Porting application code from TDA2x to TDA3x
Other Parts Discussed in Thread: MATHLIB, TDA2
I am working on porting the application from tda2x to tda3x.
Currently the application runs fine on tda2x.The application uses bios,xdc,ipc,bsp,edma,ivahd,eve,vlib,mathlib packages from vision sdk.
On tda2 physical master is a15 that launches the secondary bootloader.The sbl will load and start the code from m4.
On tda3 what will be the scenario since tda3 does not support a15.
a) How the secondary bootloader launches on TDA3x
b)Is it fine to port the software modules running on a15 in TDA2 on m4 in TDA3x.
c)Does disabling a15 support from whole application,compiling the ti packages with TDA3 and then generating the application image is right procedure.
d)How should i proceed for porting application from tda2x to tda3x.
Mayank
