PMIC probe problem
Other Parts Discussed in Thread: TPS65910, AM3357
                         tps65910 0-002d: No interrupt support, no core IRQ
[    3.219797] tps65910 0-002d: Error in configuring external control EN1
[    3.227109] tps65910 0-002d: Failed to initialise ext control config
[    3.238406] vrtc: failed to enable
[    3.249576] tps65910 0-002d: failed to register tps65910-pmic regulator
[    3.257019] tps65910-pmic: probe of tps65910-pmic failed with error -121
  • Your queries will not be processed unless you provide information about processor being used and SDK version. This is the second time you are posting insufficient information. Please provide the required information.
  • Dear Biser,
    e2e.ti.com/.../508057
    i have already mentioned that thing in previous post hmmm there is no fault in my side.............any way i'm using SDK-08 and my board is am3357 custom board
  • I know this, but this forum is intended to help other people too, who search for solutions to issues similar to theirs. They will not know the background to your post, so this is information that is necessary when a new thread is started.
    Anyway, this has been forwarded to the software team now.
  • By the way, is your PMIC connected to I2C0?
  • yes,it is connected to i2c0
    Can you paste your full dmesg (boot log) and attach the .dts & .dtsi files?
    Yordan
  • here is my log file.............
    U-Boot SPL 2014.07-00107-gd28f2b9-dirty (Apr 22 2016 - 18:45:53)
    reading args
    spl_load_image_fat_os: error reading image args, err - -1
    reading u-boot.img
    reading u-boot.img
    U-Boot 2014.07-00107-gd28f2b9-dirty (Apr 22 2016 - 18:45:53)
    I2C:   ready
    DRAM:  512 MiB
    NAND:  256 MiB
    MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    reading uboot.env
    ** Unable to read "uboot.env" from mmc0:1 **
    Using default environment
    Net:   Net Initialization Skipped
    No ethernet found.
    Hit any key to stop autoboot:  1  0
    U-Boot#
    U-Boot#
    U-Boot#
    U-Boot#
    U-Boot#
    U-Boot# fatload mmc 0  0x80F80000 am335x-evm.dtb
    reading am335x-evm.dtb
    39244 bytes read in 19 ms (2 MiB/s)
    U-Boot# fatload mmc 0 0x80007FC0 uImage
    reading uImage
    3751664 bytes read in 506 ms (7.1 MiB/s)
    U-Boot# setenv bootargs console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
    U-Boot# bootm 0x80007FC0 - 0x80F80000
    ## Booting kernel from Legacy Image at 80007fc0 ...
       Image Name:   Linux-3.14.26-g07d13c6-dirty
       Created:      2016-04-22   9:52:10 UTC
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    3751600 Bytes = 3.6 MiB
       Load Address: 80008000
       Entry Point:  80008000
       Verifying Checksum ... OK
    ## Flattened Device Tree blob at 80f80000
       Booting using the fdt blob at 0x80f80000
       XIP Kernel Image ... OK
       Loading Device Tree to 8fff3000, end 8ffff94b ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 3.14.26-g07d13c6-dirty (atl@diversense) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #6 SMP Fri Apr 22 15:21:49 IST 2016
    [    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] Machine model: TI AM335x EVM
    [    0.000000] cma: CMA: reserved 16 MiB at 9e800000
    [    0.000000] Memory policy: Data cache writeback
    [    0.000000] CPU: All CPU(s) started in SVC mode.
    [    0.000000] AM335X ES2.1 (neon )
    [    0.000000] PERCPU: Embedded 9 pages/cpu @df9d1000 s13824 r8192 d14848 u36864
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 129536
    [    0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
    [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    0.000000] Memory: 487964K/522240K available (4774K kernel code, 652K rwdata, 1904K rodata, 365K init, 5464K bss, 34276K reserved, 0K highmem)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    [    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000]       .text : 0xc0008000 - 0xc068db94   (6679 kB)
    [    0.000000]       .init : 0xc068e000 - 0xc06e9600   ( 366 kB)
    [    0.000000]       .data : 0xc06ea000 - 0xc078d2e8   ( 653 kB)
    [    0.000000]        .bss : 0xc078d2e8 - 0xc0ce3414   (5465 kB)
    [    0.000000] Hierarchical RCU implementation.
    [    0.000000] 	RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
    [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
    [    0.000000] NR_IRQS:16 nr_irqs:16 16
    [    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
    [    0.000000] Total of 128 interrupts on 1 active controller
    [    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
    [    0.000033] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956969942ns
    [    0.000149] OMAP clocksource: timer1 at 24000000 Hz
    [    0.002312] Console: colour dummy device 80x30
    [    0.097184] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
    [    0.097221] ... MAX_LOCKDEP_SUBCLASSES:  8
    [    0.097246] ... MAX_LOCK_DEPTH:          48
    [    0.097269] ... MAX_LOCKDEP_KEYS:        8191
    [    0.097292] ... CLASSHASH_SIZE:          4096
    [    0.097316] ... MAX_LOCKDEP_ENTRIES:     16384
    [    0.097339] ... MAX_LOCKDEP_CHAINS:      32768
    [    0.097361] ... CHAINHASH_SIZE:          16384
    [    0.097385]  memory used by lock dependency info: 3695 kB
    [    0.097410]  per task-struct memory footprint: 1152 bytes
    [    0.097543] Calibrating delay loop... 297.36 BogoMIPS (lpj=1486848)
    [    0.157215] pid_max: default: 32768 minimum: 301
    [    0.158254] Security Framework initialized
    [    0.158581] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.158621] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.230731] CPU: Testing write buffer coherency: ok
    [    0.234161] CPU0: thread -1, cpu 0, socket -1, mpidr 0
    [    0.234318] Setting up static identity map for 0x80489720 - 0x80489790
    [    0.243239] Brought up 1 CPUs
    [    0.243285] SMP: Total of 1 processors activated.
    [    0.243313] CPU: All CPU(s) started in SVC mode.
    [    0.251523] devtmpfs: initialized
    [    0.278519] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    [    0.393910] omap_hwmod: tptc0 using broken dt data from edma
    [    0.395011] omap_hwmod: tptc1 using broken dt data from edma
    [    0.396082] omap_hwmod: tptc2 using broken dt data from edma
    [    0.415366] omap_hwmod: debugss: _wait_target_disable failed
    [    0.498223] pinctrl core: initialized pinctrl subsystem
    [    0.510955] regulator-dummy: no parameters
    [    0.521293] NET: Registered protocol family 16
    [    0.537540] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.553843] cpuidle: using governor ladder
    [    0.553908] cpuidle: using governor menu
    [    0.583794] syscon 44e10000.control_module: regmap [mem 0x44e10000-0x44e107fb] registered
    [    0.595332] platform 49000000.edma: alias fck already exists
    [    0.595426] platform 49000000.edma: alias fck already exists
    [    0.595487] platform 49000000.edma: alias fck already exists
    [    0.607948] OMAP GPIO hardware version 0.1
    [    0.697092] omap-gpmc 50000000.gpmc: could not find pctldev for node /pinmux@44e10800/nandflash_pins_default, deferring probe
    [    0.697398] platform 50000000.gpmc: Driver omap-gpmc requests probe deferral
    [    0.729293] No ATAGs?
    [    0.729358] hw-breakpoint: debug architecture 0x4 unsupported.
    [    0.880901] bio: create slab <bio-0> at 0
    [    1.000985] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
    [    1.006880] vmmcsd_fixed: 3300 mV
    [    1.011737] vbat: 5000 mV
    [    1.014716] lis3_reg: no parameters
    [    1.019347] wlan-en-regulator: 1800 mV
    [    1.036828] i2c-core: driver [palmas] using legacy suspend method
    [    1.036875] i2c-core: driver [palmas] using legacy resume method
    [    1.041849] SCSI subsystem initialized
    [    1.044520] usbcore: registered new interface driver usbfs
    [    1.045769] usbcore: registered new interface driver hub
    [    1.048881] usbcore: registered new device driver usb
    [    1.053550] omap_i2c 44e0b000.i2c: could not find pctldev for node /pinmux@44e10800/pinmux_i2c0_pins, deferring probe
    [    1.053657] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral
    [    1.053823] omap_i2c 4802a000.i2c: could not find pctldev for node /pinmux@44e10800/pinmux_i2c1_pins, deferring probe
    [    1.053898] platform 4802a000.i2c: Driver omap_i2c requests probe deferral
    [    1.070650] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
    [    1.087896] Switched to clocksource timer1
    [    1.499128] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
    [    1.520385] futex hash table entries: 256 (order: 2, 16384 bytes)
    [    1.926224] VFS: Disk quotas dquot_6.5.2
    [    1.926851] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    1.931028] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
    [    1.932181] msgmni has been set to 985
    [    1.940147] io scheduler noop registered
    [    1.940208] io scheduler deadline registered
    [    1.940372] io scheduler cfq registered (default)
    [    1.949090] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
    [    2.067564] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    2.091391] omap_uart 44e09000.serial: no wakeirq for uart0
    [    2.093066] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88, base_baud = 3000000) is a OMAP UART0
    [    2.762703] console [ttyO0] enabled
    [    2.772351] omap_uart 48022000.serial: no wakeirq for uart0
    [    2.779345] 48022000.serial: ttyO1 at MMIO 0x48022000 (irq = 89, base_baud = 3000000) is a OMAP UART1
    [    2.802351] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
    [    2.902160] brd: module loaded
    [    2.959863] loop: module loaded
    [    2.982522] mtdoops: mtd device (mtddev=name/number) must be supplied
    [    3.001176] usbcore: registered new interface driver cdc_acm
    [    3.007171] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    [    3.018096] usbcore: registered new interface driver usblp
    [    3.025074] usbcore: registered new interface driver cdc_wdm
    [    3.032741] usbcore: registered new interface driver usbtmc
    [    3.041076] usbcore: registered new interface driver usb-storage
    [    3.048892] usbcore: registered new interface driver ums_eneub6250
    [    3.056454] usbcore: registered new interface driver ums-jumpshot
    [    3.064410] usbcore: registered new interface driver ums-realtek
    [    3.072132] usbcore: registered new interface driver ums-sddr55
    [    3.079928] usbcore: registered new interface driver ums-usbat
    [    3.088719] usbcore: registered new interface driver usbserial
    [    3.096050] usbcore: registered new interface driver usblcd
    [    3.103554] usbcore: registered new interface driver ldusb
    [    3.111019] usbcore: registered new interface driver usbled
    [    3.118263] usbcore: registered new interface driver usbsevseg
    [    3.130432] mousedev: PS/2 mouse device common for all mice
    [    3.151401] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
    [    3.163582] i2c /dev entries driver
    [    3.168693] Driver for 1-wire Dallas network protocol.
