rvmLink usecase problem in DM8127 IPNC RDK 3.8
Hello everyone!
      I'm new with DM817 IPNC RDK 3.8 .
      I want to creat a alg running on DSP and add it to usecase. I have heard that neither OSD nor SCD DSP algorithm were not tested in IPNC RDK. Fortunately then I found there is a usecase in ipnc_rdk\ipnc_mcfw\mcfw\src_linux\mcfw_api\usecases\multich_rvm.c . So I intend to refer to this usecase. But when I ran this usecase by NFS, there was an error:
[c6xdsp ] 6882: Assertion @ Line: 117 in links_c6xdsp/rvm/rvmLink_tsk.c: rvmLutPrm.errorCode == 0 : failed !!!   ,which made me quite disappointed.
      Here is error log:
U-Boot 2010.06 (Mar 19 2014 - 14:57:42) DM8127_IPNC_3.80.00
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk:  200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
DRAM:  512 MiB
DCACHE:  Off
NAND:  HW ECC BCH8 Selected
256 MiB
Using default environment
The 2nd stage U-Boot will now be auto-loaded
Please do not interrupt the countdown till TI8148_EVM prompt if 2nd stage is already flashed
Hit any key to stop autoboot:  0
NAND read: device 0 offset 0x20000, size 0x40000
 262144 bytes read: OK
## Starting application at 0x81000000 ...
U-Boot 2010.06 (Mar 19 2014 - 15:00:10) DM8127_IPNC_3.80.00
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
L3 clk:  200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
I2C:   ready
DRAM:  512 MiB
DCACHE:  On
256 MiB
MMC:   OMAP SD/MMC: 0, ON-BOARD SDIO: 1
                          .:;rrr;;.
                    ,5#@@@@#####@@@@@@#2,
                 ,A@@@hi;;;r5;;;;r;rrSG@@@A,
               r@@#i;:;s222hG;rrsrrrrrr;ri#@@r
             :@@hr:r;SG3ssrr2r;rrsrsrsrsrr;rh@@:
            B@H;;rr;3Hs;rrr;sr;;rrsrsrsrsrsr;;H@B
           @@s:rrs;5#;;rrrr;r#@H:;;rrsrsrsrsrr:s@@
          @@;;srs&X#9;r;r;;,2@@@rrr:;;rrsrsrsrr;;@@
         @@;;rrsrrs@MB#@@@@@###@@@@@@#rsrsrsrsrr;;@@
        G@r;rrsrsr;#X;SX25Ss#@@#M@#9H9rrsrsrsrsrs;r@G
        @9:srsrsrs;2@;:;;:.X@@@@@H::;rrsrsrsrsrsrr:3@
       X@;rrsrsrsrr;XAi;;:&@@#@Bs:rrsrsrsrsrsrsrsrr;@X
       @#;rsrsrsrsrr;r2ir@@@###::rrsrsrsrsrsrsrsrsr:@@
       @A:rrsrsrsrr;:2@29@@M@@@;:;rrrrsrsrsrsrsrsrs;H@
       @&;rsrsrsrr;A@@@@@@###@@@s::;:;;rrsrsrsrsrsr;G@
       @#:rrsrsrsr;G@5Hr25@@@#@@@#9XG9s:rrrrsrsrsrs:#@
       M@;rsrsrsrs;r@&#;::S@@@@@@@M@@@@Grr:;rsrsrsr;@#
       :@s;rsrsrsrr:M#Msrr;;&#@@@@@@@@@@H@@5;rsrsr;s@,
        @@:rrsrsrsr;S@rrrsr;:;r3MH@@#@M5,S@@irrsrr:@@
         @A:rrsrsrsrrrrrsrsrrr;::;@##@r:;rH@h;srr:H@
         ;@9:rrsrsrsrrrsrsrsrsr;,S@Hi@i:;s;MX;rr:h@;
          r@B:rrrrsrsrsrsrsrr;;sA@#i,i@h;r;S5;r:H@r
           ,@@r;rrrsrsrsrsrr;2BM3r:;r:G@:rrr;;r@@,
             B@Mr;rrrrsrsrsr@@S;;;rrr:5M;rr;rM@H
              .@@@i;;rrrrsrs2i;rrrrr;r@M:;i@@@.
                .A@@#5r;;;r;;;rrr;r:r#AsM@@H.
                   ;&@@@@MhXS5i5SX9B@@@@G;
                       :ihM#@@@@@##hs,
Date: 2012-11-10 (Saturday)    Time:  7:41:47
Net:   Detected MACID:0:c:c:a0:ff:fa
cpsw
Booting from NFS...
