Other Parts Discussed in Thread: TVP5146, TVP7002
I am using the DVSDK (v 3.10) to capture and display a video feed. I am trying to use the Capture_detectVideoStd function to automatically detect between Composite and Component video inputs.
This scenario is not tried in DVSDK. Can you please run your application with DMAI_DEBUG=2 and send the log?
Sajesh
I set DMAI_DEBUG=2 in the environment, but the program output was the same as before.
This is the log. During the first run, the program failed to create the capture device; the second run was successful.
-sh-4.1# ./pip2
EVM: switch to tvp5146 SD video input
Encodedecode demo started.
Opening command socket: 56561
Trying input 1, std 0
starting data port: 256 x 192 (98304)
Opening data socket: 14703
EVM: switch to tvp7002 HD video input
Trying input 2, std 0
reg 0, val = 2
reg 1, val = 67
reg 2, val = 20
reg 3, val = a0
reg 4, val = 80
reg 5, val = 32
reg 6, val = 20
reg 7, val = 60
reg 8, val = 0
reg 9, val = 0
reg a, val = 0
reg b, val = 80
reg c, val = 80
reg d, val = 80
reg e, val = 20
reg f, val = 2e
reg 10, val = 5d
reg 11, val = 47
reg 12, val = 0
reg 13, val = 0
reg 14, val = 2d
reg 15, val = 47
reg 16, val = 1
reg 17, val = 0
reg 18, val = 1
reg 19, val = 0
reg 1a, val = 67
reg 1b, val = 77
reg 1c, val = 7
reg 1d, val = 0
reg 1e, val = 10
reg 1f, val = 10
reg 20, val = 10
reg 21, val = 8
reg 22, val = 0
reg 23, val = 8
reg 24, val = d2
reg 25, val = 9
reg 26, val = 80
reg 27, val = c
reg 28, val = 53
reg 29, val = 8
reg 2a, val = 7
reg 2b, val = 0
reg 2c, val = 50
reg 2d, val = 0
reg 2e, val = 80
reg 2f, val = 8c
reg 30, val = 4
reg 31, val = 5a
reg 32, val = 18
reg 33, val = 60
reg 34, val = 3
reg 35, val = 10
reg 36, val = 0
reg 37, val = 2
reg 38, val = 20
reg 39, val = 0
reg 3a, val = 0
reg 3b, val = 0
reg 3c, val = 2
reg 3d, val = 3
reg 3e, val = 4
reg 3f, val = 1
reg 40, val = 47
reg 41, val = 1
reg 42, val = 4b
reg 43, val = 6
reg 44, val = 5
reg 45, val = 0
reg 46, val = 2d
reg 47, val = 0
reg 48, val = 0
reg 49, val = 0
reg 4a, val = e3
reg 4b, val = 16
reg 4c, val = 4f
reg 4d, val = 2
reg 4e, val = ce
reg 4f, val = 6
reg 50, val = ab
reg 51, val = f3
reg 52, val = 0
reg 53, val = 10
reg 54, val = 55
reg 55, val = fc
reg 56, val = 78
reg 57, val = f1
reg 58, val = 88
reg 59, val = fe
reg 5a, val = 0
reg 5b, val = 10
tvp7002 1-005c: querystd, erorxxx, val = 1, val1 = 2
Trying input 0, std 0
davinci_resizer davinci_resizer.2: RSZ_G_CONFIG:0:1:124
CAPTURE: User resolution (720x48davinci_previewer davinci_previewer.2: ipipe_set
_preview_config
0), Video standadavinci_previewer davinci_previewer.2: ipipe_set_preview_config
rd (5)
vpfe-capture vpfe-capture: width = 720, height = 480, bpp = 2
vpfe-capture vpfe-capture: adjusted width = 720, height = 480, bpp = 2, bytesper
line = 1440, sizeimage = 691200
Error: Failed to create capture device
Display: InputStd 5
Process one buffer to figure out buffer requirements
davinci_v4l2 davinci_v4l2.1: Before finishing with S_FMT:
layer.pix_fmt.bytesperline = 736,
layer.pix_fmt.width = 720,
layer.pix_fmt.height = 480,
layer.pix_fmt.sizeimage =529920
davinci_v4l2 davinci_v4l2.1: pixfmt->width = 720,
layer->layer_info.config.line_length= 736
^C
-sh-4.1# echo $DMAI_DEBUG
2
-sh-4.1# ./pip2
vpfe-capture vpfe-capture: IPIPE Chained
Trying input 1, vpfe-capture vpfe-capture: Resizer present
std 0
reg 0, val = 2
reg 1, val = 67
reg 2, val = 20
reg 3, val = a0
reg 4, val = 80
reg 5, val = 32
reg 6, val = 20
reg 7, val = 60
reg 8, val = 0
reg 9, val = 0
reg a, val = 0
reg b, val = 80
reg c, val = 80
reg d, val = 80
reg e, val = 20
reg f, val = 2e
reg 10, val = 5d
reg 11, val = 47
reg 12, val = 0
reg 13, val = 0
reg 14, val = 2d
reg 15, val = 47
reg 16, val = 1
reg 17, val = 0
reg 18, val = 1
reg 19, val = 0
reg 1a, val = 67
reg 1b, val = 77
reg 1c, val = 7
reg 1d, val = 0
reg 1e, val = 10
reg 1f, val = 10
reg 20, val = 10
reg 21, val = 8
reg 22, val = 0
reg 23, val = 8
reg 24, val = d2
reg 25, val = 9
reg 26, val = 80
reg 27, val = c
reg 28, val = 53
reg 29, val = 8
reg 2a, val = 7
reg 2b, val = 0
reg 2c, val = 50
reg 2d, val = 0
reg 2e, val = 80
reg 2f, val = 8c
reg 30, val = 4
reg 31, val = 5a
reg 32, val = 18
reg 33, val = 60
reg 34, val = 3
reg 35, val = 10
reg 36, val = 0
reg 37, val = 2
reg 38, val = 20
reg 39, val = 0
reg 3a, val = 0
reg 3b, val = 0
reg 3c, val = 2
reg 3d, val = 3
reg 3e, val = 4
reg 3f, val = 1
reg 40, val = 47
reg 41, val = 1
reg 42, val = 4b
reg 43, val = 6
reg 44, val = 5
reg 45, val = 0
reg 46, val = 2d
reg 47, val = 0
reg 48, val = 0
reg 49, val = 0
reg 4a, val = e3
reg 4b, val = 16
reg 4c, val = 4f
reg 4d, val = 2
reg 4e, val = ce
reg 4f, val = 6
reg 50, val = ab
reg 51, val = f3
reg 52, val = 0
reg 53, val = 10
reg 54, val = 55
reg 55, val = fc
reg 56, val = 78
reg 57, val = f1
reg 58, val = 88
reg 59, val = fe
reg 5a, val = 0
reg 5b, val = 10
_preview_config
rd (5)
vpfe-capture vpfe-capture: width = 720, height = 480, bpp = 1
vpfe-capture vpfe-capture: adjusted width = 720, height = 480, bpp = 1, bytesper
line = 736, sizeimage = 529920
Display: InputStd 5
Prime the display thread
dst = 0,0, Dim = 720 x 480
pip = 144,240, Dim = 128 x 96
tvp514x 1-005d: Write: retry ... 0
^Ctvp514x 1-005d: Write: retry ... 1
tvp514x 1-005d: Write: retry ... 2
tvp514x 1-005d: Write: retry ... 3
tvp514x 1-005d: Write: retry ... 4
tvp514x 1-005d: Write: retry ... 5
tvp514x 1-005d: Unable to turn off decoder
vpfe-capture vpfe-capture: stream off failed in subdev
-sh-4.1#
It appears that the colorSpace parameter is being lost when it fails. I set colorSpace to YUV420PSEMI for each call in my capture routine, but the log shows it reverts to bpp=2 and bytesperline=1440 when it fails. Also notice the "IPIPE Chained" message when the program succeeds.
-sh-4.1# DMAI_DEBUG=2 ./pip2
@0x000e5607:[T:0x4001ef80] ti.sdo.dmai - [Dmai] Dmai log level sEVM: switch to t
et to '2'. Note that calling CERuntime_init after this point may cause unexpecte
d change to DMAI tracing behavior.
