BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
Other Parts Discussed in Thread: TPS65217
Hi Forum,
An  Objective is to get 7" LCD screen get working .....
I am using BBB C revision I configured board as follow:
1/ Erased all eMMC so it can boot from Micro SD
2/ I have Element 14 a LCD screen 7" with BB -View cape
3/ The cape has installed in the extension with two LED's 1/ Red  2/Green along with 5 Push button
6/ I am using 1/ Angstrom OS 3.8.13 released after boot of OS I get following an errors.
================ Screen out put FOR ANGSTROM.====================================
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.196494] omap2_mbox_probe: platform not supported
[ 0.207162] tps65217-bl tps65217-bl: no platform data provided
[ 0.283596] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 0.320703] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 0.357812] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 0.394921] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 0.414781] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 0.424392] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 0.444935] omap_hsmmc mmc.5: of_parse_phandle_with_args of 'reset' failed
[ 0.452233] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.520376] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 0.532086] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 0.539470] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
systemd-fsck[86]: Angstrom: clean, 111287/218160 files, 629040/872448 blocks
[ 6.257586] Unhandled fault: external abort on non-linefetch (0x1018) at 0xb6f7f44c
[ 6.592826] libphy: PHY 4a101000.mdio:01 not found
[ 6.597903] net eth0: phy 4a101000.mdio:01 not found on slave 1
.---O---.
| | .-. o o
| | | __ | ---'| '--.| .-'| | |
The Angstrom Distribution beaglebone ttyO0
Angstrom v2012.12 - Kernel 3.8.13
beaglebone login:
================================= Screen output END ===========================
================================== FOR DEBIAN OS ============================
Starting kernel ...
[ 0.400961] omap2_mbox_probe: platform not supported
[ 0.556692] tps65217-bl tps65217-bl: no platform data provided
[ 0.619939] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 0.657048] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 0.694156] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 0.731265] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 0.749856] omap_hsmmc mmc.5: of_parse_phandle_with_args of 'reset' failed
[ 0.784326] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 0.796039] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 0.803324] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
Loading, please wait...
[ 1.101629] bone-capemgr bone_capemgr.9: failed to load firmware 'BB-VIEW-LCD7-01--00A0.dtbo'
[ 1.110640] bone-capemgr bone_capemgr.9: loader: failed to load slot-7 BB-VIEW-LCD7-01-:00A0 (prio 0)
[ 1.282620] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 1.292391] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 1.299228] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
systemd-fsck[227]: rootfs: clean, 98192/211744 files, 514858/845568 blocks
Debian GNU/Linux 7 beaglebone ttyO0
BeagleBoard.org Debian Image 2015-11-12
Support/FAQ: elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
beaglebone login: [ 29.266893] libphy: PHY 4a101000.mdio:01 not found
[ 29.271960] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 35.409409] libphy: PHY 4a101000.mdio:01 not found
[ 35.414495] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 36.399882] libphy: PHY 4a101000.mdio:01 not found
[ 36.404984] net eth0: phy 4a101000.mdio:01 not found on slave 1
The IP Address for usb0 is: 192.168.7.2
beaglebone login:
========================================= End of screen output =====================
I wonder if you guys out there have similar problem, if anyone can direct me to the right direction will be much appreciated,
I tried various images and build myself but to get going with BB-View cape with 7" LCD screen not in success!!
Thank you,
    Could you share the dts files you use? From the bootlog I can see that your kernel has problems parsing the display cape dts nodes.
    As for the BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI), this indicates, that the device ball connected to P8.45 is muxed twice as different IPs, and is probably claimed by more than one dts node.
    Yordan
  • Than you Yordan,
    for your reply I have a BB-View cape with 7" LCD screen from Element14 and following Debian OS
    root@beaglebone:~# uname -a
    Linux beaglebone 3.8.13-bone79 #1 SMP Tue Oct 13 20:44:55 UTC 2015 armv7l GNU/Linux
    root@beaglebone:~# lsb_release -a
    No LSB modules are available.
