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
16: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
16: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
17: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
18: SYSTEM: Notify register to [DSP] line 0, event 15 ...
18: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
19: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
19: SYSTEM: IPC init DONE !!!
20: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
22: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
23: SYSTEM: ListElem Shared Addr = 0x40713680
24: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
26: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
27: SYSTEM: ListElem Shared Addr = 0x4074a480
28: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
30: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
31: SYSTEM: ListElem Shared Addr = 0x40781280
32: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
34: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
35: SYSTEM: ListElem Shared Addr = 0x407c4580
36: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
38: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
39: SYSTEM: ListElem Shared Addr = 0x40807880
57: SYSTEM: System Common Init Done !!!
[host] HDMI Ctrl :Initializing
[HOST]
ThreadName:Vdis_hdmiControlThread_0,ThreadID:682
[host] HDMI Ctrl :Initialized
[host] HDMI Ctrl :Sink Connected
Enable file write (YES - y / NO - n) : y
File write ENABLED !!!
Enter file write path : /home /root/encode
Selected file write path [/home/root/encode]
[host] Partition Free Size for Path[/home/root/encode/VBITS_HDR_0_LAYER_0.bin] = [0x17113320]
[host] Max File size per channel:0x3D83330
[HOST]
ThreadName:VcapVencVdecVdis_ipcBitsRecvFxn,ThreadID:683
AUDIO: Do you enable Audio <Y/N>: [FBDEV]
[FBDEV] FB: Starting !!!
[FBDEV] FB: Opened device [/dev/fb0] (fd=406) !!!
[FBDEV]
[FBDEV] Fix Screen Info
[FBDEV] ---------------
[FBDEV] Line Length - 1600
[FBDEV] Physical Address = 86a00000
[FBDEV] Buffer Length = 2097152
[FBDEV]
[FBDEV]
[FBDEV] Var Screen Info
[FBDEV] Xres - 800
[FBDEV] Yres - 600
[FBDEV] Xres Virtual - 800
[FBDEV] Yres Virtual - 600
[FBDEV] Bits Per Pixel - 16
[FBDEV] Pixel Clk - 6734
[FBDEV] Rotation - 0
[FBDEV]
[FBDEV]
[FBDEV] Reg Params Info
[FBDEV] region 0, postion 0 x 0, prioirty 1
[FBDEV] first 1, last 1
[FBDEV] sc en 1, sten en 0
[FBDEV] tran en 1, type 0, key 16777215
[FBDEV] blend 0, alpha 0
[FBDEV] bb en 0, alpha 0
[FBDEV]
[FBDEV]
[FBDEV] ### BUF SIZE = 960000 Bytes !!!
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV] Xres - 800
[FBDEV] Yres - 600
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV]
[FBDEV] grpx_fb_draw ...
[FBDEV] grpx_fb_draw ... Done !!!
[FBDEV] FB: Start DONE !!!
[FBDEV]
********* Entered usecase 4CH <814x> Enc/Dec OSD Enabled SCD Enabled
16145: MCFW : CPU Revision [ES2.1] !!!
VCAP: DEVICE-0 (0x58): Device not found !!!
[m3vpss ] 212576: CAPTURE: Create in progress !!!
[m3vpss ] 212609: CAPTURE: VIP0 PortA capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 58 (58)
[m3vpss ] UTILS: DMA: 0 of 4: Allocated PaRAM = 58 (0x49004740)
[m3vpss ] UTILS: DMA: 1 of 4: Allocated PaRAM = 64 (0x49004800)
[m3vpss ] UTILS: DMA: 2 of 4: Allocated PaRAM = 65 (0x49004820)
[m3vpss ] UTILS: DMA: 3 of 4: Allocated PaRAM = 66 (0x49004840)
[m3vpss ] CAPTURE::HEAPID:0 USED:328
[m3vpss ] CAPTURE::HEAPID:4 USED:17713152
[m3vpss ] 212684: CAPTURE: Create Done !!!
[m3vpss ] 212684: DEI : Create in progress !!!
