dra72x(J6E) HDMI i2c master error issue
Other Parts Discussed in Thread: TPD12S015
Hi All,
We are using 7.02.00.02 SDK + J6E (dra72x ) CPU , but currently we always have HDMI failure message  which is HDMI I2C master error when we type "modetest" .
Attachment files are bootlog and my dts file.
Could someone can give us a hint how to modify dts ?
Andy
     * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/
     * This program is free software; you can redistribute it and/or modify
     * it under the terms of the GNU General Public License version 2 as
     * published by the Free Software Foundation.
    /dts-v1/;
    #include "dra72x.dtsi"
    #include <dt-bindings/interrupt-controller/irq.h>
    #include <dt-bindings/gpio/gpio.h>
    #include <dt-bindings/clk/ti-dra7-atl.h>
    #include <dt-bindings/pinmux/mux_dra7xx.h>
    	model = "TI DRA722";
    	compatible = "ti,dra72-evm", "ti,dra722", "ti,dra72", "ti,dra7";
    	memory {
    		device_type = "memory";
    		reg = <0x80000000 0x40000000>; /* 1024 MB */
    	reserved_mem: reserved-memory {
    		#address-cells = <1>;
    		#size-cells = <1>;
    		ranges;
    		ipu2_cma_pool: ipu2_cma@95800000 {
    			compatible = "shared-dma-pool";
    			reg = <0x95800000 0x3800000>;
    			reusable;
    			status = "okay";
    		dsp1_cma_pool: dsp1_cma@99000000 {
    			reg = <0x99000000 0x4000000>;
    			reusable;
    			status = "okay";
    		ipu1_cma_pool: ipu1_cma@9d000000 {
    			reg = <0x9d000000 0x2000000>;
    			reusable;
    			status = "okay";
    		dsp2_cma_pool: dsp2_cma@9f000000 {
    			reg = <0x9f000000 0x800000>;
    			reusable;
    			status = "okay";
    	extcon_usb1: extcon_usb1 {
    		compatible = "linux,extcon-usb-gpio";
    		id-gpios = <&pcf_gpio_21 1 GPIO_ACTIVE_HIGH>;
    	extcon_usb2: extcon_usb2 {
    		id-gpios = <&pcf_gpio_21 2 GPIO_ACTIVE_HIGH>;
    	evm_3v3_sd: fixedregulator-evm_3v3_sd {
    		compatible = "regulator-fixed";
    		regulator-name = "evm_3v3_sd";
    		regulator-min-microvolt = <3300000>;
    		regulator-max-microvolt = <3300000>;
    	evm_3v3_sw: fixedregulator-evm_3v3_sw {
    		regulator-name = "evm_3v3_sw";
    //		vin-supply = <&sysen1>;
    	aic_dvdd: fixedregulator-aic_dvdd {
    		/* TPS77018DBVT */
    		regulator-name = "aic_dvdd";
    		vin-supply = <&evm_3v3_sw>;
    		regulator-min-microvolt = <1800000>;
    		regulator-max-microvolt = <1800000>;
    	vmmcwl_fixed: fixedregulator-mmcwl {
    		regulator-name = "vmmcwl_fixed";
    		//gpio = <&gpio5 8 0>;	/* gpio5_8 */
    		startup-delay-us = <70000>;
    		//enable-active-high;
    	kim {
    		compatible = "kim";
    		nshutdown_gpio = <132>;
    		dev_name = "/dev/ttyS2";
    		flow_cntrl = <1>;
    		baud_rate = <3686400>;
    	btwilink {
    		compatible = "btwilink";
    	vtt_fixed: fixedregulator-vtt {
    		regulator-name = "vtt_fixed";
    		regulator-min-microvolt = <1350000>;
    		regulator-max-microvolt = <1350000>;
    		regulator-always-on;
    		regulator-boot-on;
    		vin-supply = <&sysen2>;
    		//gpio = <&gpio7 11 GPIO_ACTIVE_HIGH>;
    	aliases {
    		display0 = &hdmi0;
    		//sound0 = &primary_sound;
    		//sound1 = &hdmi;
    	hdmi0: connector@1 {
    		compatible = "hdmi-connector";
    		label = "hdmi";
    		type = "a";
    		port {
    			hdmi_connector_in: endpoint {
    				remote-endpoint = <&tpd12s015_out>;
    	tpd12s015: encoder@1 {
    		compatible = "ti,dra7evm-tpd12s015";
    		pinctrl-names = "i2c", "ddc";
    		pinctrl-0 = <&hdmi_i2c_sel_pin &hdmi_i2c_pins_i2c>;
    		pinctrl-1 = <&hdmi_i2c_sel_pin &hdmi_i2c_pins_ddc>;
    		ddc-i2c-bus = <&i2c2>;
    		mcasp-gpio = <&mcasp8>;
    		gpios = <&pcf_hdmi 4 0>,	/* P4, CT CP HPD */
    			<&pcf_hdmi 5 0>,	/* P5, LS OE */
    			<&gpio7 12 0>;	/* gpio7_12/sp1_cs2, HPD */