    [    3.187324] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    3.202594] sdhci: Secure Digital Host Controller Interface driver
    [    3.209487] sdhci: Copyright(c) Pierre Ossman
    [    3.273230] mmc0: mmc_rescan_try_freq: trying to init card at 400000 Hz
    [    3.379482] mmc0: new high speed SDHC card at address aaaa
    [    3.393431] mmcblk0: mmc0:aaaa SS04G 3.69 GiB
    [    3.414826]  mmcblk0: p1 p2
    [    3.420975] sdhci-pltfm: SDHCI platform and OF driver helper
    [    3.443814] mmc1: mmc_rescan_try_freq: trying to init card at 400000 Hz
    [    3.452806] usbcore: registered new interface driver usbhid
    [    3.459024] usbhid: USB HID core driver
    [    3.467297] platform 44d00000.wkup_m3: Driver wkup_m3 requests probe deferral
    [    3.494260] oprofile: using arm/armv7
    [    3.505773] PM: bootloader does not support rtc-only!
    [    3.511507] ThumbEE CPU extension supported.
    [    3.516136] Registering SWP/SWPB emulation handler
    [    3.521311] SmartReflex Class3 initialized
    [    3.538383] wlan-en-regulator: disabling
    [    3.542621] lis3_reg: disabling
    [    3.545951] vbat: disabling
    [    3.549050] regulator-dummy: disabling
    [    3.556406] omap-gpmc 50000000.gpmc: GPMC revision 6.0
    [    3.562499] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
    [    3.574675] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
    [    3.581886] nand: Micron MT29F2G08ABAEAWP
    [    3.586130] nand: 256MiB, SLC, page size: 2048, OOB size: 64
    [    3.592366] nand: error: CONFIG_MTD_NAND_OMAP_BCH not enabled
    [    3.598685] omap2-nand: probe of omap2-nand.0 failed with error -22
    [    3.624647] tps65910 0-002d: No interrupt support, no core IRQ
    [    3.641675] tps65910 0-002d: Error in configuring external control EN1
    [    3.648972] tps65910 0-002d: Failed to initialise ext control config
    [    3.660527] vrtc: failed to enable
    [    3.671425] tps65910 0-002d: failed to register tps65910-pmic regulator
    [    3.678846] tps65910-pmic: probe of tps65910-pmic failed with error -121
    [    3.690900] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
    [    3.718351] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
    [    3.727438]  remoteproc0: wkup_m3 is available
    [    3.732612]  remoteproc0: Note: remoteproc is still under development and considered experimental.
    [    3.742303]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [    3.755753]  remoteproc0: Direct firmware load failed with error -2
    [    3.762571]  remoteproc0: Falling back to user helper
    [    3.784467] input: volume_keys.9 as /devices/volume_keys.9/input/input0
    [    3.800751] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
    [    3.810155] sr_init: No PMIC hook to init smartreflex
    [    3.818432] sr_init: platform driver register failed for SR
    [    3.900805] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [    3.908739] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [   10.478386] EXT4-fs (mmcblk0p2): recovery complete
    [   10.504719] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [   10.513800] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [   10.523601] devtmpfs: mounted
    [   10.528669] Freeing unused kernel memory: 364K (c068e000 - c06e9000)
    INIT: version 2.88 booting
    Error opening /dev/fb0: No such file or directory
    Starting udev
    udevd[668]: error getting socket: Address family not supported by protocol
    error initializing udev control socketudevd[668]: error initializing udev control socket
    [   12.349319] random: nonblocking pool is initialized
    udevadm[675]: error getting socket: Address family not supported by protocol
    udevadm[681]: error getting socket: Address family not supported by protocol
    [   13.233081] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
    Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or directory
    bootlogd.
    Populating dev cache
    ALSA: Restoring mixer settings...
    /usr/sbin/alsactl: load_state:1729: No soundcards found...
    Wed Feb 11 14:32:00 UTC 2015
    INIT: Entering runlevel: 5
    Configuring network interfaces... ifconfig: socket: Address family not supported by protocol
    done.
    Starting system message bus: Failed to start message bus: Failed to open socket: Address family not supported by protocol
    dbus.
    Starting telnet daemon.
    Starting rpcbind daemon...rpcbind: cannot create socket for local
    rpcbind: cannot create socket for udp
    rpcbind: cannot create socket for tcp
    rpcbind: cannot create socket for udp6
    rpcbind: cannot create socket for tcp6
    done.
    creating NFS state directory: done
    starting statd: done
    Starting syslogd/klogd: done
    Starting thttpd.
    Stopping Bootlog daemon: bootlogd.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org am335x-evm /dev/ttyO0
    Arago 2015.02 am335x-evm /dev/ttyO0
    am335x-evm login: root
    root@am335x-evm:~#
    root@am335x-evm:~#
    root@am335x-evm:~#
    root@am335x-evm:~#
    root@am335x-evm:~#
    root@am335x-evm:~#
    root@am335x-evm:~# lsusb
    unable to initialize libusb: -99
    root@am335x-evm:~#
     * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
     * This program is free software; you can redistribute it and/or modify
     * it under the terms of the GNU General Public License version 2 as
     * published by the Free Software Foundation.
    /dts-v1/;
    #include "am33xx.dtsi"
    #include <dt-bindings/interrupt-controller/irq.h>
    	model = "TI AM335x EVM";
    	compatible = "ti,am335x-evm", "ti,am33xx";
    	cpus {
    		cpu@0 {
    			cpu0-supply = <&vdd1_reg>;
    	memory {
    		device_type = "memory";
    		reg = <0x80000000 0x10000000>; /* 256 MB */
    	vbat: fixedregulator@0 {
    		compatible = "regulator-fixed";
    		regulator-name = "vbat";
    		regulator-min-microvolt = <5000000>;
    		regulator-max-microvolt = <5000000>;
    		regulator-boot-on;
    	lis3_reg: fixedregulator@1 {
    		regulator-name = "lis3_reg";
    		regulator-boot-on;
    	wlan_en_reg: fixedregulator@2 {
    		regulator-name = "wlan-en-regulator";
    		regulator-min-microvolt = <1800000>;
    		regulator-max-microvolt = <1800000>;
    		/* WLAN_EN GPIO for this board - Bank1, pin16 */
    		gpio = <&gpio1 16 0>;
    		/* WLAN card specific delay */
    		startup-delay-us = <70000>;
    		enable-active-high;
    	matrix_keypad: matrix_keypad@0 {
    		compatible = "gpio-matrix-keypad";
    		debounce-delay-ms = <5>;
    		col-scan-delay-us = <2>;
    		pinctrl-names = "default", "sleep";
    		pinctrl-0 = <&matrix_keypad_default>;
    		pinctrl-1 = <&matrix_keypad_sleep>;
    		row-gpios = <&gpio1 25 GPIO_ACTIVE_HIGH		/* Bank1, pin25 */
    			     &gpio1 26 GPIO_ACTIVE_HIGH		/* Bank1, pin26 */
    			     &gpio1 27 GPIO_ACTIVE_HIGH>;	/* Bank1, pin27 */
    		col-gpios = <&gpio1 21 GPIO_ACTIVE_HIGH		/* Bank1, pin21 */
    			     &gpio1 22 GPIO_ACTIVE_HIGH>;	/* Bank1, pin22 */
    		linux,keymap = <0x0000008b	/* MENU */
    				0x0100009e	/* BACK */
    				0x02000069	/* LEFT */
    				0x0001006a	/* RIGHT */
    				0x0101001c	/* ENTER */
    				0x0201006c>;	/* DOWN */
    	gpio_keys: volume_keys@0 {
    		compatible = "gpio-keys";
    		#address-cells = <1>;
    		#size-cells = <0>;
    		autorepeat;
    		switch@9 {
    			label = "volume-up";
    			linux,code = <115>;
    			gpios = <&gpio0 2 GPIO_ACTIVE_LOW>;
    			gpio-key,wakeup;
    		switch@10 {
    			label = "volume-down";
    			linux,code = <114>;
    			gpios = <&gpio0 3 GPIO_ACTIVE_LOW>;
    			gpio-key,wakeup;
    	backlight {
    		compatible = "pwm-backlight";
    		pwms = <&ecap0 0 50000 0>;
    		brightness-levels = <0 51 53 56 62 75 101 152 255>;
    		default-brightness-level = <8>;
    	panel {
    		compatible = "ti,tilcdc,panel";
    		status = "okay";
