Cant able to load image through mpmcl
I am trying to load mpmsrv_keystone2_example.out to slave dsp's using mpmcl.
This image comes in default MCSDK package.
When i  try to load  the image using mpmcl command , i get error msg in /var/log/syslog
mpmcl load dsp0 mpmsrv_keystone2_example.out
Jan  9 00:09:20 k2hk-evm kernel: [  141.089219] keystone-rproc 10800000.dsp0: assigned reserved memory node dsp_common_cma_pool
Jan  9 00:09:20 k2hk-evm kernel: [  141.097707]  remoteproc0: 10800000.dsp0 is available
Jan  9 00:09:20 k2hk-evm kernel: [  141.102735]  remoteproc0: Note: remoteproc is still under development and considered experimental.
Jan  9 00:09:20 k2hk-evm kernel: [  141.111617]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
Jan  9 00:09:20 k2hk-evm kernel: [  141.126378] keystone-rproc 11800000.dsp1: assigned reserved memory node dsp_common_cma_pool
Jan  9 00:09:20 k2hk-evm kernel: [  141.134868]  remoteproc1: 11800000.dsp1 is available
Jan  9 00:09:20 k2hk-evm kernel: [  141.139795]  remoteproc1: Note: remoteproc is still under development and considered experimental.
Jan  9 00:09:20 k2hk-evm kernel: [  141.148829]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
Jan  9 00:09:26 k2hk-evm kernel: [  147.347908] keystone-dsp-mem c000000.dspmem: registered misc device dspmem
Jan  9 00:19:00 k2hk-evm mpmsrv[1366]: mpmsrv.c:105:mpm_server: received message of size 44 bytes for cmd 0
Jan  9 00:19:00 k2hk-evm mpmsrv[1366]: mpmsrv.c:122:mpm_server: received ping command
Jan  9 00:19:00 k2hk-evm mpmsrv[1366]: mpmsrv.c:76:mpm_server: waiting for slave message
Jan  9 00:19:06 k2hk-evm mpmsrv[1366]: mpmsrv.c:105:mpm_server: received message of size 74 bytes for cmd 1
Jan  9 00:19:06 k2hk-evm mpmsrv[1366]: mpmsrv.c:129:mpm_server: received load command for dsp0 filename /mpmsrv_keystone2_example.out
Jan  9 00:19:06 k2hk-evm mpmsrv[1366]: mpmdlif.c:425:mpm_dlif_reset: Not expected ....
Jan  9 00:19:06 k2hk-evm mpmsrv[1366]: mpmdlif.c:395:mpm_rproc_cpu_reset:  ERROR: device not opened
Jan  9 00:19:06 k2hk-evm mpmsrv[1366]: mpmdlif.c:429:mpm_dlif_reset: Can't reset DSP
Jan  9 00:19:06 k2hk-evm mpmsrv[1366]: mpmssm.c:419:mpm_ssm_state_error: entered error state for dsp0
Jan  9 00:19:06 k2hk-evm mpmsrv[1366]: mpmdlif.c:198:map_and_copy_segment: Invalid transport handle for 263080
Jan  9 00:19:06 k2hk-evm mpmsrv[1366]: mpmdlif.c:1258:DLIF_allocate: map and copy failed for image /mpmsrv_keystone2_example.out with addr 0x800000, size 0xb8
Jan  9 00:19:06 k2hk-evm mpmsrv[1366]: mpmdlif.c:1421:DLIF_error: << D L O A D >> ERROR:
Jan  9 00:19:06 k2hk-evm mpmsrv[1366]: mpmdlif.c:1424:DLIF_error: Failed to allocate target memory for static executable.
Jan  9 00:19:06 k2hk-evm mpmsrv[1366]: mpmdlif.c:853:mpm_dlif_load: Image loading failed for file /mpmsrv_keystone2_example.out
Jan  9 00:19:06 k2hk-evm mpmsrv[1366]: mpmssm.c:510:mpm_load_slave: Image loading failed for dsp0 : image
Jan  9 00:19:06 k2hk-evm mpmsrv[1366]: mpmsrv.c:76:mpm_server: waiting for slave message
Jan  9 00:19:08 k2hk-evm mpmsrv[1366]: mpmsrv.c:105:mpm_server: received message of size 74 bytes for cmd 1
Jan  9 00:19:08 k2hk-evm mpmsrv[1366]: mpmsrv.c:129:mpm_server: received load command for dsp0 filename /mpmsrv_keystone2_example.out
Jan  9 00:19:08 k2hk-evm mpmsrv[1366]: mpmssm.c:428:mpm_ssm_state_error: received unexpected load event for dsp0
Jan  9 00:19:08 k2hk-evm mpmsrv[1366]: mpmsrv.c:76:mpm_server: waiting for slave message
Jan  9 00:20:03 k2hk-evm mpmsrv[1366]: mpmsrv.c:105:mpm_server: received message of size 44 bytes for cmd 4
Jan  9 00:20:03 k2hk-evm mpmsrv[1366]: mpmsrv.c:248:mpm_server: received status command
Jan  9 00:20:03 k2hk-evm mpmsrv[1366]: mpmsrv.c:76:mpm_server: waiting for slave message
Jan  9 00:20:07 k2hk-evm mpmsrv[1366]: mpmsrv.c:105:mpm_server: received message of size 44 bytes for cmd 3
Jan  9 00:20:07 k2hk-evm mpmsrv[1366]: mpmsrv.c:228:mpm_server: received reset command
Jan  9 00:20:07 k2hk-evm mpmsrv[1366]: mpmssm.c:541:mpm_reset_slave: resetting dsp0
Jan  9 00:20:07 k2hk-evm mpmsrv[1366]: mpmdlif.c:425:mpm_dlif_reset: Not expected ....
Jan  9 00:20:07 k2hk-evm mpmsrv[1366]: mpmdlif.c:395:mpm_rproc_cpu_reset:  ERROR: device not opened
Jan  9 00:20:07 k2hk-evm mpmsrv[1366]: mpmdlif.c:429:mpm_dlif_reset: Can't reset DSP
Jan  9 00:20:07 k2hk-evm mpmsrv[1366]: mpmdlif.c:504:mpm_dlif_stop: rproc reset fail
Jan  9 00:20:07 k2hk-evm mpmsrv[1366]: mpmssm.c:544:mpm_reset_slave: Reset DSP failed for dsp0
Jan  9 00:20:07 k2hk-evm mpmsrv[1366]: mpmsrv.c:76:mpm_server: waiting for slave message
Jan  9 00:20:09 k2hk-evm mpmsrv[1366]: mpmsrv.c:105:mpm_server: received message of size 44 bytes for cmd 3
Jan  9 00:20:09 k2hk-evm mpmsrv[1366]: mpmsrv.c:228:mpm_server: received reset command
Jan  9 00:20:09 k2hk-evm mpmsrv[1366]: mpmssm.c:541:mpm_reset_slave: resetting dsp0
Jan  9 00:20:09 k2hk-evm mpmsrv[1366]: mpmdlif.c:425:mpm_dlif_reset: Not expected ....
Jan  9 00:20:09 k2hk-evm mpmsrv[1366]: mpmdlif.c:395:mpm_rproc_cpu_reset:  ERROR: device not opened
Jan  9 00:20:09 k2hk-evm mpmsrv[1366]: mpmdlif.c:429:mpm_dlif_reset: Can't reset DSP
Jan  9 00:20:09 k2hk-evm mpmsrv[1366]: mpmdlif.c:504:mpm_dlif_stop: rproc reset fail
Jan  9 00:20:09 k2hk-evm mpmsrv[1366]: mpmssm.c:544:mpm_reset_slave: Reset DSP failed for dsp0
Jan  9 00:20:09 k2hk-evm mpmsrv[1366]: mpmsrv.c:76:mpm_server: waiting for slave message
Please let me know about this error message,
  • Please make sure that you are using pre-built images from latest processor SDK.
    Can you please do the same in K2H board if you doing in custom board ?
    We were able to load and run some of the IPC examples through mpmcl using latest PSDK package.
  • I am able to run this image in K2HK evm.But not in our custom board.
    In this linker.cmd of this project, ddr is mapped to address  ,0x80000000.
    MEMORY
        L2SRAM (RWX) : org = 0x800000, len = 0x100000
        MSMCSRAM (RWX) : org = 0xc000000, len = 0x600000
        DDR3 : org = 0x80000000, len = 0x80000000
    But as per the
    L2 Local 	0x00800000 	1MB
    L2 Global 	0x[1-4]0800000 	1MB
    MSMC 	0x0C000000 	6MB
    DDR3 	0xA0000000 	(512MB)
    Could this difference be cause for error ??
    Please let me know,
  • You may have to rebuild that mpm project.