    		ports {
    			#size-cells = <0>;
    			port@0 {
    				reg = <0>;
    				tpd12s015_in: endpoint@0 {
    					remote-endpoint = <&hdmi_out>;
    			port@1 {
    				reg = <1>;
    				tpd12s015_out: endpoint@0 {
    					remote-endpoint = <&hdmi_connector_in>;
        ocp {
            gpu: gpu@0x56000000 {
                gpu0-voltdm = <&voltdm_gpu>;
    	primary_sound: primary_sound {
    		compatible = "ti,dra7xx-evm-audio";
    		ti,model = "DRA7xx-EVM";
    		ti,always-on;
    		ti,audio-codec = <&tlv320aic3106>;
    		ti,mcasp-controller = <&mcasp3>;
    		ti,codec-clock-rate = <11289600>;
    		clocks = <&atl_clkin2_ck>;
    		clock-names = "mclk";
    		ti,audio-routing =
    			"Headphone Jack",       "HPLOUT",
    			"Headphone Jack",       "HPROUT",
    			"Line Out",		"LLOUT",
    			"Line Out",		"RLOUT",
    			"MIC3L",		"Mic Jack",
    			"MIC3R",		"Mic Jack",
    			"Mic Jack",		"Mic Bias",
    			"LINE1L",               "Line In",
    			"LINE1R",               "Line In";
    	btwilink_sound: btwilink_sound {
    		#sound-dai-cells = <0>;
    		compatible = "linux,bt-sco-audio";
    		status = "okay";
    	simple_bt_sco_card: bt_sco_card {
    		compatible = "simple-audio-card";
    		simple-audio-card,name = "DRA7xx-WiLink";
    		simple-audio-card,format = "dsp_a";
    		simple-audio-card,frame-master = <&btwilink_codec>;
    		simple-audio-card,bitclock-master = <&btwilink_codec>;
    		simple-audio-card,frame-inversion;
    		simple-audio-card,cpu {
    			sound-dai = <&mcasp7>;
    		btwilink_codec: simple-audio-card,codec {
    			sound-dai = <&btwilink_sound>;
    &dra7_pmx_core {
    	tps65917_pins_default: tps65917_pins_default {
    		pinctrl-single,pins = <
    			0x424 (PIN_INPUT_PULLUP | MUX_MODE1)	/* wakeup3.sys_nirq1 */
    	uart3_pins: pinmux_uart3_pins {
    			0x34c (PIN_INPUT_PULLUP | PIN_INPUT | MUX_MODE4)	/* mcasp5_axr0.uart3_rxd */
    			0x350 (PIN_OUTPUT | MUX_MODE4)	/* mcasp5_axr1.uart3_txd */
    	uart5_pins: pinmux_uart5_pins {
    			0x1dc (PIN_INPUT_PULLUP | PIN_INPUT | MUX_MODE2)	/* vout1_d0.uart5_rxd F11 */
    			0x1e0 (PIN_OUTPUT | MUX_MODE2)	/* vout1_d1.uart5_txd  G10 */
    	uart6_pins: pinmux_uart6_pins {
    			0x1fc (PIN_INPUT_PULLUP | PIN_INPUT | MUX_MODE2)	/* vout1_d8.uart6_rxd E8 */
    			0x200 (PIN_OUTPUT | MUX_MODE2)	/* vout1_d9.uart6_txd  D9 */
    	uart10_pins: pinmux_uart10_pins {
    			0x170 (PIN_INPUT_PULLUP | PIN_INPUT | MUX_MODE8)	/* vin2a_d2.uart10_rxd D1 */
    			0x174 (PIN_OUTPUT | MUX_MODE8)	/* vin2a_d3.uart10_txd  E2 */
    	hdmi_i2c_sel_pin: pinmux_hdmi_i2c_sel_pin {
    			/* this pin is used as a GPIO via mcasp */
    			0x2fc	(PIN_OUTPUT | MUX_MODE1) /* mcasp8_axr2 */
    	hdmi_i2c_pins_i2c: pinmux_hdmi_i2c_pins_default {
    			0x408	(PIN_INPUT | MUX_MODE0) /* i2c2_sda.i2c2_sda */
    			0x40c	(PIN_INPUT | MUX_MODE0) /* i2c2_scl.i2c2_scl */
    	hdmi_i2c_pins_ddc: pinmux_hdmi_i2c_pins_ddc {
    			0x408	(PIN_INPUT | MUX_MODE1) /* i2c2_sda.hdmi1_ddc_scl */
    			0x40c	(PIN_INPUT | MUX_MODE1) /* i2c2_scl.hdmi1_ddc_sda */
    	dcan1_pins_default: dcan1_pins_default {
    			0x3d0   (PIN_OUTPUT_PULLUP | MUX_MODE0)	/* dcan1_tx */
    			0x418   (PULL_UP | MUX_MODE1)		/* wakeup0.dcan1_rx */
    	dcan1_pins_sleep: dcan1_pins_sleep {
    			0x3d0   (MUX_MODE15 | PULL_UP)	/* dcan1_tx.off */
    			0x418   (MUX_MODE15 | PULL_UP)	/* wakeup0.off */
    	mmc1_pins_default: pinmux_mmc1_default_pins {
    			0x354 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_clk.clk */
    			0x358 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_cmd.cmd */
    			0x35c (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat0.dat0 */
    			0x360 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat1.dat1 */