Loading from nand0, offset 0x280000
   Image Name:   Linux-2.6.37_DM8127_IPNC_3.80.00
   Created:      2014-03-19   7:17:56 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2493804 Bytes = 2.4 MiB
   Load Address: 80008000
   Entry Point:  80008000
## Booting kernel from Legacy Image at 81000000 ...
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37_DM8127_IPNC_3.80.00 (root@localhost.localdomain) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 Wed Mar 19 15:17:39 CST 2014
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148ipnc
vram size = 4194304 at 0x0
bootconsole [earlycon0] enabled
ti81xx_reserve: ### Reserved DDR region @84f00000
reserved size = 4194304 at 0x0
FB: Reserving 4194304 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 2.1
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 19040
Kernel command line: console=ttyO0,115200n8 root=/dev/nfs rw mem=80M vram=4M notifyk.vpssm3_sva=0xBFD00000 nfsroot=192.168.1.200:/home/zfang/yze/dm8127-ipnc/Source/ipnc_rdk/target/filesys,nolock eth=00:0C:0C:A0:FF:FA ip=192.168.1.224 cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 earlyprintk
cpsw: kernel boot params Ethernet address: 00:0C:0C:A0:FF:FA
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 74MB 1MB = 75MB total
Memory: 70660k/70660k available, 11260k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xc5800000 - 0xf8000000   ( 808 MB)
    lowmem  : 0xc0000000 - 0xc5000000   (  80 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc003e000   ( 216 kB)
      .text : 0xc003e000 - 0xc04bf000   (4612 kB)
      .data : 0xc04c0000 - 0xc05005c0   ( 258 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 599.65 BogoMIPS (lpj=2998272)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
TI81XX: Map 0x84f00000 to 0xfe500000 for dram barrier
TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
_omap_mux_init_gpio: Could not set gpio79
_omap_mux_init_gpio: Could not set gpio80
Cannot clk_get ck_32
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
PWM0 init success.
PWM1 init success.
bio: create slab <bio-0> at 0
SCSI subsystem initialized
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
regulator: VRTC: 1800 mV
regulator: VIO: 1500 mV
regulator: VDD1: 600 <--> 1500 mV at 1100 mV
regulator: VDD2: 600 <--> 1500 mV at 1350 mV
regulator: VDDCTRL: 600 <--> 1400 mV at 1200 mV
regulator: LDO1: 1100 <--> 3300 mV at 1800 mV
regulator: LDO2: 1100 <--> 3300 mV at 1800 mV
regulator: LDO3: 1100 <--> 3300 mV at 3300 mV
regulator: LDO4: 1100 <--> 3300 mV at 1800 mV
regulator: LDO5: 1100 <--> 3300 mV at 3300 mV
regulator: LDO6: 1100 <--> 3300 mV at 3300 mV
regulator: LDO7: 1100 <--> 3300 mV at 3300 mV
regulator: LDO8: 1100 <--> 3300 mV at 1800 mV
tps65911-rtc tps65911-rtc: rtc core: registered tps65911-rtc as rtc0
tps65910 1-002d: No interrupt support, no core IRQ
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, peripheral, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
usb2phy: computed values rxcalib(15)DACs(29 14 15)
usb2phy: override computed values rxcalib(15)DACs(29 14 15)
usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f6edd7e
musb-hdrc musb-hdrc.0: USB Peripheral mode controller at c581e000 using DMA, IRQ 18
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 138
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
CMEMK module: built on Mar 19 2014 at 15:03:44
  Reference Linux version 2.6.37
  File /opt/workdir/DM8127_DM385_Ver3_8/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xc7000000 of size 0x4000000
cmemk initialized
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled, bootconsole disabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
omap2-nand driver initializing
ONFI param page 0 valid
ONFI flash detected
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron NAND 256MiB 3,3V 16-bit)
omap2-nand: detected x16 NAND flash
Creating 8 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x0000006c0000 : "Kernel"
0x0000006c0000-0x000006fc0000 : "File System"
0x000006fc0000-0x000007bc0000 : "Data"
0x000007bc0000-0x00000b0c0000 : "File System2"
0x00000b0c0000-0x000010000000 : "Reserved"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
Linux video capture interface: v2.00
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0xbfd00000
cm: Module associated with clock hdmi_i2s_fck didn't enable in 100000 tries
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
  #0: TI8148 IPNC
nf_conntrack version 0.5.0 (1104 buckets, 4416 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 17
Bridge firewalling registered
lib80211: common routines for IEEE802.11 drivers
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=0:c:c:a0:ff:fa
tps65911-rtc tps65911-rtc: setting system clock to 2012-11-10 07:41:54 UTC (1352533314)
CPSW phy found : id is : 0x4dd074
PHY 0:01 not found
mmc1: new high speed SD card at address 0002
mmcblk0: mmc1:0002 00000 1.86 GiB
 mmcblk0: p1 p2 p3
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Complete:
     device=eth0, addr=192.168.1.224, mask=255.255.255.0, gw=255.255.255.255,
     host=192.168.1.224, domain=, nis-domain=(none),
     bootserver=255.255.255.255, rootserver=192.168.1.200, rootpath=
PHY: 0:00 - Link is Up - 100/Full
VFS: Mounted root (nfs filesystem) on device 0:14.
devtmpfs: mounted
Freeing init memory: 216K
INIT: version 2.86 booting
Please wait: booting...