    Distributor ID: Debian
    Description: Debian GNU/Linux 7.9 (wheezy)
    Release: 7.9
    Codename: wheezy
    1/ In the /boot/ directory I have followings:
    -rw-r--r-- 1 root root 110269 Oct 13 2015 config-3.8.13-bone79
    drwxr-xr-x 3 root root 4096 Nov 12 2015 dtbs
    -rw-r--r-- 1 root root 2862929 Nov 12 2015 initrd.img-3.8.13-bone79
    -rw------- 1 root root 501 Nov 12 2015 SOC.sh
    -rw-r--r-- 1 root root 2435652 Oct 13 2015 System.map-3.8.13-bone79
    drwx------ 2 root root 4096 Nov 12 2015 uboot
    -rw------- 1 root root 1757 Nov 12 2015 uEnv.txt
    -rwxr-xr-x 1 root root 5644336 Oct 13 2015 vmlinuz-3.8.13-bone79
    2/ In the dtb directory have following:
    am335x-boneblack.dtb
    am335x-bone.dtb
    am335x-bonegreen.dtb
    am335x-evm.dtb
    am335x-evmsk.dtb
    am335x-tester.dtb
    arduino-tre.dtb
    omap2420-h4.dtb
    omap3-beagle.dtb
    omap3-beagle-xm.dtb
    omap3-evm.dtb
    omap3-tobi.dtb
    omap4-panda-a4.dtb
    omap4-panda.dtb
    omap4-panda-es.dtb
    omap4-sdp.dtb
    omap4-var-som.dtb
    omap5-evm.dtb
    3/ I assume the main dtb file get loaded during the post kernel initialisation "am335-boneblack.dtb" the file's contents as follow:
    /dts-v1/;
    #address-cells = <0x1>;
    #size-cells = <0x1>;
    compatible = "ti,am335x-bone", "ti,am33xx";
    interrupt-parent = <0x1>;
    model = "TI AM335x BeagleBone";
    chosen {
    aliases {
    serial0 = "/ocp/serial@44e09000";
    serial1 = "/ocp/serial@48022000";
    serial2 = "/ocp/serial@48024000";
    serial3 = "/ocp/serial@481a6000";
    serial4 = "/ocp/serial@481a8000";
    serial5 = "/ocp/serial@481aa000";
    memory {
    device_type = "memory";
    reg = <0x80000000 0x10000000>;
    cpus {
    cpu@0 {
    compatible = "arm,cortex-a8";
    operating-points = <0xf4240 0x149970 0xc3500 0x13d620 0x927c0 0x10f7c0 0x493e0 0xec928>;
    voltage-tolerance = <0x2>;
    clock-latency = <0x493e0>;
    cpu0-supply = <0x2>;
    linux,phandle = <0x13>;
    phandle = <0x13>;
    pmu {
    compatible = "arm,cortex-a8-pmu";
    interrupts = <0x3>;
    soc {
    compatible = "ti,omap-infra";
    mpu {
    compatible = "ti,omap3-mpu";
    ti,hwmods = "mpu";
    pinmux@44e10800 {
    compatible = "pinctrl-single";
    reg = <0x44e10800 0x238>;
    #size-cells = <0x0>;
    pinctrl-single,register-width = <0x20>;
    pinctrl-single,function-mask = <0x7f>;
    pinctrl-names = "default";
    pinctrl-0 = <0x3>;
    linux,phandle = <0x14>;
    phandle = <0x14>;
    pinmux_userled_pins {
    pinctrl-single,pins = <0x54 0x7 0x58 0x17 0x5c 0x7 0x60 0x17>;
    linux,phandle = <0x3>;
    phandle = <0x3>;
    pinmux_i2c0_pins {
    pinctrl-single,pins = <0x188 0x70 0x18c 0x70>;
    linux,phandle = <0x6>;
    phandle = <0x6>;
    pinmux_i2c2_pins {
    pinctrl-single,pins = <0x178 0x73 0x17c 0x73>;
    linux,phandle = <0x7>;
    phandle = <0x7>;
    pinmux_mmc1_pins {
    pinctrl-single,pins = <0x160 0x2f>;
    linux,phandle = <0x9>;
    phandle = <0x9>;
    pinmux_rstctl_pins {
    pinctrl-single,pins = <0x50 0x17>;
    linux,phandle = <0x4>;
    phandle = <0x4>;
    ocp {
    compatible = "simple-bus";
    ranges;
    ti,hwmods = "l3_main";
    linux,phandle = <0x15>;
    phandle = <0x15>;
    interrupt-controller@48200000 {
    compatible = "ti,omap2-intc";
    interrupt-controller;
    #interrupt-cells = <0x1>;
    ti,intc-size = <0x80>;
    reg = <0x48200000 0x1000>;
    linux,phandle = <0x1>;
    phandle = <0x1>;
    sgx@0x56000000 {
    compatible = "ti,sgx";
    ti,hwmods = "gfx";
    clock-frequency = <0xbebc200>;
    reg = <0x56000000 0x1000000>;
    interrupts = <0x25>;
    edma@49000000 {
    compatible = "ti,edma3";
    ti,hwmods = "tpcc", "tptc0", "tptc1", "tptc2";
    reg = <0x49000000 0x10000 0x44e10f90 0x40>;
    interrupts = <0xc 0xd 0xe>;
    #dma-cells = <0x1>;
    dma-channels = <0x40>;
    ti,edma-regions = <0x4>;
    ti,edma-slots = <0x100>;
    ti,edma-queue-tc-map = <0x0 0x0 0x1 0x1 0x2 0x2>;
    ti,edma-queue-priority-map = <0x0 0x0 0x1 0x1 0x2 0x2>;
    ti,edma-default-queue = <0x1>;
    ti,edma-xbar-event-map = <0x20 0xc 0x1e 0x14>;
    linux,phandle = <0x8>;
    phandle = <0x8>;
    gpio@44e07000 {
    compatible = "ti,omap4-gpio";
    ti,hwmods = "gpio1";
    gpio-controller;