    			0x364 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat2.dat2 */
    			0x368 (PIN_INPUT_PULLUP | MUX_MODE0)	/* mmc1_dat3.dat3 */
    			0x36c (PIN_INPUT | MUX_MODE14)		/* mmc1sdcd.gpio187 */
    	mmc1_pins_sdr12: pinmux_mmc1_sdr12_pins {
    	mmc1_pins_hs: pinmux_mmc1_hs_pins {
    			0x354 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_clk.clk */
    			0x358 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_cmd.cmd */
    			0x35c (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat0.dat0 */
    			0x360 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat1.dat1 */
    			0x364 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat2.dat2 */
    			0x368 (PIN_INPUT_PULLUP | MUX_VIRTUAL_MODE11 | MUX_MODE0)	/* mmc1_dat3.dat3 */
    	mmc1_pins_sdr25: pinmux_mmc1_sdr25_pins {
    	mmc1_pins_ddr50: pinmux_mmc1_ddr50_pins {
    			0x354 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_clk.clk */
    			0x358 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_cmd.cmd */
    			0x35c (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat0.dat0 */
    			0x360 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat1.dat1 */
    			0x364 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat2.dat2 */
    			0x368 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE0)	/* mmc1_dat3.dat3 */
    	mmc2_pins_default: mmc2_pins_default {
    			0x9c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a23.mmc2_clk */
    			0xb0 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_cs1.mmc2_cmd */
    			0xa0 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a24.mmc2_dat0 */
    			0xa4 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a25.mmc2_dat1 */
    			0xa8 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a26.mmc2_dat2 */
    			0xac (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a27.mmc2_dat3 */
    			0x8c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a19.mmc2_dat4 */
    			0x90 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a20.mmc2_dat5 */
    			0x94 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a21.mmc2_dat6 */
    			0x98 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_a22.mmc2_dat7 */
    	mmc2_pins_hs: pinmux_mmc2_hs_pins {
    	mmc2_pins_ddr_3_3v: pinmux_mmc2_ddr_3_3v_pins {
    			0x9c (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a23.mmc2_clk */
    			0xb0 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_cs1.mmc2_cmd */
    			0xa0 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a24.mmc2_dat0 */
    			0xa4 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a25.mmc2_dat1 */
    			0xa8 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a26.mmc2_dat2 */
    			0xac (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a27.mmc2_dat3 */
    			0x8c (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a19.mmc2_dat4 */
    			0x90 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a20.mmc2_dat5 */
    			0x94 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a21.mmc2_dat6 */
    			0x98 (PIN_INPUT_PULLUP | MANUAL_MODE | MUX_MODE1) /* gpmc_a22.mmc2_dat7 */
    	mmc4_pins_default: pinmux_mmc4_default_pins {
    			UART1_CTSN (PIN_INPUT_PULLUP | MUX_MODE3)	/* uart1_ctsn.mmc4_clk  E25 */
    			UART1_RTSN (PIN_INPUT_PULLUP | MUX_MODE3)	/* uart1_rtsn.mmc4_cmd C27 */
    			UART1_RXD (PIN_INPUT_PULLUP | MUX_MODE3)	/* uart2_rxd.mmc4_dat0 D28 */
    			UART1_TXD (PIN_INPUT_PULLUP | MUX_MODE3)	/* uart2_txd.mmc4_dat1 D26 */
    			UART2_CTSN (PIN_INPUT_PULLUP | MUX_MODE3)	/* uart2_ctsn.mmc4_dat2  D27 */
    			UART2_RTSN (PIN_INPUT_PULLUP | MUX_MODE3)	/* uart2_rtsn.mmc4_dat3 C28 */
    &dra7_iodelay_core {
    	mmc1_iodelay_ddr50_conf: mmc1_iodelay_ddr50_conf {