[m3vpss ] DEI: Ch 0, Outformat is PROGRESSIVE
[m3vpss ] 212700: DEI: OUT0: 0: Format: PROGRESSIVE, 0xb9500c80, 704 x 480, 4 frames
[m3vpss ] DEI: Ch 1, Outformat is PROGRESSIVE
[m3vpss ] 212715: DEI: OUT0: 1: Format: PROGRESSIVE, 0xb9794c80, 704 x 480, 4 frames
[m3vpss ] DEI: Ch 2, Outformat is PROGRESSIVE
[m3vpss ] 212730: DEI: OUT0: 2: Format: PROGRESSIVE, 0xb9a28c80, 704 x 480, 4 frames
[m3vpss ] DEI: Ch 3, Outformat is PROGRESSIVE
[m3vpss ] 212744: DEI: OUT0: 3: Format: PROGRESSIVE, 0xb9cbcc80, 704 x 480, 4 frames
[m3vpss ] 212756: DEI: OUT1: 0: Format: PROGRESSIVE, 0xb9f50c80, 704 x 480, 4 frames
[m3vpss ] 212767: DEI: OUT1: 1: Format: PROGRESSIVE, 0xba13fc80, 704 x 480, 4 frames
[m3vpss ] 212778: DEI: OUT1: 2: Format: PROGRESSIVE, 0xba32ec80, 704 x 480, 4 frames
[m3vpss ] 212789: DEI: OUT1: 3: Format: PROGRESSIVE, 0xba51dc80, 704 x 480, 4 frames
[m3vpss ] 212792: DEI: OUT2: 0: Format: PROGRESSIVE, 0xba70cc80, 352 x 240, 4 frames
[m3vpss ] 212795: DEI: OUT2: 1: Format: PROGRESSIVE, 0xba788880, 352 x 240, 4 frames
[m3vpss ] 212798: DEI: OUT2: 2: Format: PROGRESSIVE, 0xba804480, 352 x 240, 4 frames
[m3vpss ] 212801: DEI: OUT2: 3: Format: PROGRESSIVE, 0xba880080, 352 x 240, 4 frames
[m3vpss ] 212808: DEI : Loading Up-scaling Co-effs
[m3vpss ] 212808: DEI : Co-effs Loading ... DONE !!!
[m3vpss ] DEI:HEAPID:0 USED:64
[m3vpss ] DEI:HEAPID:1 USED:9600
[m3vpss ] DEI:HEAPID:4 USED:21626880
[m3vpss ] 212808: DEI : Create Done !!!
[m3vpss ] 212813: DUP: 0: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 212813: DUP: 1: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 212813: DUP: 2: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 212813: DUP: 3: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 212815: DUP : Create Done !!!
[m3vpss ] 212815: NSF: Create in progress !!!
[m3video] 212865: IPC_IN_M3 : Create in progress !!!
[m3video] 212866: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3vpss ] NSF::HEAPID:0 USED:128
[m3video] 212866: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3vpss ] NSF::HEAPID:1 USED:9152
[m3video] 212869: IPC_IN_M3 : Create Done !!!
[m3vpss ] NSF::HEAPID:4 USED:8110080
[m3video] 212869: ALG : Create in progress !!!
[m3vpss ] 212860: NSF: Create Done !!!
[m3vpss ] 212861: MERGE: 0: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 212861: MERGE: 1: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 212861: MERGE: 2: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 212862: MERGE: 3: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 212862: MERGE: 4: Format: PROGRESSIVE, 352 x 240
[m3vpss ] 212862: MERGE: 5: Format: PROGRESSIVE, 352 x 240
[m3vpss ] 212862: MERGE: 6: Format: PROGRESSIVE, 352 x 240
[m3vpss ] 212862: MERGE: 7: Format: PROGRESSIVE, 352 x 240
[m3vpss ] 212863: MERGE: 8: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 212863: MERGE: 9: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 212863: MERGE: 10: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 212863: MERGE: 11: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 212864: MERGE : Create Done !!!
[m3vpss ] 212864: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 212865: IPC_OUT_M3 : Create Done !!!
[m3video] 212882: ALG : Prev Link ID = 10000002 !!!
[m3video] 212883: OSD: Opening algorithm ... !!!
[m3video] 212896: OSD: Opening algorithm ... DONE !!!
