PDK for K2K EVM
Other Parts Discussed in Thread: MATHLIB, SYSBIOS
Hello TI,
could you please provide the link of  latest PDK for  K2K boards?
Manjunath
  • Hi Manjunath,
    You can download the latest Processor SDK of K2H for PDK of K2K. The K2H and K2K shares the same PDK.
    The directory name is pdk_k2hk_X_x_x
    PATH: ~\ti\pdk_k2hk_X_x_x\packages\ti
    Please find the Processor SDK download link below my signature. Thank you.
  • Hello Raja,
    thanks for the update and installed PDK for k2K
    Now I want to generate test project 'PA_emacExample" project for K2K I followed below steps
    1)run -->pdksetupenv.bat
    2)pdkProjectCreate.bat K2K all little all arm
    I am facing below error while generating test project
    !ERROR: Unknown RTSC product-type ID 'com.ti.pdk.k2k'!"
    could you please help? could you share PA_emacExample_K2KArmBiosExampleProject as ccs project???
    its little urgent for us
    Detected Test Project: PA_emacExample_K2KArmBiosExampleProject
    Creating project 'PA_emacExample_K2KArmBiosExampleProject'...
    NOTE: Refer to the following list of available RTSC product-type IDs (the di
    splay-names in square brackets are for reference only):
    com.ti.ctoolslib [CTools Library]
    ti.mas.dsplib.c66x [DSPLIB C66x]
    com.ti.sdo.edma3 [EDMA3 Low Level Driver]
    com.ti.rtsc.FrameworkComponents [Framework Components]
    ti.imglib.c66x [IMGLIB C66x]
    com.ti.rtsc.IPC [IPC]
    ti.pdk [Keystone2 PDK]
    ti.mathlib.c66x [MATHLIB C66x]
    com.ti.biosmcsdk.mcsdk [MCSDK]
    com.ti.rtsc.NDK [NDK]
    com.ti.rtsc.openmp [OpenMP Runtime 2.x library]
    com.ti.rtsc.SYSBIOS [SYS/BIOS]
    com.ti.uia [System Analyzer (UIA Target)]
    com.ti.rtsc.TIRTOSc2000 [TI-RTOS for C2000]
    com.ti.rtsc.XDAIS [XDAIS]
    com.ti.pdk.k2l [k2l PDK]
    Copying macro.ini
    The system cannot find the path specified.
    0 file(s) copied.
    Manjunath
  • HI,
    Open the CCS and discover the newly installed packages.
    Once this step is done, carry out the same steps you did. That particular error will get vanished.
    If CCS is already opened, close and reopen again.
    Let me know how it goes for you.
    I came across this issue and this was the work around. Actually, Once the products are discovered by the CCS,
    system paths were set it right.
  • Hello Shankari,
    Thanks for the update , I tried the steps suggested by you, my ccs discovered the pdk and I installed it.
    after that I followed same steps
    still the error is same
    Copying macro.ini
    0 file(s) copied.
    it would be helpful if you could share 'PA_emacExample_K2KArmBiosExampleProject'
    regards
    manjunath
  • Hello shankari,
    I was able to solve the error by rebooting my machine.
    thanks for your help
  • Thank you so much for the update. We are glad that the issue has been resolved.
