My question is how to interface a FPGA. The FPGA is already interfaced with a sensor using i2c(for sensor configuration), meanwhile the data from sensor ate stored in the system mermory.
The DSP is used to configure the sensor via FPGA and get the data from the system memory, which means, DSP send command to FPGA such as take a photo at a certain resolution,then FPGA transfer the resolution parameter to sensor and store the data in the memory.
I don't know if the approch is reasonable and this is what I'm planning to do base on some research. I want to know how could I interface TI with FPGA.
Thanks for your attention and responses.
