AM572x IPU loading without remoteproc
Other Parts Discussed in Thread: AM5728
I am trying to load IPU1 Core0 with some firmware on AM5728 processor. The MLO and Uboot are from Linux PSDK 02.00.00.00. My usecase is to load the IPU from Uboot, so I don't have the option of loading IPU from Linux using remoteproc. This is a hard requirement.
We have a simple ELF loader at Uboot which loads the different sections of ELF onto DDR and returns the entry point. Now, I am not aware of how to inform IPU, this entry point. With the GEL file code it seems like entry code should be present in IPU_RAM. Is the understanding correct? Where can I find this in TRM? If my entry point is in DDR, how do I inform this to IPU?
  • Also, I have validated the loading by running my loader, connecting to IPU via CCS and then setting the PC of IPU to entry point of firmware and then running. This works fine. How can I do it programmatically? Should i write few instructions in the IPU's IRAM to jump to my entry point?
  • Mohnish,
    There is some reference code for waking up the IPUSS, enabling its clock, configurring the UniCache and MMU and providing an application entry point in the Secondary bootloader code provided in the RTOS SDK.
    Please refer to the file sbl_slave_core_boot.c file found under the path pdk_am57xx_1_0_3\packages\ti\boot\sbl\soc\am57xx. You can use that code as reference to wake the IPU from your u-boot code. I am attaching the version of this file provided in PSDK RTOS 3.00 release.
     *  \file   sbl_slave_core_boot.c
     *  \brief  This file contain functions related to slave core boot-up.
     * Copyright (C) 2015-2016 Texas Instruments Incorporated - http://www.ti.com/
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * Redistributions of source code must retain the above copyright
     * notice, this list of conditions and the following disclaimer.
     * Redistributions in binary form must reproduce the above copyright
     * notice, this list of conditions and the following disclaimer in the
     * documentation and/or other materials provided with the
     * distribution.
     * Neither the name of Texas Instruments Incorporated nor the names of
     * its contributors may be used to endorse or promote products derived
     * from this software without specific prior written permission.
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
     * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
     * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
     * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
     * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
     * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
     * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
     * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    /*                             Include Files                                  */
     #include <stdint.h>
     #include <string.h>
     #include <ti/csl/cslr_device.h>
     #include <ti/csl/hw_types.h>
     #include <ti/drv/uart/UART_stdio.h>
     #include "sbl_prcm.h"
     #include "sbl_slave_core_boot.h"
    #if defined(BOOT_QSPI)
    #include "sbl_qspi.h"
    #endif
    #if defined(BOOT_MMCSD)
    #include "sbl_mmcsd.h"
    #endif
    /*                           Macros & Typedefs                                */
    /* Macro defining the reg address where DSP1 Core boot address is to be written */
    #define DSP1BOOTADDR            (CSL_DSP_CTRL_MODULE_CORE_REGS + 0x55CU)
    #define DSP1BOOTADDRVALUE       (0x00800000U)
    /* Entry address for DSP1 applications in the memory region where trampolene is located */
    #define DSP1_ENTRY_ADDR         (0x40330400)
    /* Macro defining the reg address where DSP2 Core boot address is to be written */
    #define DSP2BOOTADDR            (CSL_DSP_CTRL_MODULE_CORE_REGS + 0x560U)
    #define DSP2BOOTADDRVALUE       (0x00800000U)
    /* Entry address for DSP2 applications in the memory region where trampolene is located */
    #define DSP2_ENTRY_ADDR         (0x40330800)
    #define MPU_IPU1_RAM             (CSL_IPU_IPU1_TARGET_REGS + \
                                         (uint32_t) 0x20000)
    #define MPU_IPU2_RAM			 (CSL_IPU_IPU1_ROM_REGS + \
                                         (uint32_t) 0x20000)
     * \brief This API enables the clock for DSP1 core.
    void DSP1_ClkEnable();
     * \brief This API enables the clock for DSP2 core.
    void DSP2_ClkEnable();
     * \brief This API enables the clock for IPU1 core.
    void IPU1_ClkEnable();
     * \brief This API enables the clock for IPU2 core.
    void IPU2_ClkEnable();
     * \brief This API brings the IPU1 core out of reset.
    void IPU1_SystemReset();
     * \brief This API brings the IPU2 core out of reset.
    void IPU2_SystemReset();
     * \brief        This is a generic function to get the DSP cores out of reset.
