Hi Team,
We are using Processor-SDK-02.00.02.11 on a custom board based on AM437x-SK-EVM design.
We integrated 320*240 Resistive Touch Panel to our board.
The display panel driver is panel-dpi.c and touchscreen driver is ti-am335x-tsc.c
We are facing 2 problems.
1. We are frequently getting the following error
[ 470.365039] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040
[ 470.371531] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040
[ 470.380260] [drm:omap_plane_error_irq] *ERROR* gfx: errors: 00000040
2. The touchscreen coordinate values are incorrect.
# ts_print_raw
946686339.982239: 2873 3705 328
946686339.984518: 2833 2944 295
946686339.986831: 2794 2983 285
946686339.989297: 2765 3022 282
946686339.991491: 2745 3043 279
946686339.993792: 2734 3068 283
946686340.005357: 2718 3090 282
946686340.007600: 2729 3091 292
946686340.009916: 2740 3098 301
946686340.012249: 2748 3100 302
946686340.014529: 2773 3098 319
946686340.016887: 2812 3106 332
946686340.019167: 2962 3126 393
When i release touch, x & y never sets to 0.
The same setup is working fine in our am335x custom board with Processor-SDK-02.00.02.11.
# ts_print_raw ---------------------------------> working coordinates am335x
946686501.309815: 2285 2438 233
946686501.311730: 2291 2481 231
946686501.313666: 2291 2496 233
946686501.315592: 2295 2502 234
946686501.317533: 2306 2527 231
946686501.319466: 2318 2564 230
946686501.321406: 2318 2579 230
946686501.323344: 2322 2586 229
946686501.356489: 0 0 0
I have attached am437x-sk-evm.dts file for your reference.
Thanks & Regards,
Arun
/* * Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/ * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. */ /* AM437x SK EVM */ /dts-v1/; #include "am4372.dtsi" #include <dt-bindings/pinctrl/am43xx.h> #include <dt-bindings/pwm/pwm.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> #include <dt-bindings/interrupt-controller/irq.h> / { model = "TI AM437x SK EVM"; compatible = "ti,am437x-sk-evm","ti,am4372","ti,am43"; aliases { display0 = &lcd0; }; backlight { compatible = "pwm-backlight"; /* default values commented by arun analogics */ /* pwms = <&ecap0 0 50000 PWM_POLARITY_INVERTED>; */ pwms = <&ecap0 0 50000 0>; brightness-levels = <0 51 53 56 62 75 101 152 255>; default-brightness-level = <8>; }; sound { compatible = "simple-audio-card"; simple-audio-card,name = "AM437x-SK-EVM"; simple-audio-card,widgets = "Headphone", "Headphone Jack"; simple-audio-card,routing = "Headphone Jack", "HPLOUT", "Headphone Jack", "HPROUT"; simple-audio-card,format = "dsp_b"; simple-audio-card,bitclock-master = <&sound_master>; simple-audio-card,frame-master = <&sound_master>; simple-audio-card,bitclock-inversion; simple-audio-card,cpu { sound-dai = <&mcasp1>; }; sound_master: simple-audio-card,codec { sound-dai = <&tlv320aic3106>; system-clock-frequency = <24000000>; }; }; matrix_keypad: matrix_keypad@0 { compatible = "gpio-matrix-keypad"; pinctrl-names = "default"; /* pinctrl-0 = <&matrix_keypad_pins>; */ debounce-delay-ms = <5>; col-scan-delay-us = <5>; row-gpios = <&gpio5 5 GPIO_ACTIVE_HIGH /* Bank5, pin5 */ &gpio5 6 GPIO_ACTIVE_HIGH>; /* Bank5, pin6 */ col-gpios = <&gpio5 13 GPIO_ACTIVE_HIGH /* Bank5, pin13 */ &gpio5 4 GPIO_ACTIVE_HIGH>; /* Bank5, pin4 */ linux,keymap = < MATRIX_KEY(0, 0, KEY_DOWN) MATRIX_KEY(0, 1, KEY_RIGHT) MATRIX_KEY(1, 0, KEY_LEFT) MATRIX_KEY(1, 1, KEY_UP) >; }; leds { compatible = "gpio-leds"; pinctrl-names = "default"; /* pinctrl-0 = <&leds_pins>; */ led@0 { label = "am437x-sk:red:heartbeat"; gpios = <&gpio5 0 GPIO_ACTIVE_HIGH>; /* Bank 5, pin 0 */ linux,default-trigger = "heartbeat"; default-state = "off"; }; led@1 { label = "am437x-sk:green:mmc1"; gpios = <&gpio5 1 GPIO_ACTIVE_HIGH>; /* Bank 5, pin 1 */ linux,default-trigger = "mmc0"; default-state = "off"; }; led@2 { label = "am437x-sk:blue:cpu0"; gpios = <&gpio5 2 GPIO_ACTIVE_HIGH>; /* Bank 5, pin 2 */ linux,default-trigger = "cpu0"; default-state = "off"; }; led@3 { label = "am437x-sk:blue:usr3"; gpios = <&gpio5 3 GPIO_ACTIVE_HIGH>; /* Bank 5, pin 3 */ default-state = "off"; }; }; /*Defualt display values commented by analogics */ /* lcd0: display { compatible = "newhaven,nhd-4.3-480272ef-atxl", "panel-dpi"; label = "lcd"; pinctrl-names = "default"; pinctrl-0 = <&lcd_pins>; enable-gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>; panel-timing { clock-frequency = <9000000>; hactive = <480>; vactive = <272>; hfront-porch = <2>; hback-porch = <2>; hsync-len = <41>; vfront-porch = <2>; vback-porch = <2>; vsync-len = <10>; hsync-active = <0>; vsync-active = <0>; de-active = <1>; pixelclk-active = <1>; }; port { lcd_in: endpoint { remote-endpoint = <&dpi_out>; }; }; }; */ /* new display values added by arun analogics */ lcd0: display { compatible = "Analogics,SKAT035GT-09-TP", "panel-dpi"; label = "lcd"; /* pinctrl-names = "default"; pinctrl-0 = <&lcd_pins>; enable-gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>;*/ panel-timing { clock-frequency = <6500000>; hactive = <320>; vactive = <240>; hfront-porch = <20>; hback-porch = <38>; hsync-len = <30>; vfront-porch = <4>; vback-porch = <15>; vsync-len = <3>; hsync-active = <0>; vsync-active = <0>; de-active = <0>; pixelclk-active = <1>; }; port { lcd_in: endpoint { remote-endpoint = <&dpi_out>; }; }; }; vmmcwl_fixed: fixedregulator-mmcwl { compatible = "regulator-fixed"; regulator-name = "vmmcwl_fixed"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; gpio = <&gpio4 8 GPIO_ACTIVE_HIGH>; enable-active-high; }; }; &am43xx_pinmux { /* matrix pinmux commented by arun analogics */ /* matrix_keypad_pins: matrix_keypad_pins { pinctrl-single,pins = < 0x24c (PIN_OUTPUT | MUX_MODE7) // gpio5_13.gpio5_13 0x250 (PIN_OUTPUT | MUX_MODE7) // spi4_sclk.gpio5_4 0x254 (PIN_INPUT | MUX_MODE7) // spi4_d0.gpio5_5 0x258 (PIN_INPUT | MUX_MODE7) // spi4_d1.gpio5_5 >; }; */ /* leds_pins: leds_pins { pinctrl-single,pins = < 0x228 (PIN_OUTPUT | MUX_MODE7) // uart3_rxd.gpio5_2 0x22c (PIN_OUTPUT | MUX_MODE7) // uart3_txd.gpio5_3 0x230 (PIN_OUTPUT | MUX_MODE7) // uart3_ctsn.gpio5_0 0x234 (PIN_OUTPUT | MUX_MODE7) // uart3_rtsn.gpio5_1 >; }; */ i2c0_pins: i2c0_pins { pinctrl-single,pins = < 0x188 (PIN_INPUT | SLEWCTRL_FAST | MUX_MODE0) /* i2c0_sda.i2c0_sda */ 0x18c (PIN_INPUT | SLEWCTRL_FAST | MUX_MODE0) /* i2c0_scl.i2c0_scl */ >; }; /* i2c1_pins: i2c1_pins { pinctrl-single,pins = < 0x15c (PIN_INPUT | SLEWCTRL_FAST | MUX_MODE2) // spi0_cs0.i2c1_scl 0x158 (PIN_INPUT | SLEWCTRL_FAST | MUX_MODE2) // spi0_d1.i2c1_sda >; }; */ /* i2c1 pinmux added by analogics */ i2c1_pins: i2c1_pins { pinctrl-single,pins = < 0x16c (PIN_INPUT | SLEWCTRL_FAST | MUX_MODE2) /* spi0_cs0.i2c1_scl */ 0x168 (PIN_INPUT | SLEWCTRL_FAST | MUX_MODE2) /* spi0_d1.i2c1_sda */ >; }; /* mmc1_pins: pinmux_mmc1_pins { pinctrl-single,pins = < 0x0f0 (PIN_INPUT | MUX_MODE0) /* mmc0_dat3.mmc0_dat3 0x0f4 (PIN_INPUT | MUX_MODE0) /* mmc0_dat2.mmc0_dat2 0x0f8 (PIN_INPUT | MUX_MODE0) /* mmc0_dat1.mmc0_dat1 0x0fc (PIN_INPUT | MUX_MODE0) /* mmc0_dat0.mmc0_dat0 0x100 (PIN_INPUT | MUX_MODE0) /* mmc0_clk.mmc0_clk 0x104 (PIN_INPUT | MUX_MODE0) /* mmc0_cmd.mmc0_cmd 0x160 (PIN_INPUT | MUX_MODE7) /* spi0_cs1.gpio0_6 >; }; */ /* MMC1 pinmux added by analogics*/ mmc1_pins: pinmux_mmc1_pins { pinctrl-single,pins = < 