[m3video] UTILS: DMA: Allocated CH (TCC) = 51 (51)
[m3video] UTILS: DMA: 0 of 8: Allocated PaRAM = 51 (0x49004660)
[m3video] UTILS: DMA: 1 of 8: Allocated PaRAM = 479 (0x49007BE0)
[m3video] UTILS: DMA: 2 of 8: Allocated PaRAM = 480 (0x49007C00)
[m3video] UTILS: DMA: 3 of 8: Allocated PaRAM = 481 (0x49007C20)
[m3video] UTILS: DMA: 4 of 8: Allocated PaRAM = 482 (0x49007C40)
[m3video] UTILS: DMA: 5 of 8: Allocated PaRAM = 483 (0x49007C60)
[m3video] UTILS: DMA: 6 of 8: Allocated PaRAM = 484 (0x49007C80)
[m3video] UTILS: DMA: 7 of 8: Allocated PaRAM = 485 (0x49007CA0)
[m3video] 212914: SCD: Opening algorithm ... !!!
[m3video] 212914: SCD: Opening algorithm ... DONE !!!
[m3video] UTILS: DMA: Allocated CH (TCC) = 56 (56)
[m3video] UTILS: DMA: 0 of 1: Allocated PaRAM = 56 (0x49004700)
[m3video] ALGLINK:HEAPID:0 USED:30672
[m3video] ALGLINK:HEAPID:3 USED:6294656
[m3video] 212933: ALG : Create Done !!!
[m3video] 212936: ENCODE: Create in progress ... !!!
[m3video] ENCLINK:INFO: !!!Number of output buffers for ch[8] set to [1]
[m3video] 212968: ENCODE: Creating CH0 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps, I-P Interval 1...
[m3video] ENCLINK_H264:HEAPID:0 USED:13888
[m3video] ENCLINK_H264:HEAPID:3 USED:2244608
[m3video] 212983: ENCODE: Creating CH1 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps, I-P Interval 1...
[m3video] ENCLINK_H264:HEAPID:0 USED:11912
[m3video] ENCLINK_H264:HEAPID:3 USED:1511424
[m3video] 212993: ENCODE: Creating CH2 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps, I-P Interval 1...
[host] IpcBitsInLink_tskMain:Entered[HOST]
ThreadName:IpcBitsInLink_tskMain_3000001a,ThreadID:672
[host] 16607: IPC_BITS_IN : Create in progress !!!
[host] 16607: IPC_BITS_IN : ListMPOpen start !!!
[host] 16607: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_24] ...
16609: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_24] ...
[host] 16610: IPC_BITS_IN : ListMPOpen done !!!
[host] 16611: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 16612: IPC_BITS_IN : Create Done !!!
[HOST]
ThreadName:IpcBitsInLink_periodicTaskFxn_3000001a,ThreadID:684
========bitsProducerLinkInfo============
numQ 1, numCh 12
Ch [0] Width 704, Height 480
Ch [1] Width 704, Height 480
Ch [2] Width 704, Height 480
Ch [3] Width 704, Height 480
Ch [4] Width 352, Height 240
Ch [5] Width 352, Height 240
Ch [6] Width 352, Height 240
Ch [7] Width 352, Height 240
Ch [8] Width 704, Height 480
Ch [9] Width 704, Height 480
Ch [10] Width 704, Height 480
Ch [11] Width 704, Height 480
Reducing bitsProducerLinkInfo.numCh to 4
[HOST]
ThreadName:IpcBitsOutLink_tskMain_30000018,ThreadID:674
[host] 16612: IPC_BITS_OUT : Create in progress !!!
[host] IPC_BITSOUT:BitBuffer Alloc.ChID:0,Size:0x14A000
[host]
******* RingBuf 0 created ********
[host] IPCBITSOUTLINK:Translated Addr Virt:0x41171d80 To Phy:0x8852cd80
[host]
###Bit buff of size from the SR # 1 : 1351680 / bufsize 337920, maxQueueDepth 50
[host] ###Bit buff BasePtr: 41171D80 / PhyAddr 8852CD80
[host] IPC_BITSOUT:BitBuffer Alloc.ChID:1,Size:0x14A000
[host]
******* RingBuf 1 created ********
[host] IPCBITSOUTLINK:Translated Addr Virt:0x412bbd80 To Phy:0x88676d80
[host]
[host] ###Bit buff BasePtr: 412BBD80 / PhyAddr 88676D80
[host] IPC_BITSOUT:BitBuffer Alloc.ChID:2,Size:0x14A000
[host]
******* RingBuf 2 created ********
[host] IPCBITSOUTLINK:Translated Addr Virt:0x41405d80 To Phy:0x887c0d80
[host]
[host] ###Bit buff BasePtr: 41405D80 / PhyAddr 887C0D80
[host] IPC_BITSOUT:BitBuffer Alloc.ChID:3,Size:0x14A000
[host]
******* RingBuf 3 created ********
[host] IPCBITSOUTLINK:Translated Addr Virt:0x4154fd80 To Phy:0x8890ad80
[host]
[host] ###Bit buff BasePtr: 4154FD80 / PhyAddr 8890AD80
[host] 16949: IPC_BITS_OUT : Create Done !!!