     * \param  cpu   core id to identify the core which has to be reset.
    void SBL_CPU_Reset(cpu_core_id_t cpu);
     *  \brief   IPU1_AMMU_Config function to configure the IPU1 AMMU. Add
     *           entries to access DDR, L4Per1,L4Per2 & L4Per3,
     *           L3 RAM & IRAM
    void IPU1_AMMU_Config(void);
     *  \brief   IPU2_AMMU_Config function to configure the IPU2 AMMU. Add
     *           L3 RAM & IRAM
    void IPU2_AMMU_Config(void);
     *  \brief    Sets the Entry Point for C66 cores within the Instruction opcodes
     *            maintained for each C66 cores.
    static void SBL_DspEntryPointSet(uint32_t entryPoint, uint32_t *pDspInstr);
     *  \brief    Sends event to be signalled to all the CPUS.
    void CPUSendEvent(void);
    ** DSP instructions to be copied to the Trampolene to avoid the alignment
    ** requirement.
    uint32_t dsp1Instruction[10] =
        0x0500002a, /* MVK.S2  destAddr, B10      */
        0x0500006a, /* MVKH.S2 destAddr, B10      */
        0x00280362, /* B.S2    B10                */
        0x00006000, /* NOP     4                  */
        0x00000000, /* NOP                        */
        0x00000000 /* NOP                        */
    uint32_t dsp2Instruction[10] =
    /*                           Internal Functions                               */
    int32_t SBL_ImageCopy(sblEntryPoint_t *pEntry)
        int32_t retval = 0;
        /* MMCSD Boot Mode Image Copy function. */
        if (SBL_MMCBootImage(pEntry) != 1U)
    #elif defined(BOOT_QSPI)
        if (SBL_QSPIBootImage(pEntry) != 1U)
    #endif
            retval = -1;
        return retval;
    void SBL_SlaveCorePrcmEnable()
    	/* Enable Clocks and Bring the slave cores out of Reset. */
    	IPU1_ClkEnable();
    	IPU1_SystemReset();
    	#if defined (AM572x_BUILD)
    	IPU2_ClkEnable();
    	IPU2_SystemReset();
    	#endif
        DSP1_ClkEnable();
        SBL_CPU_Reset(DSP1_ID);
        DSP2_ClkEnable();
        SBL_CPU_Reset(DSP2_ID);
        #endif
        SBL_PRCMModuleEnable(CSL_MPU_DSP1_CM_CORE_AON_REGS,
                        CSL_DSP1_CM_CORE_AON_CM_DSP1_DSP1_CLKCTRL_REG,
                        CSL_DSP1_CM_CORE_AON_CM_DSP1_CLKSTCTRL_REG,
                        CM_DSP1_CLKSTCTRL_CLKACTIVITY_DSP1_GFCLK_MASK);
        SBL_PRCMSetClkOperMode(CSL_MPU_DSP1_CM_CORE_AON_REGS,
            PRCM_CD_CLKTRNMODES_SW_WAKEUP);
        SBL_PRCMModuleEnable(CSL_MPU_DSP2_CM_CORE_AON_REGS,
                        CSL_DSP2_CM_CORE_AON_CM_DSP2_DSP2_CLKCTRL_REG,
                        CSL_DSP2_CM_CORE_AON_CM_DSP2_CLKSTCTRL_REG,
                        CM_DSP2_CLKSTCTRL_CLKACTIVITY_DSP2_GFCLK_MASK);
        SBL_PRCMSetClkOperMode(CSL_MPU_DSP2_CM_CORE_AON_REGS,
    	/* Select CORE_IPU_ISS_BOOST_CLK from CORE_DPLL for IPU1_GFCLK */
    	HW_WR_FIELD32_RAW(CSL_IPU_IPU_CM_CORE_AON_REGS + CM_IPU1_IPU1_CLKCTRL,