    			0x618 (A_DELAY(572) | G_DELAY(540))	/* CFG_MMC1_CLK_IN */
    			0x624 (A_DELAY(0) | G_DELAY(600))	/* CFG_MMC1_CMD_IN */
    			0x630 (A_DELAY(403) | G_DELAY(120))	/* CFG_MMC1_DAT0_IN */
    			0x63c (A_DELAY(23) | G_DELAY(60))	/* CFG_MMC1_DAT1_IN */
    			0x648 (A_DELAY(25) | G_DELAY(60))	/* CFG_MMC1_DAT2_IN */
    			0x654 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT3_IN */
    			0x620 (A_DELAY(1525) | G_DELAY(0))	/* CFG_MMC1_CLK_IN */
    			0x628 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_CMD_OEN */
    			0x62c (A_DELAY(55) | G_DELAY(0))	/* CFG_MMC1_CMD_OUT */
    			0x634 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT0_OEN */
    			0x638 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT0_OUT */
    			0x640 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT1_OEN */
    			0x644 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT1_OUT */
    			0x64c (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT2_OEN */
    			0x650 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT2_OUT */
    			0x658 (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT3_OEN */
    			0x65c (A_DELAY(0) | G_DELAY(0))		/* CFG_MMC1_DAT3_OUT */
    	mmc2_iodelay_ddr_3_3v_conf: mmc2_iodelay_ddr_3_3v_conf {
    			0x18c (A_DELAY(0) | G_DELAY(120))	/* CFG_GPMC_A19_IN */
    			0x1a4 (A_DELAY(265) | G_DELAY(360))	/* CFG_GPMC_A20_IN */
    			0x1b0 (A_DELAY(0) | G_DELAY(120))	/* CFG_GPMC_A21_IN */
    			0x1bc (A_DELAY(0) | G_DELAY(120))	/* CFG_GPMC_A22_IN */
    			0x1c8 (A_DELAY(287) | G_DELAY(420))	/* CFG_GPMC_A23_IN */
    			0x1d4 (A_DELAY(144) | G_DELAY(240))	/* CFG_GPMC_A24_IN */
    			0x1e0 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A25_IN */
    			0x1ec (A_DELAY(0) | G_DELAY(120))	/* CFG_GPMC_A26_IN */
    			0x1f8 (A_DELAY(120) | G_DELAY(180))	/* CFG_GPMC_A27_IN */
    			0x360 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_CS1_IN */
    			0x190 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A19_OEN */
    			0x194 (A_DELAY(174) | G_DELAY(0))	/* CFG_GPMC_A19_OUT */
    			0x1a8 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A20_OEN */
    			0x1ac (A_DELAY(168) | G_DELAY(0))	/* CFG_GPMC_A20_OUT */
    			0x1b4 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A21_OEN */
    			0x1b8 (A_DELAY(136) | G_DELAY(0))	/* CFG_GPMC_A21_OUT */
    			0x1c0 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A22_OEN */
    			0x1c4 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A22_OUT */
    			0x1d0 (A_DELAY(879) | G_DELAY(0))	/* CFG_GPMC_A23_OUT */
    			0x1d8 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A24_OEN */
    			0x1dc (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A24_OUT */
    			0x1e4 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A25_OEN */
    			0x1e8 (A_DELAY(34) | G_DELAY(0))	/* CFG_GPMC_A25_OUT */
    			0x1f0 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A26_OEN */
    			0x1f4 (A_DELAY(120) | G_DELAY(0))	/* CFG_GPMC_A26_OUT */
    			0x1fc (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A27_OEN */
    			0x200 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_A27_OUT */
    			0x364 (A_DELAY(0) | G_DELAY(0))		/* CFG_GPMC_CS1_OEN */
    			0x368 (A_DELAY(11) | G_DELAY(0))	/* CFG_GPMC_CS1_OUT */
    &i2c1 {
    	status = "okay";
    	clock-frequency = <400000>;
    	tps65917: tps65917@58 {
    		compatible = "ti,tps65917";
    		reg = <0x58>;
    		pinctrl-names = "default";
    		pinctrl-0 = <&tps65917_pins_default>;
    		interrupts-extended = <&gic GIC_SPI 2 IRQ_TYPE_NONE
    					&dra7_pmx_core 0x424>;
    		interrupt-parent = <&gic>;
    		interrupt-controller;
    		#interrupt-cells = <2>;
    		ti,system-power-controller;
    		tps65917_pmic {
    			compatible = "ti,tps65917-pmic";
