I have downloaded the ti-processor-sdk-linux-k2e-evm and run the setup.sh as the SDK getting started guide told. But it says it can't find my K2E EVM as follows.
root@hjj64-virtual-machine:~# cd /usr/local/ti/ti-processor-sdk-linux-k2e-evm-02.00.01.07/
root@hjj64-virtual-machine:/usr/local/ti/ti-processor-sdk-linux-k2e-evm-02.00.01.07# ./setup.sh
TISDK setup script
This script will set up your development host for SDK development.
Parts of this script require administrator priviliges (sudo access).
Verifying Linux host distribution
Ubuntu 12.04 LTS and Ubuntu 14.04 LTS is being used, continuing..
Starting with Ubuntu 12.04 serial devices are only accessible by members of the 'dialout' group.
A user must be apart of this group to have the proper permissions to access a serial device.
Are you running this script using sudo? The detected username is 'root'.
Verify and enter your Linux username below
[ root ]
User 'root' is already apart of the 'dialout' group
setup package script
This script will make sure you have the proper host support packages installed
This script requires administrator priviliges (sudo access) if packages are to be installed.
System has required packages!
Package verification and installation successfully completed
In which directory do you want to install the target filesystem?(if this directory does not exist it will be created)
[ /usr/local/ti/ti-processor-sdk-linux-k2e-evm-02.00.01.07/targetNFS ]
This step will extract the target filesystem to /usr/local/ti/ti-processor-sdk-linux-k2e-evm-02.00.01.07/targetNFS
Note! This command requires you to have administrator priviliges (sudo access)
on your host.
Press return to continue
/usr/local/ti/ti-processor-sdk-linux-k2e-evm-02.00.01.07/targetNFS already exists
(r) rename existing filesystem (o) overwrite existing filesystem (s) skip filesystem extraction
[r] s
Skipping filesystem extraction
WARNING! Keeping the previous filesystem may cause compatibility problems if you are upgrading the SDK
This step will set up the SDK to install binaries in to:
/usr/local/ti/ti-processor-sdk-linux-k2e-evm-02.00.01.07/targetNFS/home/root/k2e-evm
The files will be available from /home/root/k2e-evm on the target.
This setting can be changed later by editing Rules.make and changing the
EXEC_DIR or DESTDIR variable (depending on your SDK).
Rules.make edited successfully..
This step will export your target filesystem for NFS access.
on your host.
/usr/local/ti/ti-processor-sdk-linux-k2e-evm-02.00.01.07/targetNFS already NFS exported, skipping..
* Stopping NFS kernel daemon [ OK ]
* Unexporting directories for NFS kernel daemon... [ OK ]
* Exporting directories for NFS kernel daemon... [ OK ]
* Starting NFS kernel daemon [ OK ]
Which directory do you want to be your tftp root directory?(if this directory does not exist it will be created for you)
[ /tftpboot ]
This step will set up the tftp server in the /tftpboot directory.
on your host.
/tftpboot already exists, not creating..
/tftpboot/zImage-k2e-evm.bin already exists. The existing installed file can be renamed and saved under the new name.
(r) rename (o) overwrite (s) skip copy
[r] s
Skipping copy of zImage-k2e-evm.bin, existing version will be used
/tftpboot/k2e-evm.dtb already exists. The existing installed file can be renamed and saved under the new name.
[o] s
Skipping copy of k2e-evm.dtb, existing version will be used
/tftpboot/u-boot-spi-k2e-evm.gph already exists. The existing installed file can be renamed and saved under the new name.
[o] s
Skipping copy of u-boot-spi-k2e-evm.gph, existing version will be used
/tftpboot/skern-k2e.bin already exists. The existing installed file can be renamed and saved under the new name.
[o] s
Skipping copy of skern-k2e.bin, existing version will be used
/tftpboot/k2-fw-initrd.cpio.gz already exists. The existing installed file can be renamed and saved under the new name.
[o] s
Skipping copy of k2-fw-initrd.cpio.gz, existing version will be used
/etc/xinetd.d/tftp already exists..
/tftpboot already exported for TFTP, skipping..
Restarting tftp server
* Stopping internet superserver xinetd [ OK ]
* Starting internet superserver xinetd [ OK ]
This step will set up minicom (serial communication application) for
SDK development
For boards that contain a USB-to-Serial converter on the board such as:
* BeagleBone
* Beaglebone Black
* AM335x EVM-SK
* AM57xx EVM
* K2H, K2L, and K2E EVMs
the port used for minicom will be automatically detected. By default Ubuntu
will not recognize this device. Setup will add a udev rule to
/etc/udev/ so that from now on it will be recognized as soon as the board is
plugged in.
For other boards, the serial will defualt to /dev/ttyS0. Please update based
on your setup.
NOTE: If your using any of the above boards simply hit enter
and the correct port will be determined automatically at a
later step. For all other boards select the serial port
that the board is connected to.
Which serial port do you want to use with minicom?
[ /dev/ttyS0 ] /dev/ttyS1
Copied existing /root/.minirc.dfl to /root/.minirc.dfl.old
Configuration saved to /root/.minirc.dfl. You can change it further from inside
minicom, see the Software Development Guide for more information.
This step will set up the u-boot variables for booting the EVM.
Autodetected the following ip address of your host, correct it if necessary
[ ] 192.168.1.20
/tftpboot/arago-base-tisdk-image-k2e-evm.ubi already exists. The existing installed file can be renamed and saved under the new name.
[o] s
Skipping copy of arago-base-tisdk-image-k2e-evm.ubi, existing version will be used
/tftpboot/tisdk-server-rootfs-image-k2e-evm.ubi already exists. The existing installed file can be renamed and saved under the new name.
[o] s
Skipping copy of tisdk-server-rootfs-image-k2e-evm.ubi, existing version will be used
Would you like to update U-boot on the board (y/n)?
[ y ] y
Select secondary boot:
1: NFS
2: UBI
[ 1 ]
Available kernel images in /tftpboot:
k2e-evm.dtb
skern-k2e.bin
zImage-k2e-evm.bin
Which kernel image do you want to boot from TFTP?
[ zImage-k2e-evm.bin ]
Would you like to create a minicom script with the above parameters (y/n)?
[ y ]
Successfully wrote /usr/local/ti/ti-processor-sdk-linux-k2e-evm-02.00.01.07/bin/setupBoard.minicom
Board could not be detected. Please connect the board to the PC.
Press any key to try checking again.
There are two manual setting. One is /dev/ttyS1 and the other is IP address 192.168.1.20.
I get the information successfully in ttyS1 like what shows below
So /dev/ttyS1 seems right and IP address I think it doesn't matter.
Is there anything I should set on K2E EVM board? When should I connect the board to PC? When should I power on?