    C:\ti\mcsdk_bios_3_01_04_07\examples\mpm\mpmsrv_keystone2_example
    What is your DDR memory size in your custom board ?
    we use 1GB DDR memory in our custom board.
    I have rebuild the project and ported the same. But still i get error when i load the image through mpmcl.
    I guess this error is due to DDR memory configuration in mpmsrv_keystone2_exampl.cfg.
    As i posted in previous, DDR memory is to be configured to 0XA0000000 as per your link.
    But this project has DDR memory configured to 0x80000000.
    May this be the reason ?
    Please guide.
  • Try to use the memory range 256MiB from offset 0x80000000.
    You may have to modify the platform file of that project to do the same.
  • Can you tell me the procedure to modify the platform file of that project. ?
  • https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/0246.mpmsrv_5F00_keystone2_5F00_example.out
    Can you please try the attached .out ?
  • What is the change in this image ?
    I am not able to load tis image too .
    Attached the screenshot
    root@k2hk-evm:/#
    root@k2hk-evm:/#
    root@k2hk-evm:/# mpmcl load dsp0 0246.mpmsrv_keystone2_example.out
    load failed (error: -104)
    root@k2hk-evm:/# mpmcl status dsp0
    dsp0 is in error state
    root@k2hk-evm:/# mpmcl reset dsp0
    reset failed (error: -105)
    root@k2hk-evm:/#
    root@k2hk-evm:/#
  • Titus,
    Can you please tell me which platform do i need to select in RTSC for 66AK2HK processor.
    When i select ti.platforms.evm6614 ,DDR is configured to 0xa00000000 - 256MB which i could see through Linker.cmd but when i select ti.platforms.evmTCI6636K2H ,DDR is configured to 0x800000000.
  • Give me some time, working on this.
  • You no need to change anything, just import the mpmsrv project and rebuild it.
    Actually we need to use "ti.platforms.evmTCI6638K2K" or "ti.platforms.evmTCI6638K2H"
    I'm able to load and run the .out on MCSDK and PSDK based Linux.
    What changes you have been made in K2H custom board ?
    By the way, the example is using completely L2SRAM so it should run.
    SECTIONS
    .text: load >> L2SRAM
    .ti.decompress: load > L2SRAM
    .stack: load > L2SRAM
    GROUP: load > L2SRAM
    .bss:
    .neardata:
    .rodata:
    .cinit: load > L2SRAM
    .pinit: load >> L2SRAM
    .init_array: load > L2SRAM
    .const: load >> L2SRAM
    .data: load >> L2SRAM
    .fardata: load >> L2SRAM
    .switch: load >> L2SRAM
    .sysmem: load > L2SRAM
    .far: load >> L2SRAM
    .args: load > L2SRAM align = 0x4, fill = 0 {_argsize = 0x0; }
    .cio: load >> L2SRAM
    .ti.handler_table: load > L2SRAM
    .c6xabi.exidx: load > L2SRAM
    .c6xabi.extab: load >> L2SRAM
    .resource_table: load > 0x800000, type = NOINIT
    .vecs: load > L2SRAM
    xdc.meta: load > L2SRAM, type = COPY
    Sounds like you are not able load and run any .out via mpmcl on custom board??
  • Hi Vidya,
    Have you gone through the FAQs of MPM guide below for some help? If Yes, please ignore.
    Thank you.
  • I tried building the project with "ti.platforms.evmTCI6638K2K" as you suggested and still error is same. And i m using CCSv5 and importing the project from mcsdk_bios_3_00_03_15
    Even in this" ti.platforms.evmTCI6638K2K"  platform,  DDR is configured to DDR3 at 0x80000000 in linker.cmd
    Why i am stressing this in all my post is, i am loading linux at address 0x82000000 and dtb at 87000000. And booting through nfs.
    I have an suspect ion whether this error is due to DDR clash. Please confirm,
    More over in our custom board, we are not able to achieve correct clock speed for 66AK2HK14 processor (core 1200/Arm 1400) . We are able to achieve core speed at 491Mhz and ARM at 500 MHz. Will this also be an reason. Please clarify,
  • As I said, that project was using the Local L2 SRAM for running.
    It just had entry DDR3 but not used.
    You can also confirm by checking the .map file.
  • Even if its using L2SRAM i should be able to load and run to dsp0.
    But i am not able to and setting dsp0 to error state
    I have attached the syslog for your reference. Hope that will give you some clue to help us.
    Jan  9 00:07:07 k2hk-evm syslog-ng[1395]: syslog-ng starting up; version='3.5.4.1'
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Booting Linux on physical CPU 0x0
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Initializing cgroup subsys cpu
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Initializing cgroup subsys cpuacct
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Linux version 4.1.13-g8dc6617 (root@localhost.localdomain) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #17 SMP PREEMPT Wed Jun 8 16:27:49 IST 2016
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] CPU: ARMv7 Processor [412fc0f4] revision 4 (ARMv7), cr=30c5387d
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Machine model: Texas Instruments Keystone 2 Kepler/Hawking EVM
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Switching physical address space to 0x800000000
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Reserved memory: created CMA memory pool at 0x000000081f800000, size 8 MiB
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Reserved memory: initialized node dsp_common_cma_pool, compatible id shared-dma-pool
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Reserved memory: created DMA memory pool at 0x0000000820000000, size 512 MiB
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Reserved memory: initialized node dsp_reserved_mpm_area, compatible id shared-dma-pool
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] cma: Reserved 16 MiB at 0x000000081e800000
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Forcing write-allocate cache policy for SMP
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Memory policy: Data cache writealloc
    Jan  9 00:07:07 k2hk-evm thttpd[1398]: bind 0.0.0.0 - Address already in use
    Jan  9 00:07:07 k2hk-evm thttpd[1398]: thttpd/2.25b 29dec2003 starting on port 8080
    Jan  9 00:07:07 k2hk-evm thttpd[1398]: started as root without requesting chroot(), warning only
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] PERCPU: Embedded 11 pages/cpu @de3a0000 s13120 r8192 d23744 u45056
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Kernel command line: console=ttyS0,115200n8 rootwait=1 rootfstype=nfs root=/dev/nfs rw nfsroot=172.17.1.146:/home/armdsp/k2hk-ti/board-support/k2hk-evm-sdk-bin-02.00.01/board-support-bin/filesystem/arm_4.1.13fs,v3,tcp,rsize=4096,wsize=4096 ip=172.17.1.57:172.17.1.146:172.17.0.3:255.255.0.0::eth0
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] log_buf_len individual max cpu contribution: 4096 bytes
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] log_buf_len total cpu_extra contributions: 12288 bytes
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] log_buf_len min size: 16384 bytes
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] log_buf_len: 32768 bytes
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] early log buf free: 14048(85%)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Memory: 487424K/524288K available (5015K kernel code, 189K rwdata, 1700K rodata, 248K init, 162K bss, 12288K reserved, 24576K cma-reserved, 0K highmem)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Virtual kernel memory layout:
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000]       .text : 0xc0008000 - 0xc0697034   (6717 kB)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000]       .init : 0xc0698000 - 0xc06d6000   ( 248 kB)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000]       .data : 0xc06d6000 - 0xc0705588   ( 190 kB)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000]        .bss : 0xc0708000 - 0xc0730b4c   ( 163 kB)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Preemptible hierarchical RCU implementation.
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] 	Additional per-CPU info printed with stalls.
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] NR_IRQS:16 nr_irqs:16 16
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] Architected cp15 timer(s) running at 81.92MHz (virt).
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x12e4acc51f, max_idle_ns: 440795202121 ns
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000010] sched_clock: 56 bits at 81MHz, resolution 12ns, wraps every 4398046511102ns
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000031] Switching to timer-based delay loop, resolution 12ns
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000430] keystone timer clock @81920000 Hz
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000879] Console: colour dummy device 80x30
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000913] Calibrating delay loop (skipped), value calculated using timer frequency.. 163.84 BogoMIPS (lpj=819200)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.000939] pid_max: default: 4096 minimum: 301
    Jan  9 00:07:27 k2hk-evm kernel: [    0.001098] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.001118] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.002112] Initializing cgroup subsys blkio
    Jan  9 00:07:27 k2hk-evm kernel: [    0.002142] Initializing cgroup subsys devices
    Jan  9 00:07:27 k2hk-evm kernel: [    0.002170] Initializing cgroup subsys freezer
    Jan  9 00:07:27 k2hk-evm kernel: [    0.002215] CPU: Testing write buffer coherency: ok
    Jan  9 00:07:27 k2hk-evm kernel: [    0.002617] /cpus/cpu@0 missing clock-frequency property
    Jan  9 00:07:27 k2hk-evm kernel: [    0.002675] /cpus/cpu@1 missing clock-frequency property
    Jan  9 00:07:27 k2hk-evm kernel: [    0.002731] /cpus/cpu@2 missing clock-frequency property
    Jan  9 00:07:27 k2hk-evm kernel: [    0.002789] /cpus/cpu@3 missing clock-frequency property
    Jan  9 00:07:27 k2hk-evm kernel: [    0.002808] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    Jan  9 00:07:27 k2hk-evm kernel: [    0.002855] Setting up static identity map for 0x80008300 - 0x8000840c
    Jan  9 00:07:27 k2hk-evm kernel: [    0.080180] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    Jan  9 00:07:27 k2hk-evm kernel: [    0.120291] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    Jan  9 00:07:27 k2hk-evm kernel: [    0.160412] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    Jan  9 00:07:27 k2hk-evm kernel: [    0.160602] Brought up 4 CPUs
    Jan  9 00:07:27 k2hk-evm kernel: [    0.160641] SMP: Total of 4 processors activated (655.36 BogoMIPS).
