I get illegal instruction when debugger started on a QT project. I finally narrowed it down when I add network capabilities into my project. The simplest way to replicate the problem is create a new project and add "network" to the project file
myproject.pro
QT += core gui network
target.path += /home
INSTALLS += target
The remaining project does not need to have any network routines.
Place a breakpoint in main.cpp just to stop the program
Have the beaglebone black connected.
start debugger and we get a SIGILL exception.
Also I get the following output in the debugger window
"Unable to find dynamic linker breakpoint function.
GDB will be unable to debug shared library initializers
and track explicitly loaded dynamic code."
I can ignore the exception and click Continue,F5, and the breakpoint is reached.
Look forward to hear from you
best regards
Naseer