[HOST]
ThreadName:IpcBitsOutLink_periodicTaskFxn_30000018,ThreadID:685
[m3video] 213002: ENCODE: Creating CH3 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps, I-P Interval 1...
[m3video] 213012: ENCODE: Creating CH4 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED ], bitrate = 500 Kbps, I-P Interval 1...
[m3video] ENCLINK_H264:HEAPID:3 USED:503808
[m3video] 213017: ENCODE: Creating CH5 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED ], bitrate = 500 Kbps, I-P Interval 1...
[m3video] 213021: ENCODE: Creating CH6 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED ], bitrate = 500 Kbps, I-P Interval 1...
[m3video] 213025: ENCODE: Creating CH7 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED ], bitrate = 500 Kbps, I-P Interval 1...
[m3video] 213030: ENCODE: Creating CH8 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps, I-P Interval 0...
[m3video] ENCLINK_JPEG:HEAPID:0 USED:2064
[m3video] 213030: ENCODE: Creating CH9 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps, I-P Interval 0...
[m3vpss ] 213504: IPC_IN_M3 : Create in progress !!!
[m3vpss ] 213504: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[m3video] 213031: ENCODE: Creating CH10 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps, I-P Interval 0...
[m3vpss ] 213504: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[m3vpss ] 213505: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 213507: IPC_IN_M3 : Create Done !!!
[m3vpss ] 213508: MERGE: 0: Format: PROGRESSIVE, 704 x 480
[m3video] 213032: ENCODE: Creating CH11 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps, I-P Interval 0...
[m3vpss ] 213508: MERGE: 1: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213508: MERGE: 2: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213508: MERGE: 3: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213509: MERGE: 4: Format: PROGRESSIVE, 704 x 480
[m3video] 213033: ENCODE: All CH Create ... DONE !!!
[m3vpss ] 213509: MERGE: 5: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213509: MERGE: 6: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213509: MERGE: 7: Format: PROGRESSIVE, 704 x 480
[m3video] ENCLINK:HEAPID:0 USED:105568
[m3vpss ] 213509: MERGE : Create Done !!!
[m3video] ENCLINK:HEAPID:2 USED:5426432
[m3video] ENCLINK:HEAPID:3 USED:8794112
[m3video] 213034: ENCODE: Create ... DONE !!!
[m3video] 213034: IPC_BITS_OUT : Create in progress !!!
[m3vpss ] 213514: DUP: 0: Format: PROGRESSIVE, 704 x 480
[m3video] 213036: IPC_BITS_OUT : Create Done !!!
[m3vpss ] 213514: DUP: 1: Format: PROGRESSIVE, 704 x 480
[m3video] 213379: IPC_BITS_IN : Create in progress !!!
[m3vpss ] 213514: DUP: 2: Format: PROGRESSIVE, 704 x 480
[m3video] 213380: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...
[m3vpss ] 213514: DUP: 3: Format: PROGRESSIVE, 704 x 480
[m3video] 213380: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...
[m3vpss ] 213514: DUP: 4: Format: PROGRESSIVE, 704 x 480
[m3video] 213381: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[m3vpss ] 213514: DUP: 5: Format: PROGRESSIVE, 704 x 480
[m3video] 213383: IPC_BITS_IN : Create Done !!!
[m3vpss ] 213514: DUP: 6: Format: PROGRESSIVE, 704 x 480
[m3video] 213384: DECODE: Create in progress ... !!!
[m3vpss ] 213515: DUP: 7: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213516: DUP : Create Done !!!