    		panel-info {
    			ac-bias           = <255>;
    			ac-bias-intrpt    = <0>;
    			dma-burst-sz      = <16>;
    			bpp               = <32>;
    			fdd               = <0x80>;
    			sync-edge         = <0>;
    			sync-ctrl         = <1>;
    			raster-order      = <0>;
    			fifo-th           = <0>;
    		display-timings {
    			800x480p62 {
    				clock-frequency = <30000000>;
    				hactive = <800>;
    				vactive = <480>;
    				hfront-porch = <39>;
    				hback-porch = <39>;
    				hsync-len = <47>;
    				vback-porch = <29>;
    				vfront-porch = <13>;
    				vsync-len = <2>;
    				hsync-active = <1>;
    				vsync-active = <1>;
    	kim {
    		compatible = "kim";
    		nshutdown_gpio = <117>; /* Bank3, pin21 */
    		dev_name = "/dev/ttyO1";
    		flow_cntrl = <1>;
    		baud_rate = <3000000>;
    	btwilink {
    		compatible = "btwilink";
    	sound {
    		compatible = "ti,da830-evm-audio";
    		ti,model = "AM335x-EVM";
    		ti,audio-codec = <&tlv320aic3106>;
    		ti,mcasp-controller = <&mcasp1>;
    		ti,codec-clock-rate = <12000000>;
    		ti,audio-routing =
    			"Headphone Jack",       "HPLOUT",
    			"Headphone Jack",       "HPROUT",
    			"LINE1L",               "Line In",
    			"LINE1R",               "Line In";
    &am33xx_pinmux {
    	pinctrl-names = "default";
    	pinctrl-0 = <&volume_keys_s0 &clkout2_pin>;
    	matrix_keypad_default: matrix_keypad_default {
    		pinctrl-single,pins = <
    			0x54 (PIN_OUTPUT_PULLDOWN | MUX_MODE7)	/* gpmc_a5.gpio1_21 */
    			0x58 (PIN_OUTPUT_PULLDOWN | MUX_MODE7)	/* gpmc_a6.gpio1_22 */
    			0x64 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_a9.gpio1_25 */
    			0x68 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_a10.gpio1_26 */
    			0x6c (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_a11.gpio1_27 */
    	matrix_keypad_sleep: matrix_keypad_sleep {
    			0x54 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_a5.gpio1_21 */
    			0x58 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_a6.gpio1_22 */
    	volume_keys_s0: volume_keys_s0 {
    			0x150 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* spi0_sclk.gpio0_2 */
    			0x154 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* spi0_d0.gpio0_3 */
    	i2c0_pins: pinmux_i2c0_pins {
    			0x188 (PIN_INPUT_PULLUP | MUX_MODE0)	/* i2c0_sda.i2c0_sda */
    			0x18c (PIN_INPUT_PULLUP | MUX_MODE0)	/* i2c0_scl.i2c0_scl */
    	i2c1_pins_default: pinmux_i2c1_pins {
    			0x158 (PIN_INPUT_PULLUP | MUX_MODE2)	/* spi0_d1.i2c1_sda */
    			0x15c (PIN_INPUT_PULLUP | MUX_MODE2)	/* spi0_cs0.i2c1_scl */
    	i2c1_pins_sleep: i2c1_pins_sleep {
    			0x158 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* spi0_d1.i2c1_sda */
    			0x15c (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* spi0_cs0.i2c1_scl */
    	uart0_pins: pinmux_uart0_pins {
    			0x170 (PIN_INPUT_PULLUP | MUX_MODE0)	/* uart0_rxd.uart0_rxd */
    			0x174 (PIN_OUTPUT_PULLDOWN | MUX_MODE0)	/* uart0_txd.uart0_txd */
    	uart1_pins_default: pinmux_uart1_pins_default {
    			0x178 (PIN_INPUT | MUX_MODE0)			/* uart1_ctsn.uart1_ctsn */
    			0x17C (PIN_OUTPUT_PULLDOWN | MUX_MODE0)	/* uart1_rtsn.uart1_rtsn */
    			0x180 (PIN_INPUT_PULLUP | MUX_MODE0)	/* uart1_rxd.uart1_rxd */
    			0x184 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) 	/* uart1_txd.uart1_txd */
    	uart1_pins_sleep: pinmux_uart1_pins_sleep {
    			0x178 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x17C (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x180 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x184 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    	clkout2_pin: pinmux_clkout2_pin {
    			0x1b4 (PIN_OUTPUT_PULLDOWN | MUX_MODE3)	/* xdma_event_intr1.clkout2 */
    	nandflash_pins_default: nandflash_pins_default {
    			0x0 (PIN_INPUT_PULLUP | MUX_MODE0)	/* gpmc_ad0.gpmc_ad0 */
    			0x4 (PIN_INPUT_PULLUP | MUX_MODE0)	/* gpmc_ad1.gpmc_ad1 */
    			0x8 (PIN_INPUT_PULLUP | MUX_MODE0)	/* gpmc_ad2.gpmc_ad2 */
    			0xc (PIN_INPUT_PULLUP | MUX_MODE0)	/* gpmc_ad3.gpmc_ad3 */
    			0x10 (PIN_INPUT_PULLUP | MUX_MODE0)	/* gpmc_ad4.gpmc_ad4 */
    			0x14 (PIN_INPUT_PULLUP | MUX_MODE0)	/* gpmc_ad5.gpmc_ad5 */
    			0x18 (PIN_INPUT_PULLUP | MUX_MODE0)	/* gpmc_ad6.gpmc_ad6 */
    			0x1c (PIN_INPUT_PULLUP | MUX_MODE0)	/* gpmc_ad7.gpmc_ad7 */
    			0x70 (PIN_INPUT_PULLUP | MUX_MODE0)	/* gpmc_wait0.gpmc_wait0 */
    			0x74 (PIN_INPUT_PULLUP | MUX_MODE7)	/* gpmc_wpn.gpio0_30 */
    			0x7c (PIN_OUTPUT | MUX_MODE0)		/* gpmc_csn0.gpmc_csn0  */
    			0x90 (PIN_OUTPUT | MUX_MODE0)		/* gpmc_advn_ale.gpmc_advn_ale */
    			0x94 (PIN_OUTPUT | MUX_MODE0)		/* gpmc_oen_ren.gpmc_oen_ren */
    			0x98 (PIN_OUTPUT | MUX_MODE0)		/* gpmc_wen.gpmc_wen */
    			0x9c (PIN_OUTPUT | MUX_MODE0)		/* gpmc_be0n_cle.gpmc_be0n_cle */
    	nandflash_pins_sleep: nandflash_pins_sleep {
    			0x0 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x4 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x8 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0xc (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x10 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x14 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x18 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x1c (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x70 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x74 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x7c (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x90 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x94 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x98 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x9c (PIN_INPUT_PULLDOWN | MUX_MODE7)
    	ecap0_pins_default: backlight_pins {
    			0x164 0x0	/* eCAP0_in_PWM0_out.eCAP0_in_PWM0_out MODE0 */
    	ecap0_pins_sleep: ecap0_pins_sleep {
    			0x164  (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* eCAP0_in_PWM0_out.eCAP0_in_PWM0_out */
    	cpsw_default: cpsw_default {
    			/* Slave 1 */
    			0x114 (PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txen.rgmii1_tctl */
    			0x118 (PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxdv.rgmii1_rctl */
    			0x11c (PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txd3.rgmii1_td3 */
    			0x120 (PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txd2.rgmii1_td2 */
    			0x124 (PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txd1.rgmii1_td1 */
    			0x128 (PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txd0.rgmii1_td0 */
    			0x12c (PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txclk.rgmii1_tclk */
    			0x130 (PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxclk.rgmii1_rclk */
    			0x134 (PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxd3.rgmii1_rd3 */
    			0x138 (PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxd2.rgmii1_rd2 */
    			0x13c (PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxd1.rgmii1_rd1 */
    			0x140 (PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxd0.rgmii1_rd0 */
    	cpsw_sleep: cpsw_sleep {
    			/* Slave 1 reset value */
    			0x114 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x118 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x11c (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x120 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x124 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x128 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x12c (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x130 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x134 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x138 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x13c (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x140 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    	davinci_mdio_default: davinci_mdio_default {