Starting udev
end_request: I/O error, dev mtdblock3, sector 112
Buffer I/O error on device mtdblock3, logical block 14
end_request: I/O error, dev mtdblock1, sector 72
Root filesystem already rw, not remounting
Caching udev devnodes
root: mount: mounting /dev/root on / failed: No such file or directory
NOT configuring network interfaces: / is an NFS mount
rm: cannot remove '/tmp': Device or resource busy
 inside finish.sh
UBI: attaching mtd5 to ubi0
UBI: physical eraseblock size:   131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: sub-page size:              512
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
UBI: max. sequence number:       7033
UBI: attached mtd5 to ubi0
UBI: MTD device name:            "Data"
UBI: MTD device size:            12 MiB
UBI: number of good PEBs:        96
UBI: number of bad PEBs:         0
UBI: number of corrupted PEBs:   0
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:     1
UBI: available PEBs:             0
UBI: total number of reserved PEBs: 96
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 80/74
UBI: image sequence number:  -933717115
UBI: background thread "ubi_bgt0d" started, PID 274
UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
UBIFS: file system size:   10285056 bytes (10044 KiB, 9 MiB, 81 LEBs)
UBIFS: journal size:       1015809 bytes (992 KiB, 0 MiB, 6 LEBs)
UBIFS: media format:       w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root:  485787 bytes (474 KiB)
UBI: attaching mtd7 to ubi1
UBI: max. sequence number:       854
UBI: attached mtd7 to ubi1
UBI: MTD device name:            "Reserved"
UBI: MTD device size:            79 MiB
UBI: number of good PEBs:        634
UBI: total number of reserved PEBs: 634
UBI: number of PEBs reserved for bad PEB handling: 6
UBI: max/mean erase counter: 3/2
UBI: image sequence number:  525766228
UBI: background thread "ubi_bgt1d" started, PID 286
UBI device number 1, total 634 LEBs (80502784 bytes, 76.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
UBIFS: file system size:   78090240 bytes (76260 KiB, 74 MiB, 615 LEBs)
UBIFS: journal size:       3936256 bytes (3844 KiB, 3 MiB, 31 LEBs)
UBIFS: reserved for root:  3688395 bytes (3601 KiB)
numid=1,iface=MIXER,name='PCM Playback Volume'
  ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
  : values=127,127
  | dBscale-min=-63.50dB,step=0.50dB,mute=0
 [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
 [m3video] Remote Debug Shared Memory @ 0xbff05020
 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.21.02.10
SysLink module created on Date:Mar  6 2016 Time:15:59:51
Trace enabled
Trace SetFailureReason enabled
/dev/mem opened.
             Phy Addr : 0x48181560 Data : 0x00000002
secss put in low power state
             Phy Addr : 0x48180f10 Data : 0x00000000
             Phy Addr : 0x48180508 Data : 0x00000302
             Phy Addr : 0x48180520 Data : 0x00000002
             Phy Addr : 0x48180524 Data : 0x00000002
             Phy Addr : 0x48180528 Data : 0x00000002
             Phy Addr : 0x4c0000e4 Data : 0x00170208
             Phy Addr : 0x4d0000e4 Data : 0x00170208
DDR IOs RX is shutdown
Creat queue id:0
queue id:0
FileMngThread created
Creat queue id:32769
queue id:32769
AlramThread created
Share memory init success
 [host]  Setting DMM priority for [ISS     ] to [0] ( 0x4e000634 = 0x00080000 )
Creat queue id:65538
queue id:65538
Creat queue id:98307
queue id:98307
queue id:32769
 [host]  Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
 [host]  Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
 [host]  Setting L3 bandwidth regulator for [ISS     ] to [press=[3,3] BW=400, WM Cycles=2500]
 [host] Attached to slave procId 2.
 [host] Attached to slave procId 1.
 [host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 2.
 [host] Started slave procId 2.
 [host] Attached to slave procId 0.
 [host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 1.
 [host] Started slave procId 1.
 [host] After Ipc_loadcallback status [0x00000000]
 [m3video] ***** SYSTEM  : Frequency <ORG> - 200000000, <NEW> - 200000000
 [m3vpss ] ***** SYSTEM  : Frequency <ORG> - 200000000, <NEW> - 200000000
 [m3video]
 [m3vpss ] notify_attach  rtnVal  0
 [m3video]  *** UTILS: CPU KHz = 400000 Khz ***
 [m3vpss ] initProxyServer  rtnVal  0
 [m3video]
 [m3vpss ]
 [m3video]  45: SYSTEM  : System Common Init in progress !!!
 [m3vpss ]  *** UTILS: CPU KHz = 400000 Khz ***
 [m3video]  45: SYSTEM: IPC init in progress !!!
 [m3vpss ]
 [m3video]  45: SYSTEM: Attaching to [HOST] ...
 [m3vpss ]  73: SYSTEM  : System Common Init in progress !!!
 [m3vpss ]  74: SYSTEM: IPC init in progress !!!
 [m3vpss ]  74: SYSTEM: Attaching to [HOST] ...
 [host] Loaded file ./firmware/ipnc_rdk_fw_c6xdsp.xe674 on slave procId 0.
