Other Parts Discussed in Thread: TPS65217
Hi team,
My customer is using a BBB that is running wec7 and PMIC TPS65217C. They are up against some powering/booting issues and would like some feedback about what this could be. Here is the high level:
Trying to use the battery charger, however when the battery is connected they were unable to turn the board off by holding the button populated at the board.
-What is the register configuration for disable the board to save power?
-Could you tell us the sequence in order to do that?
From the spec, it looks like that the battery voltage is always on at sys pin.
-The other problem area is: when the battery status is not ok, like undervoltage status , the BBB does not boot up even when its at an ac adapter. How could they avoid that ?
Thanks in advance for the help,
Billy