    			/* MDIO */
    			0x148 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0)	/* mdio_data.mdio_data */
    			0x14c (PIN_OUTPUT_PULLUP | MUX_MODE0)			/* mdio_clk.mdio_clk */
    	davinci_mdio_sleep: davinci_mdio_sleep {
    			/* MDIO reset value */
    			0x148 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x14c (PIN_INPUT_PULLDOWN | MUX_MODE7)
    	mmc1_pins_default: pinmux_mmc1_pins {
    			0x0F0 (PIN_INPUT_PULLUP | MUX_MODE0)    /* mmc0_dat3.mmc0_dat3 */
    			0x0F4 (PIN_INPUT_PULLUP | MUX_MODE0)    /* mmc0_dat2.mmc0_dat2 */
    			0x0F8 (PIN_INPUT_PULLUP | MUX_MODE0)    /* mmc0_dat1.mmc0_dat1 */
    			0x0FC (PIN_INPUT_PULLUP | MUX_MODE0)    /* mmc0_dat0.mmc0_dat0 */
    			0x100 (PIN_INPUT_PULLUP | MUX_MODE0)    /* mmc0_clk.mmc0_clk */
    			0x104 (PIN_INPUT_PULLUP | MUX_MODE0)    /* mmc0_cmd.mmc0_cmd */
    			0x1A0 (PIN_INPUT| MUX_MODE4)    /* mcasp0_aclkr.gpio3_18 */
    			0x160 (PIN_INPUT_PULLUP | MUX_MODE5)           /* spi0_cs1.gpio0_6 */
    	mmc1_pins_sleep: pinmux_mmc1_pins_sleep {
    			0x0F0 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x0F4 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x0F8 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x0FC (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x100 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x104 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    			0x1A0 (PIN_INPUT_PULLDOWN | MUX_MODE7)
    	/* wl12xx/wl18xx card on mmc3 */
    	mmc3_pins_default: pinmux_mmc3_pins_default {
    			0x44 (PIN_INPUT_PULLUP | MUX_MODE3)	/* gpmc_a1.mmc2_dat0 */
    			0x48 (PIN_INPUT_PULLUP | MUX_MODE3)	/* gpmc_a2.mmc2_dat1 */
    			0x4C (PIN_INPUT_PULLUP | MUX_MODE3)	/* gpmc_a3.mmc2_dat2 */
    			0x78 (PIN_INPUT_PULLUP | MUX_MODE3)	/* gpmc_ben1.mmc2_dat3 */
    			0x88 (PIN_INPUT_PULLUP | MUX_MODE3)	/* gpmc_csn3.mmc2_cmd */
    			0x8C (PIN_INPUT_PULLUP | MUX_MODE3)	/* gpmc_clk.mmc2_clk */
    	mmc3_pins_sleep: pinmux_mmc3_pins_sleep {
    			0x44 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_a1.mmc2_dat0 */
    			0x48 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_a2.mmc2_dat1 */
    			0x4C (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_a3.mmc2_dat2 */
    			0x78 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_ben1.mmc2_da */
    			0x88 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_csn3.mmc2_cmd */
    			0x8C (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_clk.mmc2_clk */
    	/* wl12xx/wl18xx card enable/irq GPIOs. */
    	wlan_pins_default: pinmux_wlan_pins_default {
    			0x40 (PIN_OUTPUT_PULLDOWN | MUX_MODE7)	/* gpmc_a0.gpio1_16 */
    			0x19C (PIN_INPUT | MUX_MODE7)		/* mcasp0_ahclkr.gpio3_17 */
    			0x1AC (PIN_OUTPUT_PULLDOWN | MUX_MODE7)	/* mcasp0_ahclkx.gpio3_21 */
    	wlan_pins_sleep: pinmux_wlan_pins_sleep {
    			0x1AC (PIN_OUTPUT_PULLUP | MUX_MODE7)	/* mcasp0_ahclkx.gpio3_21 */
    	lcd_pins_default: lcd_pins_default {
    			0x20 0x01	/* gpmc_ad8.lcd_data16, OUTPUT | MODE1 */
    			0x24 0x01	/* gpmc_ad9.lcd_data17, OUTPUT | MODE1 */
    			0x28 0x01	/* gpmc_ad10.lcd_data18, OUTPUT | MODE1 */
    			0x2c 0x01	/* gpmc_ad11.lcd_data19, OUTPUT | MODE1 */
    			0x30 0x01	/* gpmc_ad12.lcd_data20, OUTPUT | MODE1 */
    			0x34 0x01	/* gpmc_ad13.lcd_data21, OUTPUT | MODE1 */
    			0x38 0x01	/* gpmc_ad14.lcd_data22, OUTPUT | MODE1 */
    			0x3c 0x01	/* gpmc_ad15.lcd_data23, OUTPUT | MODE1 */
    			0xa0 0x00	/* lcd_data0.lcd_data0, OUTPUT | MODE0 */
    			0xa4 0x00	/* lcd_data1.lcd_data1, OUTPUT | MODE0 */
    			0xa8 0x00	/* lcd_data2.lcd_data2, OUTPUT | MODE0 */
    			0xac 0x00	/* lcd_data3.lcd_data3, OUTPUT | MODE0 */
    			0xb0 0x00	/* lcd_data4.lcd_data4, OUTPUT | MODE0 */
    			0xb4 0x00	/* lcd_data5.lcd_data5, OUTPUT | MODE0 */
    			0xb8 0x00	/* lcd_data6.lcd_data6, OUTPUT | MODE0 */
    			0xbc 0x00	/* lcd_data7.lcd_data7, OUTPUT | MODE0 */
    			0xc0 0x00	/* lcd_data8.lcd_data8, OUTPUT | MODE0 */
    			0xc4 0x00	/* lcd_data9.lcd_data9, OUTPUT | MODE0 */
    			0xc8 0x00	/* lcd_data10.lcd_data10, OUTPUT | MODE0 */
    			0xcc 0x00	/* lcd_data11.lcd_data11, OUTPUT | MODE0 */
    			0xd0 0x00	/* lcd_data12.lcd_data12, OUTPUT | MODE0 */
    			0xd4 0x00	/* lcd_data13.lcd_data13, OUTPUT | MODE0 */
    			0xd8 0x00	/* lcd_data14.lcd_data14, OUTPUT | MODE0 */
    			0xdc 0x00	/* lcd_data15.lcd_data15, OUTPUT | MODE0 */
    			0xe0 0x00	/* lcd_vsync.lcd_vsync, OUTPUT | MODE0 */
    			0xe4 0x00	/* lcd_hsync.lcd_hsync, OUTPUT | MODE0 */
    			0xe8 0x00	/* lcd_pclk.lcd_pclk, OUTPUT | MODE0 */
    			0xec 0x00	/* lcd_ac_bias_en.lcd_ac_bias_en, OUTPUT | MODE0 */
    	lcd_pins_sleep: lcd_pins_sleep {
    			0x20 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_ad8.lcd_data16 */
    			0x24 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_ad9.lcd_data17 */
    			0x28 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_ad10.lcd_data18 */
    			0x2c (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_ad11.lcd_data19 */
    			0x30 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_ad12.lcd_data20 */
    			0x34 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_ad13.lcd_data21 */
    			0x38 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_ad14.lcd_data22 */
    			0x3c (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* gpmc_ad15.lcd_data23 */
    			0xa0 (PULL_DISABLE | MUX_MODE7)		/* lcd_data0.lcd_data0 */
    			0xa4 (PULL_DISABLE | MUX_MODE7)		/* lcd_data1.lcd_data1 */
    			0xa8 (PULL_DISABLE | MUX_MODE7)		/* lcd_data2.lcd_data2 */
    			0xac (PULL_DISABLE | MUX_MODE7)		/* lcd_data3.lcd_data3 */
    			0xb0 (PULL_DISABLE | MUX_MODE7)		/* lcd_data4.lcd_data4 */
    			0xb4 (PULL_DISABLE | MUX_MODE7)		/* lcd_data5.lcd_data5 */
    			0xb8 (PULL_DISABLE | MUX_MODE7)		/* lcd_data6.lcd_data6 */
    			0xbc (PULL_DISABLE | MUX_MODE7)		/* lcd_data7.lcd_data7 */
    			0xc0 (PULL_DISABLE | MUX_MODE7)		/* lcd_data8.lcd_data8 */
    			0xc4 (PULL_DISABLE | MUX_MODE7)		/* lcd_data9.lcd_data9 */
    			0xc8 (PULL_DISABLE | MUX_MODE7)		/* lcd_data10.lcd_data10 */
    			0xcc (PULL_DISABLE | MUX_MODE7)		/* lcd_data11.lcd_data11 */
    			0xd0 (PULL_DISABLE | MUX_MODE7)		/* lcd_data12.lcd_data12 */
    			0xd4 (PULL_DISABLE | MUX_MODE7)		/* lcd_data13.lcd_data13 */
    			0xd8 (PULL_DISABLE | MUX_MODE7)		/* lcd_data14.lcd_data14 */
    			0xdc (PULL_DISABLE | MUX_MODE7)		/* lcd_data15.lcd_data15 */
    			0xe0 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* lcd_vsync.lcd_vsync, OUTPUT | MODE0 */
    			0xe4 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* lcd_hsync.lcd_hsync */
    			0xe8 (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* lcd_pclk.lcd_pclk */
    			0xec (PIN_INPUT_PULLDOWN | MUX_MODE7)	/* lcd_ac_bias_en.lcd_ac_bias_en */
    	am335x_evm_audio_pins: am335x_evm_audio_pins {
    			0x10c (PIN_INPUT_PULLDOWN | MUX_MODE4) /* mii1_rx_dv.mcasp1_aclkx */
    			0x110 (PIN_INPUT_PULLDOWN | MUX_MODE4) /* mii1_txd3.mcasp1_fsx */
    			0x108 (PIN_OUTPUT_PULLDOWN | MUX_MODE4) /* mii1_col.mcasp1_axr2 */
    			0x144 (PIN_INPUT_PULLDOWN | MUX_MODE4) /* rmii1_ref_clk.mcasp1_axr3 */
    	am335x_evm_audio_pins_sleep: am335x_evm_audio_pins_sleep {
    			0x10c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* mii1_rx_dv.mcasp1_aclkx */
    			0x110 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* mii1_txd3.mcasp1_fsx */
    			0x108 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* mii1_col.mcasp1_axr2 */
    			0x144 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* rmii1_ref_clk.mcasp1_axr3 */
    	dcan1_pins_default: dcan1_pins_default {
    			0x168 (PIN_OUTPUT | MUX_MODE2) /* uart0_ctsn.d_can1_tx */
    			0x16c (PIN_INPUT_PULLDOWN | MUX_MODE2) /* uart0_rtsn.d_can1_rx */
    &uart0 {
    	pinctrl-0 = <&uart0_pins>;
    	status = "okay";
    &uart1 {
    	pinctrl-0 = <&uart1_pins_default>;
