Matlab Link
I am unable to access the .out file (rtdx) of ccs3.1 using matlab.
I have installed the Matlab Support Package for c6000 board which has only CCS3.3 CCS4 CCS5 access in it.
Is there some way i might be able to access CCS3.1 in matlab2014?
Thanking You
  • You will need to upgrade to CSCv3.3.
    Thanks for your post.
    Unfortunately, RTDX is no longer supported.   I think your customer needs to stick with CCSv3.1 or find another communications link to use.
    For porting code written in MATLAB to CCS, you need to use Embedded MATLAB (this supports code generation for real time embedded system) to make your code to embeddable C code. For that your code must be Embedded MATLAB complaint. For further information regarding complaincy, you can check MATHWORKS site for this.
    Please try contacting MathWorks at c2000_expert@mathworks.com
    Thanks & regards,
    Sivaraj K
    Please click the Verify Answer button on this post if it answers your question.
