Uniflash with AM437x
I'm trying to use the uniflash tool, version 3.4.1.00012 on windows 10 with our custom board without success at the moment.
I keep the console open on the serial port but I see nothing come through.
If I set the sysboot switches to [5..0] 11 0110
I see the boot timeout apply (about 40secs) and the am437x boot from the sd card instead, and see the uboot output on the serial port.
With the boot pins as [5..0] 11 1100 it will keep trying unsuccessfully from the ethernet port. I see the ethenet lights go off completely every 40secs and then it tries again., but see nothing in the logs or the serial port.
I followed the guide http://processors.wiki.ti.com/index.php/Sitara_Uniflash_Quick_Start_Guide
to set up the windows machine with a static ip. I've tried both a standard network cable and a crossover network cable direct from the pc to the EVM network port Both with the same result.  I've also turned off the windows firewall.
the dhcp log file
[15-Apr-16 10:32:47] Logging: All
[15-Apr-16 10:32:47] DHCP Range: 192.168.2.3-192.168.2.254/255.255.255.0
[15-Apr-16 10:32:47] DHCP Range: 192.168.102.2-192.168.102.254/255.255.255.0
[15-Apr-16 10:32:47] Server Name: Lenovo-Ian
1.59 Windows Build 1036 Starting...
[15-Apr-16 10:32:47] Warning: Section [LISTEN_ON], Interface 192.168.2.2 is not Static, ignored
[15-Apr-16 10:32:47] Detecting Static Interfaces..
[15-Apr-16 10:32:47] Warning: Section [LISTEN_ON], Interface 192.168.102.1 not available, ignored
[15-Apr-16 10:32:47] No Static Interface ready, Waiting...
 192.168.103.1 not available, ignored
[15-Apr-16 10:32:47] Retrying failed Listening Interfaces..
[15-Apr-16 10:32:47] Warning: Section [LISTEN_ON], Interface 192.168.103.1 not available, ignored
[15-Apr-16 10:32:47] Warning: Section [LISTEN_ON], Interface 192.168.101.1 not available, ignored
[15-Apr-16 10:32:47] Lease Status URL: <a href="127.0.0.1:6789">http:/.../a>
[15-Apr-16 10:32:47] Listening On: 192.168.2.2
[15-Apr-16 10:33:31] Retrying failed Listening Interfaces..
[15-Apr-16 10:33:31] Warning: Section [LISTEN_ON], Interface 192.168.2.2 is not Static, ignored
[15-Apr-16 10:33:31] Warning: Section [LISTEN_ON], Interface 192.168.103.1 not available, ignored
[15-Apr-16 10:33:31] Warning: Section [LISTEN_ON], Interface 192.168.101.1 not available, ignored
[15-Apr-16 10:33:31] No Static Interface ready, Waiting...
[15-Apr-16 10:33:31] Warning: Section [LISTEN_ON], Interface 192.168.102.1 not available, ignored
[15-Apr-16 10:33:31] Lease Status URL: <a href="127.0.0.1:6789">http:/.../a>
[15-Apr-16 10:33:31] Listening On: 192.168.2.2
[15-Apr-16 10:34:07] Retrying failed Listening Interfaces..
[15-Apr-16 10:34:07] Warning: Section [LISTEN_ON], Interface 192.168.2.2 is not Static, ignored
[15-Apr-16 10:34:07] Warning: Section [LISTEN_ON], Interface 192.168.103.1 not available, ignored
[15-Apr-16 10:34:07] No Static Interface ready, Waiting...
[15-Apr-16 10:34:07] Warning: Section [LISTEN_ON], Interface 192.168.101.1 not available, ignored
[15-Apr-16 10:34:07] Warning: Section [LISTEN_ON], Interface 192.168.102.1 not available, ignored
and the tftp log
[15-Apr-16 10:32:47] Open TFTP Server MultiThreaded Version 1.64 Windows Built 2001 Starting..
[15-Apr-16 10:32:47] starting TFTP service
[15-Apr-16 10:32:47] alias / is mapped to C:\AM335x_Flashtool\images\
[15-Apr-16 10:32:47] permitted clients: all
[15-Apr-16 10:32:47] server port range: all
[15-Apr-16 10:32:47] max blksize: 65464
[15-Apr-16 10:32:47] default blksize: 512
[15-Apr-16 10:32:47] default timeout: 3
[15-Apr-16 10:32:47] file read allowed: Yes
[15-Apr-16 10:32:47] file create allowed: No
[15-Apr-16 10:32:47] file overwrite allowed: No
[15-Apr-16 10:32:47] thread pool size: 8
[15-Apr-16 10:32:47] 192.168.101.1 Port 69 bind failed
[15-Apr-16 10:32:47] 192.168.102.1 Port 69 bind failed
[15-Apr-16 10:32:47] 192.168.103.1 Port 69 bind failed
[15-Apr-16 10:32:47] Listening On: 192.168.2.2:69
[15-Apr-16 10:33:02] Retrying failed Listening Interfaces..
[15-Apr-16 10:33:02] 192.168.101.1 Port 69 bind failed
[15-Apr-16 10:33:02] 192.168.102.1 Port 69 bind failed
[15-Apr-16 10:33:02] 192.168.103.1 Port 69 bind failed
[15-Apr-16 10:33:02] Listening On: 192.168.2.2:69
[15-Apr-16 10:33:31] 192.168.101.1 Port 69 bind failed
[15-Apr-16 10:33:31] 192.168.102.1 Port 69 bind failed
[15-Apr-16 10:33:31] 192.168.103.1 Port 69 bind failed
[15-Apr-16 10:33:31] Listening On: 192.168.2.2:69
[15-Apr-16 10:33:39] Retrying failed Listening Interfaces..
[15-Apr-16 10:33:39] 192.168.101.1 Port 69 bind failed
[15-Apr-16 10:33:39] 192.168.102.1 Port 69 bind failed
[15-Apr-16 10:33:39] 192.168.103.1 Port 69 bind failed
[15-Apr-16 10:33:39] Listening On: 192.168.2.2:69
[15-Apr-16 10:34:07] 192.168.101.1 Port 69 bind failed
[15-Apr-16 10:34:07] 192.168.102.1 Port 69 bind failed
[15-Apr-16 10:34:07] 192.168.103.1 Port 69 bind failed
[15-Apr-16 10:34:07] Listening On: 192.168.2.2:69
[15-Apr-16 10:34:14] Retrying failed Listening Interfaces..
[15-Apr-16 10:34:14] 192.168.101.1 Port 69 bind failed
[15-Apr-16 10:34:14] 192.168.102.1 Port 69 bind failed
[15-Apr-16 10:34:14] 192.168.103.1 Port 69 bind failed
[15-Apr-16 10:34:14] Listening On: 192.168.2.2:69
[15-Apr-16 10:34:15] Retrying failed Listening Interfaces..
[15-Apr-16 10:34:15] 192.168.101.1 Port 69 bind failed
[15-Apr-16 10:34:15] 192.168.102.1 Port 69 bind failed
[15-Apr-16 10:34:15] 192.168.103.1 Port 69 bind failed
[15-Apr-16 10:34:15] Listening On: 192.168.2.2:69
Also a link to a previous thread on the CCS forum.
https://e2e.ti.com/support/development_tools/code_composer_studio/f/81/p/506298/1836354
I confirmed the pc is using the static ip using the ipconfig command at the command prompt.
Any ideas where this might be going wrong?
Kind regards
Ian