    Jan  9 00:07:27 k2hk-evm kernel: [    0.160654] CPU: All CPU(s) started in SVC mode.
    Jan  9 00:07:27 k2hk-evm kernel: [    0.161505] devtmpfs: initialized
    Jan  9 00:07:27 k2hk-evm kernel: [    0.182084] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    Jan  9 00:07:27 k2hk-evm kernel: [    0.182923] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    Jan  9 00:07:27 k2hk-evm kernel: [    0.184463] pinctrl core: initialized pinctrl subsystem
    Jan  9 00:07:27 k2hk-evm kernel: [    0.186327] NET: Registered protocol family 16
    Jan  9 00:07:27 k2hk-evm kernel: [    0.188267] DMA: preallocated 256 KiB pool for atomic coherent allocations
    Jan  9 00:07:27 k2hk-evm kernel: [    0.211228] irq: no irq domain found for /soc/keystone_irq@26202a0 !
    Jan  9 00:07:27 k2hk-evm kernel: [    0.211824] irq: no irq domain found for /soc/keystone_irq@26202a0 !
    Jan  9 00:07:27 k2hk-evm kernel: [    0.228484] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    Jan  9 00:07:27 k2hk-evm kernel: [    0.228503] hw-breakpoint: maximum watchpoint size is 8 bytes.
    Jan  9 00:07:27 k2hk-evm kernel: [    0.253883] vgaarb: loaded
    Jan  9 00:07:27 k2hk-evm kernel: [    0.254633] SCSI subsystem initialized
    Jan  9 00:07:27 k2hk-evm kernel: [    0.255754] usbcore: registered new interface driver usbfs
    Jan  9 00:07:27 k2hk-evm kernel: [    0.255985] usbcore: registered new interface driver hub
    Jan  9 00:07:27 k2hk-evm kernel: [    0.256253] usbcore: registered new device driver usb
    Jan  9 00:07:27 k2hk-evm kernel: [    0.259443] pps_core: LinuxPPS API ver. 1 registered
    Jan  9 00:07:27 k2hk-evm kernel: [    0.259460] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    Jan  9 00:07:27 k2hk-evm kernel: [    0.259623] PTP clock support registered
    Jan  9 00:07:27 k2hk-evm kernel: [    0.261829] Switched to clocksource arch_sys_counter
    Jan  9 00:07:27 k2hk-evm kernel: [    0.292910] NET: Registered protocol family 2
    Jan  9 00:07:27 k2hk-evm kernel: [    0.294216] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.294296] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.294437] TCP: Hash tables configured (established 4096 bind 4096)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.294508] UDP hash table entries: 256 (order: 1, 8192 bytes)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.294551] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.294847] NET: Registered protocol family 1
    Jan  9 00:07:27 k2hk-evm kernel: [    0.295268] RPC: Registered named UNIX socket transport module.
    Jan  9 00:07:27 k2hk-evm kernel: [    0.295287] RPC: Registered udp transport module.
    Jan  9 00:07:27 k2hk-evm kernel: [    0.295300] RPC: Registered tcp transport module.
    Jan  9 00:07:27 k2hk-evm kernel: [    0.295314] RPC: Registered tcp NFSv4.1 backchannel transport module.
    Jan  9 00:07:27 k2hk-evm kernel: [    0.296033] CPU PMU: Failed to parse /pmu/interrupt-affinity[0]
    Jan  9 00:07:27 k2hk-evm kernel: [    0.296102] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    Jan  9 00:07:27 k2hk-evm kernel: [    0.298250] platform alarmtimer: set dma_pfn_offset00780000
    Jan  9 00:07:27 k2hk-evm kernel: [    0.300011] futex hash table entries: 16 (order: -2, 1024 bytes)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.325042] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
    Jan  9 00:07:27 k2hk-evm kernel: [    0.325274] ntfs: driver 2.1.32 [Flags: R/O].
    Jan  9 00:07:27 k2hk-evm kernel: [    0.325989] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    Jan  9 00:07:27 k2hk-evm kernel: [    0.329687] NET: Registered protocol family 38
    Jan  9 00:07:27 k2hk-evm kernel: [    0.330260] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.330295] io scheduler noop registered
    Jan  9 00:07:27 k2hk-evm kernel: [    0.330323] io scheduler deadline registered
    Jan  9 00:07:27 k2hk-evm kernel: [    0.330394] io scheduler cfq registered (default)
    Jan  9 00:07:27 k2hk-evm kernel: [    0.330711] keystone_irq soc:keystone_irq@26202a0: irqchip registered, nr_irqs 28
    Jan  9 00:07:27 k2hk-evm kernel: [    0.337037] keystone-pcie 21801000.pcie: No pcie serdes driver found: -38
    Jan  9 00:07:27 k2hk-evm kernel: [    0.337088] keystone-pcie: probe of 21801000.pcie failed with error -38
    Jan  9 00:07:27 k2hk-evm kernel: [    0.337681] keystone-navigator-qmss soc:qmss@2a40000: qmgr start queue 0, number of queues 8192
    Jan  9 00:07:27 k2hk-evm kernel: [    0.337978] keystone-navigator-qmss soc:qmss@2a40000: added qmgr start queue 0, num of queues 8192, reg_peek e0980000, reg_status e097a000, reg_config e097c000, reg_region e097e000, reg_push e09c0000, reg_pop e0a00000
    Jan  9 00:07:27 k2hk-evm kernel: [    0.338007] keystone-navigator-qmss soc:qmss@2a40000: qmgr start queue 8192, number of queues 8192
    Jan  9 00:07:27 k2hk-evm kernel: [    0.338286] keystone-navigator-qmss soc:qmss@2a40000: added qmgr start queue 8192, num of queues 8192, reg_peek e0a40000, reg_status e09a2400, reg_config e09a4000, reg_region e09a6000, reg_push e0a80000, reg_pop e0ac0000
    Jan  9 00:07:27 k2hk-evm kernel: [    0.338600] keystone-navigator-qmss soc:qmss@2a40000: failed to get firmware for pdsp
    Jan  9 00:07:27 k2hk-evm kernel: [    0.340501] keystone-navigator-qmss soc:qmss@2a40000: pdsp id 0 not started for range acc-low-0
    Jan  9 00:07:27 k2hk-evm kernel: [    0.342176] keystone-navigator-dma soc:knav_dmas@0: DMA dma_gbe registered 41 logical channels, flows 32, tx chans: 9, rx chans: 24
    Jan  9 00:07:27 k2hk-evm kernel: [    0.342460] keystone-navigator-dma soc:knav_dmas@0: DMA dma_xgbe registered 48 logical channels, flows 32, tx chans: 16, rx chans: 16
    Jan  9 00:07:27 k2hk-evm kernel: [    0.521985] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    Jan  9 00:07:27 k2hk-evm kernel: [    0.522200] platform serial8250: set dma_pfn_offset00780000
    Jan  9 00:07:27 k2hk-evm kernel: [    0.526317] console [ttyS0] disabled
    Jan  9 00:07:27 k2hk-evm kernel: [    0.526411] 2530c00.serial: ttyS0 at MMIO 0x2530c00 (irq = 26, base_baud = 5120000) is a 16550A
    Jan  9 00:07:27 k2hk-evm kernel: [    1.342500] console [ttyS0] enabled
    Jan  9 00:07:27 k2hk-evm kernel: [    1.347575] 2531000.serial: ttyS1 at MMIO 0x2531000 (irq = 27, base_baud = 5120000) is a 16550A
    Jan  9 00:07:27 k2hk-evm kernel: [    1.374115] brd: module loaded
    Jan  9 00:07:27 k2hk-evm kernel: [    1.387190] loop: module loaded
    Jan  9 00:07:27 k2hk-evm kernel: [    1.390686] at24 0-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write
    Jan  9 00:07:27 k2hk-evm kernel: [    1.451865] davinci_mdio 2090300.mdio: davinci mdio revision 1.5