    	pinctrl-1 = <&uart1_pins_sleep>;
    	status = "okay";
    &i2c0 {
    	pinctrl-0 = <&i2c0_pins>;
    	status = "okay";
    	clock-frequency = <400000>;
    	tps: tps@2d {
    		reg = <0x2d>;
    &usb {
    	status = "okay";
    	control@44e10620 {
    		status = "okay";
    	usb-phy@47401300 {
    		status = "okay";
    	usb-phy@47401b00 {
    		status = "okay";
    	usb@47401000 {
    		status = "okay";
    	usb@47401800 {
    		status = "okay";
    		dr_mode = "host";
    	dma-controller@47402000  {
    		status = "okay";
    &i2c1 {
    	pinctrl-0 = <&i2c1_pins_default>;
    	pinctrl-1 = <&i2c1_pins_sleep>;
    	status = "okay";
    	clock-frequency = <100000>;
    	lis331dlh: lis331dlh@18 {
    		compatible = "st,lis331dlh", "st,lis3lv02d";
    		reg = <0x18>;
    		Vdd-supply = <&lis3_reg>;
    		Vdd_IO-supply = <&lis3_reg>;
    		st,click-single-x;
    		st,click-single-y;
    		st,click-single-z;
    		st,click-thresh-x = <10>;
    		st,click-thresh-y = <10>;
    		st,click-thresh-z = <10>;
    		st,irq1-click;
    		st,irq2-click;
    		st,wakeup-x-lo;
    		st,wakeup-x-hi;
    		st,wakeup-y-lo;
    		st,wakeup-y-hi;
    		st,wakeup-z-lo;
    		st,wakeup-z-hi;
    		st,min-limit-x = <120>;
    		st,min-limit-y = <120>;
    		st,min-limit-z = <140>;
    		st,max-limit-x = <550>;
    		st,max-limit-y = <550>;
    		st,max-limit-z = <750>;
    	tsl2550: tsl2550@39 {
    		compatible = "taos,tsl2550";
    		reg = <0x39>;
    	tmp275: tmp275@48 {
    		compatible = "ti,tmp275";
    		reg = <0x48>;
    	tlv320aic3106: tlv320aic3106@1b {
    		compatible = "ti,tlv320aic3106";
    		reg = <0x1b>;
    		status = "okay";
    		/* Regulators */
    		AVDD-supply = <&vaux2_reg>;
    		IOVDD-supply = <&vaux2_reg>;
    		DRVDD-supply = <&vaux2_reg>;
    		DVDD-supply = <&vbat>;
    &lcdc {
    	status = "okay";
    	pinctrl-0 = <&lcd_pins_default>;
    	pinctrl-1 = <&lcd_pins_sleep>;
    &elm {
    	status = "okay";
    &epwmss0 {
    	status = "okay";
    	ecap0: ecap@48300100 {
    		status = "okay";
    		pinctrl-0 = <&ecap0_pins_default>;
    		pinctrl-1 = <&ecap0_pins_sleep>;
    &gpmc {
    	status = "okay";
    	pinctrl-0 = <&nandflash_pins_default>;
    	pinctrl-1 = <&nandflash_pins_sleep>;
    	ranges = <0 0 0x08000000 0x10000000>;	/* CS0: NAND */
    	nand@0,0 {
    		reg = <0 0 0>; /* CS0, offset 0 */
    		ti,nand-ecc-opt = "bch8";
    		ti,elm-id = <&elm>;
    		nand-bus-width = <8>;
    		gpmc,device-width = <1>;
    		gpmc,sync-clk-ps = <0>;
    		gpmc,cs-on-ns = <0>;
    		gpmc,cs-rd-off-ns = <44>;
    		gpmc,cs-wr-off-ns = <44>;
    		gpmc,adv-on-ns = <6>;
    		gpmc,adv-rd-off-ns = <34>;
    		gpmc,adv-wr-off-ns = <44>;
    		gpmc,we-on-ns = <0>;
    		gpmc,we-off-ns = <40>;
    		gpmc,oe-on-ns = <0>;
    		gpmc,oe-off-ns = <54>;
    		gpmc,access-ns = <64>;
    		gpmc,rd-cycle-ns = <82>;
    		gpmc,wr-cycle-ns = <82>;
    		gpmc,wait-on-read = "true";
    		gpmc,wait-on-write = "true";
    		gpmc,bus-turnaround-ns = <0>;
    		gpmc,cycle2cycle-delay-ns = <0>;
    		gpmc,clk-activation-ns = <0>;
    		gpmc,wait-monitoring-ns = <0>;
    		gpmc,wr-access-ns = <40>;
    		gpmc,wr-data-mux-bus-ns = <0>;
    		/* MTD partition table */
    		/* All SPL-* partitions are sized to minimal length
    		 * which can be independently programmable. For
    		 * NAND flash this is equal to size of erase-block */
    		#size-cells = <1>;
    		partition@0 {
    			label = "NAND.SPL";
    			reg = <0x00000000 0x000020000>;
    		partition@1 {
    			label = "NAND.SPL.backup1";
    			reg = <0x00020000 0x00020000>;
    		partition@2 {
    			label = "NAND.SPL.backup2";
    			reg = <0x00040000 0x00020000>;
    		partition@3 {
    			label = "NAND.SPL.backup3";
    			reg = <0x00060000 0x00020000>;
    		partition@4 {
    			label = "NAND.u-boot-spl-os";
    			reg = <0x00080000 0x00040000>;
    		partition@5 {
    			label = "NAND.u-boot";
    			reg = <0x000C0000 0x00100000>;
    		partition@6 {
    			label = "NAND.u-boot-env";
    			reg = <0x001C0000 0x00020000>;
    		partition@7 {
    			label = "NAND.u-boot-env.backup1";
    			reg = <0x001E0000 0x00020000>;
    		partition@8 {
    			label = "NAND.kernel";
    			reg = <0x00200000 0x00800000>;
    		partition@9 {
    			label = "NAND.file-system";
    			reg = <0x00A00000 0x0F600000>;
    #include "tps65910.dtsi"
    &mcasp1 {
    	pinctrl-0 = <&am335x_evm_audio_pins>;
    	pinctrl-1 = <&am335x_evm_audio_pins_sleep>;
    	status = "okay";
    	op-mode = <0>;          /* MCASP_IIS_MODE */
    	tdm-slots = <2>;
    	/* 4 serializers */
    	serial-dir = <  /* 0: INACTIVE, 1: TX, 2: RX */
    		0 0 1 2
    	tx-num-evt = <32>;
    	rx-num-evt = <32>;
    &tps {
    	vcc1-supply = <&vbat>;
    	vcc2-supply = <&vbat>;
    	vcc3-supply = <&vbat>;
    	vcc4-supply = <&vbat>;
    	vcc5-supply = <&vbat>;
    	vcc6-supply = <&vbat>;
    	vcc7-supply = <&vbat>;
    	vccio-supply = <&vbat>;
    	regulators {
    		vrtc_reg: regulator@0 {
    			regulator-always-on;
    		vio_reg: regulator@1 {
    		vdd1_reg: regulator@2 {
    			/* VDD_MPU voltage limits 0.95V - 1.325V with +/-4% tolerance */
    			regulator-name = "vdd_mpu";
    			regulator-min-microvolt = <912500>;
    			regulator-max-microvolt = <1378000>;
    			regulator-boot-on;
    		vdd2_reg: regulator@3 {
    			/* VDD_CORE voltage limits 0.95V - 1.1V with +/-4% tolerance */
    			regulator-name = "vdd_core";
    			regulator-max-microvolt = <1150000>;
    			regulator-boot-on;
    		vdd3_reg: regulator@4 {
    		vdig1_reg: regulator@5 {
    		vdig2_reg: regulator@6 {
    		vpll_reg: regulator@7 {
    		vdac_reg: regulator@8 {
    		vaux1_reg: regulator@9 {
    		vaux2_reg: regulator@10 {
    		vaux33_reg: regulator@11 {
    		vmmc_reg: regulator@12 {
    			regulator-max-microvolt = <3300000>;
    &mac {
    	pinctrl-0 = <&cpsw_default>;
    	pinctrl-1 = <&cpsw_sleep>;
    &davinci_mdio {
    	pinctrl-0 = <&davinci_mdio_default>;
    	pinctrl-1 = <&davinci_mdio_sleep>;
    &cpsw_emac0 {
    	phy_id = <&davinci_mdio>, <0>;
    	phy-mode = "rgmii-txid";
    &cpsw_emac1 {
    	phy_id = <&davinci_mdio>, <1>;
    &tscadc {
    	status = "okay";
    	tsc {
    		ti,wires = <4>;
    		ti,x-plate-resistance = <200>;
    		ti,coordinate-readouts = <5>;
    		ti,wire-config = <0x00 0x11 0x22 0x33>;
    	adc {
    		ti,adc-channels = <4 5 6 7>;
    &mmc1 {
    	status = "okay";
    	vmmc-supply = <&vmmc_reg>;
    	bus-width = <4>;
    	pinctrl-0 = <&mmc1_pins_default>;
    	pinctrl-1 = <&mmc1_pins_sleep>;
    	cd-gpios = <&gpio0 6 GPIO_ACTIVE_HIGH>;
    	wp-gpios = <&gpio3 18 GPIO_ACTIVE_HIGH>;
    	vmmc-supply = <&vmmcsd_fixed>;        /* my_naveen */
    &mmc3 {
    	/* these are on the crossbar and are outlined in the
    	   xbar-event-map element */
    	dmas = <&edma 12
    		&edma 13>;
    	dma-names = "tx", "rx";
    	status = "okay";
    	vmmc-supply = <&wlan_en_reg>;
    	bus-width = <4>;
    	pinctrl-0 = <&mmc3_pins_default &wlan_pins_default>;
    	pinctrl-1 = <&mmc3_pins_sleep &wlan_pins_sleep>;
    	ti,non-removable;
    	ti,needs-special-hs-handling;
    	cap-power-off-card;
    	keep-power-in-suspend;
    	#size-cells = <0>;
    	wlcore: wlcore@0 {
    		compatible = "ti,wlcore";
    		reg = <2>;
    		interrupt-parent = <&gpio3>;
    		interrupts = <17 IRQ_TYPE_NONE>;
    &edma {
    	ti,edma-xbar-event-map = /bits/ 16 <1 12
    					    2 13>;
    &sham {
    	status = "okay";
    &aes {
    	status = "okay";
    &wkup_m3 {
    	ti,scale-data-fw = "am335x-evm-scale-data.bin";
    &dcan1 {
    	status = "disabled";	/* Enable only if Profile 1 is selected */
    	pinctrl-0 = <&dcan1_pins_default>;
     * Device Tree Source for AM33XX SoC
     * This file is licensed under the terms of the GNU General Public License
     * version 2.  This program is licensed "as is" without any warranty of any
     * kind, whether express or implied.