@0x000fe407:[T:0x4001ef80] ti.sdo.dmai - [Display] Found width=720 height=480, y
res_virtual=480,xres_virtual=720, line_length=384
@0x000fe555:[T:0x4001ef80] ti.sdo.dmai - [Display] Setting width=720 height=480,
yres_virtual=480, xres_virtual=720
@0x000fe65c:[T:0x4001ef80] ti.sdo.dmai - [Display] New width=720, height=480, yr
@0x000fe78a:[T:0x4001ef80] ti.sdo.dmai - [BufTab] Allocating BufTab for 1 buffer
s
@0x000fea0f:[T:0x4001ef80] ti.sdo.dmai - [Buffer] Set user pointer 0x403eb000 (p
hysical 0x83300000)
@0x000fef55:[T:0x4001ef80] ti.sdo.dmai - [Display] Display buffer 0 mapped to 0x
403eb000 has physical address 0
@0x001017ce:[T:0x41c17470] ti.sdo.dmai - [Capture] Composite input selected
@0x002684fd:[T:0x41c17470] ti.sdo.dmai - [Capture] Failed to set video input to
0 (Invalid argument)
@0x002690c5:[T:0x41c17470] ti.sdo.dmai - [Capture] Component input selected
@0x0026a3e4:[T:0x41c17470] ti.sdo.dmai - [Capture] Checking video standard
reg 0, val = 2
reg 1, val = 67
reg 2, val = 20
reg 3, val = a0
reg 4, val = 80
reg 5, val = 32
reg 6, val = 20
reg 7, val = 60
reg 8, val = 0
reg 9, val = 0
reg a, val = 0
reg b, val = 80
reg c, val = 80
reg d, val = 80
reg e, val = 20
reg f, val = 2e
reg 10, val = 5d
reg 11, val = 47
reg 12, val = 0
reg 13, val = 0
reg 14, val = 2d
reg 15, val = 47
reg 16, val = 1
reg 17, val = 0
reg 18, val = 1
reg 19, val = 0
reg 1a, val = 67
reg 1b, val = 77
reg 1c, val = 7
reg 1d, val = 0
reg 1e, val = 10
reg 1f, val = 10
reg 20, val = 10
reg 21, val = 8
reg 22, val = 0
reg 23, val = 8
reg 24, val = d2
reg 25, val = 9
reg 26, val = 80
reg 27, val = c
reg 28, val = 53
reg 29, val = 8
reg 2a, val = 7
reg 2b, val = 0
reg 2c, val = 50
reg 2d, val = 0
reg 2e, val = 80
reg 2f, val = 8c
reg 30, val = 4
reg 31, val = 5a
reg 32, val = 18
reg 33, val = 60
reg 34, val = 3
reg 35, val = 10
reg 36, val = 0
reg 37, val = 2
reg 38, val = 20
reg 39, val = 0
reg 3a, val = 0
reg 3b, val = 0
reg 3c, val = 2
reg 3d, val = 3
reg 3e, val = 4
reg 3f, val = 1
reg 40, val = 47
reg 41, val = 1
reg 42, val = 4b
reg 43, val = 6
reg 44, val = 5
reg 45, val = 0
reg 46, val = 2d
reg 47, val = 0
reg 48, val = 0
reg 49, val = 0
reg 4a, val = e3
reg 4b, val = 16
reg 4c, val = 4f
reg 4d, val = 2
reg 4e, val = ce
reg 4f, val = 6
reg 50, val = ab
reg 51, val = f3
reg 52, val = 0
reg 53, val = 10
reg 54, val = 55
reg 55, val = fc
reg 56, val = 78
reg 57, val = f1
reg 58, val = 88
reg 59, val = fe
reg 5a, val = 0
reg 5b, val = 10
@0x002f082d:[T:0x41c17470] ti.sdo.dmai - [Capture] VIDIOC_QUERYSTD failed on /de
v/video0. Video input connected?