    	CM_IPU1_IPU1_CLKCTRL_CLKSEL_MASK, CM_IPU1_IPU1_CLKCTRL_CLKSEL_SHIFT,
    	CM_IPU1_IPU1_CLKCTRL_CLKSEL_SEL_CORE_IPU_ISS_BOOST_CLK);
        SBL_PRCMModuleEnable(CSL_IPU_IPU_CM_CORE_AON_REGS,
                        CM_IPU1_CLKSTCTRL,
                        CM_IPU_CLKSTCTRL_CLKACTIVITY_IPU_L3_GICLK_MASK);
        SBL_PRCMSetClkOperMode(CSL_IPU_IPU_CM_CORE_AON_REGS,
            CM_IPU1_CLKSTCTRL,
        SBL_PRCMModuleEnable(CSL_IPU_CORE_CM_CORE_REGS,
                        CM_IPU2_IPU2_CLKCTRL,
                        CM_IPU2_CLKSTCTRL,
                        CM_IPU2_CLKSTCTRL_CLKACTIVITY_IPU2_GFCLK_MASK);
            CM_IPU2_CLKSTCTRL,
        uint32_t retVal;
        if(cpu == DSP1_ID)
            /* SYSTEM Reset */
            SBL_ResetAssert((CSL_DSP_DSP1_PRM_REGS + RM_DSP1_RSTCTRL),
                            RM_DSP1_RSTCTRL_RST_DSP1_SHIFT);
            /* Local Reset */
                            RM_DSP1_RSTCTRL_RST_DSP1_LRST_SHIFT);
            SBL_ResetGetStatus((CSL_DSP_DSP1_PRM_REGS + RM_DSP1_RSTST),
                    RM_DSP1_RSTST_RST_DSP1_LRST_SHIFT, &retVal);
            if(0x1U == retVal)
                /* clear Status */
                SBL_ResetClearStatus((CSL_DSP_DSP1_PRM_REGS + RM_DSP1_RSTST),
                    RM_DSP1_RSTST_RST_DSP1_LRST_SHIFT);
            /* System Reset */
                    RM_DSP1_RSTST_RST_DSP1_SHIFT, &retVal);
            if(0x1U == retVal)
                /* Clear Status */
                    RM_DSP1_RSTST_RST_DSP1_SHIFT);
            SBL_ResetRelease((CSL_DSP_DSP1_PRM_REGS + RM_DSP1_RSTCTRL),
                              RM_DSP1_RSTCTRL_RST_DSP1_SHIFT,
        else if(cpu == DSP2_ID)
            /* SYSTEM Reset */
            SBL_ResetAssert((CSL_DSP_DSP2_PRM_REGS + RM_DSP2_RSTCTRL),
                            RM_DSP2_RSTCTRL_RST_DSP2_SHIFT);
            /* Local Reset */
                            RM_DSP2_RSTCTRL_RST_DSP2_LRST_SHIFT);
            SBL_ResetGetStatus((CSL_DSP_DSP2_PRM_REGS + RM_DSP2_RSTST),
                    RM_DSP2_RSTST_RST_DSP2_LRST_SHIFT, &retVal);
            if(0x1U == retVal)
                /* clear Status */
                SBL_ResetClearStatus((CSL_DSP_DSP2_PRM_REGS + RM_DSP2_RSTST),
                    RM_DSP2_RSTST_RST_DSP2_LRST_SHIFT);
            /* System Reset */
                    RM_DSP2_RSTST_RST_DSP2_SHIFT, &retVal);
            if(0x1U == retVal)
                /* Clear Status */
                    RM_DSP2_RSTST_RST_DSP2_SHIFT);
            SBL_ResetRelease((CSL_DSP_DSP2_PRM_REGS + RM_DSP2_RSTCTRL),
                              RM_DSP2_RSTCTRL_RST_DSP2_SHIFT,
    void SBL_DSP1_BringUp(uint32_t EntryPoint)
        uint32_t i = 0U;
        if(EntryPoint != 0U)
            /* Set the Entry point of the application in the trampolene code. */
            SBL_DspEntryPointSet(EntryPoint, dsp1Instruction);
