Socket Sendto() real-time udp stream
Hello again.
I'm trying to make my board (TMDXEVM6670L) to send packets to my PC, using following code:
for(;;)
	        tmp = sizeof( sin1 );
	        i = (int)recvnc( s, (void **)&pBuf, 0, &hBuffer );
	        printf(pBuf);
	        printf("\n");
	        poutbuf = outbuf;
	        if( i >= 0 )
	        	for (j = 1; j < 100; j++)
	        		outval = j;
					ltoa(outval, poutbuf);//
	        		if (j < 10)
	        			sendto(s, poutbuf, 1, 0,(PSA)&sin1, sizeof(sin1) );
	        			printf(poutbuf, "\n");
	        			platform_delay(40000); // 0.04 sec
	        	 	if (j >= 10 && j <100)
	        			sendto(s, poutbuf, 2, 0,(PSA)&sin1, sizeof(sin1) );
	        		if (j >= 100 && j < 1000)
	        			sendto(s, poutbuf, 3, 0,(PSA)&sin1, sizeof(sin1) );
	        		if (j >= 1000 && j < 10000)
	        			sendto(s, poutbuf, 4, 0,(PSA)&sin1, sizeof(sin1) );
	            sendto(s, 0, 0, 0,(PSA)&sin1, sizeof(sin1) );
	            recvncfree( hBuffer );
	        else
	            break;
The problem is, that operations do not work inside the loop, until the loop itself does not end. I need to send a large amount of packets like that, and i don't know why this is happening. Could you please help me to understand, how to rework this code properly?
  • Dear Taras,
    I hope this loop will not end.
    Where you are decreasing the value of "i" and also for loop is in infinite loop.
    Can you please try the following code.
    for(;;)
    printf(pBuf);
    printf("\n");
    poutbuf = outbuf;
    if( i >= 0 )
    //Titus : Use it here or last line
    // i--;
    outval = j;
    if (j < 10)
    //Titus
    i--;
    else
    break;
  • Ok, that i can understand. But why the "Sendto" functions are not responding? When i'm using them once, they are executing like i need, but they are not working inside loop. Why is this happening?
  • Firstly, try to send around 100 packets then increase it and test.
    Try this code.
    for(;;)
    printf(pBuf);
    printf("\n");
    poutbuf = outbuf;
    if( i >= 0 )
    i--;
    outval = j;
    if (j < 10)
    else
    break;
    break;
  • While step-by-step debug, sendto "slips" without performing and returns nor result neither error...
  • Okay, let me try it on my machine and update you.
