Hi, everyone
When I building DM365 IPNC ( Private_IPNC_DM365_1.0.0.tgz ) the first time, met error as below:
dsp@sam:~/workdir/ipnc$ make exe
mkdir -p /home/dsp/workdir/ipnc/av_capture/build/lib/
mkdir -p /home/dsp/workdir/ipnc/av_capture/build/lib/obj/drv/
drv: Building dependancies
/opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -c -Wall -fPIC -DBOARD_AP_IPNC -I/home/dsp/workdir/lsp/ti-davinci/linux-2.6.18_pro500/include -I../inc -I../priv -I/home/dsp/workdir/ipnc/av_capture/build/../framework/osa/inc -I/home/dsp/workdir/dvsdk_2_10_01_18/linuxutils_2_24_02/packages/ti/sdo/linuxutils/cmem/include -I/home/dsp/workdir/ipnc/av_capture/build/../framework/csl/inc -I/home/dsp/workdir/ipnc/av_capture/build/../framework/image_tune/inc -I/home/dsp/workdir/ipnc/av_capture/build/../framework/drv/inc -I/home/dsp/workdir/ipnc/av_capture/build/../framework/alg/inc -I../../kermod/inc drv_audio.c drv.c drv_capture.c drv_clk.c drv_display.c drv_dma.c drv_faceDetect.c drv_frameCopy.c drv_h3a.c drv_i2c.c drv_imageTune.c drv_imgs.c drv_ipipe.c drv_isif.c drv_ldc.c drv_regrw.c drv_resz.c drv_vpss.c -M > MAKEFILE.DEPEND
make[7]: Leaving directory `/home/dsp/workdir/ipnc/av_capture/framework/drv/usermod/src'
make -fMAKEFILE.MK -C/home/dsp/workdir/ipnc/av_capture/framework/drv/usermod/src/imgs_MT9P031_5MP MODULE=drv depend
make[7]: Entering directory `/home/dsp/workdir/ipnc/av_capture/framework/drv/usermod/src/imgs_MT9P031_5MP'
drv: Making Directories, if not already created
/opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -c -Wall -fPIC -DBOARD_AP_IPNC -I/home/dsp/workdir/lsp/ti-davinci/linux-2.6.18_pro500/include -I../inc -I../priv -I/home/dsp/workdir/ipnc/av_capture/build/../framework/osa/inc -I/home/dsp/workdir/dvsdk_2_10_01_18/linuxutils_2_24_02/packages/ti/sdo/linuxutils/cmem/include -I/home/dsp/workdir/ipnc/av_capture/build/../framework/csl/inc -I/home/dsp/workdir/ipnc/av_capture/build/../framework/image_tune/inc -I/home/dsp/workdir/ipnc/av_capture/build/../framework/drv/inc -I"./ldc_tables" drv_imgsCalcCfg_MT9P031_5MP.c drv_imgsH3aCfg_MT9P031_5MP.c drv_imgsIpipeCfg_MT9P031_5MP.c drv_imgsIsifCfg_MT9P031_5MP.c drv_imgsLdcCfg_MT9P031_5MP.c drv_imgs_MT9P031_5MP.c -M > MAKEFILE.DEPEND
make[7]: Leaving directory `/home/dsp/workdir/ipnc/av_capture/framework/drv/usermod/src/imgs_MT9P031_5MP'
make[6]: Leaving directory `/home/dsp/workdir/ipnc/av_capture/framework/drv'
make[5]: Leaving directory `/home/dsp/workdir/ipnc/av_capture/framework/drv'
make -fMAKEFILE.MK -C./osa/src MODULE=osa depend
make[5]: Entering directory `/home/dsp/workdir/ipnc/av_capture/framework/osa/src'
osa: Making Directories, if not already created
mkdir -p /home/dsp/workdir/ipnc/av_capture/build/lib/obj/osa/
osa: Building dependancies
/opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -c -Wall -fPIC -DBOARD_AP_IPNC -I/home/dsp/workdir/lsp/ti-davinci/linux-2.6.18_pro500/include -I../inc -I../priv -I/home/dsp/workdir/ipnc/av_capture/build/../framework/osa/inc -I/home/dsp/workdir/dvsdk_2_10_01_18/linuxutils_2_24_02/packages/ti/sdo/linuxutils/cmem/include osa_buf.c osa.c osa_cmem.c osa_file.c osa_flg.c osa_ipc.c osa_mbx.c osa_msgq.c osa_mutex.c osa_prf.c osa_que.c osa_sem.c osa_test.c osa_test_ipc.c osa_thr.c osa_tsk.c -M > MAKEFILE.DEPEND
make[5]: Leaving directory `/home/dsp/workdir/ipnc/av_capture/framework/osa/src'
make -fMAKEFILE.MK -C./alg/src MODULE=alg depend
cat: alg_config/compiler.opt: no file or no directory.