            ** Copy the dsp opcodes to create a trampoline at the specified memory
            ** location which is aligned at 0x400. This helps us in removing the
            ** entry address alignment limitation.
            memcpy((void *) DSP1_ENTRY_ADDR, (void *)dsp1Instruction,
                sizeof(dsp1Instruction));
        /*DSP L2RAM*/
        /* Set the Entry point */
        if (EntryPoint != 0U)
            HW_WR_REG32(DSP1BOOTADDR, (DSP1_ENTRY_ADDR >> 0xAU));
        else
            HW_WR_REG32(DSP1BOOTADDR, (EntryPoint >> 0xAU));
            /* Self branch loop for DSP */
             for (i = 0; i < 8; i++) {
                HWREG(CSL_MPU_DSP1_L2_SRAM_REGS + 4 * i) = 0x12;
        /* Reset de-assertion for DSP CPUs */
        HW_WR_REG32((CSL_DSP_DSP1_PRM_REGS + RM_DSP1_RSTCTRL), 0x0);
        /* Check the reset state: DSPSS Core, Cache and Slave interface */
        while ((HW_RD_REG32((CSL_DSP_DSP1_PRM_REGS + RM_DSP1_RSTST)) & 0x3) != 0x3);
        /* Check module mode */
        while ((HW_RD_REG32(CSL_MPU_DSP1_CM_CORE_AON_REGS + CSL_DSP1_CM_CORE_AON_CM_DSP1_DSP1_CLKCTRL_REG) & 0x30000) != 0x0);
    void SBL_DSP2_BringUp(uint32_t EntryPoint)
        uint32_t i = 0U;
            SBL_DspEntryPointSet(EntryPoint, dsp2Instruction);
            ** Copy the updated dsp opcodes to create a trampoline at the specified
            ** memory location.
            memcpy((void *) DSP2_ENTRY_ADDR, (void *)dsp2Instruction,
                sizeof(dsp2Instruction));
        /*DSP L2RAM*/
        /*Set the Entry point*/
            HW_WR_REG32(DSP2BOOTADDR, (DSP2_ENTRY_ADDR >> 0xAU));
        else
            HW_WR_REG32(DSP2BOOTADDR, (EntryPoint >> 0xAU));
                HWREG(CSL_MPU_DSP2_L2_SRAM_REGS + 4 * i) = 0x12;
        HW_WR_REG32((CSL_DSP_DSP2_PRM_REGS + RM_DSP2_RSTCTRL), 0x0);
        while ((HW_RD_REG32((CSL_DSP_DSP2_PRM_REGS + RM_DSP2_RSTST)) & 0x3) != 0x3);
        while ((HW_RD_REG32(CSL_MPU_DSP2_CM_CORE_AON_REGS + CSL_DSP2_CM_CORE_AON_CM_DSP2_DSP2_CLKCTRL_REG) & 0x30000) != 0x0);
    #endif
    	uint32_t retStat = 0U;
    	/* Assert the Reset */
    	SBL_ResetAssert((CSL_IPU_IPU_PRM_REGS + RM_IPU1_RSTCTRL),
    					RM_IPU1_RSTCTRL_RST_CPU1_SHIFT);