    #include <dt-bindings/gpio/gpio.h>
    #include <dt-bindings/pinctrl/am33xx.h>
    #include "skeleton.dtsi"
    	compatible = "ti,am33xx";
    	interrupt-parent = <&intc>;
    	aliases {
    		i2c0 = &i2c0;
    		i2c1 = &i2c1;
    		i2c2 = &i2c2;
    		serial0 = &uart0;
    		serial1 = &uart1;
    		serial2 = &uart2;
    		serial3 = &uart3;
    		serial4 = &uart4;
    		serial5 = &uart5;
    		d_can0 = &dcan0;
    		d_can1 = &dcan1;
    		usb0 = &usb0;
    		usb1 = &usb1;
    		phy0 = &usb0_phy;
    		phy1 = &usb1_phy;
    		ethernet0 = &cpsw_emac0;
    		ethernet1 = &cpsw_emac1;
    	cpus {
    		#size-cells = <0>;
    		cpu@0 {
    			compatible = "arm,cortex-a8";
    			device_type = "cpu";
    			reg = <0>;
    			voltage-tolerance = <2>; /* 2 percentage */
    			clocks = <&dpll_mpu_ck>;
    			clock-names = "cpu";
    			clock-latency = <300000>; /* From omap-cpufreq driver */
    	pmu {
    		compatible = "arm,cortex-a8-pmu";
    		interrupts = <3>;
    	 * The soc node represents the soc top level view. It is uses for IPs
    	 * that are not memory mapped in the MPU view or for the MPU itself.
    	soc {
    		compatible = "ti,omap-infra";
    		mpu {
    			compatible = "ti,omap3-mpu";
    			ti,hwmods = "mpu";
    	am33xx_control_module: control_module@4a002000 {
    		compatible = "syscon";
    		reg = <0x44e10000 0x7fc>;
    	am33xx_pinmux: pinmux@44e10800 {
    		compatible = "pinctrl-single";
    		reg = <0x44e10800 0x0238>;
    		#size-cells = <0>;
    		pinctrl-single,register-width = <32>;
    		pinctrl-single,function-mask = <0x7f>;
    	 * XXX: Use a flat representation of the AM33XX interconnect.
    	 * The real AM33XX interconnect network is quite complex.Since
    	 * that will not bring real advantage to represent that in DT
    	 * for the moment, just use a fake OCP bus entry to represent
    	 * the whole bus hierarchy.
    	ocp {
    		compatible = "simple-bus";
    		#size-cells = <1>;
    		ranges;
    		ti,hwmods = "l3_main";
    		prcm: prcm@44e00000 {
    			compatible = "ti,am3-prcm";
    			reg = <0x44e00000 0x4000>;
    			prcm_clocks: clocks {
    				#size-cells = <0>;
    			prcm_clockdomains: clockdomains {
    		scrm: scrm@44e10000 {
    			compatible = "ti,am3-scrm";
    			reg = <0x44e10000 0x2000>;
    			scrm_clocks: clocks {
    				#size-cells = <0>;
    			scrm_clockdomains: clockdomains {
    		intc: interrupt-controller@48200000 {
    			compatible = "ti,omap2-intc";
    			interrupt-controller;
    			#interrupt-cells = <1>;
    			ti,intc-size = <128>;
    			reg = <0x48200000 0x1000>;
    		edma: edma@49000000 {
    			compatible = "ti,edma3";
    			ti,hwmods = "tpcc", "tptc0", "tptc1", "tptc2";
    			reg =	<0x49000000 0x10000>,
    				<0x44e10f90 0x40>;
    			interrupts = <12 13 14>;
    			#dma-cells = <1>;
    		gpio0: gpio@44e07000 {
    			compatible = "ti,omap4-gpio";
    			ti,hwmods = "gpio1";
    			gpio-controller;
    			#gpio-cells = <2>;
    			#interrupt-cells = <2>;
    			reg = <0x44e07000 0x1000>;
    			interrupts = <96>;
    		gpio1: gpio@4804c000 {
    			ti,hwmods = "gpio2";
    			gpio-controller;
    			#gpio-cells = <2>;
    			reg = <0x4804c000 0x1000>;
    			interrupts = <98>;
    		gpio2: gpio@481ac000 {
    			ti,hwmods = "gpio3";
    			gpio-controller;
    			#gpio-cells = <2>;
    			reg = <0x481ac000 0x1000>;
    			interrupts = <32>;
    		gpio3: gpio@481ae000 {
    			ti,hwmods = "gpio4";
    			gpio-controller;
    			#gpio-cells = <2>;
    			reg = <0x481ae000 0x1000>;
    			interrupts = <62>;
    		uart0: serial@44e09000 {
    			compatible = "ti,omap3-uart";
    			ti,hwmods = "uart1";
    			clock-frequency = <48000000>;
    			reg = <0x44e09000 0x2000>;
    			interrupts = <72>;
    			dmas = <&edma 26>, <&edma 27>;
    		uart1: serial@48022000 {
    			ti,hwmods = "uart2";
    			reg = <0x48022000 0x2000>;
    			interrupts = <73>;
    			dmas = <&edma 28>, <&edma 29>;
    		uart2: serial@48024000 {
    			ti,hwmods = "uart3";
    			reg = <0x48024000 0x2000>;
    			interrupts = <74>;
    			dmas = <&edma 30>, <&edma 31>;
    		uart3: serial@481a6000 {
    			ti,hwmods = "uart4";
    			reg = <0x481a6000 0x2000>;
    			interrupts = <44>;
    		uart4: serial@481a8000 {
    			ti,hwmods = "uart5";
    			reg = <0x481a8000 0x2000>;
    			interrupts = <45>;
    		uart5: serial@481aa000 {
    			ti,hwmods = "uart6";
    			reg = <0x481aa000 0x2000>;
    			interrupts = <46>;
    		i2c0: i2c@44e0b000 {
    			compatible = "ti,omap4-i2c";
    			#size-cells = <0>;
    			ti,hwmods = "i2c1";
    			reg = <0x44e0b000 0x1000>;
    			interrupts = <70>;
    		i2c1: i2c@4802a000 {
    			#size-cells = <0>;
    			ti,hwmods = "i2c2";
    			reg = <0x4802a000 0x1000>;
    			interrupts = <71>;
    		i2c2: i2c@4819c000 {
    			#size-cells = <0>;
    			ti,hwmods = "i2c3";
    			reg = <0x4819c000 0x1000>;
    			interrupts = <30>;
    			status = "okay";
    		mmc1: mmc@48060000 {
    			compatible = "ti,omap4-hsmmc";
    			ti,hwmods = "mmc1";
    			ti,dual-volt;
    			ti,needs-special-reset;
    			dmas = <&edma 24
    				&edma 25>;
    			interrupts = <64>;
    			reg = <0x48060000 0x1000>;
    			status = "okay";
    	   	 vmmcsd_fixed: fixedregulator@0 {		/*my _naveen */
           			compatible = "regulator-fixed";		/*my_naveen  */
            		regulator-name = "vmmcsd_fixed";	/*my_naveen  */
            		regulator-min-microvolt = <3300000>;	/*my_naveen */
            		regulator-max-microvolt = <3300000>;	/*my_naveen*/
    		mmc2: mmc@481d8000 {
    			ti,hwmods = "mmc2";
    			dmas = <&edma 2
    				&edma 3>;
    			interrupts = <28>;
    			reg = <0x481d8000 0x1000>;
    		mmc3: mmc@47810000 {
    			ti,hwmods = "mmc3";
    			interrupts = <29>;
    			reg = <0x47810000 0x1000>;
    		hwspinlock: spinlock@480ca000 {
    			compatible = "ti,omap4-hwspinlock";
    			reg = <0x480ca000 0x1000>;
    			ti,hwmods = "spinlock";
    			#hwlock-cells = <1>;
    		wdt2: wdt@44e35000 {
    			compatible = "ti,omap3-wdt";
    			ti,hwmods = "wd_timer2";
    			reg = <0x44e35000 0x1000>;
    			interrupts = <91>;
    		dcan0: can@481cc000 {
    			compatible = "ti,am3352-d_can";
    			ti,hwmods = "d_can0";
    			clocks = <&dcan0_fck>;
    			clock-names = "fck";
    			reg = <0x481cc000 0x2000>;
    			syscon-raminit = <&am33xx_control_module 0x644 0>;
    			interrupts = <52>;
    		dcan1: can@481d0000 {
    			ti,hwmods = "d_can1";
    			clocks = <&dcan1_fck>;
    			reg = <0x481d0000 0x2000>;
    			syscon-raminit = <&am33xx_control_module 0x644 1>;
    			interrupts = <55>;
    		mailbox: mailbox@480C8000 {
    			compatible = "ti,omap4-mailbox";
    			reg = <0x480C8000 0x200>;
    			interrupts = <77>;
    			ti,hwmods = "mailbox";
    			#mbox-cells = <1>;
    			ti,mbox-num-users = <4>;
    			ti,mbox-num-fifos = <8>;
    			mbox_wkupm3: wkup_m3 {
    				ti,mbox-send-noirq;
    				ti,mbox-tx = <0 0 0>;
    				ti,mbox-rx = <0 0 3>;
    			mbox_pru0: mbox_pru0 {
    				ti,mbox-tx = <2 0 0>;
    				ti,mbox-rx = <3 0 0>;
    			mbox_pru1: mbox_pru1 {
    				ti,mbox-tx = <4 0 0>;
    				ti,mbox-rx = <5 0 0>;
    		timer1: timer@44e31000 {
    			compatible = "ti,am335x-timer-1ms";
    			reg = <0x44e31000 0x400>;
    			interrupts = <67>;
    			ti,hwmods = "timer1";
    			ti,timer-alwon;
    		timer2: timer@48040000 {
    			compatible = "ti,am335x-timer";
    			reg = <0x48040000 0x400>;
    			interrupts = <68>;
    			ti,hwmods = "timer2";
    		timer3: timer@48042000 {
    			reg = <0x48042000 0x400>;
    			interrupts = <69>;
    			ti,hwmods = "timer3";
    		timer4: timer@48044000 {
