1.What is rmd file?
2. Right now we have used, what ever rmd file was given with some example,is it ok??
1.What is rmd file?
Hi Sanjay,
You can either call hex6x utility with options mentioned or as command(.rmd) file(list).
Hex6x utility in C6000 Compiler: The hex conversion utility converts an object file (.out) into the boot table format required by the DSP boot loader. This utility is documented Chapter 11 of the C6000 Assembly Tools user guide included as part of the C6000 compiler.
http://www.ti.com/lit/ug/spru186w/spru186w.pdf
I hope this answers your question.