 [host] Started slave procId 0.
 [c6xdsp ] ***** SYSTEM  : Frequency <ORG> - 500000000, <NEW> - 500000000
 [m3video]  95: SYSTEM: Attaching to [HOST] ...
 [c6xdsp ]
 [c6xdsp ]  *** UTILS: CPU KHz = 500000 Khz ***
 [c6xdsp ]
 [c6xdsp ]  1: SYSTEM  : System Common Init in progress !!!
 [c6xdsp ]  1: SYSTEM: IPC init in progress !!!
 [c6xdsp ]  1: SYSTEM: Attaching to [HOST] ...
 [host] After Ipc_startcallback status [0x00000000]
 [c6xdsp ]  51: SYSTEM: Attaching to [HOST] ...
 [m3video]  122: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3vpss ]  124: SYSTEM: Attaching to [HOST] ...
 [c6xdsp ]  76: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3video]  122: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  174: SYSTEM: Attaching to [HOST] ...
 [c6xdsp ]  76: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3video]  172: SYSTEM: Attaching to [DSP] ...
 [m3vpss ]  191: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
 [m3vpss ]  191: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  125: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3video]  222: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  128: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [m3video]  222: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [c6xdsp ]  128: SYSTEM: Attaching to [VPSS-M3] ...
 [m3video]  223: SYSTEM: Attaching to [VPSS-M3] ...
 [m3vpss ]  241: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  177: SYSTEM: Attaching to [VPSS-M3] ...
 [m3video]  272: SYSTEM: Attaching to [VPSS-M3] ...
 [c6xdsp ]  196: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  291: SYSTEM: Attaching to [DSP] ...
 [c6xdsp ]  196: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3vpss ]  291: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
 [m3vpss ]  291: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3video]  322: SYSTEM: Attaching to [VPSS-M3] ...
 [m3video]  342: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
 [m3vpss ]  342: SYSTEM: Attaching to [VIDEO-M3] ...
 [m3video]  342: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3vpss ]  342: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
 [m3video]  343: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
 [m3vpss ]  342: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [m3video]  343: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
 [m3vpss ]  343: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
 [m3video]  345: SYSTEM: Notify register to [HOST] line 0, event 12 ...
 [m3vpss ]  343: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
 [m3video]  346: SYSTEM: Notify register to [DSP] line 0, event 12 ...
 [m3vpss ]  345: SYSTEM: Notify register to [HOST] line 0, event 12 ...
 [m3video]  346: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
 [m3vpss ]  345: SYSTEM: Notify register to [DSP] line 0, event 12 ...
 [m3video]  346: SYSTEM: IPC init DONE !!!
 [m3vpss ]  346: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
 [m3vpss ]  346: SYSTEM: IPC init DONE !!!
 [m3video]  357: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
 [m3vpss ]  357: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
 [m3video]  357: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
 [m3vpss ]  357: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
 [m3video]  359: SYSTEM  : System Common Init Done !!!
 [m3vpss ]  359: SYSTEM  : System Common Init Done !!!
 [m3vpss ] Received character 's'
 [c6xdsp ]  296: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [c6xdsp ]  296: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
 [c6xdsp ]  296: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
 [m3video] Received character 's'
 [c6xdsp ]  297: SYSTEM: Notify register to [HOST] line 0, event 12 ...
 [c6xdsp ]  297: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
 [c6xdsp ]  297: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
 [c6xdsp ]  297: SYSTEM: IPC init DONE !!!
 [c6xdsp ]  301: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
 [c6xdsp ]  301: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
 [c6xdsp ]  301: SYSTEM  : System Common Init Done !!!
 [c6xdsp ] Received character 's'
queue id:65538
Creat queue id:131076
queue id:131076
CPU is TI812x
    IPNC BUILD VERSION: IPNC RDK VERSION 03.80.00.05 (FULL FEATURE)
DEMOCFG Value   : 0
Videocodecmode  : 8
Videocodecres   : 0
streamtype      : 2
 vsenable : 0
./bin/ipnc_rdk_mcfw.out   VNF_QUALITY TRISTREAM TRIPLE_H264 TI2A AEWB 1080P_D1 H264 HIGH_SPEED1 H264 HIGH_SPEED2 MJPEG 80 &
Error: SemWait: Invalid Semaphore handler
Error: SemRelease: Invalid Semaphore handler
Creat queue id:163845
queue id:163845
queue id:65538
 [m3vpss ]  659: SYSTEM  : System VPSS Init in progress !!!
ApproDrvInit: 7
queue id:163845
 [m3vpss ] === I2C0/2 Clk is active ===
 [m3vpss ]  677: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
 [m3vpss ]  678: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
 [m3vpss ]  678: SYSTEM: ListElem Shared Addr = 0xbe98b680
 [m3vpss ]  680: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
 [m3vpss ]  681: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
 [m3vpss ]  681: SYSTEM: ListElem Shared Addr = 0xbe98eb80
 [c6xdsp ]  600: SYSTEM  : System DSP Init in progress !!!
