TI-RTOS TivaC service DHCP error Fault 2.
Other Parts Discussed in Thread: TM4C129ENCPDT
TI-RTOS Tiva Service DHCP error Fault 2.
Characteristics:
Microcontroller: TM4C129ENCPDT.
TI-RTOS: V2.10.1.38.
DHCP function enabled on a router works fine if I change my router, dhcp server and other network crashes.
When it works good:
When the interface can not get the ip address:
Function:
What can be the reason of the problem, since the network 1 works perfectly but the network 2 crashes?
Patricio
  • 1) I'm not sure I understand the environmental differences between the working configuration and the non-working configuration. Can you please provide more details?
    2) Have you tried changing only one piece of the configuration at a time to isolate which piece is causing the failure?
    3) I notice that "dhcpc" is a local variable in your C code. I'm wondering if this needs to be a global variable since it is being added as a Cfg entry.
    4) Can you try using a more recent (ie 2.16.00.08) release of TI-RTOS?
    software-dl.ti.com/.../index.html
    Alan
  • Hi Alan,
    Thank you so much for your answer.
    I updated the RTOS for 2.16.00.08 version, and DHCP began to work well on both networks. But I did not know why the previous version of the RTOS did not work.
    Patricio