    			regulators {
    				smps1_reg: smps1 {
    					/* VDD_MPU */
    					regulator-name = "smps1";
    					regulator-min-microvolt = <850000>;
    					regulator-max-microvolt = <1500000>;
    					regulator-boot-on;
    				smps2_reg: smps2 {
    					/* VDD_CORE */
    					regulator-name = "smps2";
    					regulator-boot-on;
    				smps3_reg: smps3 {
    					/* VDD_GPU IVA DSPEVE */
    					regulator-name = "smps3";
    					regulator-boot-on;
    				smps4_reg: smps4 {
    					/* VDDS1V8 */
    					regulator-name = "smps4";
    					regulator-boot-on;
    				smps5_reg: smps5 {
    					/* VDD_DDR */
    					regulator-name = "smps5";
    					regulator-boot-on;
    				ldo1_reg: ldo1 {
    					/* LDO1_OUT --> SDIO  */
    					regulator-name = "ldo1";
    					regulator-boot-on;
    				ldo2_reg: ldo2 {
    					/* LDO2_OUT --> TP1017 (UNUSED)  */
    					regulator-name = "ldo2";
    				ldo3_reg: ldo3 {
    					/* VDDA_1V8_PHY */
    					regulator-name = "ldo3";
    					regulator-boot-on;
    				ldo5_reg: ldo5 {
    					/* VDDA_1V8_PLL */
    					regulator-name = "ldo5";
    					regulator-boot-on;
    				ldo4_reg: ldo4 {
    					/* VDDA_3V_USB: VDDA_USBHS33 */
    					regulator-name = "ldo4";
    					regulator-boot-on;
    		tps65917_power_button {
    			compatible = "ti,palmas-pwrbutton";
    			interrupt-parent = <&tps65917>;
    			interrupts = <1 IRQ_TYPE_NONE>;
    			wakeup-source;
    			ti,palmas-long-press-seconds = <6>;
    	pcf_lcd: gpio@20 {
    		compatible = "nxp,pcf8575";
    		reg = <0x20>;
    		gpio-controller;
    		#gpio-cells = <2>;
    	pcf_gpio_21: gpio@21 {
    		reg = <0x21>;
    		lines-initial-states = <0x1408>;
    		gpio-controller;
    		#gpio-cells = <2>;
    		interrupt-parent = <&gpio6>;
    		interrupts = <11 IRQ_TYPE_EDGE_FALLING>;
    	tlv320aic3106: tlv320aic3106@18 {
    		compatible = "ti,tlv320aic3106";
    		reg = <0x18>;
    		adc-settle-ms = <40>;
    		ai3x-micbias-vg = <1>;		// 2.0V
    		status = "okay";
    		// Regulators
    		AVDD-supply = <&evm_3v3_sw>;
    		IOVDD-supply = <&evm_3v3_sw>;
    		DRVDD-supply = <&evm_3v3_sw>;
    		DVDD-supply = <&aic_dvdd>;
    i2c_p3_exp: &i2c2 {
    	status = "okay";
    	pcf_hdmi: gpio@26 {
    		reg = <0x26>;
    		lines-initial-states = <0xffeb>;
    		gpio-controller;
    		#gpio-cells = <2>;
    	ov10633@37 {
    		compatible = "ovti,ov10633";
    		reg = <0x37>;
    		mux-gpios = <&pcf_hdmi 3	GPIO_ACTIVE_LOW>; /* CAM_FPD_MUX_S0 */
    		port {
    			onboardLI: endpoint {
    				remote-endpoint = <&vin1a>;
    				hsync-active = <1>;
    				vsync-active = <1>;
    				pclk-sample = <0>;
    &i2c3 {
    	status = "okay";
    	clock-frequency = <3400000>;
    &mcspi1 {
    	status = "okay";
    	spidev@0 {
    		compatible = "rohm,dh2228fv";
    		//compatible = "spidev";
    		spi-max-frequency = <24000000>;
    		reg = <0>;
    &mcspi2 {
    	status = "okay";
    &uart1 {
    	status = "okay";
    	interrupts-extended = <&gic GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH
    			       &dra7_pmx_core 0x3e0>;
    &uart2 {
    	status = "okay";
    * &uart3 {
    *	status = "okay";
    *	gpios = <&pcf_gpio_21 14 GPIO_ACTIVE_LOW>;
    &uart3 {
    	status = "okay";
    	pinctrl-0 = <&uart3_pins>;
    &uart5 {
    	status = "okay";
    	pinctrl-0 = <&uart5_pins>;
    &uart6 {
    	status = "okay";
    	pinctrl-0 = <&uart6_pins>;
    &uart10 {
    	status = "okay";
    	pinctrl-0 = <&uart10_pins>;
    &mmc1 {
    	status = "okay";
    	pbias-supply = <&pbias_mmc_reg>;
    	vmmc-supply = <&evm_3v3_sd>;
    	vmmc_aux-supply = <&ldo1_reg>;
    	bus-width = <4>;
    	 * SDCD signal is not being used here - using the fact that GPIO mode
    	 * is always hardwired.