 [m3vpss ]  694: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
 [m3vpss ]  694: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
 [m3vpss ]  695: SYSTEM: ListElem Shared Addr = 0xbe992080
 [m3vpss ]  697: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
 [m3vpss ]  698: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
 [m3vpss ]  698: SYSTEM: ListElem Shared Addr = 0xbe9b1a80
 [c6xdsp ]  606: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
 [m3vpss ]  700: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
 [c6xdsp ]  606: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
 [m3vpss ]  701: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
 [c6xdsp ]  606: SYSTEM: ListElem Shared Addr = 0xbe9d1780
 [m3vpss ]  701: SYSTEM: ListElem Shared Addr = 0xbe9f0e80
 [c6xdsp ]  607: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
 [m3vpss ]  707: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
 [c6xdsp ]  607: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
 [m3vpss ]  708: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
 [c6xdsp ]  607: SYSTEM: ListElem Shared Addr = 0xbea10880
 [m3vpss ]  708: SYSTEM: ListElem Shared Addr = 0xbea83580
 [c6xdsp ]  608: SYSTEM: Creating ListMP [DSP_IPC_OUT_26] in region 0 ...
 [m3vpss ]  710: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
 [c6xdsp ]  609: SYSTEM: Creating ListMP [DSP_IPC_IN_26] in region 0 ...
 [m3vpss ]  711: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
 [c6xdsp ]  609: SYSTEM: ListElem Shared Addr = 0xbea30280
 [c6xdsp ]  610: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ...
 [c6xdsp ]  610: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ...
 [c6xdsp ]  610: SYSTEM: ListElem Shared Addr = 0xbea4fc80
 [c6xdsp ]  611: SYSTEM: Creating ListMP [DSP_IPC_OUT_30] in region 0 ...
 [c6xdsp ]  611: SYSTEM: Creating ListMP [DSP_IPC_IN_30] in region 0 ...
 [c6xdsp ]  611: SYSTEM: ListElem Shared Addr = 0xbea69900
 [c6xdsp ] !!WARNING.Resource already registered:2
 [c6xdsp ]  611: SYSTEM  : Initializing Links !!!
 [m3vpss ]  711: SYSTEM: ListElem Shared Addr = 0xbea9d200
 [c6xdsp ]  613: SYSTEM  : FREE SPACE : System Heap      = 6282440 B, Mbx = 10240 msgs)
 [m3vpss ]  713: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
 [m3vpss ]  713: SYSTEM  : FVID2 Init in progress !!!
 [c6xdsp ]  627: SYSTEM  : Initializing Links ... DONE !!!
 [c6xdsp ]  627: SYSTEM  : System DSP Init Done !!!
 [m3video]  759: SYSTEM  : System Video Init in progress !!!
 [m3video]  760: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
 [m3video]  760: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
 [m3video]  760: SYSTEM: ListElem Shared Addr = 0xbeab6e80
 [m3video]  763: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
 [m3video]  763: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
 [m3video]  763: SYSTEM: ListElem Shared Addr = 0xbeaba380
 [m3video]  773: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
 [m3video]  773: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
 [m3video]  774: SYSTEM: ListElem Shared Addr = 0xbeabd880
 [m3video]  776: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
 [m3video]  776: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
 [m3video]  777: SYSTEM: ListElem Shared Addr = 0xbead7500
 [m3video]  779: HDVICP: Doing PRCM for IVAHD[0] ...
 [m3video]  779: HDVICP: PRCM for IVAHD[0] ... DONE.
 [m3video]  780: SYSTEM  : Initializing Links !!!
 [m3video]  780: SYSTEM  : FREE SPACE : System Heap      = 6282072 B, Mbx = 10240 msgs)
 [m3vpss ]  784: SYSTEM  : FVID2 Init in progress DONE !!!
 [m3vpss ]  784: SYSTEM  : Device Init in progress !!!
 [m3video]  780: SYSTEM  : FREE SPACE : SR0 Heap         = 14742656 B (14 MB)
 [m3vpss ]  Iss_init called !!!!!!
 [m3vpss ]  CPIS_init DONE !!!!!!
 [m3video]  781: SYSTEM  : FREE SPACE : Frame Buffer     = 110100352 B (104 MB)
 [m3vpss ] initPrms.isI2cInitReq = 1
 [m3video]  781: SYSTEM  : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
 [m3video]  781: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 [m3video]  782: SYSTEM  : FREE SPACE : Tiler Buffer     = 128 B (0 MB)  - TILER OFF
 [m3video] Entered the MctnfLink_init()
 [m3video]  841: SYSTEM  : Initializing Links ... DONE !!!
 [m3video]  841: SYSTEM  : System Video Init Done !!!
 [m3vpss ]  Vps_deviceInit Daughter card not detected/connected!
 [m3vpss ]  I2C2: Passed for address 0x36 !!!
 [m3vpss ]  I2C2: Passed for address 0x55 !!!
 [m3vpss ]  3518: SYSTEM  : Device Init in progress DONE !!!
 [m3vpss ]  3546: SYSTEM  : System VPSS Init Done !!!
