Problem on program the 6678 DSP
I am a new guy to DSP ,And I am doing my design with TMDSEVM6678L, I read the EMIF16 User Guide , I got some idea of the registor configuration to make the port run. But I don't know the exact program code or functions, to control the EMIF16 registers(or make my ideas come true).
I watch the TI-RTOS workshop videos,read several simple source files of the workshop labs.I am aware of some basic knowledge of programming. So I can understand the basic structure of the program in workshop labs. But when it comes to some instructs specific to registers, I/O ports, I am totally confused about them.
For example, In TI-RTOS workshop lab 04, source file "main.c", subroutine called "ledToggle":
Functions like this: "CSL_FINS(gpioRegs->BANK[0].OUT_DATA,GPIO_OUT_DATA_OUT9,1);".    I cannot understand them at all !!!  I think it has some relationship about something called "API" or "LLD".
I think I lack some specific knowledge and I could not find some proper material to learn from.  What workshop , course, material or documents should I take to meet the gap??? Please help me out!
Thank you
Fantastone
  • Hi Fantastone,
    This functions starts CSL are part of CSL(Chip Select Libs) available under PDK directory. Please find the doxygen generated document available for API documentation.
    PATH: ~\ti\pdk_C6678_1_1_2_6\packages\ti\csl\docs
    The function specified above is part of cslr.h
    /* the Field INSert macro */
    #define CSL_FINS(reg, PER_REG_FIELD, val) \
    ((reg) = ((reg) & ~CSL_##PER_REG_FIELD##_MASK) \
    | CSL_FMK(PER_REG_FIELD, val))
    Thank you.
  • Hi Raja,
    Thank you ! I am searching the path ~ti\pdk_C6678_1_1_2_5\packages\ti\csl
    I found the header file named "cslr_emif16.h" , but I only got html file abuout EMIF4F in the path ~C:\ti\pdk_C6678_1_1_2_5\packages\ti\csl\docs\doxygen\html. So where can I find the explanation about EMIF16 header files?
    Thank you
    Fantastone
  • Hi Fantastone,
    We do not have any other resources to understand the code. Also you can refer the EMIF user guide. Thank you.
  • Thanks a lot for your advice. ~^_^~