    	/* cd-gpios = <&gpio6 27 0>; */
    	ti,non-removable;
    	pinctrl-names = "default", "hs", "sdr12", "sdr25", "ddr50";
    	pinctrl-0 = <&mmc1_pins_default>;
    	pinctrl-1 = <&mmc1_pins_hs>;
    	pinctrl-2 = <&mmc1_pins_sdr12>;
    	pinctrl-3 = <&mmc1_pins_sdr25>;
    	pinctrl-4 = <&mmc1_pins_ddr50 &mmc1_iodelay_ddr50_conf>;
    	sd-uhs-ddr50;
    	sd-uhs-sdr25;
    	sd-uhs-sdr12;
    &mmc2 {
    	status = "okay";
    	//vmmc-supply = <&evm_3v3_sw>;
    	bus-width = <8>;
    	pinctrl-names = "default", "hs", "ddr_3_3v";
    	pinctrl-0 = <&mmc2_pins_default>;
    	pinctrl-1 = <&mmc2_pins_hs>;
    	pinctrl-2 = <&mmc2_pins_ddr_3_3v &mmc2_iodelay_ddr_3_3v_conf>;
    	mmc-ddr-1_8v;
    &mmc4 {
    	status = "okay";
    	bus-width = <4>;
    	cap-power-off-card;
    	keep-power-in-suspend;
    	ti,non-removable;
    	pinctrl-0 = <&mmc4_pins_default>;
    &mmc4 {
    	status = "okay";
    	vmmc-supply = <&vmmcwl_fixed>;
    	bus-width = <4>;
    	cap-power-off-card;
    	ti,non-removable;
    	#size-cells = <0>;
    	wlcore: wlcore@0 {
    		compatible = "ti,wlcore";
    		reg = <2>;
    		interrupt-parent = <&gpio5>;
    		interrupts = <7 IRQ_TYPE_LEVEL_HIGH>;
    &cpu0 {
    	cpu0-voltdm = <&voltdm_mpu>;
    	voltage-tolerance = <1>;
    &voltdm_mpu {
    	vdd-supply = <&smps1_reg>;
    &voltdm_dspeve {
    	vdd-supply = <&smps3_reg>;
    &voltdm_gpu {
    &voltdm_ivahd {
    &voltdm_core {
    	vdd-supply = <&smps2_reg>;
    &qspi {
    	status = "okay";
    	spi-max-frequency = <48000000>;
    	m25p80@0 {
    		compatible = "s25fl256s1";
    		reg = <0>;
    		spi-tx-bus-width = <1>;
    		spi-rx-bus-width = <4>;
    		spi-cpol;
    		spi-cpha;
    		#size-cells = <1>;
    		/* MTD partition table.
    		 * The ROM checks the first four physical blocks
    		 * for a valid file to boot and the flash here is
    		 * 64KiB block size.