    Jan  9 00:07:27 k2hk-evm kernel: [    1.457821] libphy: 2090300.mdio: probed
    Jan  9 00:07:27 k2hk-evm kernel: [    1.464976] netcp-1.0 2620110.netcp: module(netcp-xgbe) not used for device
    Jan  9 00:07:27 k2hk-evm kernel: [    1.472135] 2620738.usb_phy supply vcc not found, using dummy regulator
    Jan  9 00:07:27 k2hk-evm kernel: [    1.880990] platform xhci-hcd.0.auto: set dma_pfn_offset00780000
    Jan  9 00:07:27 k2hk-evm kernel: [    1.888464] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    Jan  9 00:07:27 k2hk-evm kernel: [    1.894305] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    Jan  9 00:07:27 k2hk-evm kernel: [    1.902645] xhci-hcd xhci-hcd.0.auto: hcc params 0x0298f06d hci version 0x100 quirks 0x00210010
    Jan  9 00:07:27 k2hk-evm kernel: [    1.911291] xhci-hcd xhci-hcd.0.auto: irq 34, io mem 0x02690000
    Jan  9 00:07:27 k2hk-evm kernel: [    1.917533] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    Jan  9 00:07:27 k2hk-evm kernel: [    1.924298] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Jan  9 00:07:27 k2hk-evm kernel: [    1.931458] usb usb1: Product: xHCI Host Controller
    Jan  9 00:07:27 k2hk-evm kernel: [    1.936324] usb usb1: Manufacturer: Linux 4.1.13-g8dc6617 xhci-hcd
    Jan  9 00:07:27 k2hk-evm kernel: [    1.942477] usb usb1: SerialNumber: xhci-hcd.0.auto
    Jan  9 00:07:27 k2hk-evm kernel: [    1.948398] hub 1-0:1.0: USB hub found
    Jan  9 00:07:27 k2hk-evm kernel: [    1.952224] hub 1-0:1.0: 1 port detected
    Jan  9 00:07:27 k2hk-evm kernel: [    1.956809] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    Jan  9 00:07:27 k2hk-evm kernel: [    1.962684] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    Jan  9 00:07:27 k2hk-evm kernel: [    1.970421] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    Jan  9 00:07:27 k2hk-evm kernel: [    1.978749] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
    Jan  9 00:07:27 k2hk-evm kernel: [    1.985514] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    Jan  9 00:07:27 k2hk-evm kernel: [    1.992703] usb usb2: Product: xHCI Host Controller
    Jan  9 00:07:27 k2hk-evm kernel: [    1.997540] usb usb2: Manufacturer: Linux 4.1.13-g8dc6617 xhci-hcd
    Jan  9 00:07:27 k2hk-evm kernel: [    2.003694] usb usb2: SerialNumber: xhci-hcd.0.auto
    Jan  9 00:07:27 k2hk-evm kernel: [    2.009557] hub 2-0:1.0: USB hub found
    Jan  9 00:07:27 k2hk-evm kernel: [    2.013368] hub 2-0:1.0: 1 port detected
    Jan  9 00:07:27 k2hk-evm kernel: [    2.018228] usbcore: registered new interface driver usb-storage
    Jan  9 00:07:27 k2hk-evm kernel: [    2.024845] mousedev: PS/2 mouse device common for all mice
    Jan  9 00:07:27 k2hk-evm kernel: [    2.030901] i2c /dev entries driver
    Jan  9 00:07:27 k2hk-evm kernel: [    2.036471] davinci-wdt 22f0080.wdt: heartbeat 60 sec
    Jan  9 00:07:27 k2hk-evm kernel: [    2.075028] keystone-crypto 20c0000.crypto: crypto accelerator enabled
    Jan  9 00:07:27 k2hk-evm kernel: [    2.082178] usbcore: registered new interface driver usbhid
    Jan  9 00:07:27 k2hk-evm kernel: [    2.087700] usbhid: USB HID core driver
    Jan  9 00:07:27 k2hk-evm kernel: [    2.094256] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xac
    Jan  9 00:07:27 k2hk-evm kernel: [    2.100555] nand: Micron MT29F4G08ABBDAHC
    Jan  9 00:07:27 k2hk-evm kernel: [    2.104570] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
    Jan  9 00:07:27 k2hk-evm kernel: [    2.112807] Bad block table found at page 262080, version 0x01
    Jan  9 00:07:27 k2hk-evm kernel: [    2.119331] Bad block table found at page 262016, version 0x01
    Jan  9 00:07:27 k2hk-evm kernel: [    2.125677] 3 ofpart partitions found on MTD device 30000000.nand
    Jan  9 00:07:27 k2hk-evm kernel: [    2.131715] Creating 3 MTD partitions on "30000000.nand":
    Jan  9 00:07:27 k2hk-evm kernel: [    2.137099] 0x000000000000-0x000000100000 : "u-boot"
    Jan  9 00:07:27 k2hk-evm kernel: [    2.143863] 0x000000100000-0x000000180000 : "params"
    Jan  9 00:07:27 k2hk-evm kernel: [    2.150499] 0x000000180000-0x000020000000 : "ubifs"
    Jan  9 00:07:27 k2hk-evm kernel: [    2.158088] davinci_nand 30000000.nand: controller rev. 2.5
    Jan  9 00:07:27 k2hk-evm kernel: [    2.164306] platform oprofile-perf.0: set dma_pfn_offset00780000
    Jan  9 00:07:27 k2hk-evm kernel: [    2.170699] oprofile: using timer interrupt.
    Jan  9 00:07:27 k2hk-evm kernel: [    2.175299] ipip: IPv4 over IPv4 tunneling driver
    Jan  9 00:07:27 k2hk-evm kernel: [    2.180983] gre: GRE over IPv4 demultiplexor driver
    Jan  9 00:07:27 k2hk-evm kernel: [    2.185979] Initializing XFRM netlink socket
    Jan  9 00:07:27 k2hk-evm kernel: [    2.190264] NET: Registered protocol family 17
    Jan  9 00:07:27 k2hk-evm kernel: [    2.194746] NET: Registered protocol family 15
    Jan  9 00:07:27 k2hk-evm kernel: [    2.199312] Registering SWP/SWPB emulation handler
    Jan  9 00:07:27 k2hk-evm kernel: [    2.242099] IP-Config: Complete:
    Jan  9 00:07:27 k2hk-evm kernel: [    2.245317]      device=eth0, hwaddr=74:da:ea:5d:c8:3b, ipaddr=172.17.1.57, mask=255.255.0.0, gw=172.17.0.3
    Jan  9 00:07:27 k2hk-evm kernel: [    2.255004]      host=172.17.1.57, domain=, nis-domain=(none)
    Jan  9 00:07:27 k2hk-evm kernel: [    2.260702]      bootserver=172.17.1.146, rootserver=172.17.1.146, rootpath=
    Jan  9 00:07:27 k2hk-evm kernel: [    2.390314] VFS: Mounted root (nfs filesystem) on device 0:14.
    Jan  9 00:07:27 k2hk-evm kernel: [    2.396915] devtmpfs: mounted
    Jan  9 00:07:27 k2hk-evm kernel: [    2.400183] Freeing unused kernel memory: 248K (c0698000 - c06d6000)
    Jan  9 00:07:27 k2hk-evm kernel: [    3.398942] random: dd urandom read with 73 bits of entropy available
    Jan  9 00:07:27 k2hk-evm kernel: [    5.152725] random: nonblocking pool is initialized
    Jan  9 00:07:27 k2hk-evm kernel: [    6.111201] NET: Registered protocol family 10
    Jan  9 00:07:49 k2hk-evm kernel: [   49.988344] keystone-rproc 10800000.dsp0: assigned reserved memory node dsp_common_cma_pool
    Jan  9 00:07:49 k2hk-evm kernel: [   49.996843]  remoteproc0: 10800000.dsp0 is available
    Jan  9 00:07:49 k2hk-evm kernel: [   50.001768]  remoteproc0: Note: remoteproc is still under development and considered experimental.
    Jan  9 00:07:49 k2hk-evm kernel: [   50.010748]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    Jan  9 00:07:49 k2hk-evm kernel: [   50.025495] keystone-rproc 11800000.dsp1: assigned reserved memory node dsp_common_cma_pool
    Jan  9 00:07:49 k2hk-evm kernel: [   50.033963]  remoteproc1: 11800000.dsp1 is available
    Jan  9 00:07:49 k2hk-evm kernel: [   50.038887]  remoteproc1: Note: remoteproc is still under development and considered experimental.