    					RM_IPU1_RSTCTRL_RST_CPU0_SHIFT);
    					RM_IPU1_RSTCTRL_RST_IPU_SHIFT);
    	/* Check the Reset Status and Clear */
    	SBL_ResetGetStatus(CSL_IPU_IPU_PRM_REGS + RM_IPU1_RSTST,
    		RM_IPU1_RSTST_RST_CPU1_SHIFT, &retStat);
    	if(0x1U == retStat)
    		SBL_ResetClearStatus(CSL_IPU_IPU_PRM_REGS + RM_IPU1_RSTST,
    			RM_IPU1_RSTST_RST_CPU1_SHIFT);
    		retStat = 0U;
    		RM_IPU1_RSTST_RST_CPU0_SHIFT, &retStat);
    	if(0x1U == retStat)
    			RM_IPU1_RSTST_RST_CPU0_SHIFT);
    		retStat = 0U;
    		RM_IPU1_RSTST_RST_IPU_SHIFT, &retStat);
    	if(0x1U == retStat)
    			RM_IPU1_RSTST_RST_IPU_SHIFT);
    		retStat = 0U;
    	/*Configure the boot translation page of IPU1 to 0x55020000 - IPU_RAM*/
        HW_WR_REG32((
            CSL_IPU_CTRL_MODULE_CORE_CORE_REGISTERS_REGS + 0x35CU), 0x00000);
        HW_WR_REG32((
            CSL_IPU_CTRL_MODULE_CORE_CORE_REGISTERS_REGS + 0x358U), 0x55020);
    	SBL_ResetRelease(CSL_IPU_IPU_PRM_REGS + RM_IPU1_RSTCTRL,
    						RM_IPU1_RSTCTRL_RST_IPU_SHIFT,
    	/* Configure the MMU settings for IPU1 M4 */
    	IPU1_AMMU_Config();
    void SBL_IPU1_CPU0_BringUp(uint32_t EntryPoint)
    	uint32_t regVal = 0U;
        if (EntryPoint == 0)
            HW_WR_REG32(MPU_IPU1_RAM, 0x10000);
            HW_WR_REG32((MPU_IPU1_RAM + 0x4), 0x9);
            HW_WR_REG32((MPU_IPU1_RAM + 0x8), 0xE7FEE7FE);
        else
            HW_WR_REG32((MPU_IPU1_RAM + 0x4), EntryPoint);
        /* Bring-out of Reset - CPU0*/
    	regVal = HW_RD_REG32(CSL_IPU_IPU_PRM_REGS + RM_IPU1_RSTCTRL);
    	regVal &= ~0x1;
    	HW_WR_REG32((CSL_IPU_IPU_PRM_REGS + RM_IPU1_RSTCTRL), regVal);
        while ((HW_RD_REG32(CSL_IPU_IPU_PRM_REGS + RM_IPU1_RSTST) & 0x1) != 0x1);
        /*Check the Status of IPU1 Module mode*/
        while ((HW_RD_REG32(CSL_IPU_IPU_CM_CORE_AON_REGS +
                      CM_IPU1_IPU1_CLKCTRL) & 0x30000) != 0x0) ;
    void SBL_IPU1_CPU1_BringUp(uint32_t EntryPoint)
        /*Assert the CPU1 Reset*/
    	/* Check the Reset Status */
    	if(retStat == 0x1U)
    		retStat = 0U;
        else
        /*Bring-out of Reset - CPU1*/
        HWREG(CSL_IPU_IPU_PRM_REGS + RM_IPU1_RSTCTRL) &= ~0x2;
        while ((HWREG(CSL_IPU_IPU_PRM_REGS + RM_IPU1_RSTST) & 0x2) != 0x2) ;