    		partition@0 {
    			label = "QSPI.SPL";
    			reg = <0x00000000 0x000010000>;
    		partition@1 {
    			label = "QSPI.SPL.backup1";
    			reg = <0x00010000 0x00010000>;
    		partition@2 {
    			label = "QSPI.SPL.backup2";
    			reg = <0x00020000 0x00010000>;
    		partition@3 {
    			label = "QSPI.SPL.backup3";
    			reg = <0x00030000 0x00010000>;
    		partition@4 {
    			label = "QSPI.u-boot";
    			reg = <0x00040000 0x00100000>;
    		partition@5 {
    			label = "QSPI.u-boot-spl-os";
    			reg = <0x00140000 0x00080000>;
    		partition@6 {
    			label = "QSPI.u-boot-env";
    			reg = <0x001c0000 0x00010000>;
    		partition@7 {
    			label = "QSPI.u-boot-env.backup1";
    			reg = <0x001d0000 0x0010000>;
    		partition@8 {
    			label = "QSPI.kernel";
    			reg = <0x001e0000 0x0800000>;
    		partition@9 {
    			label = "QSPI.file-system";
    			reg = <0x009e0000 0x01620000>;
    &omap_dwc3_1 {
    	extcon = <&extcon_usb1>;
    &omap_dwc3_2 {
    	extcon = <&extcon_usb2>;
    &usb1 {
    	dr_mode = "host";
    &usb2 {
    	dr_mode = "host";
    &mac {
    	status = "disabled";
    &mac {
    	status = "okay";
    	dual_emac;
    	ti,no-idle;
    &cpsw_emac0 {
    	phy_id = <&davinci_mdio>, <2>;
    	phy-mode = "rgmii";
    	dual_emac_res_vlan = <1>;
    &cpsw_emac1 {
    	phy_id = <&davinci_mdio>, <3>;
    	phy-mode = "rgmii";
    	dual_emac_res_vlan = <2>;
    &elm {
    	status = "okay";
    &gpmc {
    	ranges = <0 0 0 0x01000000>;	/* minimum GPMC partition = 16MB */
    	nand@0,0 {
    		reg = <0 0 4>;		/* device IO registers */
    		ti,nand-ecc-opt = "bch8";
    		ti,elm-id = <&elm>;
    		nand-bus-width = <16>;
    		gpmc,device-width = <2>;
    		gpmc,sync-clk-ps = <0>;
    		gpmc,cs-on-ns = <0>;
    		gpmc,cs-rd-off-ns = <80>;
    		gpmc,cs-wr-off-ns = <80>;
    		gpmc,adv-on-ns = <0>;
    		gpmc,adv-rd-off-ns = <60>;
    		gpmc,adv-wr-off-ns = <60>;
    		gpmc,we-on-ns = <10>;
    		gpmc,we-off-ns = <50>;
    		gpmc,oe-on-ns = <4>;
    		gpmc,oe-off-ns = <40>;
    		gpmc,access-ns = <40>;
    		gpmc,wr-access-ns = <80>;
    		gpmc,rd-cycle-ns = <80>;
    		gpmc,wr-cycle-ns = <80>;
    		gpmc,bus-turnaround-ns = <0>;
    		gpmc,cycle2cycle-delay-ns = <0>;
    		gpmc,clk-activation-ns = <0>;
    		gpmc,wait-monitoring-ns = <0>;
    		gpmc,wr-data-mux-bus-ns = <0>;
    		/* MTD partition table */
    		/* All SPL-* partitions are sized to minimal length
    		 * which can be independently programmable. For
    		 * NAND flash this is equal to size of erase-block */
    		#size-cells = <1>;
    		partition@0 {
    			label = "NAND.SPL";
    			reg = <0x00000000 0x000020000>;
    		partition@1 {
    			label = "NAND.SPL.backup1";
    			reg = <0x00020000 0x00020000>;
    		partition@2 {
    			label = "NAND.SPL.backup2";
    			reg = <0x00040000 0x00020000>;
    		partition@3 {
    			label = "NAND.SPL.backup3";
    			reg = <0x00060000 0x00020000>;
    		partition@4 {
    			label = "NAND.u-boot-spl-os";
    			reg = <0x00080000 0x00040000>;
    		partition@5 {
    			label = "NAND.u-boot";
    			reg = <0x000c0000 0x00100000>;
    		partition@6 {
    			label = "NAND.u-boot-env";
    			reg = <0x001c0000 0x00020000>;
    		partition@7 {
    			label = "NAND.u-boot-env.backup1";
    			reg = <0x001e0000 0x00020000>;
    		partition@8 {
    			label = "NAND.kernel";
    			reg = <0x00200000 0x00800000>;
    		partition@9 {
    			label = "NAND.file-system";
    			reg = <0x00a00000 0x0f600000>;
    &gpio7 {
    	ti,no-reset-on-init;
    	ti,no-idle-on-init;
    &dss {
    	status = "ok";
    	vdda_video-supply = <&ldo5_reg>;
    &hdmi {
    	status = "ok";
    	vdda-supply = <&ldo3_reg>;
    	port {
    		hdmi_out: endpoint {
    			remote-endpoint = <&tpd12s015_in>;
    &dcan1 {
    	status = "ok";
    	pinctrl-names = "default", "sleep";
    	pinctrl-0 = <&dcan1_pins_default>;