    			reg = <0x48044000 0x400>;
    			interrupts = <92>;
    			ti,hwmods = "timer4";
    			ti,timer-pwm;
    		timer5: timer@48046000 {
    			reg = <0x48046000 0x400>;
    			interrupts = <93>;
    			ti,hwmods = "timer5";
    			ti,timer-pwm;
    		timer6: timer@48048000 {
    			reg = <0x48048000 0x400>;
    			interrupts = <94>;
    			ti,hwmods = "timer6";
    			ti,timer-pwm;
    		timer7: timer@4804a000 {
    			reg = <0x4804a000 0x400>;
    			interrupts = <95>;
    			ti,hwmods = "timer7";
    			ti,timer-pwm;
    		rtc@44e3e000 {
    			compatible = "ti,am3352-rtc";
    			reg = <0x44e3e000 0x1000>;
    			interrupts = <75
    				      76>;
    			ti,hwmods = "rtc";
    		spi0: spi@48030000 {
    			compatible = "ti,omap4-mcspi";
    			#size-cells = <0>;
    			reg = <0x48030000 0x400>;
    			interrupts = <65>;
    			ti,spi-num-cs = <2>;
    			ti,hwmods = "spi0";
    			dmas = <&edma 16
    				&edma 17
    				&edma 18
    				&edma 19>;
    			dma-names = "tx0", "rx0", "tx1", "rx1";
    		spi1: spi@481a0000 {
    			#size-cells = <0>;
    			reg = <0x481a0000 0x400>;
    			interrupts = <125>;
    			ti,hwmods = "spi1";
    			dmas = <&edma 42
    				&edma 43
    				&edma 44
    				&edma 45>;
    		usb: usb@47400000 {
    			compatible = "ti,am33xx-usb";
    			reg = <0x47400000 0x1000>;
    			ranges;
    			#size-cells = <1>;
    			ti,hwmods = "usb_otg_hs";
    			usb_ctrl_mod: control@44e10620 {
    				compatible = "ti,am335x-usb-ctrl-module";
    				reg = <0x44e10620 0x10
    					0x44e10648 0x4>;
    				reg-names = "phy_ctrl", "wakeup";
    			usb0_phy: usb-phy@47401300 {
    				compatible = "ti,am335x-usb-phy";
    				reg = <0x47401300 0x100>;
    				reg-names = "phy";
    				ti,ctrl_mod = <&usb_ctrl_mod>;
    			usb0: usb@47401000 {
    				compatible = "ti,musb-am33xx";
    				reg = <0x47401400 0x400
    					0x47401000 0x200>;
    				reg-names = "mc", "control";
    				interrupts = <18>;
    				interrupt-names = "mc";
    				dr_mode = "otg";
    				mentor,multipoint = <1>;
    				mentor,num-eps = <16>;
    				mentor,ram-bits = <12>;
    				mentor,power = <500>;
    				phys = <&usb0_phy>;
    				dmas = <&cppi41dma  0 0 &cppi41dma  1 0
    					&cppi41dma  2 0 &cppi41dma  3 0
    					&cppi41dma  4 0 &cppi41dma  5 0
    					&cppi41dma  6 0 &cppi41dma  7 0
    					&cppi41dma  8 0 &cppi41dma  9 0
    					&cppi41dma 10 0 &cppi41dma 11 0
    					&cppi41dma 12 0 &cppi41dma 13 0
    					&cppi41dma 14 0 &cppi41dma  0 1
    					&cppi41dma  1 1 &cppi41dma  2 1
    					&cppi41dma  3 1 &cppi41dma  4 1
    					&cppi41dma  5 1 &cppi41dma  6 1
    					&cppi41dma  7 1 &cppi41dma  8 1
    					&cppi41dma  9 1 &cppi41dma 10 1
    					&cppi41dma 11 1 &cppi41dma 12 1
    					&cppi41dma 13 1 &cppi41dma 14 1>;
    				dma-names =
    					"rx1", "rx2", "rx3", "rx4", "rx5", "rx6", "rx7",
    					"rx8", "rx9", "rx10", "rx11", "rx12", "rx13",
    					"rx14", "rx15",
    					"tx1", "tx2", "tx3", "tx4", "tx5", "tx6", "tx7",
    					"tx8", "tx9", "tx10", "tx11", "tx12", "tx13",
    					"tx14", "tx15";
    			usb1_phy: usb-phy@47401b00 {
    				reg = <0x47401b00 0x100>;
    				reg-names = "phy";
    			usb1: usb@47401800 {
    				reg = <0x47401c00 0x400
    					0x47401800 0x200>;
    				interrupts = <19>;
    				dr_mode = "otg";
    				phys = <&usb1_phy>;
    				dmas = <&cppi41dma 15 0 &cppi41dma 16 0
    					&cppi41dma 17 0 &cppi41dma 18 0
    					&cppi41dma 19 0 &cppi41dma 20 0
    					&cppi41dma 21 0 &cppi41dma 22 0
    					&cppi41dma 23 0 &cppi41dma 24 0
    					&cppi41dma 25 0 &cppi41dma 26 0
    					&cppi41dma 27 0 &cppi41dma 28 0
    					&cppi41dma 29 0 &cppi41dma 15 1
    					&cppi41dma 16 1 &cppi41dma 17 1
    					&cppi41dma 18 1 &cppi41dma 19 1
    					&cppi41dma 20 1 &cppi41dma 21 1
    					&cppi41dma 22 1 &cppi41dma 23 1
    					&cppi41dma 24 1 &cppi41dma 25 1
    					&cppi41dma 26 1 &cppi41dma 27 1
    					&cppi41dma 28 1 &cppi41dma 29 1>;
    				dma-names =
    					"rx14", "rx15",
    					"tx14", "tx15";
    			cppi41dma: dma-controller@47402000 {
    				compatible = "ti,am3359-cppi41";
    					0x47402000 0x1000
    					0x47403000 0x1000
    					0x47404000 0x4000>;
    				reg-names = "glue", "controller", "scheduler", "queuemgr";
    				interrupts = <17>;
    				interrupt-names = "glue";
    				#dma-cells = <2>;
    				#dma-channels = <30>;
    				#dma-requests = <256>;
    		epwmss0: epwmss@48300000 {
    			compatible = "ti,am33xx-pwmss";
    			reg = <0x48300000 0x10>;
    			ti,hwmods = "epwmss0";
    			#size-cells = <1>;
    			ranges = <0x48300100 0x48300100 0x80   /* ECAP */
    				  0x48300180 0x48300180 0x80   /* EQEP */
    				  0x48300200 0x48300200 0x80>; /* EHRPWM */
    				compatible = "ti,am33xx-ecap";
    				#pwm-cells = <3>;
    				reg = <0x48300100 0x80>;
    				ti,hwmods = "ecap0";
    			ehrpwm0: ehrpwm@48300200 {
    				compatible = "ti,am33xx-ehrpwm";
    				#pwm-cells = <3>;
    				reg = <0x48300200 0x80>;
    				ti,hwmods = "ehrpwm0";
    		epwmss1: epwmss@48302000 {
    			reg = <0x48302000 0x10>;
    			ti,hwmods = "epwmss1";
    			#size-cells = <1>;
    			ranges = <0x48302100 0x48302100 0x80   /* ECAP */
    				  0x48302180 0x48302180 0x80   /* EQEP */
    				  0x48302200 0x48302200 0x80>; /* EHRPWM */
    			ecap1: ecap@48302100 {
    				#pwm-cells = <3>;
    				reg = <0x48302100 0x80>;
    				ti,hwmods = "ecap1";
    			ehrpwm1: ehrpwm@48302200 {
    				#pwm-cells = <3>;
    				reg = <0x48302200 0x80>;
    				ti,hwmods = "ehrpwm1";
    		epwmss2: epwmss@48304000 {
    			reg = <0x48304000 0x10>;
    			ti,hwmods = "epwmss2";
    			#size-cells = <1>;
    			ranges = <0x48304100 0x48304100 0x80   /* ECAP */
    				  0x48304180 0x48304180 0x80   /* EQEP */
    				  0x48304200 0x48304200 0x80>; /* EHRPWM */
    			ecap2: ecap@48304100 {
    				#pwm-cells = <3>;
    				reg = <0x48304100 0x80>;
    				ti,hwmods = "ecap2";
    			ehrpwm2: ehrpwm@48304200 {
    				#pwm-cells = <3>;
    				reg = <0x48304200 0x80>;
    				ti,hwmods = "ehrpwm2";
    		mac: ethernet@4a100000 {
    			compatible = "ti,cpsw";
    			ti,hwmods = "cpgmac0";
    			clocks = <&cpsw_125mhz_gclk>, <&cpsw_cpts_rft_clk>;
    			clock-names = "fck", "cpts";
    			cpdma_channels = <8>;
    			ale_entries = <1024>;
    			bd_ram_size = <0x2000>;
    			no_bd_ram = <0>;
    			rx_descs = <64>;
    			mac_control = <0x20>;
    			slaves = <2>;
    			active_slave = <0>;
    			cpts_clock_mult = <0x80000000>;
    			cpts_clock_shift = <29>;
    			reg = <0x4a100000 0x800
    			       0x4a101200 0x100>;
    			#size-cells = <1>;
    			 * c0_rx_thresh_pend
    			 * c0_rx_pend
    			 * c0_tx_pend
    			 * c0_misc_pend
    			interrupts = <40 41 42 43>;
    			ranges;
    			davinci_mdio: mdio@4a101000 {
    				compatible = "ti,davinci_mdio";
    				#size-cells = <0>;
    				ti,hwmods = "davinci_mdio";
    				bus_freq = <1000000>;
    				reg = <0x4a101000 0x100>;
    			cpsw_emac0: slave@4a100200 {
    				/* Filled in by U-Boot */
    				mac-address = [ 00 00 00 00 00 00 ];
    			cpsw_emac1: slave@4a100300 {
    			phy_sel: cpsw-phy-sel@44e10650 {
    				compatible = "ti,am3352-cpsw-phy-sel";
    				reg= <0x44e10650 0x4>;
    				reg-names = "gmii-sel";
    		ocmcram: ocmcram@40300000 {
    			compatible = "ti,am3352-ocmcram";
    			reg = <0x40300000 0x10000>;
    			ti,hwmods = "ocmcram";
    		wkup_m3: wkup_m3@44d00000 {
    			compatible = "ti,am3353-wkup-m3";
    			reg = <0x44d00000 0x4000
    			       0x44d80000 0x2000
    			       0x44e11324 0x0024>;