        while ((HWREG(CSL_IPU_IPU_CM_CORE_AON_REGS +
                      CM_IPU1_IPU1_CLKCTRL) & 0x30000) != 0x0);
    	SBL_ResetAssert((CSL_IPU_CORE_PRM_REGS + RM_IPU2_RSTCTRL),
                         RM_IPU2_RSTCTRL_RST_CPU1_SHIFT);
    					RM_IPU2_RSTCTRL_RST_CPU0_SHIFT);
    					RM_IPU2_RSTCTRL_RST_IPU_SHIFT);
    	SBL_ResetGetStatus(CSL_IPU_CORE_PRM_REGS + RM_IPU2_RSTST,
    		RM_IPU2_RSTST_RST_CPU1_SHIFT, &retStat);
    	if(0x1U == retStat)
    		SBL_ResetClearStatus(CSL_IPU_CORE_PRM_REGS + RM_IPU2_RSTST,
    			RM_IPU2_RSTST_RST_CPU1_SHIFT);
    		retStat = 0U;
    		RM_IPU2_RSTST_RST_CPU0_SHIFT, &retStat);
    	if(0x1U == retStat)
    			RM_IPU2_RSTST_RST_CPU0_SHIFT);
    		retStat = 0U;
    		RM_IPU2_RSTST_RST_IPU_SHIFT, &retStat);
    	if(0x1U == retStat)
    			RM_IPU2_RSTST_RST_IPU_SHIFT);
    		retStat = 0U;
        HW_WR_REG32((
        HW_WR_REG32((
    	SBL_ResetRelease(CSL_IPU_CORE_PRM_REGS + RM_IPU2_RSTCTRL,
                            RM_IPU2_RSTCTRL_RST_IPU_SHIFT,
    	/* Configure the MMU settings for IPU2 M4 */
    	IPU2_AMMU_Config();
    void SBL_IPU2_CPU0_BringUp(uint32_t EntryPoint)
            HW_WR_REG32(MPU_IPU2_RAM, 0x10000);
            HW_WR_REG32((MPU_IPU2_RAM + 0x4), 0x9);
            HW_WR_REG32((MPU_IPU2_RAM + 0x8), 0xE7FEE7FE);
        else
            HW_WR_REG32((MPU_IPU2_RAM + 0x4), EntryPoint);
    	regVal = HW_RD_REG32(CSL_IPU_CORE_PRM_REGS + RM_IPU2_RSTCTRL);
    	regVal &= ~0x1;
    	HW_WR_REG32((CSL_IPU_CORE_PRM_REGS + RM_IPU2_RSTCTRL), regVal);
    	while ((HW_RD_REG32(CSL_IPU_CORE_PRM_REGS + RM_IPU2_RSTST) & 0x1) != 0x1);
        while ((HW_RD_REG32(CSL_IPU_CORE_CM_CORE_REGS +
                      CM_IPU2_IPU2_CLKCTRL) & 0x30000) != 0x0);
    void SBL_IPU2_CPU1_BringUp(uint32_t EntryPoint)
        uint32_t regVal = 0;
    	if(retStat == 0x1U)
    		retStat = 0U;
        else
    	regVal &= ~0x2;
    	while((HW_RD_REG32(CSL_IPU_CORE_PRM_REGS + RM_IPU2_RSTST) & 0x2) != 0x2);
        /*Check the Status of IPU2 Module mode*/
        while((HW_RD_REG32(CSL_IPU_CORE_CM_CORE_REGS +
     * \brief     This function brings up the MPU Core1. Core0 will program the
     *            AUXBOOT registers and then it will send the SEV instruction.