    #gpio-cells = <0x2>;
    reg = <0x44e07000 0x1000>;
    interrupts = <0x60>;
    linux,phandle = <0xa>;
    phandle = <0xa>;
    gpio@4804c000 {
    ti,hwmods = "gpio2";
    gpio-controller;
    reg = <0x4804c000 0x1000>;
    interrupts = <0x62>;
    linux,phandle = <0x5>;
    phandle = <0x5>;
    gpio@481ac000 {
    ti,hwmods = "gpio3";
    gpio-controller;
    reg = <0x481ac000 0x1000>;
    interrupts = <0x20>;
    linux,phandle = <0x16>;
    phandle = <0x16>;
    gpio@481ae000 {
    ti,hwmods = "gpio4";
    gpio-controller;
    reg = <0x481ae000 0x1000>;
    interrupts = <0x3e>;
    linux,phandle = <0x17>;
    phandle = <0x17>;
    rstctl@0 {
    status = "okay";
    compatible = "gpio-rctrl";
    pinctrl-0 = <0x4>;
    #reset-cells = <0x2>;
    gpios = <0x5 0x14 0x0>;
    gpio-names = "eMMC_RSTn";
    linux,phandle = <0xc>;
    phandle = <0xc>;
    serial@44e09000 {
    compatible = "ti,omap3-uart";
    ti,hwmods = "uart1";
    clock-frequency = <0x2dc6c00>;
    reg = <0x44e09000 0x2000>;
    interrupts = <0x48>;
    status = "okay";
    linux,phandle = <0x18>;
    phandle = <0x18>;
    serial@48022000 {
    ti,hwmods = "uart2";
    reg = <0x48022000 0x2000>;
    interrupts = <0x49>;
    status = "disabled";
    linux,phandle = <0x19>;
    phandle = <0x19>;
    serial@48024000 {
    ti,hwmods = "uart3";
    reg = <0x48024000 0x2000>;
    interrupts = <0x4a>;
    linux,phandle = <0x1a>;
    phandle = <0x1a>;
    serial@481a6000 {
    ti,hwmods = "uart4";
    reg = <0x481a6000 0x2000>;
    interrupts = <0x2c>;
    linux,phandle = <0x1b>;
    phandle = <0x1b>;
    serial@481a8000 {
    ti,hwmods = "uart5";
    reg = <0x481a8000 0x2000>;
    interrupts = <0x2d>;
    linux,phandle = <0x1c>;
    phandle = <0x1c>;
    serial@481aa000 {
    ti,hwmods = "uart6";
    reg = <0x481aa000 0x2000>;
    interrupts = <0x2e>;
    linux,phandle = <0x1d>;
    phandle = <0x1d>;
    i2c@44e0b000 {
    compatible = "ti,omap4-i2c";
    ti,hwmods = "i2c1";
    reg = <0x44e0b000 0x1000>;
    interrupts = <0x46>;
    status = "okay";
    clock-frequency = <0x61a80>;
    pinctrl-0 = <0x6>;
    linux,phandle = <0x1e>;
    phandle = <0x1e>;
    tps@24 {
    reg = <0x24>;
    compatible = "ti,tps65217";
    ti,pmic-shutdown-controller;
    interrupts = <0x7>;
    linux,phandle = <0x1f>;
    phandle = <0x1f>;
    regulators {
    regulator@0 {
    reg = <0x0>;
    regulator-compatible = "dcdc1";
    regulator-always-on;
    linux,phandle = <0x20>;
    phandle = <0x20>;
    regulator@1 {
    reg = <0x1>;
    regulator-compatible = "dcdc2";
    regulator-name = "vdd_mpu";
    regulator-min-microvolt = <0xe1d48>;
    regulator-max-microvolt = <0x1437c8>;
    regulator-boot-on;
    linux,phandle = <0x2>;
    phandle = <0x2>;
    regulator@2 {
    reg = <0x2>;
    regulator-compatible = "dcdc3";
    regulator-name = "vdd_core";
    regulator-max-microvolt = <0x118c30>;
    regulator-boot-on;
    linux,phandle = <0x21>;
    phandle = <0x21>;
    regulator@3 {
    reg = <0x3>;
    regulator-compatible = "ldo1";
    linux,phandle = <0x22>;
    phandle = <0x22>;
    regulator@4 {
    reg = <0x4>;
    regulator-compatible = "ldo2";
    linux,phandle = <0x23>;
    phandle = <0x23>;
    regulator@5 {
    reg = <0x5>;
    regulator-compatible = "ldo3";
    regulator-min-microvolt = <0x1b7740>;
    regulator-max-microvolt = <0x1b7740>;
    linux,phandle = <0x24>;
    phandle = <0x24>;
    regulator@6 {
    reg = <0x6>;
    regulator-compatible = "ldo4";
    linux,phandle = <0x25>;
    phandle = <0x25>;
    baseboard_eeprom@50 {
    compatible = "at,24c256";
    reg = <0x50>;
    linux,phandle = <0xe>;
    phandle = <0xe>;
    i2c@4802a000 {
    ti,hwmods = "i2c2";
    reg = <0x4802a000 0x1000>;
    interrupts = <0x47>;
    linux,phandle = <0x26>;
    phandle = <0x26>;
    i2c@4819c000 {
    ti,hwmods = "i2c3";
    reg = <0x4819c000 0x1000>;
    interrupts = <0x1e>;
    status = "okay";
    pinctrl-0 = <0x7>;
    clock-frequency = <0x186a0>;
    linux,phandle = <0x27>;
    phandle = <0x27>;
    cape_eeprom0@54 {
    reg = <0x54>;
    linux,phandle = <0xf>;
    phandle = <0xf>;
    cape_eeprom1@55 {
    reg = <0x55>;
    linux,phandle = <0x10>;
    phandle = <0x10>;
    cape_eeprom2@56 {
    reg = <0x56>;
