Hi
I am trying to compile gpioLEDblink example from StarterWare, but, rtsv7A8_A_le_eabi.lib can not be built:
**** Build of configuration Debug for project gpioLEDBlink ****
"C:\\ti\\ccsv6.1.1\\ccsv6\\utils\\bin\\gmake" -k -j 2 -s all
'Building file: C:/ti/AM335X_StarterWare_02_00_01_01/examples/beaglebone/gpio/gpioLEDBlink.c'
'Invoking: ARM Compiler'
'Finished building: C:/ti/AM335X_StarterWare_02_00_01_01/examples/beaglebone/gpio/gpioLEDBlink.c'
'Building target: ../../../../../../../binary/armv7a/cgt_ccs/am335x/beaglebone/gpio/Debug/gpioLEDBlink.out'
'Invoking: ARM Linker'
<Linking>
warning #10366-D: automatic library build: using library
"C:\ti\ccsv6.1.1\ccsv6\tools\compiler\ti-cgt-arm_5.2.7\lib\rtsv7A8_A_le_eabi
.lib" for the first time, so it must be built. This may take a few
minutes.
'[' nÆo ‚ reconhecido como um comando interno
ou externo, um programa oper vel ou um arquivo em lotes.
process_begin: CreateProcess(NULL, armcl array_del.cpp -O --embed_icode --keep_asm --diag_warning=225 --quiet -mv7A8 --abi=eabi --fp_mode=strict --no_visible_enums -c --ti_lib --keep_unneeded_types=false -me -fg --rtti --building_runtime -Ic:/ti/ccsv61~1.1/ccsv6/tools/compiler/ti-cgt~1.7/lib/src -fr c:/users/sergio/appdata/local/temp/tiba0f~1/obj -fs c:/users/sergio/appdata/local/temp/tiba0f~1/obj -ft c:/users/sergio/appdata/local/temp/tiba0f~1/obj, ...) failed.
process_begin: CreateProcess(NULL, armcl array_new.cpp -O --embed_icode --keep_asm --diag_warning=225 --quiet -mv7A8 --abi=eabi --fp_mode=strict --no_visible_enums -c --ti_lib --keep_unneeded_types=false -me -fg --rtti --building_runtime -Ic:/ti/ccsv61~1.1/ccsv6/tools/compiler/ti-cgt~1.7/lib/src -fr c:/users/sergio/appdata/local/temp/tiba0f~1/obj -fs c:/users/sergio/appdata/local/temp/tiba0f~1/obj -ft c:/users/sergio/appdata/local/temp/tiba0f~1/obj, ...) failed.
make (e=2): O sistema não pode encontrar o arquivo especificado.
gmake.exe[1]: *** [c:/users/sergio/appdata/local/temp/tiba0f~1/obj/array_del.obj] Error 2
process_begin: CreateProcess(NULL, armcl array_nodel.cpp -O --embed_icode --keep_asm --diag_warning=225 --quiet -mv7A8 --abi=eabi --fp_mode=strict --no_visible_enums -c --ti_lib --keep_unneeded_types=false -me -fg --rtti --building_runtime -Ic:/ti/ccsv61~1.1/ccsv6/tools/compiler/ti-cgt~1.7/lib/src -fr c:/users/sergio/appdata/local/temp/tiba0f~1/obj -fs c:/users/sergio/appdata/local/temp/tiba0f~1/obj -ft c:/users/sergio/appdata/local/temp/tiba0f~1/obj, ...) failed.
gmake.exe[1]: *** [c:/users/sergio/appdata/local/temp/tiba0f~1/obj/array_new.obj] Error 2
process_begin: CreateProcess(NULL, armcl array_nonew.cpp -O --embed_icode --keep_asm --diag_warning=225 --quiet -mv7A8 --abi=eabi --fp_mode=strict --no_visible_enums -c --ti_lib --keep_unneeded_types=false -me -fg --rtti --building_runtime -Ic:/ti/ccsv61~1.1/ccsv6/tools/compiler/ti-cgt~1.7/lib/src -fr c:/users/sergio/appdata/local/temp/tiba0f~1/obj -fs c:/users/sergio/appdata/local/temp/tiba0f~1/obj -ft c:/users/sergio/appdata/local/temp/tiba0f~1/obj, ...) failed.
Attached follows complete compilation log.
I am using CCSv6.1.1 and StarterWare 02_00_01_01, under Windows 10.
I already applied PATCH for am335x over StarterWare ( StarterWare_BBB_suport.tar.gz).
Any help will welcome.