     * \param     EntryPoint       CPU entry point location
    void SBL_MPU_CPU1_BringUp(uint32_t EntryPoint)
        if (0U != EntryPoint)
            /* Write the entry-point into AUXBOOT1 */
            HW_WR_REG32(CSL_MPU_MPU_WUGEN_REGS + 0x804, EntryPoint);
            /* Write the enable indicator into AUXBOOT0 */
            HW_WR_REG32(CSL_MPU_MPU_WUGEN_REGS + 0x800, 0x10U);
            /* Send event to wake-up CPU1 */
            CPUSendEvent();
        else
            HW_WR_REG32(CSL_MPU_MPU_WUGEN_REGS + 0x410U, 0);
            HW_WR_REG32(CSL_MPU_MPU_WUGEN_REGS + 0x414U, 0);
            HW_WR_REG32(CSL_MPU_MPU_WUGEN_REGS + 0x418U, 0);
            HW_WR_REG32(CSL_MPU_MPU_WUGEN_REGS + 0x41CU, 0);
            HW_WR_REG32(CSL_MPU_MPU_WUGEN_REGS + 0x420U, 0);
    #endif
        /*Large Page Translations */
        /* Logical Address */
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS, 0x40000000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x04U, 0x80000000U);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x08U, 0xa0000000U);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x0CU, 0x60000000);
        /* Physical Address */
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x20U, 0x40000000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x24U, 0x80000000U);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x28U, 0xa0000000U);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x2CU, 0x40000000);
        /* Policy Register */
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x40U, 0x00000007);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x44U, 0x000B0007);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x48U, 0x00020007);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x4CU, 0x00000007);
        /*Medium Page*/
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x60U, 0x00300000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x64U, 0x00400000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0xA0U, 0x40300000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0xA4U, 0x40400000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0xE0U, 0x00000007);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0xE4U, 0x00020007);
        /*Small Page*/
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x120U, 0x00000000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x124U, 0x40000000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x128U, 0x00004000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x12CU, 0x00008000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x130U, 0x20000000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x1A0U, 0x55020000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x1A4U, 0x55080000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x1A8U, 0x55024000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x1ACU, 0x55028000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x1B0U, 0x55020000);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x220U, 0x0001000B);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x224U, 0x0000000B);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x228U, 0x00010007);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x22CU, 0x00000007);
        HW_WR_REG32(CSL_IPU_UNICACHE_MMU_REGS + 0x230U, 0x00000007);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE, 0x40000000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x04U, 0x80000000U);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x08U, 0xa0000000U);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x0CU, 0x60000000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x20U, 0x40000000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x24U, 0x80000000U);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x28U, 0xa0000000U);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x2CU, 0x40000000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x40U, 0x00000007);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x44U, 0x000B0007);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x48U, 0x00020007);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x4CU, 0x00000007);
        /*Medium Page*/
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x60U, 0x00300000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x64U, 0x00400000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0xA0U, 0x40300000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0xA4U, 0x40400000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0xE0U, 0x00000007);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0xE4U, 0x00020007);
        /*Small Page*/
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x120U, 0x00000000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x124U, 0x40000000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x128U, 0x00004000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x12CU, 0x00008000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x130U, 0x20000000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x1A0U, 0x55020000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x1A4U, 0x55080000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x1A8U, 0x55024000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x1ACU, 0x55028000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x1B0U, 0x55020000);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x220U, 0x0001000B);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x224U, 0x0000000B);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x228U, 0x00010007);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x22CU, 0x00000007);
        HW_WR_REG32(SOC_IPU2_TARGET_UNICACHE_MMU_BASE + 0x230U, 0x00000007);
        uint32_t entryVal = 0U;
        uint32_t dspOpcode = 0U;
        entryVal = (entryPoint & 0x0000FFFF);
        dspOpcode = *pDspInstr;
        ** Mask and update the lower 16 bits of entry address within the MVK
        ** instruction opcode.
        *pDspInstr = (((dspOpcode) & ~(0x007FFF80)) | (( (entryVal) << 0x7) & 0x007FFF80));
        entryVal = ((entryPoint & 0xFFFF0000) >> 16);
        dspOpcode = *(pDspInstr + 1);
        ** Mask and update the upper 16 bits of entry address within the MVK
        *(pDspInstr + 1) = (((dspOpcode) & ~(0x007FFF80)) | (( (entryVal) << 0x7) & 0x007FFF80));
        /*Data Synchronization Barrier */
        asm (" DSB");
        /*SEV Instruction */
        asm (" SEV");
    Checkout the functions:
    IPU1_ClkEnable, IPU1_SystemReset, SBL_IPU1_CPU0_BringUp, SBL_IPU2_CPU0_BringUp
    Hope this helps.
    Rahul
  • Thanks Rahul for the quick reply and great support. I was able to load IPU1 Core 0 with my firmware.
