There are several occations when I get this error.
1.) I try and open a config file. The program fails with the above error and tells me to close and relaunch the XGConf editor.
2.) I try and compile an example project. I get the error
/opt/ti/xdctools_3_32_00_06_core/xs.x86_64U: error: can't create session manager: can't find a JVM; the environment variable 'XDCTOOLS_JAVA_HOME' is set, but does not appear to be a directory containing a 64-bit Java Runtime Environment (1.7 or greater); e.g., '/usr/lib/jvm/java-7-openjdk-amd64'.
gmake: *** No rule to make target 'configPkg/linker.cmd', needed by 'configPkg/compiler.opt'.
If I go to the terminal and run $echo XDCTOOLS_JAVA_HOME it says
echo $XDCTOOLS_JAVA_HOME
/usr/lib/jvm/java-1.7.0-openjdk-amd64
if I run
ls /usr/lib/jvm/
I see
default-java java-1.7.0-openjdk-amd64 java-7-openjdk-amd64 java-8-oracle
I have tried manually setting the environment to each one of these in my bashrc and then sourcing the file yet still no luck.
I have see the thread at:
https://e2e.ti.com/support/embedded/tirtos/f/355/t/522505
but there doesn't seem to be any resolution.
Does anyone have any idea how I can make this editor work?