[m3vpss ] 213516: SWMS: Create in progress !!!
[m3video] DECLINK_H264:HEAPID:0 USED:2368
[m3video] DECLINK_H264:HEAPID:3 USED:1249280
[m3video] 213412: DECODE: Creating CH0 of 704 x 480 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 213441: DECODE: Creating CH1 of 704 x 480 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 213468: DECODE: Creating CH2 of 704 x 480 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 213496: DECODE: Creating CH3 of 704 x 480 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 213498: DECODE: All CH Create ... DONE !!!
[m3video] DECLINK:HEAPID:0 USED:9512
[m3video] DECLINK:HEAPID:3 USED:19447808
[m3video] 213502: DECODE: Create ... DONE !!!
[m3video] 213502: IPC_OUT_M3 : Create in progress !!!
[m3video] 213503: IPC_OUT_M3 : Create Done !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 59 (59)
[m3vpss ] UTILS: DMA: 0 of 1: Allocated PaRAM = 59 (0x49004760)
[m3vpss ] SWMS: instance 0, sc id 7, start win 0 end win 17
[m3vpss ] 213702: SWMS : VipScReq is FALSE!!!
[m3vpss ] 213705: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 213706: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 213706: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ] AVSYNC:WARNING!! Application wrongly configureddisplayID[-1]. Reseting to correct displayID[0]
[m3vpss ] 213707: SWMS: 0: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213707: SWMS: 1: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213707: SWMS: 2: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213707: SWMS: 3: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213707: SWMS: 4: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213707: SWMS: 5: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213707: SWMS: 6: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213707: SWMS: 7: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213708: SWMS : ******* Configuring clock 15 secs...
[m3vpss ] 213708: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 213708: SWMS0 : Loading Horizontal Co-effs (10/16)x ...
[m3vpss ] 213708: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Parameters ***
[m3vpss ]
[m3vpss ] Output FPS: 60
[m3vpss ]
[m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Scan | Low Cost | SWMS | Data | Blank |
[m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Fmt | ON / OFF | Inst | Format| Frame |
[m3vpss ] ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 0 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 0, 0 | 480 x 270 | 3840 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 422I | OFF |
[m3vpss ] 1 | 1 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 480, 0 | 480 x 270 | 3840 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 422I | OFF |
[m3vpss ] 2 | 2 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 960, 0 | 480 x 270 | 3840 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 422I | OFF |
[m3vpss ] 3 | 3 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 1440, 0 | 480 x 270 | 3840 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 422I | OFF |
[m3vpss ] 4 | 4 | 0, 0 | 704 x 240 | 1792 / 1792 | NON-TILED | 0, 270 | 480 x 270 | 3840 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 420SP | OFF |
[m3vpss ] 5 | 5 | 0, 0 | 704 x 240 | 1792 / 1792 | NON-TILED | 480, 270 | 480 x 270 | 3840 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 420SP | OFF |
[m3vpss ] 6 | 6 | 0, 0 | 704 x 240 | 1792 / 1792 | NON-TILED | 960, 270 | 480 x 270 | 3840 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 420SP | OFF |
[m3vpss ] 7 | 7 | 0, 0 | 704 x 240 | 1792 / 1792 | NON-TILED | 1440, 270 | 480 x 270 | 3840 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 420SP | OFF |
[m3vpss ] 8 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 0, 540 | 480 x 270 | 3840 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
[m3vpss ] 9 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 480, 540 | 480 x 270 | 3840 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
[m3vpss ] 10 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 960, 540 | 480 x 270 | 3840 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
[m3vpss ] 11 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 1440, 540 | 480 x 270 | 3840 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
[m3vpss ] 12 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 0, 810 | 480 x 270 | 3840 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
[m3vpss ] 13 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 480, 810 | 480 x 270 | 3840 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
[m3vpss ] 14 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 960, 810 | 480 x 270 | 3840 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
[m3vpss ] 15 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 1440, 810 | 480 x 270 | 3840 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
[m3vpss ]
[m3vpss ] SWMS:HEAPID:0 USED:224
[m3vpss ] SWMS:HEAPID:1 USED:13024
[m3vpss ] SWMS:HEAPID:3 USED:4147200
[m3vpss ] SWMS:HEAPID:4 USED:29030400
[m3vpss ] 213715: SWMS: Create Done !!!