 [m3vpss ]  3546: UTILS: DMA: HWI Create for INT62 !!!
 [m3vpss ]  3547: SYSTEM  : Initializing Links !!!
 [m3vpss ]  3547: SYSTEM  : FREE SPACE : System Heap      = 1677496 B, Mbx = 10240 msgs)
 [m3vpss ]  3547: SYSTEM  : FREE SPACE : SR0 Heap         = 14742656 B (14 MB)
 [m3vpss ]  3547: SYSTEM  : FREE SPACE : Frame Buffer     = 105790336 B (100 MB)
 [m3vpss ]  3548: SYSTEM  : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
 [m3vpss ]  3548: SYSTEM  : FREE SPACE : Tiler Buffer     = 128 B (0 MB)  - TILER OFF
 [m3vpss ] Received character 't'
 [m3vpss ]  3681: SYSTEM  : Initializing Links ... DONE !!!
 [m3video] Received character 't'
 [c6xdsp ] Received character 't'
DMA: Module install successful, device major num = 248
DRV: Module install successful
DRV: Module built on Mar  6 2016 16:20:32
HDMI W1 rev 4.0
HDMI CEC Spec version 1.2
 [host]
 [host]  ORG 0x46c00524: 0
 [host]  NEW 0x46c00524: 2
 [host]
 [host] Application Start Completed
 [host] Vdis_setDefaultConfig >> ----------- Device: 0
 [host]
CHANNEL | WINDOW | ENABLE(1)/DISABLE(0)
 [host]       0 |      0 |      1
 [host]       1 |      1 |      1
 [host]       2 |      2 |      1
 [host]       3 |      3 |      1
 [host]       4 |      4 |      1
 [host]       5 |      5 |      1
 [host]       6 |      6 |      1
 [host]       7 |      7 |      1
 [host]       8 |      8 |      1
 [host]       9 |      9 |      1
 [host]      10 |     10 |      1
 [host]      11 |     11 |      1
 [host]      12 |     12 |      1
 [host]      13 |     13 |      1
 [host]      14 |     14 |      1
 [host]      15 |     15 |      1
 [host]      16 |     16 |      1
 [host]      17 |     17 |      1
 [host]      18 |     18 |      1
 [host]      19 |     19 |      1
 [host]      20 |     20 |      1
 [host]      21 |     21 |      1
 [host]      22 |     22 |      1
 [host]      23 |     23 |      1
 [host]      24 |     24 |      1
 [host]      25 |     25 |      1
 [host]      26 |     26 |      1
 [host]      27 |     27 |      1
 [host]      28 |     28 |      1
 [host]      29 |     29 |      1
 [host]      30 |     30 |      1
 [host]      31 |     31 |      1
 [host] Vdis_setDefaultConfig >> ----------- Device: 1
 [host]
 [host]       0 |      0 |      1
 [host]       1 |      1 |      1
 [host]       2 |      2 |      1
 [host]       3 |      3 |      1
 [host]       4 |      4 |      1
 [host]       5 |      5 |      1
 [host]       6 |      6 |      1
 [host]       7 |      7 |      1
 [host]       8 |      8 |      1
 [host]       9 |      9 |      1
 [host]      10 |     10 |      1
 [host]      11 |     11 |      1
 [host]      12 |     12 |      1
 [host]      13 |     13 |      1
 [host]      14 |     14 |      1
 [host]      15 |     15 |      1
 [host]      16 |     16 |      1
 [host]      17 |     17 |      1
 [host]      18 |     18 |      1
 [host]      19 |     19 |      1
 [host]      20 |     20 |      1
 [host]      21 |     21 |      1
 [host]      22 |     22 |      1
 [host]      23 |     23 |      1
 [host]      24 |     24 |      1
 [host]      25 |     25 |      1
 [host]      26 |     26 |      1
 [host]      27 |     27 |      1
 [host]      28 |     28 |      1
 [host]      29 |     29 |      1
 [host]      30 |     30 |      1
 [host]      31 |     31 |      1
 [host] Vdis_setDefaultConfig >> ----------- Device: 2
 [host]
 [host]       0 |      0 |      1
 [host]       1 |      1 |      1
 [host]       2 |      2 |      1
 [host]       3 |      3 |      1
 [host]       4 |      4 |      1
 [host]       5 |      5 |      1
 [host]       6 |      6 |      1
 [host]       7 |      7 |      1
 [host]       8 |      8 |      1
 [host]       9 |      9 |      1
 [host]      10 |     10 |      1
 [host]      11 |     11 |      1
 [host]      12 |     12 |      1
 [host]      13 |     13 |      1
 [host]      14 |     14 |      1
 [host]      15 |     15 |      1
 [host]      16 |     16 |      1
 [host]      17 |     17 |      1
 [host]      18 |     18 |      1
 [host]      19 |     19 |      1
 [host]      20 |     20 |      1
 [host]      21 |     21 |      1
 [host]      22 |     22 |      1
 [host]      23 |     23 |      1
 [host]      24 |     24 |      1
 [host]      25 |     25 |      1
 [host]      26 |     26 |      1
 [host]      27 |     27 |      1
 [host]      28 |     28 |      1
 [host]      29 |     29 |      1
 [host]      30 |     30 |      1
 [host]      31 |     31 |      1
 [host] Vdis_setDefaultConfig >> ----------- Device: 3
 [host]
 [host]       0 |      0 |      1
 [host]       1 |      1 |      1
 [host]       2 |      2 |      1
 [host]       3 |      3 |      1
 [host]       4 |      4 |      1
 [host]       5 |      5 |      1
 [host]       6 |      6 |      1
 [host]       7 |      7 |      1
 [host]       8 |      8 |      1
 [host]       9 |      9 |      1
 [host]      10 |     10 |      1
 [host]      11 |     11 |      1
 [host]      12 |     12 |      1
 [host]      13 |     13 |      1
 [host]      14 |     14 |      1
 [host]      15 |     15 |      1
 [host]      16 |     16 |      1
 [host]      17 |     17 |      1
 [host]      18 |     18 |      1
 [host]      19 |     19 |      1
 [host]      20 |     20 |      1
 [host]      21 |     21 |      1
 [host]      22 |     22 |      1
 [host]      23 |     23 |      1
 [host]      24 |     24 |      1
 [host]      25 |     25 |      1
