Hi all,
so we are basically facing an issue on a custom board and would love to get your thoughts on this.
C5517 is connected to host through USB 2.0 mini and is used to transfer data at high rate ~500ko/s.
The issue we are facing is random but regular USB bubble error from all tested hosts (Linux, Windows and Mac). We highly suspect a ground issue, knowing USB is on flex conductor and that the error is persistent even at lower data rate (so DSP burden does not seem to be the issue).
Has anyone experienced similar issue and could provide help on that front. Also we want to draw the eye diagram with our board, does TI provide a USB test mode script that we could use to quickly run our diagnosis ?
Jean