[m3vpss ] 213716: SWMS: Create in progress !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 60 (60)
[m3vpss ] UTILS: DMA: 0 of 1: Allocated PaRAM = 60 (0x49004780)
[m3vpss ] SWMS: instance 0, sc id 5, start win 0 end win 17
[m3vpss ] 213764: SWMS1 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 213764: SWMS1 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 213764: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ] AVSYNC:WARNING!! Application wrongly configureddisplayID[-1]. Reseting to correct displayID[2]
[m3vpss ] 213765: SWMS: 0: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213765: SWMS: 1: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213766: SWMS: 2: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213766: SWMS: 3: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213766: SWMS: 4: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213766: SWMS: 5: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213766: SWMS: 6: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213766: SWMS: 7: Format: PROGRESSIVE, 704 x 480
[m3vpss ] 213766: SWMS : ******* Configuring clock 15 secs...
[m3vpss ] 213766: SWMS1 : Loading Vertical Co-effs (7/16)x ...
[m3vpss ] 213766: SWMS1 : Loading Horizontal Co-effs (3/16)x ...
[m3vpss ] 213767: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ] *** [SWMS1] Mosaic Parameters ***
[m3vpss ]
[m3vpss ]
[m3vpss ] 0 | 0 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 0, 0 | 176 x 120 | 1472 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 422I | OFF |
[m3vpss ] 1 | 1 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 176, 0 | 176 x 120 | 1472 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 422I | OFF |
[m3vpss ] 2 | 2 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 352, 0 | 176 x 120 | 1472 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 422I | OFF |
[m3vpss ] 3 | 3 | 0, 0 | 704 x 240 | 2816 / 2816 | NON-TILED | 528, 0 | 192 x 120 | 1472 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 422I | OFF |
[m3vpss ] 4 | 4 | 0, 0 | 704 x 240 | 1792 / 1792 | NON-TILED | 0, 120 | 176 x 120 | 1472 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 420SP | OFF |
[m3vpss ] 5 | 5 | 0, 0 | 704 x 240 | 1792 / 1792 | NON-TILED | 176, 120 | 176 x 120 | 1472 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 420SP | OFF |
[m3vpss ] 6 | 6 | 0, 0 | 704 x 240 | 1792 / 1792 | NON-TILED | 352, 120 | 176 x 120 | 1472 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 420SP | OFF |
[m3vpss ] 7 | 7 | 0, 0 | 704 x 240 | 1792 / 1792 | NON-TILED | 528, 120 | 192 x 120 | 1472 / 0 | NON-TILED | PROGRESSIVE | ON | 0 | 420SP | OFF |
[m3vpss ] 8 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 0, 240 | 176 x 120 | 1472 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
[m3vpss ] 9 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 176, 240 | 176 x 120 | 1472 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
[m3vpss ] 10 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 352, 240 | 176 x 120 | 1472 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
DEMO: No video detected at CH [0] !!!
[m3vpss ] 11 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 528, 240 | 192 x 120 | 1472 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
[m3vpss ] 12 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 0, 360 | 176 x 120 | 1472 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
[m3vpss ] 13 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 176, 360 | 176 x 120 | 1472 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
[m3vpss ] 14 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 352, 360 | 176 x 120 | 1472 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
[m3vpss ] 15 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 528, 360 | 192 x 120 | 1472 / 0 | NON-TILED | INTERLACE | ON | 0 | 422I | OFF |
[m3vpss ]
DEMO: No video detected at CH [1] !!!
DEMO: No video detected at CH [2] !!!
DEMO: No video detected at CH [3] !!!
[HOST]
ThreadName:Demo_run,ThreadID:669
Run-Time Menu
1: Capture Settings
2: Encode Settings
3: Decode Settings
4: Display Settings
5: Audio Capture <TVP5158> & Encode <AAC-LC, G711> demo
6: Change Playback Channel <valid only if capture/playback is active>
7: Audio encode demo <File In/Out>
8: Audio decode demo <File In/Out>
c: Change 8CH modes (8CH usecase ONLY!!!!)
d: Change 16CH modes (16CH usecase ONLY!!!!)
i: Print detailed system information
s: Core Status: Active/In-active
e: Stop Demo
Enter Choice: [m3vpss ] SWMS:HEAPID:0 USED:224
[m3vpss ] SWMS:HEAPID:1 USED:47296
[m3vpss ] SWMS:HEAPID:3 USED:5087232
[m3vpss ] SWMS:HEAPID:4 USED:1695744
[m3vpss ] 213774: SWMS: Create Done !!!
