I have asked a question when I get a trouble in rebuilding IPC LIB at
Now I have pass this question and get the "ipc_3_42_00_02_lib" and "ti_platforms_evmC66AK2E_core0" folders. However, when I want to get further to build ex02_messageq in the example folder, an error appears that bin/debug/obj/main_host.ov7A: file not recognized: File format not recognized. What should I do and the product.mak in "ipc_3_42_00_02/examples/66AK2E_linux_elf/ex02_messageq" folder are as follows.
# # Copyright (c) 2012-2015 Texas Instruments Incorporated - http://www.ti.com # All rights reserved. # # Redistribution and use in source and binary forms, with or without # modification, are permitted provided that the following conditions # are met: # # * Redistributions of source code must retain the above copyright # notice, this list of conditions and the following disclaimer. # # * Redistributions in binary form must reproduce the above copyright # notice, this list of conditions and the following disclaimer in the # documentation and/or other materials provided with the distribution. # # * Neither the name of Texas Instruments Incorporated nor the names of # its contributors may be used to endorse or promote products derived # from this software without specific prior written permission. # # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" # AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, # THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR # PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR # CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, # EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, # PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; # OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, # WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR # OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, # EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. # # # ======== products.mak ======== # # look for other products.mak file to override local settings ifneq (,$(wildcard $(EXBASE)/../products.mak)) include $(EXBASE)/../products.mak else ifneq (,$(wildcard $(EXBASE)/../../products.mak)) include $(EXBASE)/../../products.mak/ # Define IPC_INSTALL_DIR since not defined in IPC top-level products.mak IPC_INSTALL_DIR = $(word 1,$(subst /examples, examples,$(CURDIR))) endif endif # By default, the necessary build variables are found/assigned via # ../products.mak or ../../products.mak, included above. If you want to # override these variables, or are building this example without # ../products.mak or ../../products.mak, uncomment and assign the variables # below. #DEPOT = _your_depot_folder_ #### Linux toolchain #### TOOLCHAIN_LONGNAME = arm-linux-gnueabihf TOOLCHAIN_INSTALL_DIR = /usr/local/gcc-linaro-4.9-2015.05-x86_64_arm-linux-gnueabihf TOOLCHAIN_PREFIX = $(TOOLCHAIN_INSTALL_DIR)/bin/$(TOOLCHAIN_LONGNAME)- #### BIOS-side dependencies #### BIOS_INSTALL_DIR = /usr/local/ti/bios_6_41_04_54 IPC_INSTALL_DIR = /usr/local/ti/ipc_3_42_00_02 XDC_INSTALL_DIR = /usr/local/ti/xdctools_3_32_00_06_core #### BIOS-side toolchains #### gnu.targets.arm.A15F = /usr/local/gcc-linaro-4.9-2015.05-x86_64_arm-linux-gnueabihf ti.targets.elf.C66 = /usr/local/ti/ccsv6/tools/compiler/C6000CGT7.4.4 # Use this goal to print your product variables. .show: @echo "HOST TOOLCHAIN_PREFIX = $(TOOLCHAIN_PREFIX)" @echo "BIOS_INSTALL_DIR = $(BIOS_INSTALL_DIR)" @echo "IPC_INSTALL_DIR = $(IPC_INSTALL_DIR)" @echo "XDC_INSTALL_DIR = $(XDC_INSTALL_DIR)" @echo "gnu.targets.arm.A15F = $(gnu.targets.arm.A15F)" @echo "ti.targets.elf.C66 = $(ti.targets.elf.C66)"
Anything wrong in the product.mak?
