Hi:
c5515 evm + ads1298 works fine with 5V DC in,but change to use battery, it don't work (ads1298 may not work),we have set JP39 to BAT ,are there any other jumpers or switches should be set ?
thanks!
Hi:
thanks!
Did you check the voltage on TP23 ?
JP39 needs to be set to BAT mode, and SW5 needs to be in ON .
If voltage is right, then try use EVM in standalone mode and check whether you are able to connect through JTAG.
Vasanth