    Jan  9 00:07:49 k2hk-evm kernel: [   50.048437]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    Jan  9 00:07:59 k2hk-evm kernel: [   60.341149] keystone-dsp-mem c000000.dspmem: registered misc device dspmem
    Jan  9 00:08:25 k2hk-evm mpmsrv[1366]: mpmsrv.c:105:mpm_server: received message of size 44 bytes for cmd 0
    Jan  9 00:08:25 k2hk-evm mpmsrv[1366]: mpmsrv.c:122:mpm_server: received ping command
    Jan  9 00:08:25 k2hk-evm mpmsrv[1366]: mpmsrv.c:76:mpm_server: waiting for slave message
    Jan  9 00:08:30 k2hk-evm mpmsrv[1366]: mpmsrv.c:105:mpm_server: received message of size 44 bytes for cmd 4
    Jan  9 00:08:30 k2hk-evm mpmsrv[1366]: mpmsrv.c:248:mpm_server: received status command
    Jan  9 00:08:30 k2hk-evm mpmsrv[1366]: mpmsrv.c:76:mpm_server: waiting for slave message
    Jan  9 00:08:40 k2hk-evm mpmsrv[1366]: mpmsrv.c:105:mpm_server: received message of size 53 bytes for cmd 1
    Jan  9 00:08:40 k2hk-evm mpmsrv[1366]: mpmsrv.c:129:mpm_server: received load command for dsp0 filename /arm.out
    Jan  9 00:08:40 k2hk-evm mpmsrv[1366]: mpmdlif.c:425:mpm_dlif_reset: Not expected ....
    Jan  9 00:08:40 k2hk-evm mpmsrv[1366]: mpmdlif.c:395:mpm_rproc_cpu_reset:  ERROR: device not opened
    Jan  9 00:08:40 k2hk-evm mpmsrv[1366]: mpmdlif.c:429:mpm_dlif_reset: Can't reset DSP
    Jan  9 00:08:40 k2hk-evm mpmsrv[1366]: mpmssm.c:419:mpm_ssm_state_error: entered error state for dsp0
    Jan  9 00:08:40 k2hk-evm mpmsrv[1366]: mpmdlif.c:198:map_and_copy_segment: Invalid transport handle for 263080
    Jan  9 00:08:40 k2hk-evm mpmsrv[1366]: mpmdlif.c:1258:DLIF_allocate: map and copy failed for image /arm.out with addr 0xa0000000, size 0xb8
    Jan  9 00:08:40 k2hk-evm mpmsrv[1366]: mpmdlif.c:1421:DLIF_error: << D L O A D >> ERROR:
    Jan  9 00:08:40 k2hk-evm mpmsrv[1366]: mpmdlif.c:1424:DLIF_error: Failed to allocate target memory for static executable.
    Jan  9 00:08:40 k2hk-evm mpmsrv[1366]: mpmdlif.c:853:mpm_dlif_load: Image loading failed for file /arm.out
    Jan  9 00:08:40 k2hk-evm mpmsrv[1366]: mpmssm.c:510:mpm_load_slave: Image loading failed for dsp0 : image
    Jan  9 00:08:40 k2hk-evm mpmsrv[1366]: mpmsrv.c:76:mpm_server: waiting for slave message
    Jan  9 00:08:43 k2hk-evm mpmsrv[1366]: mpmsrv.c:105:mpm_server: received message of size 53 bytes for cmd 1
    Jan  9 00:08:43 k2hk-evm mpmsrv[1366]: mpmsrv.c:129:mpm_server: received load command for dsp0 filename /arm.out
    Jan  9 00:08:43 k2hk-evm mpmsrv[1366]: mpmssm.c:428:mpm_ssm_state_error: received unexpected load event for dsp0
    Jan  9 00:08:43 k2hk-evm mpmsrv[1366]: mpmsrv.c:76:mpm_server: waiting for slave message
    Jan  9 00:08:48 k2hk-evm mpmsrv[1366]: mpmsrv.c:105:mpm_server: received message of size 44 bytes for cmd 2
    Jan  9 00:08:48 k2hk-evm mpmsrv[1366]: mpmsrv.c:183:mpm_server: received run command
    Jan  9 00:08:48 k2hk-evm mpmsrv[1366]: mpmssm.c:428:mpm_ssm_state_error: received unexpected run event for dsp0
    Jan  9 00:08:48 k2hk-evm mpmsrv[1366]: mpmsrv.c:76:mpm_server: waiting for slave message
  • I dint get any inputs for this query.
    Loading to dsp from Arm is the major one for us to prove our processor.
    If mpmcl utility is not working, what are the other ways to load the dsp binaries from arm and execute ?
    And also please suggest why mpmcl utility is failing while loading the binaries
    This is major issue for us .
  • I suspect the CMEM driver.
    drivers/soc/ti/keystone_dsp_mem.c
    Due to your DDR3 memory, it may needs to be changed through dts file.
    arch/arm/boot/dts/k2hk-evm.dts
    compatible = "ti,k2hk-evm", "ti,k2hk", "ti,keystone";
    model = "Texas Instruments Keystone 2 Kepler/Hawking EVM";
    reserved-memory {
    #address-cells = <2>;
    #size-cells = <2>;
    ranges;
    dsp_common_cma_pool: dsp_common_cma_pool {
    compatible = "shared-dma-pool";
    reg = <0x00000008 0x1f800000 0x00000000 0x800000>;
    reusable;
    dsp_common_mpm_area: dsp_reserved_mpm_area {
    reg = <0x00000008 0x20000000 0x00000000 0x20000000>;
    no-map;
    status = "okay";
    Can you please attach your complete linux bootup log ?
    Also do "lsmod" and give the output.
  • Should i need to change the dts based on my 1GB DDR3.
    If so, please let me know where to undergo changes in DTS file.
    And When i do keystone_remoteproc.ko , kernel hangs.
    Please find the attached,
  • =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2016.06.10 15:33:21 =~=~=~=~=~=~=~=~=~=~=~=
    U-Boot#
    U-Boot#
    U-Boot# setenv name_mon 'skern-tisdk.bin';setenv name_kern 'armuImageIndpcie';setenv name_fdt 'k2hk-evm-tisdk.dtb'
    Trying K2HK_EMAC
    + emac_open
    - emac_open
    BOOTP broadcast 1
    DHCPHandler: got packet: (src=67, dst=68, len=308) state: 3
    Filtering pkt = 0
    DHCPHandler: got DHCP packet: (src=67, dst=68, len=308) state: 3
    DHCP: state=SELECTING bp_file: "//k2-fw-initrd.cpio.gz"
    TRANSITIONING TO REQUESTING STATE
    *** Unhandled DHCP Option in OFFER/ACK: 224
    dhcp_send_request_packet: Sending DHCPREQUEST
    Transmitting DHCPREQUEST packet: len = 342
    DHCPHandler: got packet: (src=67, dst=68, len=308) state: 4
    Filtering pkt = 0
    DHCPHandler: got DHCP packet: (src=67, dst=68, len=308) state: 4
    DHCP State: REQUESTING
    net_boot_file_name: //k2-fw-initrd.cpio.gz
    Initial value for argc=3
    Final value for argc=3
    DHCP client bound to address 172.17.2.5 (67 ms)
    TFTP blocksize = 1468, timeout = 5000 ms
    Using K2HK_EMAC device
    TFTP from server 172.17.1.146; our IP address is 172.17.2.5
    Filename '//k2-fw-initrd.cpio.gz'.
    Load address: 0x88080000
    Loading: *send option "timeout 5"
    Got OACK: timeout 5
    Blocksize ack: 1468, 1468
     242.2 KiB/s
    done
    Bytes transferred = 3231 (c9f hex)
    + emac_close
    - emac_close
    + emac_close
    Trying K2HK_EMAC
    + emac_open
    - emac_open
    BOOTP broadcast 1
    Filtering pkt = 0
    DHCP: state=SELECTING bp_file: "//k2hk-evm-tisdk.dtb"
    Filtering pkt = 0
    net_boot_file_name: //k2hk-evm-tisdk.dtb
    DHCP client bound to address 172.17.2.5 (63 ms)
    Filename '//k2hk-evm-tisdk.dtb'.
    Load address: 0x88000000
    Got OACK: timeout 5
     725.6 KiB/s
    done
    Bytes transferred = 40167 (9ce7 hex)
    + emac_close
    - emac_close
    + emac_close
    Trying K2HK_EMAC
    + emac_open
    - emac_open
    BOOTP broadcast 1
    Filtering pkt = 0
    DHCP: state=SELECTING bp_file: "//skern-tisdk.bin"
    Filtering pkt = 0
    net_boot_file_name: //skern-tisdk.bin
    Filename '//skern-tisdk.bin'.