    linux,phandle = <0x11>;
    phandle = <0x11>;
    cape_eeprom3@57 {
    reg = <0x57>;
    linux,phandle = <0x12>;
    phandle = <0x12>;
    mmc@48060000 {
    compatible = "ti,omap3-hsmmc";
    ti,hwmods = "mmc1";
    ti,dual-volt;
    ti,needs-special-reset;
    ti,needs-special-hs-handling;
    dmas = <0x8 0x18 0x8 0x19>;
    dma-names = "tx", "rx";
    status = "okay";
    pinctrl-0 = <0x9>;
    bus-width = <0x4>;
    cd-gpios = <0xa 0x6 0x0>;
    cd-inverted;
    vmmc-supply = <0xb>;
    ti,vcc-aux-disable-is-sleep;
    linux,phandle = <0x28>;
    phandle = <0x28>;
    mmc@481d8000 {
    ti,hwmods = "mmc2";
    dmas = <0x8 0x2 0x8 0x3>;
    bus-width = <0x8>;
    ti,non-removable;
    reset = <0xc 0x0 0x0>;
    reset-names = "eMMC_RSTn-CONSUMER";
    linux,phandle = <0x29>;
    phandle = <0x29>;
    mmc@47810000 {
    ti,hwmods = "mmc3";
    linux,phandle = <0x2a>;
    phandle = <0x2a>;
    wdt@44e35000 {
    compatible = "ti,omap3-wdt";
    ti,hwmods = "wd_timer2";
    reg = <0x44e35000 0x1000>;
    interrupts = <0x5b>;
    linux,phandle = <0x2b>;
    phandle = <0x2b>;
    d_can@481cc000 {
    compatible = "bosch,d_can";
    ti,hwmods = "d_can0";
    reg = <0x481cc000 0x2000>;
    interrupts = <0x34>;
    linux,phandle = <0x2c>;
    phandle = <0x2c>;
    d_can@481d0000 {
    ti,hwmods = "d_can1";
    reg = <0x481d0000 0x2000>;
    interrupts = <0x37>;
    linux,phandle = <0x2d>;
    phandle = <0x2d>;
    timer@44e31000 {
    compatible = "ti,omap2-timer";
    reg = <0x44e31000 0x400>;
    interrupts = <0x43>;
    ti,hwmods = "timer1";
    ti,timer-alwon;
    linux,phandle = <0x2e>;
    phandle = <0x2e>;
    timer@48040000 {
    reg = <0x48040000 0x400>;
    interrupts = <0x44>;
    ti,hwmods = "timer2";
    linux,phandle = <0x2f>;
    phandle = <0x2f>;
    timer@48042000 {
    reg = <0x48042000 0x400>;
    interrupts = <0x45>;
    ti,hwmods = "timer3";
    linux,phandle = <0x30>;
    phandle = <0x30>;
    timer@48044000 {
    reg = <0x48044000 0x400>;
    interrupts = <0x5c>;
    ti,hwmods = "timer4";
    ti,timer-pwm;
    linux,phandle = <0x31>;
    phandle = <0x31>;
    timer@48046000 {
    reg = <0x48046000 0x400>;
    interrupts = <0x5d>;
    ti,hwmods = "timer5";
    ti,timer-pwm;
    linux,phandle = <0x32>;
    phandle = <0x32>;
    timer@48048000 {
    reg = <0x48048000 0x400>;
    interrupts = <0x5e>;
    ti,hwmods = "timer6";
    ti,timer-pwm;
    linux,phandle = <0x33>;
    phandle = <0x33>;
    timer@4804a000 {
    reg = <0x4804a000 0x400>;
    interrupts = <0x5f>;
    ti,hwmods = "timer7";
    ti,timer-pwm;
    linux,phandle = <0x34>;
    phandle = <0x34>;
    pruss@4a300000 {
    compatible = "ti,pruss-v2";
    ti,hwmods = "pruss";
    ti,deassert-hard-reset = "pruss", "pruss";
    reg = <0x4a300000 0x80000>;
    ti,pintc-offset = <0x20000>;
    interrupts = <0x14 0x15 0x16 0x17 0x18 0x19 0x1a 0x1b>;
    linux,phandle = <0x35>;
    phandle = <0x35>;
    rtc@44e3e000 {
    compatible = "ti,da830-rtc";
    reg = <0x44e3e000 0x1000>;
    interrupts = <0x4b 0x4c>;
    ti,hwmods = "rtc";
    ti,system-power-controller;
    spi@48030000 {
    compatible = "ti,omap4-mcspi";
    reg = <0x48030000 0x400>;
    interrupt = <0x41>;
    ti,spi-num-cs = <0x2>;
    ti,hwmods = "spi0";
    dmas = <0x8 0x10 0x8 0x11 0x8 0x12 0x8 0x13>;
    dma-names = "tx0", "rx0", "tx1", "rx1";
    linux,phandle = <0x36>;
    phandle = <0x36>;
    spi@481a0000 {
    reg = <0x481a0000 0x400>;
    interrupt = <0x7d>;
    ti,hwmods = "spi1";
    dmas = <0x8 0x2a 0x8 0x2b 0x8 0x2c 0x8 0x2d>;
    linux,phandle = <0x37>;
    phandle = <0x37>;
    gpmc@50000000 {
    compatible = "ti,am3352-gpmc";
    ti,hwmods = "gpmc";
    reg = <0x50000000 0x1000000>;
    interrupts = <0x64>;
    gpmc,num-cs = <0x7>;
    gpmc,num-waitpins = <0x2>;
    #address-cells = <0x2>;
    linux,phandle = <0x38>;
    phandle = <0x38>;
    nop-phy@0 {
    compatible = "nop-xceiv-usb";
    nop-phy@1 {
    usb@47400000 {
    compatible = "ti,musb-am33xx";
    reg = <0x47400000 0x1000 0x47401000 0x800 0x47401800 0x800>;
    interrupts = <0x11 0x12 0x13>;
    multipoint = <0x1>;
    num-eps = <0x10>;
    ram-bits = <0xc>;
    port0-mode = <0x3>;
    port1-mode = <0x1>;
    power = <0xfa>;
    ti,hwmods = "usb_otg_hs";