make[5]: Entering directory `/home/dsp/workdir/ipnc/av_capture/framework/alg/src'
alg: Making Directories, if not already created
mkdir -p /home/dsp/workdir/ipnc/av_capture/build/lib/obj/alg/
alg: Building dependancies
/opt/mv_pro_5.0/montavista/pro/devkit/arm/v5t_le/bin/arm_v5t_le-gcc -c -Wall -fPIC -DDM355 -Dti_sdo_ce_osal_Memory_USEDEPRECATEDAPIS=1 -DBOARD_AP_IPNC -I/home/dsp/workdir/lsp/ti-davinci/linux-2.6.18_pro500/include -I../inc -I../priv -I/home/dsp/workdir/ipnc/av_capture/build/../framework/osa/inc -I/home/dsp/workdir/dvsdk_2_10_01_18/linuxutils_2_24_02/packages/ti/sdo/linuxutils/cmem/include -I/home/dsp/workdir/ipnc/av_capture/build/../framework/csl/inc -I/home/dsp/workdir/ipnc/av_capture/build/../framework/drv/inc -I/home/dsp/workdir/ipnc/av_capture/build/../framework/image_tune/inc -I/home/dsp/workdir/dvsdk_2_10_01_18/dm365_codecs_01_00_06/examples -I/home/dsp/workdir/dvsdk_2_10_01_18/dm365_codecs_01_00_06/packages -I/home/dsp/workdir/dvsdk_2_10_01_18/codec_engine_2_24/packages -I/home/dsp/workdir/dvsdk_2_10_01_18/xdais_6_24/packages -I/home/dsp/workdir/dvsdk_2_10_01_18/framework_components_2_24/packages -I/home/dsp/workdir/dvsdk_2_10_01_18/linuxutils_2_24_02/packages -I/home/dsp/workdir/dvsdk_2_10_01_18/edma3_lld_1_06_00_01/packages -I/home/dsp/workdir/dvsdk_2_10_01_18/xdctools_3_15_01_59/packages -I../priv/vstab -I../priv/swosd alg.c alg_crypto.c alg_g711.c alg_jpgDec.c alg_jpgEnc.c alg_motionDetect.c alg_swosd.c alg_vidDec.c alg_vidEnc.c alg_vnf.c alg_vstab.c -M > MAKEFILE.DEPEND
alg_vnf.c:6:38: error: ti/sdo/codecs/ktnf/iktnf.h:no file or no directory.
make[5]: *** [depend] Error 1
make[5]: Leaving directory `/home/dsp/workdir/ipnc/av_capture/framework/alg/src'
make[4]: *** [libs] Error 2
make[4]: Leaving directory `/home/dsp/workdir/ipnc/av_capture/framework'
make[3]: *** [depend] Error 2
make[3]: Leaving directory `/home/dsp/workdir/ipnc/av_capture/framework'
make[2]: *** [libs] Error 2
make[2]: Leaving directory `/home/dsp/workdir/ipnc'
make[1]: *** [depend] Error 2
make[1]: Leaving directory `/home/dsp/workdir/ipnc'
make: *** [exe] Error 2
what's the problem? Thanks for any advice!
