ADC value on HTTP Server of TI-RTOS
Hello !
i am getting the value "0" on accessing cgi through html.
 * Copyright (c) 2015, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  ======== empty.c ========
/* XDCtools Header files */
#include <xdc/std.h>
#include <xdc/runtime/System.h>
#include<stdio.h>
#include <stdbool.h>
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_pwm.h"
#include "inc/hw_types.h"
#include "driverlib/gpio.h"
#include "driverlib/pwm.h"
#include "driverlib/sysctl.h"
#include "driverlib/adc.h"
/* BIOS Header files */
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
    #include <ti/ndk/inc/netmain.h>
  #include "index.h"
#include"greetings.h"
#include"chip.h"
//#include"getLEDSTATUS.h"
/* TI-RTOS Header files */
 #include <ti/drivers/EMAC.h>
#include <ti/drivers/GPIO.h>
// #include <ti/drivers/I2C.h>
// #include <ti/drivers/SDSPI.h>
// #include <ti/drivers/SPI.h>
// #include <ti/drivers/UART.h>
// #include <ti/drivers/USBMSCHFatFs.h>
// #include <ti/drivers/Watchdog.h>
// #include <ti/drivers/WiFi.h>
/* Board Header file */
#include "Board.h"
#define TASKSTACKSIZE   512
Task_Struct task0Struct;
Char task0Stack[TASKSTACKSIZE];
		 uint32_t adc_value[4];
char bufer[4];
	 //volatile float signal_ch0,signal_ch1,signal_ch2,signal_ch3;
 *  ======== heartBeatFxn ========
 *  Toggle the Board_LED0. The Task_sleep is determined by arg0 which
 *  is configured for the heartBeat Task instance.
Void heartBeatFxn(UArg arg0, UArg arg1)
    while (1) {
        Task_sleep((unsigned int)arg0);
        GPIO_toggle(Board_LED0);
 *  ======== main ========
   Int getTime(SOCKET s, int length)
       Char buf[200];
       //static UInt scalar = 0;
       httpSendStatusLine(s, HTTP_OK, CONTENT_TYPE_HTML);
       httpSendClientStr(s, CRLF);
           "<html><head><title>DATA ACQUSITIONS "\
   	"Time</title></head><body><h1>ADC CHANNEL</h1>\n");
       System_sprintf(buf,"%d",adc_value[0]);
                   httpSendClientStr(s, buf);
            System_sprintf(buf,"%d",adc_value[1]);
       httpSendClientStr(s, "</table></body></html>");
       return (1);
   Void AddWebFiles(Void)
          //Note: both INDEX_SIZE and INDEX are defined in index.h
          efs_createfile("index.html", INDEX_SIZE, (UINT8 *)INDEX);
          efs_createfile("getTime.cgi", 0, (UINT8 *)&getTime);
          efs_createfile("chip.jpg", CHIP_SIZE,(UINT8 *)CHIP);
          efs_createfile("greetings.html", GREETINGS_SIZE,(UINT8 *)GREETINGS);
      Void RemoveWebFiles(Void)
          efs_destroyfile("index.html");
          efs_destroyfile("getTime.cgi");
          efs_destroyfile("chip.jpg");
          efs_destroyfile("greetings.html");
int main(void)
    Task_Params taskParams;
    /* Call board init f
     *unctions */
    Board_initGeneral();
     Board_initEMAC();
    Board_initGPIO();
    // Board_initI2C();
    // Board_initSDSPI();
    // Board_initSPI();
    // Board_initUART();
    // Board_initUSB(Board_USBDEVICE);
    // Board_initUSBMSCHFatFs();
    // Board_initWatchdog();
    // Board_initWiFi();
    /* Construct heartBeat Task  thread */
    Task_Params_init(&taskParams);
    taskParams.arg0 = 1000;
    taskParams.stackSize = TASKSTACKSIZE;
    taskParams.stack = &task0Stack;
    Task_construct(&task0Struct, (Task_FuncPtr)heartBeatFxn, &taskParams, NULL);
     /* Turn on user LED */
    GPIO_write(Board_LED0, Board_LED_ON);
    		 volatile uint32_t adc0,adc1,adc2,adc3;
    GPIOPinTypeADC(GPIO_PORTE_BASE,GPIO_PIN_4);
    GPIOPinTypeADC(GPIO_PORTE_BASE,GPIO_PIN_5);
    GPIOPinTypeADC(GPIO_PORTB_BASE,GPIO_PIN_4);
    GPIOPinTypeADC(GPIO_PORTB_BASE,GPIO_PIN_5);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);
    ADCSequenceConfigure(ADC0_BASE,2,ADC_TRIGGER_PROCESSOR,0);  //CONFIGURE THE ADC SAMPLE SEQUENCER THAT U WANA USE
    ADCSequenceStepConfigure(ADC0_BASE,2,0, ADC_CTL_CH9 );		//CONFIGURE THE STEPS OF SAMPLE SEQUENCER
    ADCSequenceStepConfigure(ADC0_BASE,2,1, ADC_CTL_CH8 );		//
    ADCSequenceStepConfigure(ADC0_BASE,2,2, ADC_CTL_CH10 );		//
    ADCSequenceStepConfigure(ADC0_BASE,2,3, ADC_CTL_CH11|ADC_CTL_IE|ADC_CTL_END );
    ADCSequenceEnable(ADC0_BASE, 2);
    ADCProcessorTrigger(ADC0_BASE,2);
    while(!ADCIntStatus(ADC0_BASE, 2, false))
    ADCIntClear(ADC0_BASE,2);
    ADCSequenceDataGet(ADC0_BASE,2,adc_value);
    System_printf("Starting the example\nSystem provider is set to SysMin. "
                  "Halt the target to view any SysMin contents in ROV.\n");
    /* SysMin will only print to the console when you call flush or exit */
    System_flush();
    /* Start BIOS */
    BIOS_start();
    return (0);
How to format from uint32_t data type for following function :
please help out