@0x002f11ef:[T:0x41c17470] ti.sdo.dmai - [Capture] S-Video input selected
@0x0038a57a:[T:0x41c17470] ti.sdo.dmai - [Capture] Checking video standard
@0x003bdd3a:[T:0x41c17470] ti.sdo.dmai - [Capturdavinci_previewer davinci_previe
e] Capture inputdavinci_previewer davinci_previewer.2: ipipe_set_preview_config
set to S-Video:5
CAPTURE: User resolution (720EVM: switch to tvp5146 SD video input
x480), Video standard (5)
@0x003be4c8:[T:0x41c17470] ti.sdo.dmai - [BufTab] Allocating BufTab for 3 buffer
s
@0x003bec86:[T:0x41c17470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 529920 at
0x42418000 (0x86ee2000 phys)
@0x003bf59e:[T:0x41c17470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 529920 at
0x42592000 (0x871d6000 phys)
@0x003bff41:[T:0x41c17470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 529920 at
0x4270c000 (0x86a74000 phys)
@0x003c083e:[T:0x41c17470] ti.sdo.dmai - [Resize] Successfully set mode to conti
nuous in resizer
@0x003c23af:[T:0x41c17470] ti.sdo.dmai - [Resize] Resizer initialized
@0x003c2bc3:[T:0x41c17470] ti.sdo.dmai - [Resize] Operating mode changed success
fully to continuous in previewer@0x003c651f:[T:0x41c17470] ti.sdo.dmai - [Resize
] Previewer initialized
@0x003c6c59:[T:0x41c17470] ti.sdo.dmai - [Capture] S-Video input selected
@0x00461626:[T:0vpfe-capture vpfe-capture: adjusted width = 720, height = 480, b
pp = 2, bytesperline = 1440, sizeimage = 691200
x41c17470] ti.sdvpfe-capture vpfe-capture: width = 720, height = 480, bpp = 2
o.dmai - [Capturvpfe-capture vpfe-capture: adjusted width = 720, height = 480, b
e] Capture input set to S-Video:5
@0x00461a1d:[T:0x41c17470] ti.sdo.dmai - [Capture] Capture dimention is set to 4
80x720
@0x0046aaa1:[T:0x41c17470] ti.sdo.dmai - [Capture] Pixel format 0x3231564e not s
upported. Received 0x59565955
Display: InputStd 5
@0x0046c2dc:[T:0x43085470] ti.sdo.dmai - [BufTab] Allocating BufTab for 4 buffer
s
@0x0046c535:[T:0x43085470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 529920 at
0x43086000 (0x86606000 phys)
@0x0046c7b9:[T:0x43085470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 529920 at
0x43200000 (0x86bee000 phys)
@0x0046ca6e:[T:0x43085470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 529920 at
0x4337a000 (0x86d68000 phys)
@0x0046cceb:[T:0x43085470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 529920 at
0x434f4000 (0x85d2a000 phys)
@0x0046cfda:[T:0x43085470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 73728 at
0x4366e000 (0x87d36000 phys)
@0x0046e48f:[T:0x43e82470] ti.sdo.dmai - [BufTab] Allocating BufTab for 8 buffer
s
@0x0046edcf:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 518400 at
0x43e83000 (0x86198000 phys)
@0x0046f7ca:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 518400 at
0x43ffd000 (0x86312000 phys)
@0x00470145:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Bufdavinci_v4l2 davinci_
fer of size 5184davinci_v4l2 davinci_v4l2.1: pixfmt->width = 720,
00 at 0x44177000 (0x8648c000 phys)
@0x00470b81:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 518400 at
0x442f1000 (0x8705c000 phys)
@0x004714cb:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 518400 at
0x4446b000 (0x868fa000 phys)
@0x00471ea2:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 518400 at
0x445e5000 (0x86780000 phys)
@0x00472823:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 518400 at
0x4475f000 (0x8601e000 phys)
@0x004731b4:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 518400 at
0x448d9000 (0x85ea4000 phys)
@0x00485a77:[T:0x43085470] ti.sdo.dmai - [Display] Video output set to size 720x
480 pitch 736 imageSize 529920
@0x00490257:[T:0x43085470] ti.sdo.dmai - [Buffer] Free Buffer of size 529920 at
@0x004909c3:[T:0x43085470] ti.sdo.dmai - [Buffer] Free Buffer of size 529920 at
@0x004910bf:[T:0x43085470] ti.sdo.dmai - [Buffer] Free Buffer of size 529920 at
@0x00491892:[T:0x43085470] ti.sdo.dmai - [Buffer] Free Buffer of size 529920 at
@0x00491fd3:[T:0x43085470] ti.sdo.dmai - [Buffer] Free Buffer of size 73728 at 0
@0x004925b6:[T:0x41c17470] ti.sdo.dmai - [Buffer] Free Buffer of size 529920 at
@0x004942f0:[T:0x41c17470] ti.sdo.dmai - [Buffer] Free Buffer of size 529920 at
@0x00496149:[T:0x41c17470] ti.sdo.dmai - [Buffer] Free Buffer of size 529920 at
@0x00498570:[T:0x43e82470] ti.sdo.dmai - [Buffer] Free Buffer of size 518400 at
@0x0049a360:[T:0x43e82470] ti.sdo.dmai - [Buffer] Free Buffer of size 518400 at
@0x0049c131:[T:0x43e82470] ti.sdo.dmai - [Buffer] Free Buffer of size 518400 at
@0x0049df1b:[T:0x43e82470] ti.sdo.dmai - [Buffer] Free Buffer of size 518400 at
@0x0049fc00:[T:0x43e82470] ti.sdo.dmai - [Buffer] Free Buffer of size 518400 at
@0x004a1c84:[T:0x43e82470] ti.sdo.dmai - [Buffer] Free Buffer of size 518400 at
@0x004a3a5b:[T:0x43e82470] ti.sdo.dmai - [Buffer] Free Buffer of size 518400 at
@0x004a59b2:[T:0x43e82470] ti.sdo.dmai - [Buffer] Free Buffer of size 518400 at
^C
@0x0005ed08:[T:0x4001ef80] ti.sdo.dmai - [Dmai] Dmai log level set to '2'. Note
that calling CERuntime_init after this point may cause unexpected change to DMAI
tracing behaviovpfe-capture vpfe-capture: IPIPE Chained
r.