    status = "okay";
    interface_type = <0x1>;
    linux,phandle = <0x39>;
    phandle = <0x39>;
    ethernet@4a100000 {
    compatible = "ti,cpsw";
    ti,hwmods = "cpgmac0";
    cpdma_channels = <0x8>;
    ale_entries = <0x400>;
    bd_ram_size = <0x2000>;
    no_bd_ram = <0x0>;
    rx_descs = <0x40>;
    mac_control = <0x20>;
    slaves = <0x2>;
    cpts_active_slave = <0x0>;
    cpts_clock_mult = <0x80000000>;
    cpts_clock_shift = <0x1d>;
    reg = <0x4a100000 0x800 0x4a101200 0x100>;
    interrupts = <0x28 0x29 0x2a 0x2b>;
    ranges;
    disable-napi;
    linux,phandle = <0x3a>;
    phandle = <0x3a>;
    mdio@4a101000 {
    compatible = "ti,davinci_mdio";
    ti,hwmods = "davinci_mdio";
    bus_freq = <0xf4240>;
    reg = <0x4a101000 0x100>;
    linux,phandle = <0xd>;
    phandle = <0xd>;
    slave@4a100200 {
    mac-address = [00 00 00 00 00 00];
    phy_id = <0xd 0x0>;
    linux,phandle = <0x3b>;
    phandle = <0x3b>;
    slave@4a100300 {
    phy_id = <0xd 0x1>;
    linux,phandle = <0x3c>;
    phandle = <0x3c>;
    tscadc@44e0d000 {
    compatible = "ti,ti-tscadc";
    reg = <0x44e0d000 0x1000>;
    interrupts = <0x10>;
    ti,hwmods = "adc_tsc";
    linux,phandle = <0x3d>;
    phandle = <0x3d>;
    lcdc@4830e000 {
    compatible = "ti,am3352-lcdc", "ti,da830-lcdc";
    reg = <0x4830e000 0x1000>;
    interrupts = <0x24>;
    ti,hwmods = "lcdc";
    linux,phandle = <0x3e>;
    phandle = <0x3e>;
    epwmss@48300000 {
    compatible = "ti,am33xx-pwmss";
    reg = <0x48300000 0x10>;
    ti,hwmods = "epwmss0";
    ranges = <0x48300100 0x48300100 0x80 0x48300180 0x48300180 0x80 0x48300200 0x48300200 0x80>;
    linux,phandle = <0x3f>;
    phandle = <0x3f>;
    ecap@48300100 {
    compatible = "ti,am33xx-ecap";
    #pwm-cells = <0x3>;
    reg = <0x48300100 0x80>;
    ti,hwmods = "ecap0";
    linux,phandle = <0x40>;
    phandle = <0x40>;
    ehrpwm@48300200 {
    compatible = "ti,am33xx-ehrpwm";
    #pwm-cells = <0x3>;
    reg = <0x48300200 0x80>;
    ti,hwmods = "ehrpwm0";
    linux,phandle = <0x41>;
    phandle = <0x41>;
    eqep@0x48300180 {
    compatible = "ti,am33xx-eqep";
    reg = <0x48300180 0x80>;
    interrupts = <0x4f>;
    ti,hwmods = "eqep0";
    linux,phandle = <0x42>;
    phandle = <0x42>;
    epwmss@48302000 {
    reg = <0x48302000 0x10>;
    ti,hwmods = "epwmss1";
    ranges = <0x48302100 0x48302100 0x80 0x48302180 0x48302180 0x80 0x48302200 0x48302200 0x80>;
    linux,phandle = <0x43>;
    phandle = <0x43>;
    ecap@48302100 {
    #pwm-cells = <0x3>;
    reg = <0x48302100 0x80>;
    ti,hwmods = "ecap1";
    linux,phandle = <0x44>;
    phandle = <0x44>;
    ehrpwm@48302200 {
    #pwm-cells = <0x3>;
    reg = <0x48302200 0x80>;
    ti,hwmods = "ehrpwm1";
    linux,phandle = <0x45>;
    phandle = <0x45>;
    eqep@0x48302180 {
    reg = <0x48302180 0x80>;
    interrupts = <0x58>;
    ti,hwmods = "eqep1";
    linux,phandle = <0x46>;
    phandle = <0x46>;
    epwmss@48304000 {
    reg = <0x48304000 0x10>;
    ti,hwmods = "epwmss2";
    ranges = <0x48304100 0x48304100 0x80 0x48304180 0x48304180 0x80 0x48304200 0x48304200 0x80>;
    linux,phandle = <0x47>;
    phandle = <0x47>;
    ecap@48304100 {
    #pwm-cells = <0x3>;
    reg = <0x48304100 0x80>;
    ti,hwmods = "ecap2";
    linux,phandle = <0x48>;
    phandle = <0x48>;
    ehrpwm@48304200 {
    #pwm-cells = <0x3>;
    reg = <0x48304200 0x80>;
    ti,hwmods = "ehrpwm2";
    linux,phandle = <0x49>;
    phandle = <0x49>;
    eqep@0x48304180 {
    reg = <0x48304180 0x80>;
    interrupts = <0x59>;
    ti,hwmods = "eqep2";
    linux,phandle = <0x4a>;
    phandle = <0x4a>;
    sham@53100000 {
    compatible = "ti,omap4-sham";
    ti,hwmods = "sham";
    reg = <0x53100000 0x200>;
    interrupts = <0x6d>;
    dmas = <0x8 0x24>;
    dma-names = "rx";
    status = "okay";
    linux,phandle = <0x4b>;
    phandle = <0x4b>;
    aes@53500000 {
    compatible = "ti,omap4-aes";
    ti,hwmods = "aes";
    reg = <0x53500000 0xa0>;
    interrupts = <0x66>;
    dmas = <0x8 0x6 0x8 0x5>;
    status = "okay";
    linux,phandle = <0x4c>;
    phandle = <0x4c>;
    mcasp@48038000 {
    compatible = "ti,omap2-mcasp-audio";
    ti,hwmods = "mcasp0";
    reg = <0x48038000 0x2000>;
    interrupts = <0x50 0x51>;
    asp-chan-q = <0x2>;