    Load address: 0xc5f0000
    Got OACK: timeout 5
     745.1 KiB/s
    done
    Bytes transferred = 45056 (b000 hex)
    + emac_close
    - emac_close
    + emac_close
    Trying K2HK_EMAC
    + emac_open
    - emac_open
    BOOTP broadcast 1
    Filtering pkt = 0
    DHCP: state=SELECTING bp_file: "//armuImageIndpcie"
    Filtering pkt = 0
    net_boot_file_name: //armuImageIndpcie
    Filename '//armuImageIndpcie'.
    Load address: 0x82000000
    Got OACK: timeout 5
     868.2 KiB/s
    done
    Bytes transferred = 3714032 (38abf0 hex)
    + emac_close
    - emac_close
    DEBUG: Message2 from Secure Mode: Core freq - 81920000Hz
    K2_BM_15. 07-nogit SoC:k2hk built:18:11:51, Jun  7 2016
    ## installed monitor, freq [81920000], status 0
    ## Current stack ends at 0xbeef4918 *  kernel: cmdline image address = 0x82000000
    Bad Linux ARM zImage magic!
    Command failed, result=1Command failed, result=1Command failed, result=1U-Boot#
    U-Boot# setenv run_kern 'bootm ${loadaddr} ${rd_spec} ${fdtaddr}'
    U-Boot# boot
    Initial value for argc=4
    Final value for argc=4
    Initial value for argc=9
    Final value for argc=9
    + emac_close
    Trying K2HK_EMAC
    + emac_open
    - emac_open
    BOOTP broadcast 1
    Filtering pkt = 0
    Filtering pkt = 0
    DHCP client bound to address 172.17.2.5 (64 ms)
    Got OACK: timeout 5
     242.2 KiB/s
    done
    + emac_close
    - emac_close
    + emac_close
    Trying K2HK_EMAC
    + emac_open
    - emac_open
    BOOTP broadcast 1
    Filtering pkt = 0
    Filtering pkt = 0
    Got OACK: timeout 5
     725.6 KiB/s
    done
    + emac_close
    - emac_close
    + emac_close
    Trying K2HK_EMAC
    + emac_open
    - emac_open
    BOOTP broadcast 1
    Filtering pkt = 0
    Filtering pkt = 0
    Got OACK: timeout 5
     745.1 KiB/s
    done
    + emac_close
    - emac_close
    + emac_close
    Trying K2HK_EMAC
    + emac_open
    - emac_open
    BOOTP broadcast 1
    Filtering pkt = 0
    Filtering pkt = 0
    Got OACK: timeout 5
     866.2 KiB/s
    done
    + emac_close
    - emac_close
    ## Current stack ends at 0xbeef4920 *  kernel: cmdline image address = 0x82000000
    ## Booting kernel from Legacy Image at 82000000 ...
       Image Name:   Linux-4.1.13-g8dc6617
       Created:      2016-06-10   4:55:58 UTC
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    3713968 Bytes = 3.5 MiB
       Load Address: 80008000
       Entry Point:  80008000
       Verifying Checksum ... OK
       kernel data at 0x82000040, len = 0x0038abb0 (3713968)
    *  ramdisk: cmdline image address = 0x88080000
       ramdisk start = 0x88080000, ramdisk end = 0x88080c9f
    *  fdt: cmdline image address = 0x88000000
    ## Checking for 'FDT'/'FDT Image' at 88000000
    *  fdt: raw FDT blob
       of_flat_tree at 0x88000000 size 0x00009ce7
       Loading Kernel Image ... OK
       kernel loaded at 0x80008000, end = 0x80392bb0
    using: FDT
    ## initrd_high = 0xffffffff, copy_to_ram = 1
       Loading Ramdisk to 8ffff000, end 8ffffc9f ... OK
       ramdisk load start = 0x8ffff000, ramdisk load end = 0x8ffffc9f
    ## device tree at 88000000 ... 88009ce6 (len=52455 [0xCCE7])
       Loading Device Tree to 8fff2000, end 8fffece6 ... OK
    No alias for ethernet0
    ## Transferring control to Linux (at address 80008000)...
    Starting kernel ...
    Uncompressing Linux... done, booting the kernel.
    DEBUG: >>>> skern_poweron_cpu(1) >>>>
    DEBUG: >>>> skern_poweron_cpu(2) >>>>
    DEBUG: >>>> skern_poweron_cpu(3) >>>>
    ** 62 printk messages dropped ** [    0.067511] CPU2: failed to boot: -6
    [    0.071435] CPU 3 bringup failed with -6
    [    0.071452] CPU3: failed to boot: -6
    [    0.071481] Brought up 1 CPUs
    [    0.071497] SMP: Total of 1 processors activated (163.84 BogoMIPS).
    [    0.071511] CPU: All CPU(s) started in SVC mode.
    [    0.072204] devtmpfs: initialized
    [    0.094094] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.094835] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.096553] pinctrl core: initialized pinctrl subsystem
    [    0.097983] NET: Registered protocol family 16
    [    0.099893] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.127962] irq: no irq domain found for /soc/keystone_irq@26202a0 !
    [    0.128941] irq: no irq domain found for /soc/keystone_irq@26202a0 !
    [    0.129731] irq: no irq domain found for /soc/keystone_irq@26202a0 !
    [    0.130343] irq: no irq domain found for /soc/keystone_irq@26202a0 !
    [    0.131031] irq: no irq domain found for /soc/keystone_irq@26202a0 !
    [    0.131693] irq: no irq domain found for /soc/keystone_irq@26202a0 !
    [    0.132381] irq: no irq domain found for /soc/keystone_irq@26202a0 !
    [    0.133073] irq: no irq domain found for /soc/keystone_irq@26202a0 !
    [    0.154450] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.154469] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.193153] vgaarb: loaded
    [    0.193655] SCSI subsystem initialized
    [    0.194219] usbcore: registered new interface driver usbfs
    [    0.194362] usbcore: registered new interface driver hub
    [    0.195214] usbcore: registered new device driver usb
    [    0.200786] pps_core: LinuxPPS API ver. 1 registered
    [    0.200805] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.200956] PTP clock support registered
    [    0.203569] Switched to clocksource arch_sys_counter
    [    0.239279] NET: Registered protocol family 2
    [    0.240904] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.240985] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
    [    0.241125] TCP: Hash tables configured (established 4096 bind 4096)
    [    0.241212] UDP hash table entries: 256 (order: 1, 8192 bytes)
    [    0.241255] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
    [    0.241576] NET: Registered protocol family 1
    [    0.242266] RPC: Registered named UNIX socket transport module.
    [    0.242285] RPC: Registered udp transport module.
    [    0.242299] RPC: Registered tcp transport module.
    [    0.242311] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.242736] Trying to unpack rootfs image as initramfs...