 [host]      26 |     26 |      1
 [host]      27 |     27 |      1
 [host]      28 |     28 |      1
 [host]      29 |     29 |      1
 [host]      30 |     30 |      1
 [host]      31 |     31 |      1
 [host]  0: SYSTEM: System Common Init in progress !!!
 [host]  0: SYSTEM: IPC init in progress !!!
 [host]  11: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
 [host]  11: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
 [host]  11: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
 [host]  11: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
 [host]  11: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
 [host]  13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
 [host]  15: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
 [host]  16: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
 [host]  17: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
 [host]  17: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 [host]  18: SYSTEM: Notify register to [DSP] line 0, event 12 ...
 [host]  19: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
 [host]  19: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
 [host]  20: SYSTEM: IPC init DONE !!!
 [host]  21: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
 [host]  23: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
 [host]  25: SYSTEM: ListElem Shared Addr = 0x40e9d180
 [host]  25: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
 [host]  27: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
 [host]  29: SYSTEM: ListElem Shared Addr = 0x40eb6e00
 [host]  30: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
 [host]  33: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
 [host]  34: SYSTEM: ListElem Shared Addr = 0x40ed0a80
 [host]  35: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
 [host]  37: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
 [host]  39: SYSTEM: ListElem Shared Addr = 0x40ef0480
 [host]  39: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
 [host]  41: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
 [host]  43: SYSTEM: ListElem Shared Addr = 0x40f0fe80
 [host]  44: SYSTEM: System Common Init Done !!!
 [host]
 [host]       0 |      0 |      1
 [host]       1 |      1 |      1
 [host]       2 |      2 |      1
 [host]       3 |      3 |      1
 [host]       4 |      4 |      1
 [host]       5 |      5 |      1
 [host]       6 |      6 |      1
 [host]       7 |      7 |      1
 [host]       8 |      8 |      1
 [host]       9 |      9 |      1
 [host]      10 |     10 |      1
 [host]      11 |     11 |      1
 [host]      12 |     12 |      1
 [host]      13 |     13 |      1
 [host]      14 |     14 |      1
 [host]      15 |     15 |      1
 [host]      16 |     16 |      1
 [host]      17 |     17 |      1
 [host]      18 |     18 |      1
 [host]      19 |     19 |      1
 [host]      20 |     20 |      1
 [host]      21 |     21 |      1
 [host]      22 |     22 |      1
 [host]      23 |     23 |      1
 [host]      24 |     24 |      1
 [host]      25 |     25 |      1
 [host]      26 |     26 |      1
 [host]      27 |     27 |      1
 [host]      28 |     28 |      1
 [host]      29 |     29 |      1
 [host]      30 |     30 |      1
 [host]      31 |     31 |      1
 [host]
 [host]       0 |      0 |      1
 [host]       1 |      1 |      1
 [host]       2 |      2 |      1
 [host]       3 |      3 |      1
 [host]       4 |      4 |      1
 [host]       5 |      5 |      1
 [host]       6 |      6 |      1
 [host]       7 |      7 |      1
 [host]       8 |      8 |      1
 [host]       9 |      9 |      1
 [host]      10 |     10 |      1
 [host]      11 |     11 |      1
 [host]      12 |     12 |      1
 [host]      13 |     13 |      1
 [host]      14 |     14 |      1
 [host]      15 |     15 |      1
 [host]      16 |     16 |      1
 [host]      17 |     17 |      1
 [host]      18 |     18 |      1
 [host]      19 |     19 |      1
 [host]      20 |     20 |      1
 [host]      21 |     21 |      1
 [host]      22 |     22 |      1
 [host]      23 |     23 |      1
 [host]      24 |     24 |      1
 [host]      25 |     25 |      1
 [host]      26 |     26 |      1
 [host]      27 |     27 |      1
 [host]      28 |     28 |      1
 [host]      29 |     29 |      1
 [host]      30 |     30 |      1
 [host]        21 |      1
 [host]      22 |     22 |      1
 [host] DMA: ChannelID allocated:4
     23 |     23 |      1
 [DMA: ChannelID allocated:5
host]      24 |     24 |      1
 [host]      25 |     25 |      1
 [host]      26 |     26 |      1
 [host]      27 |     27 |      1
 [host]      28 |     28 |      1
 [host]      29 |     29 |      1
 [host]      30 |     30 |      1
 [host]      31 |     31 |      1
 [host] Vsys_allocBuf - addr = 0x4c94f000,size = 65011712
##########pInfo->totalsize 63897600
 [host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
 [host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
 [host] MCF sbulla: unknown partition table
W_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered... inside autorun
 [host] Vsys_allocBuf - addr = 0x519ca000,size = 33603
 [host] DCC buffer allocated for size 33603
 [host] DCC Default File Intialization Done
 [host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
INIT: Entering runlevel: 5
 [host]
********** REAR VIEW MODULE USECASE ********
 [host]  654: MCFW  : CPU Revision [ES2.1] !!!