    tx-dma-offset = <0x46000000>;
    rx-dma-offset = <0x46000000>;
    dmas = <0x8 0x8 0x8 0x9>;
    linux,phandle = <0x4d>;
    phandle = <0x4d>;
    mcasp@4803C000 {
    ti,hwmods = "mcasp1";
    reg = <0x4803c000 0x2000>;
    interrupts = <0x52 0x53>;
    asp-chan-q = <0x2>;
    tx-dma-offset = <0x46400000>;
    rx-dma-offset = <0x46400000>;
    dmas = <0x8 0xa 0x8 0xb>;
    linux,phandle = <0x4e>;
    phandle = <0x4e>;
    bandgap@44e10448 {
    compatible = "ti,am335x-bandgap";
    reg = <0x44e10448 0x8>;
    rng@483100000 {
    compatible = "ti,omap4-rng";
    ti,hwmods = "rng";
    reg = <0x48310000 0x2000>;
    interrupts = <0x6f>;
    linux,phandle = <0x4f>;
    phandle = <0x4f>;
    gpio-leds {
    compatible = "gpio-leds";
    pinctrl-0 = <0x3>;
    led0 {
    label = "beaglebone:green:usr0";
    gpios = <0x5 0x15 0x0>;
    linux,default-trigger = "heartbeat";
    default-state = "off";
    led1 {
    label = "beaglebone:green:usr1";
    gpios = <0x5 0x16 0x0>;
    linux,default-trigger = "mmc0";
    led2 {
    label = "beaglebone:green:usr2";
    gpios = <0x5 0x17 0x0>;
    linux,default-trigger = "cpu0";
    led3 {
    label = "beaglebone:green:usr3";
    gpios = <0x5 0x18 0x0>;
    linux,default-trigger = "mmc1";
    bone_capemgr {
    compatible = "ti,bone-capemgr";
    status = "okay";
    eeprom = <0xe>;
    baseboardmaps {
    board@0 {
    board-name = "A335BONE";
    compatible-name = "ti,beaglebone";
    linux,phandle = <0x50>;
    phandle = <0x50>;
    board@1 {
    board-name = "A335BNLT";
    compatible-name = "ti,beaglebone-black";
    linux,phandle = <0x51>;
    phandle = <0x51>;
    slots {
    slot@0 {
    eeprom = <0xf>;
    slot@1 {
    eeprom = <0x10>;
    slot@2 {
    eeprom = <0x11>;
    slot@3 {
    eeprom = <0x12>;
    slot@5 {
    ti,cape-override;
    compatible = "kernel-command-line", "runtime";
    board-name = "Bone-Geiger";
    version = "00A0";
    manufacturer = "Geiger Inc.";
    part-number = "BB-BONE-GEIGER";
    slot@7 {
    ti,cape-override;
    board-name = "Bone-Nixie";
    version = "00A0";
    manufacturer = "Ranostay Industries";
    part-number = "BB-BONE-NIXIE";
    slot@8 {
    ti,cape-override;
    board-name = "Bone-TFT";
    version = "00A0";
    manufacturer = "Adafruit";
    part-number = "BB-BONE-TFT-01";
    slot@9 {
    ti,cape-override;
    board-name = "Bone-RTC";
    version = "00A0";
    part-number = "BB-BONE-RTC-01";
    slot@10 {
    ti,cape-override;
    board-name = "Bone-Hexy";
    version = "00A0";
    manufacturer = "Koen Kooi";
    part-number = "BB-BONE-HEXY-01";
    slot@11 {
    ti,cape-override;
    board-name = "Bone-MRF24J40";
    version = "00A0";
    manufacturer = "Signal 11 Software";
    part-number = "BB-BONE-MRF24J40";
    slot@12 {
    ti,cape-override;
    board-name = "BB-BONE-RS232";
    version = "00A0";
    part-number = "BB-BONE-RS232-01";
    slot@13 {
    board-name = "BB-BONE-GPS";
    version = "00A0";
    part-number = "BB-BONE-GPS-01";
    slot@100 {
    ti,cape-override;
    priority = <0x1>;
    compatible = "ti,beaglebone-green", "ti,beaglebone-black";
    board-name = "Bone-LT-eMMC-2G";
    version = "00A0";
    manufacturer = "Texas Instruments";
    part-number = "BB-BONE-EMMC-2G";
    slot@101 {
    ti,cape-override;
    priority = <0x1>;
    compatible = "ti,beaglebone-black";
    board-name = "Bone-Black-HDMI";
    version = "00A0";
    part-number = "BB-BONELT-HDMI";
    slot@102 {
    ti,cape-override;
    priority = <0x2>;
    board-name = "Bone-Black-HDMIN";
    version = "00A0";
    part-number = "BB-BONELT-HDMIN";
    capemaps {
    cape@0 {
    part-number = "BB-BONE-DVID-01";
    version@00A0 {
    version = "00A0";
    dtbo = "cape-bone-dvi-00A0.dtbo";
    version@00A1 {
    version = "00A1", "01";
    dtbo = "cape-bone-dvi-00A1.dtbo";
    version@00A2 {
    version = "00A2", "A2";
    dtbo = "cape-bone-dvi-00A2.dtbo";
    version@00A3 {
    version = "00A3";
    cape@1 {
    version@00A0 {
    version = "00A0";
    dtbo = "cape-bone-2g-emmc1.dtbo";
    cape@2 {
    version@00A0 {
    version = "00A0";
    dtbo = "cape-bone-geiger-00A0.dtbo";
    cape@3 {
    part-number = "BB-BONE-LCD3-01";
    version@00A0 {
    version = "00A0";
    dtbo = "cape-bone-lcd3-00A0.dtbo";