    [    0.245707] Freeing initrd memory: 4K (cffff000 - d0000000)
    [    0.246033] CPU PMU: Failed to parse /pmu/interrupt-affinity[0]
    [    0.246092] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.248464] platform alarmtimer: set dma_pfn_offset00780000
    [    0.250184] futex hash table entries: 16 (order: -2, 1024 bytes)
    [    0.285034] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
    [    0.285254] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.285962] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    [    0.291147] NET: Registered protocol family 38
    [    0.291547] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
    [    0.291577] io scheduler noop registered
    [    0.291601] io scheduler deadline registered
    [    0.291667] io scheduler cfq registered (default)
    [    0.291995] keystone_irq soc:keystone_irq@26202a0: irqchip registered, nr_irqs 28
    [    0.305542] keystone-pcie 21801000.pcie: missing *config* reg space
    [    0.307536] keystone-pcie 21801000.pcie: PCI host bridge to bus 0000:00
    [    0.307565] pci_bus 0000:00: root bus resource [io  0x1000-0x3fff]
    [    0.307587] pci_bus 0000:00: root bus resource [mem 0x50000000-0x5fffffff]
    [    0.307609] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    0.308384] PCI: bus0: Fast back to back transfers disabled
    [    0.323299] PCI: bus1: Fast back to back transfers disabled
    [    0.323343] pci 0000:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    0.336007] PCI: bus2: Fast back to back transfers disabled
    [    0.336051] pci 0000:02:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    0.336109] pci 0000:02:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    0.336165] pci 0000:02:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    0.336220] pci 0000:02:04.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    0.336275] pci 0000:02:05.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    0.336330] pci 0000:02:06.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    0.336385] pci 0000:02:07.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    0.336438] pci 0000:02:08.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    0.336491] pci 0000:02:0c.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    0.336544] pci 0000:02:10.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    0.336596] pci 0000:02:14.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    0.337278] PCI: bus3: Fast back to back transfers enabled
    [    0.337779] PCI: bus4: Fast back to back transfers enabled
    [    0.338378] PCI: bus5: Fast back to back transfers enabled
    [    0.338876] PCI: bus6: Fast back to back transfers enabled
    [    0.339471] PCI: bus7: Fast back to back transfers enabled
    [    0.340074] PCI: bus8: Fast back to back transfers enabled
    [    0.341570] vgaarb: device added: PCI:0000:09:00.0,decodes=io+mem,owns=none,locks=none
    [    0.342132] PCI: bus9: Fast back to back transfers disabled
    [    0.342746] PCI: bus10: Fast back to back transfers enabled
    [    0.343354] PCI: bus11: Fast back to back transfers enabled
    [    0.343847] PCI: bus12: Fast back to back transfers enabled
    [    0.344447] PCI: bus13: Fast back to back transfers enabled
    [    0.345696] pci 0000:00:00.0: BAR 8: assigned [mem 0x50000000-0x55ffffff]
    [    0.345722] pci 0000:01:00.0: BAR 8: assigned [mem 0x50000000-0x55ffffff]
    [    0.345748] pci 0000:02:07.0: BAR 8: assigned [mem 0x50000000-0x55ffffff]
    [    0.345768] pci 0000:02:01.0: PCI bridge to [bus 03]
    [    0.345826] pci 0000:02:02.0: PCI bridge to [bus 04]
    [    0.345881] pci 0000:02:03.0: PCI bridge to [bus 05]
    [    0.345936] pci 0000:02:04.0: PCI bridge to [bus 06]
    [    0.345988] pci 0000:02:05.0: PCI bridge to [bus 07]
    [    0.346041] pci 0000:02:06.0: PCI bridge to [bus 08]
    [    0.346104] pci 0000:09:00.0: BAR 0: assigned [mem 0x50000000-0x53ffffff pref]
    [    0.346135] pci 0000:09:00.0: BAR 1: assigned [mem 0x54000000-0x541fffff]
    [    0.346165] pci 0000:09:00.0: BAR 6: assigned [mem 0x54200000-0x5420ffff pref]
    [    0.346185] pci 0000:02:07.0: PCI bridge to [bus 09]
    [    0.346216] pci 0000:02:07.0:   bridge window [mem 0x50000000-0x55ffffff]
    [    0.346258] pci 0000:02:08.0: PCI bridge to [bus 0a]
    [    0.346312] pci 0000:02:0c.0: PCI bridge to [bus 0b]
    [    0.346364] pci 0000:02:10.0: PCI bridge to [bus 0c]
    [    0.346417] pci 0000:02:14.0: PCI bridge to [bus 0d]
    [    0.346470] pci 0000:01:00.0: PCI bridge to [bus 02-0d]
    [    0.346500] pci 0000:01:00.0:   bridge window [mem 0x50000000-0x55ffffff]
    [    0.346542] pci 0000:00:00.0: PCI bridge to [bus 01-0d]
    [    0.346563] pci 0000:00:00.0:   bridge window [mem 0x50000000-0x55ffffff]
    [    0.347573] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
    [    0.347595] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
    [    0.347611] pci 0000:02:01.0: Signaling PME through PCIe PME interrupt
    [    0.347626] pci 0000:02:02.0: Signaling PME through PCIe PME interrupt
    [    0.347641] pci 0000:02:03.0: Signaling PME through PCIe PME interrupt
    [    0.347656] pci 0000:02:04.0: Signaling PME through PCIe PME interrupt
    [    0.347670] pci 0000:02:05.0: Signaling PME through PCIe PME interrupt
    [    0.347684] pci 0000:02:06.0: Signaling PME through PCIe PME interrupt
    [    0.347698] pci 0000:02:07.0: Signaling PME through PCIe PME interrupt
    [    0.347712] pci 0000:09:00.0: Signaling PME through PCIe PME interrupt
    [    0.347726] pci 0000:02:08.0: Signaling PME through PCIe PME interrupt
    [    0.347740] pci 0000:02:0c.0: Signaling PME through PCIe PME interrupt
    [    0.347754] pci 0000:02:10.0: Signaling PME through PCIe PME interrupt
    [    0.347768] pci 0000:02:14.0: Signaling PME through PCIe PME interrupt
    [    0.348464] pcieport 0000:01:00.0: enabling device (0140 -> 0142)
    [    0.355688] pcieport 0000:02:07.0: enabling device (0140 -> 0142)
    [    0.362067] keystone-navigator-qmss soc:qmss@2a40000: qmgr start queue 0, number of queues 8192
    [    0.362405] keystone-navigator-qmss soc:qmss@2a40000: added qmgr start queue 0, num of queues 8192, reg_peek e09c0000, reg_status e098c000, reg_config e098e000, reg_region e0990000, reg_push e0a00000, reg_pop e0a40000
    [    0.362432] keystone-navigator-qmss soc:qmss@2a40000: qmgr start queue 8192, number of queues 8192
    [    0.362711] keystone-navigator-qmss soc:qmss@2a40000: added qmgr start queue 8192, num of queues 8192, reg_peek e0a80000, reg_status e0992400, reg_config e0994000, reg_region e0996000, reg_push e0ac0000, reg_pop e0b00000
    [    0.363064] keystone-navigator-qmss soc:qmss@2a40000: firmware file ks2_qmss_pdsp_acc48.bin downloaded for PDSP
    [    0.367701] keystone-navigator-dma soc:knav_dmas@0: DMA dma_gbe registered 41 logical channels, flows 32, tx chans: 9, rx chans: 24
    [    0.367981] keystone-navigator-dma soc:knav_dmas@0: DMA dma_xgbe registered 48 logical channels, flows 32, tx chans: 16, rx chans: 16
    [    0.589646] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    [    0.589836] platform serial8250: set dma_pfn_offset00780000
    [    0.595667] console [ttyS0] disabled
    [    0.595759] 2530c00.serial: ttyS0 at MMIO 0x2530c00 (irq = 26, base_baud = 5120000) is a 16550A
    [    1.474541] console [ttyS0] enabled
    [    1.479730] 2531000.serial: ttyS1 at MMIO 0x2531000 (irq = 27, base_baud = 5120000) is a 16550A
    [    1.512535] brd: module loaded
    [    1.527653] loop: module loaded
    [    1.531644] at24 0-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write
    [    1.593220] davinci_mdio 2090300.mdio: davinci mdio revision 1.5
    [    1.599176] libphy: 2090300.mdio: probed
    [    1.607699] netcp-1.0 2620110.netcp: module(netcp-xgbe) not used for device
    [    1.615691] 2620738.usb_phy supply vcc not found, using dummy regulator
    [    2.025100] platform xhci-hcd.0.auto: set dma_pfn_offset00780000
    [    2.033014] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    2.039437] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    2.047834] xhci-hcd xhci-hcd.0.auto: hcc params 0x0298f06d hci version 0x100 quirks 0x00210010
    [    2.056566] xhci-hcd xhci-hcd.0.auto: irq 34, io mem 0x02690000
    [    2.062794] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [    2.069601] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.076841] usb usb1: Product: xHCI Host Controller
    [    2.081681] usb usb1: Manufacturer: Linux 4.1.13-g8dc6617 xhci-hcd
    [    2.087977] usb usb1: SerialNumber: xhci-hcd.0.auto
    [    2.094110] hub 1-0:1.0: USB hub found
    [    2.098104] hub 1-0:1.0: 1 port detected
    [    2.102687] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    2.108694] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [    2.116632] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    2.124968] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
    [    2.131699] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.138938] usb usb2: Product: xHCI Host Controller
    [    2.143907] usb usb2: Manufacturer: Linux 4.1.13-g8dc6617 xhci-hcd
    [    2.150034] usb usb2: SerialNumber: xhci-hcd.0.auto
    [    2.156139] hub 2-0:1.0: USB hub found
    [    2.160122] hub 2-0:1.0: 1 port detected
    [    2.165262] usbcore: registered new interface driver usb-storage
    [    2.172182] mousedev: PS/2 mouse device common for all mice
    [    2.178683] i2c /dev entries driver
    [    2.185124] davinci-wdt 22f0080.wdt: heartbeat 60 sec
    [    2.224522] keystone-crypto 20c0000.crypto: crypto accelerator enabled
    [    2.232094] usbcore: registered new interface driver usbhid
    [    2.237992] usbhid: USB HID core driver
    [    2.244916] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xac
    [    2.251213] nand: Micron MT29F4G08ABBDAHC
    [    2.255817] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
    [    2.264087] Bad block table found at page 262080, version 0x01
    [    2.270612] Bad block table found at page 262016, version 0x01
    [    2.277012] 3 ofpart partitions found on MTD device 30000000.nand
    [    2.283051] Creating 3 MTD partitions on "30000000.nand":
    [    2.288669] 0x000000000000-0x000000100000 : "u-boot"
    [    2.295821] 0x000000100000-0x000000180000 : "params"
    [    2.303239] 0x000000180000-0x000020000000 : "ubifs"
    [    2.311561] davinci_nand 30000000.nand: controller rev. 2.5
    [    2.318492] platform oprofile-perf.0: set dma_pfn_offset00780000
    [    2.325374] oprofile: using timer interrupt.