@0x00078007:vpfe-capture vpfe-capture: Resizer present
[T:0x4001ef80] tEVM: switch to tvp5146 SD video input
i.sdo.dmai - [Display] Found width=720 height=480, yres_virtual=480,xres_virtual
@0x00078156:[T:0x4001ef80] ti.sdo.dmai - [Display] Setting width=720 height=480,
@0x0007825e:[T:0x4001ef80] ti.sdo.dmai - [Display] New width=720, height=480, yr
@0x00078392:[T:0x4001ef80] ti.sdo.dmai - [BufTab] Allocating BufTab for 1 buffer
s
@0x00078642:[T:0x4001ef80] ti.sdo.dmai - [Buffer] Set user pointer 0x403eb000 (p
hysical 0x83300000)
@0x00078bba:[T:0x4001ef80] ti.sdo.dmai - [Display] Display buffer 0 mapped to 0x
@0x0007da0b:[T:0x41c17470] ti.sdo.dmai - [Capture] Composite input selected
@0x001e46b4:[T:0x41c17470] ti.sdo.dmai - [Capture] Failed to set video input to
@0x001e5268:[T:0x41c17470] ti.sdo.dmai - [Capture] Component input selected
@0x001e65cd:[T:0x41c17470] ti.sdo.dmai - [Capture] Checking video standard
reg 0, val = 2
reg 1, val = 67
reg 2, val = 20
reg 3, val = a0
reg 4, val = 80
reg 5, val = 32
reg 6, val = 20
reg 7, val = 60
reg 8, val = 0
reg 9, val = 0
reg a, val = 0
reg b, val = 80
reg c, val = 80
reg d, val = 80
reg e, val = 20
reg f, val = 2e
reg 10, val = 5d
reg 11, val = 47
reg 12, val = 0
reg 13, val = 0
reg 14, val = 2d
reg 15, val = 47
reg 16, val = 1
reg 17, val = 0
reg 18, val = 1
reg 19, val = 0
reg 1a, val = 67
reg 1b, val = 77
reg 1c, val = 7
reg 1d, val = 0
reg 1e, val = 10
reg 1f, val = 10
reg 20, val = 10
reg 21, val = 8
reg 22, val = 0
reg 23, val = 8
reg 24, val = d2
reg 25, val = 9
reg 26, val = 80
reg 27, val = c
reg 28, val = 53
reg 29, val = 8
reg 2a, val = 7
reg 2b, val = 0
reg 2c, val = 50
reg 2d, val = 0
reg 2e, val = 80
reg 2f, val = 8c
reg 30, val = 4
reg 31, val = 5a
reg 32, val = 18
reg 33, val = 60
reg 34, val = 3
reg 35, val = 10
reg 36, val = 0
reg 37, val = 2
reg 38, val = 20
reg 39, val = 0
reg 3a, val = 0
reg 3b, val = 0
reg 3c, val = 2
reg 3d, val = 3
reg 3e, val = 4
reg 3f, val = 1
reg 40, val = 47
reg 41, val = 1
reg 42, val = 4b
reg 43, val = 6
reg 44, val = 5
reg 45, val = 0
reg 46, val = 2d
reg 47, val = 0
reg 48, val = 0
reg 49, val = 0
reg 4a, val = e3
reg 4b, val = 16
reg 4c, val = 4f
reg 4d, val = 2
reg 4e, val = ce
reg 4f, val = 6
reg 50, val = ab
reg 51, val = f3
reg 52, val = 0
reg 53, val = 10
reg 54, val = 55
reg 55, val = fc
reg 56, val = 78
reg 57, val = f1
reg 58, val = 88
reg 59, val = fe
reg 5a, val = 0
reg 5b, val = 10
@0x00272960:[T:0x41c17470] ti.sdo.dmai - [Capture] VIDIOC_QUERYSTD failed on /de
@0x00273340:[T:0x41c17470] ti.sdo.dmai - [Capture] S-Video input selected
@0x0030dd3e:[T:0x41c17470] ti.sdo.dmai - [Capture] Checking video standard
@0x00341640:[T:0x41c17470] ti.sdo.dmai - [Capturdavinci_previewer davinci_previe
set to S-Video:5
@0x00341d3d:[T:0x41c17470] ti.sdo.dmai - [BufTab] Allocating BufTab for 3 buffer
s
@0x003425b9:[T:0x41c17470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 529920 at
0x42418000 (0x85ea4000 phys)
@0x00342e4f:[T:0x41c17470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 529920 at
