A question about Binary file running from L2?
Hi experts,
My setup:
Board: EVMK2H Rev 40.
MCSDK: MCSDK_bios_3_01_00_03
I use a way of  download to run a i.out file , it does run up from the  ENTRY POINT (0085b9e0).
I put the .bin file (converted from i.out) in the DDR, and then move it to L2. Third, I set its ENTRY POINT (0085b9e0). As a result,it doesn't  run up from the ENTRY POINT.
Could you tell me What happened?  How I to solve it?
Thanks!
Brian
               TMS320C6x Linker PC v7.4.4
>> Linked Mon Jun 27 16:30:36 2016
OUTPUT FILE NAME:   <HelloWorld_cmd_EVMTCI6638K2K(COFF).out>
ENTRY POINT SYMBOL: "_c_int00"  address: 0085b9e0
MEMORY CONFIGURATION
         name            origin    length      used     unused   attr    fill
  L2SRAM                0085b480   0000b000  00000ab4  0000a54c  RWIX
  MSMCSRAM              0c000000   00600000  00000000  00600000  RWIX
  DDR3                  80000000   80000000  00000000  80000000  RWIX
SECTION ALLOCATION MAP
 output                                  attributes/
section   page    origin      length       input sections
.text      0    0085b480    00000660
                  0085b480    00000240     rts6200.lib : memcpy62.obj (.text:_memcpy)
                  0085b6c0    00000100                 : autoinit.obj (.text:__auto_init)
                  0085b7c0    000000e0                 : exit.obj (.text:_exit)
                  0085b8a0    000000c0                 : cpy_tbl.obj (.text:_copy_in)
                  0085b960    00000080                 : cpp_init.obj (.text:___TI_cpp_init)
                  0085b9e0    00000080                 : boot.obj (.text:_c_int00)
                  0085ba60    00000040                 : args_main.obj (.text:__args_main)
                  0085baa0    00000020     Shello.obj (.text)
                  0085bac0    00000020     rts6200.lib : exit.obj (.text:_abort)
.stack     0    0085bae0    00000400     UNINITIALIZED
                  0085bae0    00000008     rts6200.lib : boot.obj (.stack)
                  0085bae8    000003f8     --HOLE--
.cinit     0    0085bee0    00000044
                  0085bee0    0000002c     rts6200.lib : exit.obj (.cinit)
                  0085bf0c    00000004     --HOLE-- [fill = 0]
                  0085bf10    0000000c     Shello.obj (.cinit)
                  0085bf1c    00000004     --HOLE-- [fill = 0]
                  0085bf20    00000004     (.pad.cinit) [fill = 0]
.far       0    0085bf24    0000000c     UNINITIALIZED
                  0085bf24    0000000c     rts6200.lib : exit.obj (.far)
.bss       0    0085bf30    00000004     UNINITIALIZED
                  0085bf30    00000004     Shello.obj (.bss)
GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
address    name
0085bf30   $bss
0085bf30   .bss
0085b480   .text
0085bac0   C$$EXIT
0085bee0   __STACK_END
00000400   __STACK_SIZE
00000001   __TI_args_main
0085b960   ___TI_cpp_init
0085bf2c   ___TI_enable_exit_profile_output
ffffffff   ___TI_pprof_out_hndl
ffffffff   ___TI_prof_data_size
ffffffff   ___TI_prof_data_start
ffffffff   ___binit__
0085bf30   ___bss__
ffffffff   ___c_args__
0085bee0   ___cinit__
0085bf34   ___end__
0085bae0   ___etext__
ffffffff   ___pinit__
0085b480   ___text__
0085ba60   __args_main
0085b6c0   __auto_init
0085bf24   __cleanup_ptr
0085bf28   __dtors_ptr
0085bae0   __stack
0085bf30   _a
0085bac0   _abort
0085b9e0   _c_int00
0085b8a0   _copy_in
0085b7c0   _exit
0085baa0   _main
0085b480   _memcpy
ffffffff   binit
0085bee0   cinit
0085bf34   end
0085bae0   etext
ffffffff   pinit
GLOBAL SYMBOLS: SORTED BY Symbol Address
address    name
0085b480   .text
0085b480   ___text__
0085b480   _memcpy
0085b7c0   _exit
0085b8a0   _copy_in
0085b9e0   _c_int00
0085baa0   _main
0085bac0   C$$EXIT
0085bac0   _abort
0085bae0   ___etext__
0085bae0   __stack
0085bae0   etext
0085bee0   ___cinit__
0085bee0   cinit
0085bf30   $bss
0085bf30   .bss
0085bf30   ___bss__
0085bf30   _a
0085bf34   ___end__
0085bf34   end
ffffffff   ___binit__
ffffffff   ___pinit__
ffffffff   binit
ffffffff   pinit
[37 symbols]