    [    2.329939] ipip: IPv4 over IPv4 tunneling driver
    [    2.336208] gre: GRE over IPv4 demultiplexor driver
    [    2.341228] Initializing XFRM netlink socket
    [    2.346015] NET: Registered protocol family 17
    [    2.350475] NET: Registered protocol family 15
    [    2.355125] Registering SWP/SWPB emulation handler
    [    2.393463] IP-Config: Complete:
    [    2.396678]      device=eth0, hwaddr=74:da:ea:5d:c8:3b, ipaddr=172.17.1.57, mask=255.255.0.0, gw=172.17.0.3
    [    2.406567]      host=172.17.1.57, domain=, nis-domain=(none)
    [    2.412267]      bootserver=172.17.1.146, rootserver=172.17.1.146, rootpath=
    [    2.541856] VFS: Mounted root (nfs filesystem) on device 0:14.
    [    2.548550] devtmpfs: mounted
    [    2.551825] Freeing unused kernel memory: 252K (c069f000 - c06de000)
    INIT: version 2.88 booting
    Starting random number generator daemonread error
    read error
    [    3.638144] random: dd urandom read with 73 bits of entropy available
    Sat Jan  9 00:07:04 UTC 2016
    INIT: Entering runlevel: 5
    NOT configuring network interfaces: / is an NFS mount
    udhcpc (v1.23.1) started
    Sending discover...
    Sending select for 172.17.2.5...
    Lease of 172.17.2.5 obtained, lease time 604800
    /etc/udhcpc.d/50default: Adding DNS 202.138.103.100
    /etc/udhcpc.d/50default: Adding DNS 202.138.96.2
    Starting system message bus: [    5.552165] random: nonblocking pool is initialized
    dbus.
    Starting Dropbear SSH server: [    6.653624] NET: Registered protocol family 10
    dropbear.
    Starting mpmsrv daemon.
    platform: k2hk-evm
    Starting softhsm daemon.
    Starting telnet daemon.
    Starting tiipclad daemon
    GateMP is not supported for this device
    Opened log file: lad.txt
    numProcessors = 9 id = 0 baseId = 0
    Spawned daemon: /usr/bin/lad_tci6638
    Starting rpcbind daemon...done.
    starting statd: done
    Starting thttpd.
    Starting Lighttpd Web Server: lighttpd.
    2016-01-09 00:07:07: (/home/gtbldadm/processor-sdk-linux-fido-build/build-CORTEX_1/arago-tmp-external-linaro-toolchain/work/cortexa15hf-vfp-neon-linux-gnueabi/lighttpd/1.4.35-r1/lighttpd-1.4.35/src/log.c.164) server started
    * starting FTP Server: vsftpd... done.
    #>>>>> LCD 12
    IP Address:
    172.17.1.57
    Enabling thermal zones...
    /etc/rc5.d/S98thermal-zone-init: line 7: /sys/class/thermal/thermal_zone*/mode: No such file or directory
    NOTICE: This file system contains the following GPLv3 packages:
    autoconf
    binutils-dev
    binutils
    bison-dev
    bison
    cpp-symlinks
    cpp
    g++-symlinks
    g++
    gawk-dev
    gawk
    gcc-symlinks
    gcc
    gdb
    gdbc6x
    gdbserver
    libgmp10
    libmpc3
    libmpfr4
    make
    If you do not wish to distribute GPLv3 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org k2hk-evm /dev/ttyS0
    Arago 2015.12 k2hk-evm /dev/ttyS0
    k2hk-evm login: root
    root@k2hk-evm:~# cd /
    root@k2hk-evm:/# ls
    0246.mpmsrv_keystone2_example.out  mpmsrv_keystone2_example_new.out
    arm.out                            opt
    bin                                proc
    boot                               run
    dev                                sbin
    etc                                srv
    home                               sys
    include                            tmp
    ipaddr                             uio_module_drv.ko
    lib                                usr
    media                              var
    mnt                                www
    root@k2hk-evm:/#
    root@k2hk-evm:/#
    root@k2hk-evm:/# inm smod lib/modules/4.1.13-g8dc6617/kernel/drivers/r 2016 Jan  9 00:07:07 k2hk-evm bind 0.0.0.0 - Address already in use
    uio/uio.ko
    root@k2hk-evm:/#
    root@k2hk-evm:/#
    root@k2hk-evm:/# insmod lib/modules/4.1.13-g8dc6617/kernel/drivers/uio/uio.ko
    root@k2hk-evm:/# lsinsmod lib/modules/4.1.13-g8dc6617/kernel/drivers/soc/ti/keystone_dsp_mem.ko
    [   37.121895] keystone-dsp-mem c000000.dspmem: registered misc device dspmem
    root@k2hk-evm:/#
    root@k2hk-evm:/#
    root@k2hk-evm:/#
    root@k2hk-evm:/# insmod lib/modules/4.1.13-g8dc6617/kernel/drivers/virtio/virtio.ko
    root@k2hk-evm:/# insmod lib/modules/4.1.13-g8dc6617/kernel/drivers/virtio/virtio_ring.ko
    root@k2hk-evm:/#
    root@k2hk-evm:/#
    root@k2hk-evm:/#
    root@k2hk-evm:/#
    root@k2hk-evm:/#
    root@k2hk-evm:/#
    root@k2hk-evm:/# lsmod
    Module                  Size  Used by
    virtio_ring            12981  0
    virtio                  6432  0
    keystone_dsp_mem        2791  0
    uio                     8851  0
    ipv6                  339102  30
    root@k2hk-evm:/#
    root@k2hk-evm:/#
    moteproc.ko
    root@k2hk-evm:/#
    root@k2hk-evm:/#
    root@k2hk-evm:/# insmod lib/modules/4.1.13-g8dc6617/kernel/drivers/remoteproc/remmoteproc.ko
    Module                  Size  Used by
    remoteproc             25173  0
    virtio_ring            12981  1 remoteproc
    virtio                  6432  1 remoteproc
    uio                     8851  0
    ipv6                  339102  30
    root@k2hk-evm:/#
    root@k2hk-evm:/# insmod lib/modules/4.1.13-g8dc6617/kernel/drivers/remoteproc/keystone_remoteproc.ko
    [   82.980874] keystone-rproc 10800000.dsp0: assigned reserved memory node dsp_common_cma_pool
    [   82.989477]  remoteproc0: 10800000.dsp0 is available
    [   82.995157]  remoteproc0: Note: remoteproc is still under development and considered experimental.
    [   83.004458]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [   83.019518] keystone-rproc 11800000.dsp1: assigned reserved memory node dsp_common_cma_pool
    [   83.028546]  remoteproc1: 11800000.dsp1 is available
    [   83.033881]  remoteproc1: Note: remoteproc is still under development and considered experimental.
    [   83.042759]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [   83.057950] keystone-rproc 12800000.dsp2: assigned reserved memory node dsp_common_cma_pool
    [   83.066535] keystone-rproc 12800000.dsp2: device does not have an alias id
    [   83.074298]  remoteproc2: 12800000.dsp2 is available
    [   83.079222]  remoteproc2: Note: remoteproc is still under development and considered experimental.
    [   83.088662]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [   83.104104] keystone-rproc 13800000.dsp3: assigned reserved memory node dsp_common_cma_pool
    [   83.112386] keystone-rproc 13800000.dsp3: device does not have an alias id
    [   83.120152]  remoteproc3: 13800000.dsp3 is available
    [   83.125547]  remoteproc3: Note: remoteproc is still under development and considered experimental.
    [   83.134905]  remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [   83.149873] keystone-rproc 14800000.dsp4: assigned reserved memory node dsp_common_cma_pool
    [   83.158843] keystone-rproc 14800000.dsp4: device does not have an alias id
    [   83.166407]  remoteproc4: 14800000.dsp4 is available
    [   83.171330]  remoteproc4: Note: remoteproc is still under development and considered experimental.
    [   83.180752]  remoteproc4: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [   83.195823] keystone-rproc 15800000.dsp5: assigned reserved memory node dsp_common_cma_pool
    [   83.204386] keystone-rpinitcall: 0c037a99