    version@00A2 {
    version = "00A2";
    dtbo = "cape-bone-lcd3-00A2.dtbo";
    cape@4 {
    part-number = "BB-BONE-WTHR-01";
    version@00A0 {
    version = "00A0";
    dtbo = "cape-bone-weather-00A0.dtbo";
    version@00B0 {
    version = "00B0";
    dtbo = "cape-bone-weather-00B0.dtbo";
    cape@5 {
    version@00A0 {
    version = "00A0";
    dtbo = "cape-boneblack-hdmi-00A0.dtbo";
    cape@6 {
    version@00A0 {
    version = "00A0";
    dtbo = "cape-bone-nixie-00A0.dtbo";
    cape@7 {
    version@00A0 {
    version = "00A0";
    dtbo = "cape-bone-adafruit-lcd-00A0.dtbo";
    cape@8 {
    version@00A0 {
    version = "00A0";
    dtbo = "BB-BONE-RTC-00A0.dtbo";
    cape@9 {
    version@00A0 {
    version = "00A0";
    dtbo = "cape-bone-hexy-00A0.dtbo";
    cape@10 {
    version@00A0 {
    version = "00A0";
    dtbo = "cape-bone-mrf24j40-00A0.dtbo";
    cape@11 {
    part-number = "BB-BONE-EXPTEST";
    version@00A0 {
    version = "00A0";
    dtbo = "cape-bone-exptest-00A0.dtbo";
    cape@12 {
    version@00A0 {
    version = "00A0";
    dtbo = "BB-BONE-RS232-00A0.dtbo";
    cape@13 {
    version@00A0 {
    version = "00A0";
    dtbo = "BB-BONE-GPS-00A0.dtbo";
    cape@14 {
    version@00A0 {
    version = "00A0";
    dtbo = "cape-boneblack-hdmin-00A0.dtbo";
    cape@15 {
    part-number = "2191";
    version@R2 {
    version = "R2";
    dtbo = "cape-bebopr-R2.dtbo";
    cape@16 {
    part-number = "BB-BONE-LOGIBONE";
    version@00R1 {
    version = "00R1";
    dtbo = "BB-BONE-LOGIBONE-00R1.dtbo";
    fixedregulator@0 {
    compatible = "regulator-fixed";
    regulator-name = "vmmcsd_fixed";
    regulator-min-microvolt = <0x325aa0>;
    regulator-max-microvolt = <0x325aa0>;
    linux,phandle = <0xb>;
    phandle = <0xb>;
    __symbols__ {
    cpu = "/cpus/cpu@0";
    am33xx_pinmux = "/pinmux@44e10800";
    userled_pins = "/pinmux@44e10800/pinmux_userled_pins";
    i2c0_pins = "/pinmux@44e10800/pinmux_i2c0_pins";
    i2c2_pins = "/pinmux@44e10800/pinmux_i2c2_pins";
    mmc1_pins = "/pinmux@44e10800/pinmux_mmc1_pins";
    rstctl_pins = "/pinmux@44e10800/pinmux_rstctl_pins";
    ocp = "/ocp";
    intc = "/ocp/interrupt-controller@48200000";
    edma = "/ocp/edma@49000000";
    gpio1 = "/ocp/gpio@44e07000";
    gpio2 = "/ocp/gpio@4804c000";
    gpio3 = "/ocp/gpio@481ac000";
    gpio4 = "/ocp/gpio@481ae000";
    rstctl = "/ocp/rstctl@0";
    uart1 = "/ocp/serial@44e09000";
    uart2 = "/ocp/serial@48022000";
    uart3 = "/ocp/serial@48024000";
    uart4 = "/ocp/serial@481a6000";
    uart5 = "/ocp/serial@481a8000";
    uart6 = "/ocp/serial@481aa000";
    i2c0 = "/ocp/i2c@44e0b000";
    tps = "/ocp/i2c@44e0b000/tps@24";
    dcdc1_reg = "/ocp/i2c@44e0b000/tps@24/regulators/regulator@0";
    dcdc2_reg = "/ocp/i2c@44e0b000/tps@24/regulators/regulator@1";
    dcdc3_reg = "/ocp/i2c@44e0b000/tps@24/regulators/regulator@2";
    ldo1_reg = "/ocp/i2c@44e0b000/tps@24/regulators/regulator@3";
    ldo2_reg = "/ocp/i2c@44e0b000/tps@24/regulators/regulator@4";
    ldo3_reg = "/ocp/i2c@44e0b000/tps@24/regulators/regulator@5";
    ldo4_reg = "/ocp/i2c@44e0b000/tps@24/regulators/regulator@6";
    baseboard_eeprom = "/ocp/i2c@44e0b000/baseboard_eeprom@50";
    i2c1 = "/ocp/i2c@4802a000";
    i2c2 = "/ocp/i2c@4819c000";
    cape_eeprom0 = "/ocp/i2c@4819c000/cape_eeprom0@54";
    cape_eeprom1 = "/ocp/i2c@4819c000/cape_eeprom1@55";
    cape_eeprom2 = "/ocp/i2c@4819c000/cape_eeprom2@56";
    cape_eeprom3 = "/ocp/i2c@4819c000/cape_eeprom3@57";
    mmc1 = "/ocp/mmc@48060000";
    mmc2 = "/ocp/mmc@481d8000";
    mmc3 = "/ocp/mmc@47810000";
    wdt2 = "/ocp/wdt@44e35000";
    dcan0 = "/ocp/d_can@481cc000";
    dcan1 = "/ocp/d_can@481d0000";
    timer1 = "/ocp/timer@44e31000";
    timer2 = "/ocp/timer@48040000";
    timer3 = "/ocp/timer@48042000";
    timer4 = "/ocp/timer@48044000";
    timer5 = "/ocp/timer@48046000";
    timer6 = "/ocp/timer@48048000";
    timer7 = "/ocp/timer@4804a000";
    pruss = "/ocp/pruss@4a300000";
    spi0 = "/ocp/spi@48030000";
    spi1 = "/ocp/spi@481a0000";
    gpmc = "/ocp/gpmc@50000000";
    usb_otg_hs = "/ocp/usb@47400000";
    mac = "/ocp/ethernet@4a100000";
    davinci_mdio = "/ocp/ethernet@4a100000/mdio@4a101000";
    cpsw_emac0 = "/ocp/ethernet@4a100000/slave@4a100200";