[m3vpss ] 213774: DISPLAY: Create in progress !!!
[m3vpss ] 213776: DISPLAY: Create Done !!!
[m3vpss ] 213776: DISPLAY: Create in progress !!!
[m3vpss ] 213777: DISPLAY: 44: Field Separate Mode ENABLED for Que 0 !!!
[m3vpss ] 213778: DISPLAY: Create Done !!!
[m3vpss ] 213785: DISPLAY: Start in progress !!!
[m3vpss ] 213848: DISPLAY: Start Done !!!
[m3vpss ] 213848: DISPLAY: HDDAC(BP0) : 31 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 8947 / 0 ) !!!
[m3vpss ] 213848: DISPLAY DRV: HDDAC(BP0) : Q:[2] Display:[2], Repeat:[1], DQ:[0]
[m3vpss ] 213848: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 0, DVO2(BP1) 1, SDDAC(SEC1) 1
[m3vpss ] 213848: SYSTEM : FREE SPACE : System Heap = 243120 B, Mbx = 10238 msgs)
[m3vpss ] 213848: SYSTEM : FREE SPACE : SR0 Heap = 1914880 B (1 MB)
[m3vpss ] 213849: SYSTEM : FREE SPACE : Frame Buffer = 417536 B (0 MB)
[m3vpss ] 213849: SYSTEM : FREE SPACE : Bitstream Buffer = 62769792 B (59 MB)
[m3vpss ] 213849: DISPLAY: Start in progress !!!
[m3vpss ] 213851: SYSTEM : FREE SPACE : Tiler 8-bit = 89063424 B (84 MB) - TILER ON
[m3vpss ] 213851: SYSTEM : FREE SPACE : Tiler 16-bit = 44040192 B (42 MB) - TILER ON
[m3vpss ] 213889: DISPLAY: Start Done !!!
[m3vpss ] 213890: DISPLAY: SDDAC(SEC1): 24 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) DropCount:0 DispLatency (Min / Max) = ( 8947 / 0 ) !!!
[m3vpss ] 213890: SWMS: Start in Progress !!!
[m3vpss ] 213890: SWMS: Start Done !!!
[m3vpss ] 213890: DISPLAY DRV: SDDAC(SEC1): Q:[2] Display:[1], Repeat:[0], DQ:[0]
[m3vpss ] 213891: SWMS: Start Done !!!
[m3vpss ] 214492: CAPTURE: Start in progress !!!
[m3vpss ] 214591: CAPTURE: Enabled Time Stamping !!!
[m3vpss ] 214599: CAPTURE: Start Done !!!
[HOST]
ThreadName:SystemLink_tskMain_3000003f,ThreadID:681
DEMO: HDMI TV/Monitor connected !!!
DEMO: TV Detected - HDMI interface !!!
DEMO: INFO : Resolution set to 1080P60 !!!
[HOST]
Run-Time Menu
1: Capture Settings
2: Encode Settings
3: Decode Settings
4: Display Settings
e: Stop Demo
Enter Choice: 1
Capture Settings Menu
1: Disable channel
2: Enable channel
3: OSD Window position
4: OSD Window size
5: OSD Window transparency
6: OSD Window global alpha
7: OSD Window enable/disable
8: Detect video
9: Dynamic resolution change
a: SCD mode selection
b: SCD Tamper sensitivity
e: Live Motion Detection (LMD) Configuration
f: BlindArea/PrivacyMask Configuration
g: Print SCD frame status
h: SCD/VA Graphics Event Display Enable/Disable
i: SCD/VA Graphics Event Display Enable/Disable all Channels
j: Capture Input Resolution Change
k: Update SCD Analytics Config
l: Print SCD Analytics Config of All Channels
p: Previous Menu
Enter Choice: 8
DEMO: 0: No video detected at CH [0,0] !!!
DEMO: 1: No video detected at CH [0,1] !!!
DEMO: 2: No video detected at CH [0,2] !!!
DEMO: 3: No video detected at CH [0,3] !!!