    			reg-names = "m3_umem", "m3_dmem", "ipc_regs";
    			interrupts = <78>;
    			ti,hwmods = "wkup_m3";
    			ti,no-reset-on-init;
    			mboxes = <&mailbox &mbox_wkupm3>;
    		pruss: pruss@4a300000 {
    			compatible = "ti,am335x-pruss";
    			ti,hwmods = "pruss";
    			reg = <0x4a300000 0x2000>,
    			      <0x4a302000 0x2000>,
    			      <0x4a310000 0x3000>,
    			      <0x4a320000 0x2000>,
    			      <0x4a326000 0x2000>;
    			reg-names = "dram0", "dram1", "shrdram2", "intc", "cfg";
    			interrupts = <20 21 22 23 24 25 26 27>;
    			#size-cells = <1>;
    			ranges;
    			pru0: pru@4a334000 {
    				compatible = "ti,pru-rproc";
    				reg = <0x4a334000 0x2000>,
    				      <0x4a322000 0x400>,
    				      <0x4a322400 0x100>;
    				reg-names = "iram", "control", "debug";
    				mboxes = <&mailbox &mbox_pru0>;
    			pru1: pru@4a338000 {
    				reg = <0x4a338000 0x2000>,
    				      <0x4a324000 0x400>,
    				      <0x4a324400 0x100>;
    				mboxes = <&mailbox &mbox_pru1>;
    		elm: elm@48080000 {
    			compatible = "ti,am3352-elm";
    			reg = <0x48080000 0x2000>;
    			interrupts = <4>;
    			ti,hwmods = "elm";
    		lcdc: lcdc@4830e000 {
    			compatible = "ti,am33xx-tilcdc";
    			reg = <0x4830e000 0x1000>;
    			interrupts = <36>;
    			ti,hwmods = "lcdc";
    		tscadc: tscadc@44e0d000 {
    			compatible = "ti,am3359-tscadc";
    			reg = <0x44e0d000 0x1000>;
    			interrupts = <16>;
    			ti,hwmods = "adc_tsc";
    			tsc {
    				compatible = "ti,am3359-tsc";
    			am335x_adc: adc {
    				#io-channel-cells = <1>;
    				compatible = "ti,am3359-adc";
    		gpmc: gpmc@50000000 {
    			compatible = "ti,am3352-gpmc";
    			ti,hwmods = "gpmc";
    			ti,no-idle-on-init;
    			reg = <0x50000000 0x2000>;
    			interrupts = <100>;
    			gpmc,num-cs = <7>;
    			gpmc,num-waitpins = <2>;
    			#address-cells = <2>;
    			#size-cells = <1>;
    		sham: sham@53100000 {
    			compatible = "ti,omap4-sham";
    			ti,hwmods = "sham";
    			reg = <0x53100000 0x200>;
    			interrupts = <109>;
    			dmas = <&edma 36>;
    			dma-names = "rx";
    		aes: aes@53500000 {
    			compatible = "ti,omap4-aes";
    			ti,hwmods = "aes";
    			reg = <0x53500000 0xa0>;
    			interrupts = <103>;
    			dmas = <&edma 6>,
    			       <&edma 5>;
    		mcasp0: mcasp@48038000 {
    			compatible = "ti,am33xx-mcasp-audio";
    			ti,hwmods = "mcasp0";
    			reg = <0x48038000 0x2000>,
    			      <0x46000000 0x400000>;
    			reg-names = "mpu", "dat";
    			interrupts = <80>, <81>;
    			interrupts-names = "tx", "rx";
    			dmas = <&edma 8>,
    				<&edma 9>;
    		mcasp1: mcasp@4803C000 {
    			ti,hwmods = "mcasp1";
    			reg = <0x4803C000 0x2000>,
    			      <0x46400000 0x400000>;
    			interrupts = <82>, <83>;
    			dmas = <&edma 10>,
    				<&edma 11>;
    		rng: rng@48310000 {
    			compatible = "ti,omap4-rng";
    			ti,hwmods = "rng";
    			reg = <0x48310000 0x2000>;
    			interrupts = <111>;
    		sgx@0x56000000 {
    			compatible = "ti,sgx";
    			ti,hwmods = "gfx";
    			reg = <0x56000000 0x1000000>;
    			interrupts = <37>;
    /include/ "am33xx-clocks.dtsi"
    Apologies for the delayed response.
    You mentioned that you use a custom board, yet, I noticed that your tps, i2c & pinmux settings are the same as in am335x evm. Does your hardware matches the am335x EVM?
    Also can you stop & u-boot stage, execute printenv & paste the output here?
    Yordan
  • U-Boot#
    U-Boot#
    U-Boot#
    U-Boot#
    U-Boot#
    U-Boot#
    U-Boot# printenv
    arch=arm
    baudrate=115200
    board=am335x
    board_name=/����
    board_rev=��u�
    boot_fdt=try
    bootcmd=run findfdt; run mmcboot;setenv mmcdev 1; setenv bootpart 1:2; run mmcboot;run nandboot;
    bootcount=1
    bootdelay=1
    bootdir=/boot
    bootenv=uEnv.txt
    bootfile=zImage
    bootm_size=0x10000000
    bootpart=0:2
    cpu=armv7
    dfu_alt_info_emmc=rawemmc raw 0 3751936;boot part 1 1;rootfs part 1 2;MLO fat 1 1;MLO.raw raw 0x100 0x100;u-boot.img.raw raw 0x300 0x400;spl-os-args.raw1
    dfu_alt_info_mmc=boot part 0 1;rootfs part 0 2;MLO fat 0 1;MLO.raw raw 0x100 0x100;u-boot.img.raw raw 0x300 0x400;spl-os-args.raw raw 0x80 0x80;spl-os-i1
    dfu_alt_info_nand=SPL part 0 1;SPL.backup1 part 0 2;SPL.backup2 part 0 3;SPL.backup3 part 0 4;u-boot part 0 5;u-boot-spl-os part 0 6;kernel part 0 8;roo9
    dfu_alt_info_ram=kernel ram 0x80200000 0xD80000;fdt ram 0x80F80000 0x80000;ramdisk ram 0x81000000 0x4000000
    eth1addr=84:eb:18:e8:51:24
    ethact=cpsw
    ethaddr=84:eb:18:e8:51:22
    fdt_addr_r=0x88000000
    fdtaddr=0x88000000
    fdtfile=undefined
    findfdt=if test $board_name = A335BONE; then setenv fdtfile am335x-bone.dtb; fi; if test $board_name = A335BNLT; then setenv fdtfile am335x-boneblack.dt
    importbootenv=echo Importing environment from mmc ...; env import -t -r $loadaddr $filesize
    kernel_addr_r=0x82000000
    loadaddr=0x82000000
    loadbootenv=load mmc ${mmcdev} ${loadaddr} ${bootenv}
    loadfdt=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}
    loadimage=load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootfile}
    loadramdisk=load mmc ${mmcdev} ${rdaddr} ramdisk.gz
    mmcargs=setenv bootargs console=${console} ${optargs} root=${mmcroot} rootfstype=${mmcrootfstype}
    mmcboot=mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on device ${mmcdev};if run loadbootenv; then echo Loaded environment from ${bootenv};ru;
    mmcdev=0
    mmcloados=run mmcargs; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootz ${loadaddr} - ${fdtaddr}; else if test ${boo;
    mmcroot=/dev/mmcblk0p2 ro
    mmcrootfstype=ext4 rootwait
    mtdids=nand0=nand.0
    mtdparts=mtdparts=nand.0:128k(NAND.SPL),128k(NAND.SPL.backup1),128k(NAND.SPL.backup2),128k(NAND.SPL.backup3),256k(NAND.u-boot-spl-os),1m(NAND.u-boot),12)
    nandargs=setenv bootargs console=${console} ${optargs} root=${nandroot} rootfstype=${nandrootfstype}
    nandboot=echo Booting from nand ...; run nandargs; nand read ${fdtaddr} NAND.u-boot-spl-os; nand read ${loadaddr} NAND.kernel; bootz ${loadaddr} - ${fdt}
    nandroot=ubi0:rootfs rw ubi.mtd=NAND.file-system,2048
    nandrootfstype=ubifs rootwait=1
    netargs=setenv bootargs console=${console} ${optargs} root=/dev/nfs nfsroot=${serverip}:${rootpath},${nfsopts} rw ip=dhcp
    netboot=echo Booting from network ...; setenv autoload no; dhcp; tftp ${loadaddr} ${bootfile}; tftp ${fdtaddr} ${fdtfile}; run netargs; bootz ${loadaddr}
    nfsopts=nolock
    partitions=uuid_disk=${uuid_gpt_disk};name=rootfs,start=2MiB,size=-,uuid=${uuid_gpt_rootfs}
    ramargs=setenv bootargs console=${console} ${optargs} root=${ramroot} rootfstype=${ramrootfstype}
    ramboot=echo Booting from ramdisk ...; run ramargs; bootz ${loadaddr} ${rdaddr} ${fdtaddr}
    ramdisk_addr_r=0x88080000
    ramroot=/dev/ram0 rw
    ramrootfstype=ext2
    rdaddr=0x88080000
    rootpath=/export/rootfs
    soc=am33xx
    spiargs=setenv bootargs console=${console} ${optargs} root=${spiroot} rootfstype=${spirootfstype}
    spiboot=echo Booting from spi ...; run spiargs; sf probe ${spibusno}:0; sf read ${loadaddr} ${spisrcaddr} ${spiimgsize}; bootz ${loadaddr}
    spibusno=0
    spiimgsize=0x362000
    spiroot=/dev/mtdblock4 rw
    spirootfstype=jffs2
    spisrcaddr=0xe0000
    static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off
    stderr=serial
    stdin=serial
    stdout=serial
    usbnet_devaddr=84:eb:18:e8:51:24
    vendor=ti
    ver=U-Boot 2014.07-00107-gd28f2b9-dirty (Apr 27 2016 - 14:48:13)
    Environment size: 4709/131068 bytes
    U-Boot#