    cpsw_emac1 = "/ocp/ethernet@4a100000/slave@4a100300";
    tscadc = "/ocp/tscadc@44e0d000";
    lcdc = "/ocp/lcdc@4830e000";
    epwmss0 = "/ocp/epwmss@48300000";
    ecap0 = "/ocp/epwmss@48300000/ecap@48300100";
    ehrpwm0 = "/ocp/epwmss@48300000/ehrpwm@48300200";
    eqep0 = "/ocp/epwmss@48300000/eqep@0x48300180";
    epwmss1 = "/ocp/epwmss@48302000";
    ecap1 = "/ocp/epwmss@48302000/ecap@48302100";
    ehrpwm1 = "/ocp/epwmss@48302000/ehrpwm@48302200";
    eqep1 = "/ocp/epwmss@48302000/eqep@0x48302180";
    epwmss2 = "/ocp/epwmss@48304000";
    ecap2 = "/ocp/epwmss@48304000/ecap@48304100";
    ehrpwm2 = "/ocp/epwmss@48304000/ehrpwm@48304200";
    eqep2 = "/ocp/epwmss@48304000/eqep@0x48304180";
    sham = "/ocp/sham@53100000";
    aes = "/ocp/aes@53500000";
    mcasp0 = "/ocp/mcasp@48038000";
    mcasp1 = "/ocp/mcasp@4803C000";
    rng = "/ocp/rng@483100000";
    baseboard_beaglebone = "/bone_capemgr/baseboardmaps/board@0";
    baseboard_beaglebone_black = "/bone_capemgr/baseboardmaps/board@1";
    vmmcsd_fixed = "/fixedregulator@0";
    By default P8.45 is LCD_DATA0, I suppose this is not changed in the dts (again I am not familiar with the debian sources, and there are no pinmux settings in the part of the dts that you share).
    However, this signals (LCD_DATAx) are used also by the HDMI interface, see BBB schematics page 10; all lcd_data signals are connected to TDA19988, and then go to the HDMI connector. So the dtb conficts you see in the bootlog may be caused, because you haven't disabled the HDMI entries in your dts => those pins are claimed by both lcd cape & hdmi entries.
    Yordan
  • Hi Yordan,
    I removed the BB-View Cape for LCD7 display adaptor all together from Beaglebone Black at the moment just bare beaglebone black
    connected to US and power supply externally and to boot from Angstrom pre built image of 3.8.13 v2012.12
    Kernel 3.8.13 and I still have same error as follow:
    Starting kernel ...
    [ 0.196407] omap2_mbox_probe: platform not supported
    [ 0.207096] tps65217-bl tps65217-bl: no platform data provided
    [ 0.283503] bone-capemgr bone_capemgr.9: slot #0: No cape found
    [ 0.320609] bone-capemgr bone_capemgr.9: slot #1: No cape found
    [ 0.357717] bone-capemgr bone_capemgr.9: slot #2: No cape found
    [ 0.394827] bone-capemgr bone_capemgr.9: slot #3: No cape found
    [ 0.414616] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
    [ 0.424229] bone-capemgr bone_capemgr.9: slot #6: Failed verification
    [ 0.444719] omap_hsmmc mmc.5: of_parse_phandle_with_args of 'reset' failed
    [ 0.452018] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
    [ 0.518329] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
    [ 0.530037] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
    [ 0.537423] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
    systemd-fsck[87]: Angstrom: clean, 111299/218160 files, 629487/872448 blocks
    [ 9.531024] Unhandled fault: external abort on non-linefetch (0x1018) at 0xb6efc44c
    [ 10.021987] libphy: PHY 4a101000.mdio:01 not found
    [ 10.027036] net eth0: phy 4a101000.mdio:01 not found on slave 1
    .---O---.
    | | .-. o o
    I ran a search in my am335-boneblack.dts file for the P8.45 just for the reference where it get assigned
    But I cannot find any existence of P8.45 pin I have search in my ..dts file for the following search:
    1/ P845
    2/ LCD_DATA0  or LCD_DATA
    3/ TDA19988
    4/ HDMI
    5/ BB-BONELT-HDMI
    I cannot find any reference in the am335x-beaglebone.dtb file. I was wondering what I suppose to be looking for an alteration or modification?
    Please advise what possibility for pin muxing at u-boot level by modifying files such mux.c and board.c ???
    I will much appreciated if please shed some light on this issue, as I have three choices
    1/ TO USE a Debian pre built image which I stated in my previous post 3.8.13
    2/ To use Angstrom OS as Kernel 3.8.13 which also pre built kernel
    3/ TO build complete new kernel from main-line branch with necessary modification to the u-boot section of pin muxing
    4/ If I take on choice number 3 what entail to accomplish the task????
    Thank you very much so far...
    IK
