power manager in 5510
hi
I'm trying to use the automatic power management in 5510. i followed the instructions of an old lab training instructions about 5510 from TI, where they mentioned the following steps:
1- add a power down function:
void powerDown(void)
PWR_powerDown(PWR_WAKEUP_MI);
2- turn on power configuration manager, and only check the CPU check box
3- create IDLE thread that calls the create function above.
when i did those steps all what comes out is a sound like a fast Woodpecker. my original project just takes audio in and gets it out using McBSP-DMA, by HWI and SWI.
when i uncheck the CPU in the power configuration, it gives normal results (sound), even if all the other check boxes are checked...
any suggestions?
       Could you pl let me know, what did you mean by “automatic power management in 5510” ? Additional details on your requirements will help.
     Vasanth
  • Hi Vasanth
    automatic Power Management (APM) is a feature designed into every C55x and operates in the background to help in power reduction, but that is not what i meant...
    i think i used the wrong words here, what i meant that i used BIOS GUI to automatically IDLE the domains i select in the power configuration, without manually controlling  the registers, via the three steps i mentioned earlier.
    sorry for the confusing use of words
    best regards
    aziz
