When target is restarted, it is not booting up and on console we could see the kernel restarting continuously as shown in the below log. Tried reflashing the SOM after this problem but even after reflashing also the problem appears again.
NAND: 128 MiB
MMC: davinci: 0
SF: Detected W25Q64 with page size 256, total 8 MiB
In: serial
Out: serial
Err: serial
ARM Clock : 300000000 Hz
DDR Clock : 150000000 Hz
Net: Ethernet PHY: GENERIC @ 0x00
DaVinci-EMAC
Hit any key to stop autoboot: 3 2 1 0
NAND read: device 0 offset 0x20000, size 0x1b0b44
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
1772356 bytes read: OK
## Booting kernel from Legacy Image at c0700000 ...
Image Name: Linux-2.6.37
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1772292 Bytes = 1.7 MiB
Load Address: c0008000
Entry Point: c0008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
resetting ...
NAND: 128 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
DaVinci-EMAC
OK
Starting kernel ...
resetting ...
NAND: 128 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
DaVinci-EMAC
OK
Starting kernel ...
resetting ...
NAND: 128 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
DaVinci-EMAC
OK
Starting kernel ...
resetting ...
NAND: 128 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
DaVinci-EMAC
OK
Starting kernel ...
resetting ...
NAND: 128 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
DaVinci-EMAC
OK
Starting kernel ...
resetting ...
NAND: 128 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
DaVinci-EMAC
OK
Starting kernel ...
resetting ...
NAND: 128 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
DaVinci-EMAC
OK
Starting kernel ...
resetting ...
NAND: 128 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
DaVinci-EMAC
OK
Starting kernel ...
resetting ...
Mounika