0x42592000 (0x8601e000 phys)
@0x0034380d:[T:0x41c17470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 529920 at
0x4270c000 (0x86780000 phys)
@0x003441b8:[T:0x41c17470] ti.sdo.dmai - [Resize] Successfully set mode to conti
nuous in resizer
@0x00345d51:[T:0x41c17470] ti.sdo.dmai - [Resize] Resizer initialized
@0x0034654a:[T:0x41c17470] ti.sdo.dmai - [Resize] Operating mode changed success
fully to continuous in previewer@0x00349ecf:[T:0x41c17470] ti.sdo.dmai - [Resize
@0x0034a71b:[T:0x41c17470] ti.sdo.dmai - [Capture] S-Video input selected
@0x003e4dca:[T:0vpfe-capture vpfe-capture: adjusted width = 720, height = 480, b
pp = 1, bytesperline = 736, sizeimage = 529920
x41c17470] ti.sdvpfe-capture vpfe-capture: width = 720, height = 480, bpp = 1
@0x003e51ca:[T:0x41c17470] ti.sdo.dmai - [Capture] Capture dimention is set to 4
80x720
@0x003ee18d:[T:0x41c17470] ti.sdo.dmai - [Capture] Video input connected size 72
0x480 pitch 736
Display: InputStdavinci_v4l2 davinci_v4l2.1: pixfmt->width = 720,
d 5
@0x0041370a:[T:0x43085470] ti.sdo.dmai - [BufTab] Allocating BufTab for 4 buffer
s
@0x0041394e:[T:0x43085470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 529920 at
0x43086000 (0x868fa000 phys)
@0x00413be0:[T:0x43085470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 529920 at
0x43200000 (0x8705c000 phys)
@0x00413e7c:[T:0x43085470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 529920 at
0x4337a000 (0x8648c000 phys)
@0x00414180:[T:0x43085470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 529920 at
0x434f4000 (0x86312000 phys)
@0x0041439e:[T:0x43085470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 73728 at
@0x00415932:[T:0x43e82470] ti.sdo.dmai - [BufTab] Allocating BufTab for 8 buffer
s
@0x00416272:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 518400 at
@0x00416c02:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 518400 at
0x43ffd000 (0x86a74000 phys)
@0x00417688:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 518400 at
0x44177000 (0x871d6000 phys)
@0x0041800f:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 518400 at
0x442f1000 (0x86ee2000 phys)
@0x0041895c:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 518400 at
0x4446b000 (0x85d2a000 phys)
@0x00419390:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 518400 at
0x445e5000 (0x86d68000 phys)
@0x00419e14:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 518400 at
0x4475f000 (0x86bee000 phys)
@0x0041a6e1:[T:0x43e82470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 518400 at
0x448d9000 (0x86606000 phys)
@0x0042b4fd:[T:0x43085470] ti.sdo.dmai - [Display] Video output set to size 720x
@0x00440274:[T:0x43085470] ti.sdo.dmai - [Buffer] Alloc Buffer of size 18432 at
0x44a53000 (0x87d4a000 phys)
-sh-4.1#
As before, the first run failed at Capture_create, and the second run was successful.
Thanks for the log. This looks like a real issue. We will debug further and get back to you.
Sajesh
We have filed an incident report to track this issue. The link to the report is SDOCM00071225
Sajesh