0x80 ( PIN_INPUT | MUX_MODE2 ) /* (B9) gpmc_csn1.mmc1_clk */ 0x84 ( PIN_OUTPUT | MUX_MODE2 ) /* (F10) gpmc_csn2.mmc1_cmd */ 0x20 ( PIN_INPUT | MUX_MODE2 ) /* (B10) gpmc_ad8.mmc1_dat0 */ 0x24 ( PIN_INPUT | MUX_MODE2 ) /* (A10) gpmc_ad9.mmc1_dat1 */ 0x28 ( PIN_INPUT | MUX_MODE2 ) /* (F11) gpmc_ad10.mmc1_dat2 */ 0x2c ( PIN_INPUT | MUX_MODE2 ) /* (D11) gpmc_ad11.mmc1_dat3 */ 0x30 ( PIN_INPUT | MUX_MODE2 ) /* (E11) gpmc_ad12.mmc1_dat4 */ 0x34 ( PIN_INPUT | MUX_MODE2 ) /* (C11) gpmc_ad13.mmc1_dat5 */ 0x38 ( PIN_INPUT | MUX_MODE2 ) /* (B11) gpmc_ad14.mmc1_dat6 */ 0x3c ( PIN_INPUT | MUX_MODE2 ) /* (A11) gpmc_ad15.mmc1_dat7 */ >; }; ecap0_pins: backlight_pins { pinctrl-single,pins = < 0x164 (PIN_OUTPUT | MUX_MODE0) /* eCAP0_in_PWM0_out.eCAP0_in_PWM0_out */ >; }; /* default pinmux commented by analogics */ /* edt_ft5306_ts_pins: edt_ft5306_ts_pins { pinctrl-single,pins = < 0x74 (PIN_INPUT | MUX_MODE7) // gpmc_wpn.gpio0_31 0x78 (PIN_OUTPUT | MUX_MODE7) // gpmc_be1n.gpio1_28 >; }; */ vpfe0_pins_default: vpfe0_pins_default { pinctrl-single,pins = < 0x1b0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_hd mode 0*/ 0x1b4 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_vd mode 0*/ 0x1b8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_field mode 0*/ 0x1bc (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_wen mode 0*/ 0x1c0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_pclk mode 0*/ 0x1c4 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data8 mode 0*/ 0x1c8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data9 mode 0*/ 0x208 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data0 mode 0*/ 0x20c (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data1 mode 0*/ 0x210 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data2 mode 0*/ 0x214 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data3 mode 0*/ 0x218 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data4 mode 0*/ 0x21c (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data5 mode 0*/ 0x220 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data6 mode 0*/ 0x224 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data7 mode 0*/ >; }; vpfe0_pins_sleep: vpfe0_pins_sleep { pinctrl-single,pins = < 0x1b0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x1b4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x1b8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x1bc (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x1c0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x1c4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x1c8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x208 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x20c (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x210 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x214 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x218 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x21c (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x220 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) 0x224 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) >; }; clkout1_pin: pinmux_clkout1_pin { pinctrl-single,pins = < 0x270 (PIN_OUTPUT_PULLDOWN | MUX_MODE3) /* XDMA_EVENT_INTR0/CLKOUT1 */ >; }; /* default pinmux commented by analogics */ /* cpsw_default: cpsw_default { pinctrl-single,pins = < // Slave 1 0x12c (PIN_OUTPUT | MUX_MODE2) /* mii1_txclk.rmii1_tclk 0x114 (PIN_OUTPUT | MUX_MODE2) /* mii1_txen.rgmii1_tctl 0x128 (PIN_OUTPUT | MUX_MODE2) /* mii1_txd0.rgmii1_td0 0x124 (PIN_OUTPUT | MUX_MODE2) /* mii1_txd1.rgmii1_td1 0x120 (PIN_OUTPUT | MUX_MODE2) /* mii1_txd0.rgmii1_td2 