 [host]  655: MCFW  : Detected [UNKNOWN] Board !!!
 [host]  655: MCFW  : Base Board Revision [REV A] !!!
 [m3vpss ] VPS_DCTRL_INST_0
 [m3vpss ] IOCTL_VPS_DCTRL_SET_V sbulla: unknown partition table
ENC_OUTPUT SYSTEM_DC_VENC_DVO2
 [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
 [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
 [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_DVO2
 [m3vpss ]  6039: CAMERA: Create in progress !!!
 [m3vpss ]  Channel Num Stream 0 Ch 0 ChannelNum 0
 [m3vpss ]  Channel Num Stream 1 Ch 0 ChannelNum 1
 [m3vpss ]  6040: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
 [m3vpss ]  6049: CAMERA: VIP 0: VID DEC 268436736 (0x36): 0002:20202020:20202020, AUD_STATUS 538976288
 [m3vpss ] Iss_captCreate:1661
quiet_error: 28 callbacks suppressed
Buffer I/O error on device mtdblock1, logical block 9
Starting telnet daemon.
Starting syslogd/klogd: done
 [m3vpss ]  6421: CAMERA: Create Done !!!
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org DM8127_IPNC ttyO0
Arago 2011.09 DM8127_IPNC ttyO0
DM8127_IPNC login: root (automatic login)
root@DM8127_IPNC:~#  [m3vpss ]  6681: CAMERA: Detect video in progress !!!
 [m3vpss ]  6681: CAMERA: Detect video Done !!!
 [m3vpss ] DCC server task running
 [m3vpss ]  6757: DISPLAY: Create in progress !!!
 [m3vpss ] DisplayId = 4,DataFormat = 7
 [m3vpss ] SD displayInstId = 2
 [m3vpss ]  6758: DISPLAY: Create Done !!!
 [m3vpss ]  6759: IPC_FRAMES_OUT   : Create in progress !!!
 [c6xdsp ]  6667: IPC_FRAMES_IN   : Create in progress !!!
 [c6xdsp ]  6668: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_24] ...
 [m3vpss ]  6762: IPC_FRAMES_OUT   : Create Done !!!
 [c6xdsp ]  6668: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_24] ...
 [c6xdsp ]  6669: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
 [c6xdsp ] IPC_FRAMES_IN:HEAPID:0       USED:304
 [c6xdsp ]  6671: IPC_FRAMES_IN   : Create Done !!!
 [c6xdsp ]  6837: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
mount: mounting /dev/mmcblk0 on /mnt/mmc failed: Invalid argument
 [host]  ERROR: SD card mount failed !!!
 [host]  ERROR: LUT file open failed !!!
mkdosfs 3.0.12 (29 Oct 2011)
unable to get drive geometry, using default 255/63
/dev/sbulla has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 1024 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT size is 1 sector, and provides 247 clusters.
There is 1 reserved sector.
Root directory contains 512 slots and uses 32 sectors.
Volume ID is 4da30b30, no volume label.
g_file_storage gadget: No serial-number string provided!
g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
g_file_storage gadget: Number of LUNs=1
g_file_storage gadget-lun0: ro=0, nofua=0, file: /dev/sbulla
Simple mixer control 'PGA',0
  Capabilities: cvolume cswitch penum
  Capture channels: Front Left - Front Right
  Limits: Capture 0 - 119
  Front Left: Capture 80 [67%] [40.00dB] [on]
  Front Right: Capture 80 [67%] [40.00dB] [on]
queue id:0
./boa: /usr/lib/libssl.so.1.0.0: no version information available (required by ./boa)
./boa: /usr/lib/libcrypto.so.1.0.0: no version information available (required by ./boa)
ApproDrvInit: 3
queue id:163845
queue id:0
queue id:32769
queue id:0
TimeOut occure in boot_proc.
Program exit.
Program exit.
     Can anybody tell me the reason and what should I do correctly ?
     Thank you in advance !