    	pinctrl-1 = <&dcan1_pins_sleep>;
    &mailbox5 {
    	status = "okay";
    	mbox_ipu1_legacy: mbox_ipu1_legacy {
    		status = "okay";
    	mbox_dsp1_legacy: mbox_dsp1_legacy {
    		status = "okay";
    &mailbox6 {
    	status = "okay";
    	mbox_ipu2_legacy: mbox_ipu2_legacy {
    		status = "okay";
    	mbox_dsp2_legacy: mbox_dsp2_legacy {
    		status = "okay";
    &mmu0_dsp1 {
    	status = "okay";
    &mmu1_dsp1 {
    	status = "okay";
    &mmu_ipu1 {
    	status = "okay";
    &mmu_ipu2 {
    	status = "okay";
    &ipu2 {
    	status = "okay";
    	memory-region = <&ipu2_cma_pool>;
    	mboxes = <&mailbox6 &mbox_ipu2_legacy>;
    	timers = <&timer3>;
    	watchdog-timers = <&timer4>, <&timer9>;
    &ipu1 {
    	status = "okay";
    	memory-region = <&ipu1_cma_pool>;
    	mboxes = <&mailbox5 &mbox_ipu1_legacy>;
    	timers = <&timer11>;
    	watchdog-timers = <&timer7>, <&timer8>;
    &dsp1 {
    	status = "okay";
    	memory-region = <&dsp1_cma_pool>;
    	mboxes = <&mailbox5 &mbox_dsp1_legacy>;
    	timers = <&timer5>;
    	watchdog-timers = <&timer10>;
    &atl {
    	status = "okay";
    	atl2 {
    		bws = <DRA7_ATL_WS_MCASP2_FSX>;
    		aws = <DRA7_ATL_WS_MCASP3_FSX>;
    &mcasp3 {
    	fck_parent = "atl_clkin2_ck";
    	status = "okay";
    	op-mode = <0>;          /* MCASP_IIS_MODE */
    	tdm-slots = <2>;
    	/* 4 serializer */
    	serial-dir = <  /* 0: INACTIVE, 1: TX, 2: RX */
    		1 2 0 0
    	tx-num-evt = <8>;
    	rx-num-evt = <8>;
    &mcasp7 {
    	status = "okay";
    	tdm-slots = <4>;
    	/* 4 serializer */
    		2 1 0 0
    	tx-num-evt = <8>;
    	rx-num-evt = <8>;
    &mcasp8 {
    	/* not used for audio. only the AXR2 pin is used as GPIO */
    	status = "okay";
    &usb2_phy1 {
    	phy-supply = <&ldo4_reg>;
    &usb2_phy2 {
    &vip1 {
    	status = "okay";
    video_in: &vin1a {
    	status = "okay";
    	endpoint@0 {
    		slave-mode;
    		remote-endpoint = <&onboardLI>;
    #include "dra7xx-jamr3.dtsi"
    &tvp_5158{
    	mux-gpios = <&pcf_hdmi 3 GPIO_ACTIVE_HIGH>,	/*CAM_FPD_MUX_S0*/
    			<&pcf_jamr3_21 8 GPIO_ACTIVE_LOW>;	/*SEL_TVP_FPD*/
    20160721-boot.log.txt
  • Hi Andy,
    I'm not sure where is exactly the issue. But did you try to set i2c pins as outputs?
    Stan
  • Hi Stan,
    Thanks for your reply , we did setting the i2c pin to be i2c function. please see the attach file .
    ports {
    #size-cells = <0>;
    port@0 {
    reg = <0>;
    port@1 {
    reg = <1>;
    By the way , I found there are two tpd12s015 driver , "ti,dra7evm-tpd12s015" and "ti,tpd12s015" .
    Which one should I use ?
    Andy
  • Andy,
    I meant in:
    PIN_INPUT
    to
    PIN_OUTPUT
    or to
    PIN_OUTPUT_PULLUP
  • Hi Andy,
    Did you manage to solve the problem?
    I recall another question to ask. Do you have a 3.3V to 5V voltage translator on the PCB? It's because SoC pins are 3.3-V , and HDMI needs 5 V.
    Stan
  • Hi Stan,
    Thanks for your reply.
    If I change from INPUT to OUTPUT, "i2cdetect -r -y 1" will pop i2c timeout and also the same at modtest command.
    If I stay with INPUT, "i2cdetect -r -y 1" can finish the scanning , but modtest still pop HDMI I2C master error.
    And we connect hdmi pins to a hdmi bridge ic , the bridge ic can accept 3.3V or 5V.
    Do you have other advice ?
    Andy
  • Hi Andy,
    1. Are you working on TI J6 Eco EVM or on a custom hardware?
    2. is this issue seen only with GLSDK 7.02? Would it be possible to try with
    the GLSDK 7.04 release?
    3. The lines are supposed to be in INPUT mode which is actually input+output.
    Setting it to OUTPUT disables input path.
    4. To ensure that we are seeing issues only with the I2C lines and not the
    rest of the HDMI lines, can you please modify the function
    video/fbdev/omap2/dss/hdmi5_core.c:hdmi5_read_edid()
    to return 0 and check that modetest passes?
    regards,
    Venkat