0x11c (PIN_OUTPUT | MUX_MODE2) /* mii1_txd1.rgmii1_td3 0x130 (PIN_INPUT | MUX_MODE2) /* mii1_rxclk.rmii1_rclk 0x118 (PIN_INPUT | MUX_MODE2) /* mii1_rxdv.rgmii1_rctl 0x140 (PIN_INPUT | MUX_MODE2) /* mii1_rxd0.rgmii1_rd0 0x13c (PIN_INPUT | MUX_MODE2) /* mii1_rxd1.rgmii1_rd1 0x138 (PIN_INPUT | MUX_MODE2) /* mii1_rxd0.rgmii1_rd2 0x134 (PIN_INPUT | MUX_MODE2) /* mii1_rxd1.rgmii1_rd3 // Slave 2 0x58 (PIN_OUTPUT | MUX_MODE2) /* gpmc_a6.rgmii2_tclk 0x40 (PIN_OUTPUT | MUX_MODE2) /* gpmc_a0.rgmii2_tctl 0x54 (PIN_OUTPUT | MUX_MODE2) /* gpmc_a5.rgmii2_td0 0x50 (PIN_OUTPUT | MUX_MODE2) /* gpmc_a4.rgmii2_td1 0x4c (PIN_OUTPUT | MUX_MODE2) /* gpmc_a3.rgmii2_td2 0x48 (PIN_OUTPUT | MUX_MODE2) /* gpmc_a2.rgmii2_td3 0x5c (PIN_INPUT | MUX_MODE2) /* gpmc_a7.rgmii2_rclk 0x44 (PIN_INPUT | MUX_MODE2) /* gpmc_a1.rgmii2_rtcl 0x6c (PIN_INPUT | MUX_MODE2) /* gpmc_a11.rgmii2_rd0 0x68 (PIN_INPUT | MUX_MODE2) /* gpmc_a10.rgmii2_rd1 0x64 (PIN_INPUT | MUX_MODE2) /* gpmc_a9.rgmii2_rd2 0x60 (PIN_INPUT | MUX_MODE2) /* gpmc_a8.rgmii2_rd3 >; }; cpsw_sleep: cpsw_sleep { pinctrl-single,pins = < // Slave 1 reset value 0x12c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x114 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x128 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x124 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x120 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x11c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x130 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x118 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x140 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x13c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x138 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x134 (PIN_INPUT_PULLDOWN | MUX_MODE7) // Slave 2 reset value 0x58 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x40 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x54 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x50 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x4c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x48 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x5c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x44 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x6c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x68 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x64 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x60 (PIN_INPUT_PULLDOWN | MUX_MODE7) >; }; */ /* cpsw pinmux added by analogics */ cpsw_default: cpsw_pins_default { pinctrl-single,pins = < 0x10c ( PIN_INPUT_PULLUP | MUX_MODE1 ) /* (B14) mii1_crs.rmii1_crs_dv */ 0x110 ( PIN_INPUT_PULLDOWN | MUX_MODE1 ) /* (B13) mii1_rx_er.rmii1_rxer */ 0x114 ( PIN_OUTPUT | MUX_MODE1 ) /* (A13) mii1_tx_en.rmii1_txen */ 0x128 ( PIN_OUTPUT | MUX_MODE1 ) /* (B15) mii1_txd0.rmii1_txd0 */ 0x124 ( PIN_OUTPUT | MUX_MODE1 ) /* (A14) mii1_txd1.rmii1_txd1 */ 0x140 ( PIN_INPUT_PULLUP | MUX_MODE1 ) /* (F17) mii1_rxd0.rmii1_rxd0 */ 0x13c ( PIN_INPUT_PULLUP | MUX_MODE1 ) /* (B16) mii1_rxd1.rmii1_rxd1 */ 0x144 ( PIN_INPUT_PULLDOWN | MUX_MODE0 ) /* (A16) rmii1_ref_clk.rmii1_refclk */ >; }; cpsw_sleep: cpsw_pins_sleep { pinctrl-single,pins = < 0x10c /* (B14) mii1_crs.rmii1_crs_dv */ 0x110 /* (B13) mii1_rx_er.rmii1_rxer */ 0x114 /* (A13) mii1_tx_en.rmii1_txen */ 0x128 /* (B15) mii1_txd0.rmii1_txd0 */ 0x124 /* (A14) mii1_txd1.rmii1_txd1 */ 0x140 /* (F17) mii1_rxd0.rmii1_rxd0 */ 0x13c /* (B16) mii1_rxd1.rmii1_rxd1 */ 0x144 /* (A16) rmii1_ref_clk.rmii1_refclk */ >; }; davinci_mdio_default: davinci_mdio_default { pinctrl-single,pins = < /* MDIO */ 0x148 (PIN_INPUT | SLEWCTRL_FAST | MUX_MODE0) /* mdio_data.mdio_data */ 0x14c (PIN_OUTPUT | MUX_MODE0) /* mdio_clk.mdio_clk */ >; }; davinci_mdio_sleep: davinci_mdio_sleep { pinctrl-single,pins = < /* MDIO reset value */ 0x148 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x14c (PIN_INPUT_PULLDOWN | MUX_MODE7) >; }; /* default pinmux commented by analogics */ /* dss_pins: dss_pins { pinctrl-single,pins = < 0x020 (PIN_OUTPUT | MUX_MODE1) /* gpmc ad 8 -> DSS DATA 23 0x024 (PIN_OUTPUT | MUX_MODE1) 0x028 (PIN_OUTPUT | MUX_MODE1) 0x02c (PIN_OUTPUT | MUX_MODE1) 0x030 (PIN_OUTPUT | MUX_MODE1) 0x034 (PIN_OUTPUT | MUX_MODE1) 0x038 (PIN_OUTPUT | MUX_MODE1) 0x03c (PIN_OUTPUT | MUX_MODE1) /* gpmc ad 15 -> DSS DATA 16 0x0a0 (PIN_OUTPUT | MUX_MODE0) /* DSS DATA 0 0x0a4 (PIN_OUTPUT | MUX_MODE0) 0x0a8 (PIN_OUTPUT | MUX_MODE0) 0x0ac (PIN_OUTPUT | MUX_MODE0) 0x0b0 (PIN_OUTPUT | MUX_MODE0) 0x0b4 (PIN_OUTPUT | MUX_MODE0) 0x0b8 (PIN_OUTPUT | MUX_MODE0) 0x0bc (PIN_OUTPUT | MUX_MODE0) 0x0c0 (PIN_OUTPUT | MUX_MODE0) 0x0c4 (PIN_OUTPUT | MUX_MODE0) 0x0c8 (PIN_OUTPUT | MUX_MODE0) 0x0cc (PIN_OUTPUT | MUX_MODE0) 0x0d0 (PIN_OUTPUT | MUX_MODE0) 0x0d4 (PIN_OUTPUT | MUX_MODE0) 0x0d8 (PIN_OUTPUT | MUX_MODE0) 0x0dc (PIN_OUTPUT | MUX_MODE0) /* DSS DATA 15 0x0e0 (PIN_OUTPUT | MUX_MODE0) /* DSS VSYNC 0x0e4 (PIN_OUTPUT | MUX_MODE0) /* DSS HSYNC 0x0e8 (PIN_OUTPUT | MUX_MODE0) /* DSS PCLK 0x0ec (PIN_OUTPUT | MUX_MODE0) /* DSS AC BIAS EN >; }; */ /* display pinmux added by analogics */ dss_pins: dss_pins_default { pinctrl-single,pins = < 0xe0 ( PIN_OUTPUT | MUX_MODE0 ) /* (B23) dss_vsync.dss_vsync */ 0xe4 ( PIN_OUTPUT | MUX_MODE0 ) /* (A23) dss_hsync.dss_hsync */ 0xe8 ( PIN_OUTPUT | MUX_MODE0 ) /* (A22) dss_pclk.dss_pclk */ 0xec ( PIN_OUTPUT | MUX_MODE0 ) /* (A24) dss_ac_bias_en.dss_ac_bias_en */ 0xa0 ( PIN_OUTPUT | MUX_MODE0 ) /* (B22) dss_data0.dss_data0 */ 0xa4 ( PIN_OUTPUT | MUX_MODE0 ) /* (A21) dss_data1.dss_data1 */ 0xa8 ( PIN_OUTPUT | MUX_MODE0 ) /* (B21) dss_data2.dss_data2 */ 0xac ( PIN_OUTPUT | MUX_MODE0 ) /* (C21) dss_data3.dss_data3 */ 0xb0 ( PIN_OUTPUT | MUX_MODE0 ) /* (A20) dss_data4.dss_data4 */ 0xb4 ( PIN_OUTPUT | MUX_MODE0 ) /* (B20) dss_data5.dss_data5 */ 0xb8 ( PIN_OUTPUT | MUX_MODE0 ) /* (C20) dss_data6.dss_data6 */ 0xbc ( PIN_OUTPUT | MUX_MODE0 ) /* (E19) dss_data7.dss_data7 */ 0xc0 ( PIN_OUTPUT | MUX_MODE0 ) /* (A19) dss_data8.dss_data8 */ 0xc4 ( PIN_OUTPUT | MUX_MODE0 ) /* (B19) dss_data9.dss_data9 */ 0xc8 ( PIN_OUTPUT | MUX_MODE0 ) /* (A18) dss_data10.dss_data10 */ 0xcc ( PIN_OUTPUT | MUX_MODE0 ) /* (B18) dss_data11.dss_data11 */ 0xd0 ( PIN_OUTPUT | MUX_MODE0 ) /* (C19) dss_data12.dss_data12 */ 0xd4 ( PIN_OUTPUT | MUX_MODE0 ) /* (D19) dss_data13.dss_data13 */ 0xd8 ( PIN_OUTPUT | MUX_MODE0 ) /* (C17) dss_data14.dss_data14 */ 0xdc ( PIN_OUTPUT | MUX_MODE0 ) /* (D17) dss_data15.dss_data15 */ 0x274 ( PIN_INPUT | MUX_MODE7 ) /* (C24) xdma_event_intr1.gpio0[20] Display Reset Pin */ >; }; /* default pinmux commented by analogics */ /* qspi_pins: qspi_pins { pinctrl-single,pins = < 0x7c (PIN_OUTPUT | MUX_MODE3) /* gpmc_csn0.qspi_csn 0x88 (PIN_OUTPUT | MUX_MODE2) /* gpmc_csn3.qspi_clk 0x90 (PIN_INPUT | MUX_MODE3) /* gpmc_advn_ale.qspi_d0 0x94 (PIN_INPUT | MUX_MODE3) /* gpmc_oen_ren.qspi_d1 0x98 (PIN_INPUT | MUX_MODE3) /* gpmc_wen.qspi_d2 0x9c (PIN_INPUT | MUX_MODE3) /* gpmc_be0n_cle.qspi_d3 >; }; */ /* default pinmux commented by analogics */ /* mcasp1_pins: mcasp1_pins { pinctrl-single,pins = < 0x10c (PIN_INPUT_PULLDOWN | MUX_MODE4) /* mii1_crs.mcasp1_aclkx 0x110 (PIN_INPUT_PULLDOWN | MUX_MODE4) /* mii1_rxerr.mcasp1_fsx 0x108 (PIN_OUTPUT_PULLDOWN | MUX_MODE4) /* mii1_col.mcasp1_axr2 0x144 (PIN_INPUT_PULLDOWN | MUX_MODE4) /* rmii1_ref_clk.mcasp1_axr3 >; }; */ /* mcasp1 added by analogics */ mcasp1_pins: mcasp_1_pins_default { pinctrl-single,pins = < 0x1a0 ( PIN_INPUT | MUX_MODE3 ) /* (L23) mcasp0_aclkr.mcasp1_aclkx */ 0x1a4 ( PIN_INPUT | MUX_MODE3 ) /* (K23) mcasp0_fsr.mcasp1_fsx */ 0x1a8 ( PIN_INPUT | MUX_MODE3 ) /* (M25) mcasp0_axr1.mcasp1_axr0 */ 0x1ac ( PIN_INPUT | MUX_MODE3 ) /* (L24) mcasp0_ahclkx.mcasp1_axr1 */ >; }; lcd_pins: lcd_pins { pinctrl-single,pins = < 0x1c (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpcm_ad7.gpio1_7 */ >; }; usb1_pins: usb1_pins { pinctrl-single,pins = < 0x2c0 (PIN_OUTPUT | MUX_MODE0) /* usb0_drvvbus.usb0_drvvbus */ >; }; usb2_pins: usb2_pins { pinctrl-single,pins = < 0x2c4 (PIN_OUTPUT | MUX_MODE0) /* usb0_drvvbus.usb0_drvvbus */ >; }; mmc3_pins_default: pinmux_mmc3_pins_default { pinctrl-single,pins = < 0x1f0 (PIN_INPUT_PULLUP | MUX_MODE3) /* (AD21) cam1_data2.mmc2_clk */ 0x1f4 (PIN_INPUT_PULLUP | MUX_MODE3) /* (AE22) cam1_data3.mmc2_cmd */ 0x1f8 (PIN_INPUT_PULLUP | MUX_MODE3) /* (AD22) cam1_data4.mmc2_dat0 */ 0x1fc (PIN_INPUT_PULLUP | MUX_MODE3) /* (AE23) cam1_data5.mmc2_dat1 */ 0x200 (PIN_INPUT_PULLUP | MUX_MODE3) /* (AD23) cam1_data6.mmc2_dat2 */ 0x204 (PIN_INPUT_PULLUP | MUX_MODE3) /* (AE24) cam1_data7.mmc2_dat3 */ >; }; mmc3_pins_sleep: pinmux_mmc3_pins_sleep { pinctrl-single,pins = < 0x1f0 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AD21) cam1_data2.mmc2_clk */ 0x1f4 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AE22) cam1_data3.mmc2_cmd */ 0x1f8 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AD22) cam1_data4.mmc2_dat0 */ 0x1fc (PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AE23) cam1_data5.mmc2_dat1 */ 0x200 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AD23) cam1_data6.mmc2_dat2 */ 0x204 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* (AE24) cam1_data7.mmc2_dat3 */ >; }; wlan_pins_default: pinmux_wlan_pins_default { pinctrl-single,pins = < 0x1d0 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* cam1_data8.gpio4_8 WL_EN */ 0x1e4 (PIN_INPUT | WAKEUP_ENABLE | MUX_MODE7) /* cam1_wen.gpio4_13 WL_IRQ */ >; }; wlan_pins_sleep: pinmux_wlan_pins_sleep { pinctrl-single,pins = < 0x1d0 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* cam1_data8.gpio4_8 WL_EN */ 0x1e4 (PIN_INPUT | WAKEUP_ENABLE | MUX_MODE7) /* cam1_wen.gpio4_13 WL_IRQ */ >; }; uart1_bt_pins_default: pinmux_uart1_bt_pins_default { pinctrl-single,pins = < 0x180 (PIN_INPUT | MUX_MODE0) /* uart1_rxd.uart1_rxd */ 0x184 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart1_txd.uart1_txd */ 0x178 (PIN_INPUT_PULLUP | MUX_MODE0) /* uart1_ctsn.uart1_ctsn */ 0x17c (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart1_rtsn.uart1_rtsn */ 0x1cc (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* cam1_data9.gpiop BT_EN */ >; }; uart1_bt_pins_sleep: pinmux_uart1_bt_pins_sleep { pinctrl-single,pins = < 0x180 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* uart1_rxd.uart1_rxd */ 0x184 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* uart1_txd.uart1_txd */ 0x178 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* uart1_ctsn.uart1_ctsn */ 0x17c (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* uart1_rtsn.uart1_rtsn */ 0x1cc (PIN_OUTPUT_PULLUP | MUX_MODE7) /* cam1_data9.gpio4_7 BT_EN */ >; }; }; &i2c0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c0_pins>; clock-frequency = <100000>; tps@24 { compatible = "ti,tps65218"; reg = <0x24>; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; interrupt-controller; #interrupt-cells = <2>; dcdc1: regulator-dcdc1 { compatible = "ti,tps65218-dcdc1"; /* VDD_CORE limits min of OPP50 and max of OPP100 */ regulator-name = "vdd_core"; regulator-min-microvolt = <912000>; regulator-max-microvolt = <1144000>; regulator-boot-on; regulator-always-on; }; dcdc2: regulator-dcdc2 { compatible = "ti,tps65218-dcdc2"; /* VDD_MPU limits min of OPP50 and max of OPP_NITRO */ regulator-name = "vdd_mpu"; regulator-min-microvolt = <912000>; regulator-max-microvolt = <1378000>; regulator-boot-on; regulator-always-on; }; dcdc3: regulator-dcdc3 { compatible = "ti,tps65218-dcdc3"; regulator-name = "vdds_ddr"; regulator-min-microvolt = <1500000>; regulator-max-microvolt = <1500000>; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; regulator-state-disk { regulator-off-in-suspend; }; }; dcdc4: regulator-dcdc4 { compatible = "ti,tps65218-dcdc4"; regulator-name = "v3_3d"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-boot-on; regulator-always-on; }; dcdc5: regulator-dcdc5 { compatible = "ti,tps65218-dcdc5"; regulator-name = "v1_0bat"; regulator-min-microvolt = <1000000>; regulator-max-microvolt = <1000000>; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; }; dcdc6: regulator-dcdc6 { compatible = "ti,tps65218-dcdc6"; regulator-name = "v1_8bat"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; }; ldo1: regulator-ldo1 { compatible = "ti,tps65218-ldo1"; regulator-name = "v1_8d"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-boot-on; regulator-always-on; }; /*Power Button Disabled by analogics */ /* power-button { compatible = "ti,tps65218-pwrbutton"; status = "okay"; interrupts = <3 IRQ_TYPE_EDGE_BOTH>; };*/ }; at24@50 { compatible = "at24,24c256"; pagesize = <64>; reg = <0x50>; }; }; &i2c1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c1_pins>; clock-frequency = <400000>; ov2659@30 { compatible = "ovti,ov2659"; reg = <0x30>; pinctrl-names = "default"; pinctrl-0 = <&clkout1_pin>; clocks = <&clkout1_mux_ck>; clock-names = "xvclk"; assigned-clocks = <&clkout1_mux_ck>; assigned-clock-parents = <&clkout1_osc_div_ck>; port { ov2659_1: endpoint { remote-endpoint = <&vpfe0_ep>; link-frequencies = /bits/ 64 <70000000>; }; }; }; /* edt-ft5306@38 { status = "okay"; compatible = "edt,edt-ft5306", "edt,edt-ft5x06"; pinctrl-names = "default"; /*pinctrl-0 = <&edt_ft5306_ts_pins>; reg = <0x38>; interrupt-parent = <&gpio0>; interrupts = <31 0>; reset-gpios = <&gpio1 28 GPIO_ACTIVE_LOW>; touchscreen-size-x = <480>; touchscreen-size-y = <272>; }; */ tlv320aic3106: tlv320aic3106@1b { #sound-dai-cells = <0>; compatible = "ti,tlv320aic3106"; reg = <0x1b>; status = "okay"; /* Regulators */ AVDD-supply = <&dcdc4>; IOVDD-supply = <&dcdc4>; DRVDD-supply = <&dcdc4>; DVDD-supply = <&ldo1>; }; lis331dlh@18 { compatible = "st,lis331dlh"; reg = <0x18>; status = "okay"; Vdd-supply = <&dcdc4>; Vdd_IO-supply = <&dcdc4>; interrupts-extended = <&gpio1 6 0>, <&gpio2 1 0>; }; }; &epwmss0 { status = "okay"; }; &ecap0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&ecap0_pins>; }; &gpio0 { status = "okay"; }; &gpio1 { status = "okay"; }; &gpio4 { status = "okay"; }; &gpio5 { status = "okay"; }; &mmc1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&mmc1_pins>; vmmc-supply = <&dcdc4>; bus-width = <4>; cd-gpios = <&gpio0 6 GPIO_ACTIVE_HIGH>; }; &uart1 { status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&uart1_bt_pins_default>; pinctrl-1 = <&uart1_bt_pins_sleep>; }; &mmc3 { status = "okay"; /* these are on the crossbar and are outlined in the xbar-event-map element */ dmas = <&edma 30 &edma 31>; dma-names = "tx", "rx"; vmmc-supply = <&vmmcwl_fixed>; bus-width = <4>; pinctrl-names = "default", "sleep"; pinctrl-0 = <&mmc3_pins_default>; pinctrl-1 = <&mmc3_pins_sleep>; cap-power-off-card; keep-power-in-suspend; ti,non-removable; #address-cells = <1>; #size-cells = <0>; wlcore: wlcore@0 { compatible = "ti,wl1835"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&wlan_pins_default>; pinctrl-1 = <&wlan_pins_sleep>; reg = <2>; interrupt-parent = <&gpio4>; interrupts = <13 IRQ_TYPE_LEVEL_HIGH>; }; }; &edma { ti,edma-xbar-event-map = /bits/ 16 <1 30 2 31>; }; &usb2_phy1 { status = "okay"; }; &usb1 { dr_mode = "otg"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&usb1_pins>; }; &usb2_phy2 { status = "okay"; }; &usb2 { dr_mode = "host"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&usb2_pins>; }; &qspi { status = "okay"; pinctrl-names = "default"; /*pinctrl-0 = <&qspi_pins>; */ spi-max-frequency = <48000000>; m25p80@0 { compatible = "mx66l51235l"; spi-max-frequency = <48000000>; reg = <0>; spi-cpol; spi-cpha; spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; #address-cells = <1>; #size-cells = <1>; /* MTD partition table. * The ROM checks the first 512KiB * for a valid file to boot(XIP). */ partition@0 { label = "QSPI.U_BOOT"; reg = <0x00000000 0x000080000>; }; partition@1 { label = "QSPI.U_BOOT.backup"; reg = <0x00080000 0x00080000>; }; partition@2 { label = "QSPI.U-BOOT-SPL_OS"; reg = <0x00100000 0x00010000>; }; partition@3 { label = "QSPI.U_BOOT_ENV"; reg = <0x00110000 0x00010000>; }; partition@4 { label = "QSPI.U-BOOT-ENV.backup"; reg = <0x00120000 0x00010000>; }; partition@5 { label = "QSPI.KERNEL"; reg = <0x00130000 0x0800000>; }; partition@6 { label = "QSPI.FILESYSTEM"; reg = <0x00930000 0x36D0000>; }; }; }; &mac { pinctrl-names = "default", "sleep"; pinctrl-0 = <&cpsw_default>; pinctrl-1 = <&cpsw_sleep>; /* dual emac commented by analogics */ /*dual_emac = <1>; */ status = "okay"; }; &davinci_mdio { pinctrl-names = "default", "sleep"; pinctrl-0 = <&davinci_mdio_default>; pinctrl-1 = <&davinci_mdio_sleep>; status = "okay"; }; &cpsw_emac0 { /* phy_id = <&davinci_mdio>, <4>; */ phy_id = <&davinci_mdio>, <0>; /* rgmii mode commented by analogics */ /*phy-mode = "rgmii"; */ phy-mode = "rmii"; dual_emac_res_vlan = <1>; }; &cpsw_emac1 { /* phy_id = <&davinci_mdio>, <5>; */ phy_id = <&davinci_mdio>, <1>; /* rgmii mode commented by analogics */ /* phy-mode = "rgmii"; */ phy-mode = "rmii"; dual_emac_res_vlan = <2>; }; &elm { status = "okay"; }; &mcasp1 { #sound-dai-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&mcasp1_pins>; status = "okay"; op-mode = <0>; tdm-slots = <2>; serial-dir = < 0 0 1 2 >; tx-num-evt = <1>; rx-num-evt = <1>; }; &dss { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&dss_pins>; port { dpi_out: endpoint@0 { remote-endpoint = <&lcd_in>; /* data-lines = <24>;*/ data-lines = <16>; }; }; }; /* touchscreen & ADC values added by arun analogics */ &tscadc { status = "okay"; tsc { ti,wires = <4>; ti,x-plate-resistance = <200>; ti,coordinate-readouts = <5>; ti,wire-config = <0x00 0x11 0x22 0x33>; /* ti,wire-config = <0x00 0x13 0x21 0x32>; */ ti,x-axis = <0 320 1>; ti,y-axis = <0 240 1>; ti,charge-delay = <0x400>; }; adc { ti,adc-channels = <4 5 6 7>; }; }; &rtc { status = "okay"; ext-clk-src; }; &wdt { status = "okay"; }; &cpu { cpu0-supply = <&dcdc2>; }; &vpfe0 { status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&vpfe0_pins_default>; pinctrl-1 = <&vpfe0_pins_sleep>; /* Camera port */ port { vpfe0_ep: endpoint { remote-endpoint = <&ov2659_1>; ti,am437x-vpfe-interface = <0>; bus-width = <8>; hsync-active = <0>; vsync-active = <0>; }; }; }; &wkup_m3_ipc { ti,scale-data-fw = "am43x-evm-scale-data.bin"; }; &sgx { status = "okay"; };
